<?php
    part-db version 0.1
    Copyright (C) 2005 Christoph Lechner
    http://www.cl-projects.de/
    part-db version 0.2+
    Copyright (C) 2009 K. Jacobs and others (see authors.php)
    http://code.google.com/p/part-db/
    This program is free software; you can redistribute it and/or
    modify it under the terms of the GNU General Public License
    as published by the Free Software Foundation; either version 2
    of the License, or (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program; if not, write to the Free Software
    Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301, USA
    $Id: start_session.php 662 2013-06-23 16:07:39Z kami89@bluewin.ch $
    Changelog (sorted by date):
        [DATE]      [NICKNAME]          [CHANGES]
        2012-09-03  kami89              - created
        2013-05-05  kami89              - added config.php updates
                                        - added workaround for STRATO servers
    * @file start_session.php
    * @brief This file must be included in every PHP file which produces HTML output!
    // set HTTP charset to UTF-8
    header('Content-type: text/html; charset=utf-8');
    $BASE_tmp = str_replace('\\', '/', dirname(__FILE__)); // temporary base path of Part-DB, without slash at the end
    include_once($BASE_tmp.'/lib/lib.start_session.php');
    *   define an exception handler for uncaught exceptions
    function exception_handler($e)
        print_messages_without_template(    'Part-DB: Schwerwiegender Fehler!', NULL,
                                            '<font color="red"><strong>Es ist ein schwerwiegender Fehler aufgetreten:'.
                                            '<br><br>'.nl2br($e->getMessage()).'</strong><br><br>'.
                                            '(Exception wurde geworfen in '.$e->getFile().', Zeile '.$e->getLine().')</font>');
        exit;
    set_exception_handler('exception_handler');
    *   For the Update from Part-DB 0.2.2 to 0.3.0:
    *   Move the file "config.php" and the folders "backup", "media" and "log" to "data/..."
    $old_config_exists = file_exists($BASE_tmp.'/config.php');
    $old_backup_exists = file_exists($BASE_tmp.'/backup');
    $old_media_exists = file_exists($BASE_tmp.'/media');
    $old_log_exists = file_exists($BASE_tmp.'/log');
    if (($old_config_exists) || ($old_backup_exists) || ($old_media_exists) || ($old_log_exists))
        $messages = '<strong>Bitte verschieben Sie die folgenden Dateien und Ordner ins Verzeichnis "data": <br><br>';
        if ($old_config_exists) {$messages .= '"config.php" --> "data/config.php"<br>';}
        if ($old_backup_exists) {$messages .= '"backup/" --> "data/backup/"<br>';}
        if ($old_media_exists)  {$messages .= '"media/" --> "data/media/"<br>';}
        if ($old_log_exists)    {$messages .= '"log/" --> "data/log/"<br>';}
        $messages .=    '<br><font color="red">WICHTIG:<br>Kopieren Sie jeweils nur den Inhalt der genannten Ordner, nicht den ganzen Ordner an sich!<br>'.
                        'Die Zielordner enthalten bereits (teilweise versteckte) Dateien, die auf keinen Fall &uuml;berschrieben werden d&uuml;rfen!<br>'.
                        'Kopieren Sie also nur den Inhalt dieser Ordner und l&ouml;schen Sie danach die alten, leeren Ordner im Hauptverzeichnis.</font></strong>';
        print_messages_without_template('Part-DB', 'Update von Part-DB: Manuelle Eingriffe notwendig', $messages);
        exit;
    *   include config files
    include_once($BASE_tmp.'/config_defaults.php'); // first, we load all default values of the $config array...
    if (file_exists($BASE_tmp.'/data/config.php') && is_readable($BASE_tmp.'/data/config.php'))
        include_once($BASE_tmp.'/data/config.php'); // ...and then we overwrite them with the user settings, if they exist
    if (count($manual_config) > 0) // $manual_config is defined in "config_defaults.php" and can be filled in "config.php"
        $config = array_merge($config, $manual_config); // if there are manual configs, add them to $config
    *   define directory constants of the part-db installation
    *   please note: we always use slashes, even if the script runs on Windows!
    *   If the paths BASE, DOCUMENT_ROOT or BASE_RELATIVE are not correct,
    *   the user can set them manually in his config.php.
    *   Example how to define it in the config.php: $manual_config['BASE'] = '/my/base';
    // directory to the part-db installation, without slash at the end
    // Example (UNIX/Linux):    "/var/www/part-db"
    // Example (Windows):       "C:/wamp/www/part-db"
    if (isset($config['BASE']))
        define('BASE', $config['BASE']);
    else
        define('BASE', $BASE_tmp);
    // server-directory without slash at the end
    // Example (UNIX/Linux):    "/var/www"
    // Example (Windows):       "C:/wamp/www"
    if (isset($config['DOCUMENT_ROOT']))
        define('DOCUMENT_ROOT', $config['DOCUMENT_ROOT']);
    elseif (isset($_SERVER['DOCUMENT_ROOT']))
        define('DOCUMENT_ROOT', rtrim(str_replace('\\', '/', $_SERVER['DOCUMENT_ROOT']), '/'));
    elseif (isset($_SERVER['SCRIPT_FILENAME']) && isset($_SERVER['PHP_SELF']))
        define('DOCUMENT_ROOT', rtrim(str_replace('\\', '/', substr($_SERVER['SCRIPT_FILENAME'], 0, 0-strlen($_SERVER['PHP_SELF'])))));
    elseif (isset($_SERVER['PATH_TRANSLATED']) && isset($_SERVER['PHP_SELF']))
        define('DOCUMENT_ROOT', rtrim(str_replace('\\', '/', substr(str_replace('\\\\', '\\', $_SERVER['PATH_TRANSLATED']), 0, 0-strlen($_SERVER['PHP_SELF'])))));
    else
        $messages = 'Die Konstante "DOCUMENT_ROOT" konnte auf Ihrem Server nicht ermittelt werden.<br>'.
