----------------------------------------------------------------------------------------- library IEEE; -- library declarations use IEEE.std_logic_1164.ALL; entity DCNTR4VHD_STIM is -- entity STIMULUS has no input/output ports end DCNTR4VHD_STIM; -- therefor no port declaration architecture TEST_BENCH of DCNTR4VHD_STIM is -- architecture structural component DCNTR4VHD -- component declaration -- component DCNTR4 port (RST : in std_logic; -- asynchronous reset CLK : in std_logic; -- clock signal CE : in std_logic; -- clock enable PE : in std_logic; -- parallel data enable P : in std_logic_vector (3 downto 0); -- parallel data in Q : out std_logic_vector (3 downto 0); -- data out signal TC : out std_logic); -- terminal count end component; signal RST, CLK : std_logic :='0'; -- net names, initial value signal CE, PE, P3, P2, P1, P0 : std_logic; -- net names signal Q3, Q2, Q1, Q0, TC : std_logic; -- net names ------------------------------------------------------------------------------- -- structural description, netlist begin DESIGN: DCNTR4VHD -- component instanciation for instance DESIGN -- DESIGN: DCNTR4VHD port map (RST => RST, -- port name => net name (int. signal name) CLK => CLK, -- formal association CE => CE, PE => PE, P(0) => P0, P(1) => P1, P(2) => P2, P(3) => P3, Q(0) => Q0, Q(1) => Q1, Q(2) => Q2, Q(3) => Q3, TC => TC); ------------------------------------------------------------------------------- STIMGEN: process is -- generation of testpattern,stimuli procedure VECTORTIMING (RSTi,CLKi,CEi,PEi,P3i,P2i,P1i,P0i: in std_logic) is ------------------------------------------------------------------------------- -- timing information for usage with synchronous designs and test -- -- tester drive formats for input pins: RZ = delayed Return to Zero -- R1 = delayed Return to One (1) -- DNRZ = Delayed Non Return to Zero ------------------------------------------------------------------------------- constant TCYCLE : Time := 100ns; -- cycle time begin RST <= RSTi after 10ns, '0'after 90ns; -- RST pulse width = 80ns CLK <= CLKi after 50ns, '0'after (TCYCLE); -- CLK pulse width = 50ns -- CE <= CEi after 20ns, '0' after 50ns; -- RTZ-signal CE <= CEi after 10ns; -- DNRZ-signal -- hold time = 10 ns PE <= PEi after 20ns, '0' after 60ns; -- RTZ-signal -- setup time = 30ns -- hold time = 10ns P3 <= P3i after 10ns, '0' after 70ns; -- pulse width = 60ns P2 <= P2i after 10ns, '0' after 70ns; -- inertial delay P1 <= P1i after 10ns, '0' after 70ns; P0 <= P0i after 10ns, '0' after 70ns; wait for TCYCLE; -- set time to cycle end end procedure VECTORTIMING; begin -- VECTORTIMING (RSTi, CLKi, CEi, PEi, P3i, P2i, P1i, P0i ); VECTORTIMING ( '1', '1', '0', '0', '1', '1', '1', '1' ); VECTORTIMING ( '0', '1', '0', '1', '1', '1', '1', '1' ); VECTORTIMING ( '1', '1', '0', '1', '1', '1', '1', '1' ); VECTORTIMING ( '0', '1', '1', '0', '0', '0', '0', '0' ); VECTORTIMING ( '0', '1', '1', '0', '0', '0', '0', '0' ); -- insert additional test vectors here ... wait; -- simulator stops end process stimgen; end TEST_BENCH;