                    'Bitte definieren Sie diese Konstante manuell in Ihrer Konfigurationsdatei "data/config.php".';
        print_messages_without_template('Part-DB', 'DOCUMENT_ROOT kann nicht ermittelt werden', $messages);
        exit;
    // the part-db installation directory without document root, without slash at the end
    // Example (UNIX/Linux):    "/part-db"
    // Example (Windows):       "/part-db"
    if (isset($config['BASE_RELATIVE']))
        define('BASE_RELATIVE', $config['BASE_RELATIVE']);
    elseif (mb_strpos(BASE, DOCUMENT_ROOT) === false)   // workaround for STRATO servers, see german post on uC.net:
        define('BASE_RELATIVE', '.');                   // http://www.mikrocontroller.net/topic/269289#3152928
    else
        define('BASE_RELATIVE', str_replace(DOCUMENT_ROOT, '', BASE));
    // for debugging uncomment these lines:
    //print 'BASE = "'.BASE.'"<br>';
    //print 'DOCUMENT_ROOT = "'.DOCUMENT_ROOT.'"<br>';
    //print 'BASE_RELATIVE = "'.BASE_RELATIVE.'"<br>';
    //print 'DIRECTORY_SEPARATOR = "'.DIRECTORY_SEPARATOR.'"<br>';
    //exit;
    *   make some checks
    $messages = check_requirements();
    if (count($messages) > 0)
        print_messages_without_template('Part-DB', 'Mindestanforderungen von Part-DB nicht erfüllt!',
            '<font color="red"><strong>&bull;'.implode('<br>&bull;', $messages).'</strong></font><br><br>'.
            'Nähere Informationen gibt es in der <a target="_blank" href="'.BASE_RELATIVE.
            '/documentation/dokuwiki/doku.php?id=anforderungen">Dokumentation</a>.');
        exit;
    $messages = check_file_permissions();
        $message = '<strong><font color="red">';
        foreach ($messages as $msg)
            $message .= '&bull;'.$msg.'<br>';
        $message .= '</font></strong><br><br>';
        $message .= 'Nähere Informationen zu den Dateirechten gibt es in der <a target="_blank" href="'.BASE_RELATIVE.
                    '/documentation/dokuwiki/doku.php?id=installation">Dokumentation</a>.<br><br>';
        $message .= '<form action="" method="post"><input type="submit" value="Seite neu laden"></form>';
        print_messages_without_template('Part-DB', 'Anpassung der Rechte von Verzeichnissen und Dateien', $message);
        exit;
        // please note: the messages and the "exit;" here are very important, we mustn't continue the script!
        // the reasen is: if the config.php is not readable, the array $config is now not loaded successfully.
    $message = check_if_config_is_valid();
    if (is_string($message))
        print_messages_without_template('Part-DB', 'Ihre config.php ist fehlerhaft!',
            '<font color="red"><strong>'.$message.'</strong></font><br><br>'.
            '/documentation/dokuwiki/doku.php?id=installation">Dokumentation</a>.<br><br>'.
            '<form action="" method="post"><input type="submit" value="Seite neu laden"></form>');
        exit;
    *   update the config.php if the system is newer than the user's config.php
    if (($config['system']['current_config_version'] < $config['system']['latest_config_version'])
        && (file_exists(BASE.'/data/config.php')) && (is_readable(BASE.'/data/config.php'))
        && (filesize(BASE.'/data/config.php') > 0))
        include_once(BASE.'/updates/config_update_steps.php');
        try
            $update_messages = update_users_config_php();
            $message =  '<strong><font color="darkgreen">Ihre config.php wurde erfolgreich aktualisiert!</font></strong><br><br>'.
                        'Es kann sein, dass jetzt der Installationsassistent startet, '.
                        'um noch einige neue Einstellungen zu tätigen.<br><br>';
            if (count($update_messages) > 0)
                $message .= '<strong><font color="red">';
                foreach ($update_messages as $text)
                    $message .= '&bull;'.$text.'<br>';
                $message .= '</font></strong><br>';
        catch (Exception $e)
            $message =  '<strong><font color="red">Es gab ein Fehler bei der Aktualisierung ihrer config.php:<br><br>'.
                        nl2br($e->getMessage()).'</font></strong><br><br>';
        print_messages_without_template('Part-DB', 'Aktualisierung ihrer config.php', $message);
        exit;
    $config['html']['http_charset'] = 'utf-8'; ///< @todo remove this later; see config_defaults.php
    *   set internal encoding / timezone / locale / error reporting
    if (($config['debug']['enable']) && ( ! $config['debug']['template_debugging_enable'])) // template debugging produces a lot of warnings!
        error_reporting(E_ALL & ~E_STRICT);
        ini_set("display_errors", 1);
    else
        ini_set("display_errors", 0);
    mb_internal_encoding(/*$config['html']['http_charset']*/ 'UTF-8');
    mb_regex_encoding('UTF-8');
    date_default_timezone_set($config['timezone']);
    own_setlocale(LC_ALL, $config['language']);
    *   start session
    session_name('Part-DB');
    session_start();
    *   autoload function for classes
    function __autoload($classname)
        if (strpos($classname, 'vlib') === 0)
            include_once(BASE.'/lib/vlib/'.$classname.'.php');
        else
            include_once(BASE.'/lib/class.'.$classname.'.php');
    *   include libraries
    include_once(BASE.'/lib/lib.functions.php');
    include_once(BASE.'/lib/lib.debug.php');
    include_once(BASE.'/lib/lib.php');
