import serial
import sys
from Tkinter import *
mGui = Tk()
global crc_table
crc_table =    [0x00, 0x02 ,0x04, 0x06, 0x08, 0x0A, 0x0C, 0x0E, 0x10, 0x12, 0x14, 0x16, 0x18,
                0x1A, 0x1C, 0x1E, 0x20, 0x22, 0x24, 0x26, 0x28, 0x2A, 0x2C, 0x2E, 0x30, 0x32,
                0x34, 0x36, 0x38, 0x3A, 0x3C, 0x3E, 0x40, 0x42, 0x44, 0x46, 0x48, 0x4A, 0x4C,
                0x4E, 0x50, 0x52, 0x54, 0x56, 0x58, 0x5A, 0x5C, 0x5E, 0x60, 0x62, 0x64, 0x66,
                0x68, 0x6A, 0x6C, 0x6E, 0x70, 0x72, 0x74, 0x76, 0x78, 0x7A, 0x7C, 0x7E, 0x80,
                0x82, 0x84, 0x86, 0x88, 0x8A, 0x8C, 0x8E, 0x90, 0x92, 0x94, 0x96, 0x98, 0x9A,
                0x9C, 0x9E, 0xA0, 0xA2, 0xA4, 0xA6, 0xA8, 0xAA, 0xAC, 0xAE, 0xB0, 0xB2, 0xB4,
                0xB6, 0xB8, 0xBA, 0xBC, 0xBE, 0xC0, 0xC2, 0xC4, 0xC6, 0xC8, 0xCA, 0xCC, 0xCE,
                0xD0, 0xD2, 0xD4, 0xD6, 0xD8, 0xDA, 0xDC, 0xDE, 0xE0, 0xE2, 0xE4, 0xE6, 0xE8,
                0xEA, 0xEC, 0xEE, 0xF0, 0xF2, 0xF4, 0xF6, 0xF8, 0xFA, 0xFC, 0xFE, 0x19, 0x1B,
                0x1D, 0x1F, 0x11, 0x13, 0x15, 0x17, 0x09, 0x0B, 0x0D, 0x0F, 0x01, 0x03, 0x05,
                0x07, 0x39, 0x3B, 0x3D, 0x3F, 0x31, 0x33, 0x35, 0x37, 0x29, 0x2B, 0x2D, 0x2F,
                0x21, 0x23, 0x25, 0x27, 0x59, 0x5B, 0x5D, 0x5F, 0x51, 0x53, 0x55, 0x57, 0x49,
                0x4B, 0x4D, 0x4F, 0x41, 0x43, 0x45, 0x47, 0x79, 0x7B, 0x7D, 0x7F, 0x71, 0x73,
                0x75, 0x77, 0x69, 0x6B, 0x6D, 0x6F, 0x61, 0x63, 0x65, 0x67, 0x99, 0x9B, 0x9D,
                0x9F, 0x91, 0x93, 0x95, 0x97, 0x89, 0x8B, 0x8D, 0x8F, 0x81, 0x83, 0x85, 0x87,
                0xB9, 0xBB, 0xBD, 0xBF, 0xB1, 0xB3, 0xB5, 0xB7, 0xA9, 0xAB, 0xAD, 0xAF, 0xA1,
                0xA3, 0xA5, 0xA7, 0xD9, 0xDB, 0xDD, 0xDF, 0xD1, 0xD3, 0xD5, 0xD7, 0xC9, 0xCB,
                0xCD, 0xCF, 0xC1, 0xC3, 0xC5, 0xC7, 0xF9, 0xFB, 0xFD, 0xFF, 0xF1, 0xF3, 0xF5,
                0xF7, 0xE9, 0xEB, 0xED, 0xEF, 0xE1, 0xE3, 0xE5, 0xE7]
global buffer
buffer=[0 for x in range(34)]
port = serial.Serial("/dev/ttyAMA0", 9600 )
def  byte_holen():
     global byte
     rcv = port.read()
     byte = ord(rcv)
def  crc_testen(leng):
     global crc_test
     crc_test = True
     crc = 0
     for i in range(0,leng):
        crc = crc_table[crc]
        crc ^= buffer[i]
     else:
       if crc == buffer[leng]:
        crc_test = True
       else:
        crc_test = False
def haupt():
 while True:
   byte_holen()
   if byte == 0xb0:
      buffer[0] = 0xb0
      for x in range (1,3):
           byte_holen()
           buffer[x] = byte
      if buffer[1] == 0:
         if buffer[2] == 0xff:
          for x in range (3,20):
             byte_holen()
             buffer[x] = byte
          if  buffer[3] == 0:
              if buffer[4] == 0:
                if buffer[5] == 3:
                 crc_testen(19)
#                 print crc_test
                 if crc_test == True:
                    if buffer[10] != 255:
                             T1 = ('Kollektor:' + str('          '))
                             Label(mGui,text=T1).grid(row=1,column=0,sticky=W)
                             T1 = ('Kollektor:' + str(float(buffer[10]*256+buffer[11])/10))
                             T2 = ('Solarspeicher:' + str(float(buffer[12]*256+buffer[13])/10))
                             Label(mGui,text=T2).grid(row=2,column=0,sticky=W)
                             mGui.update_idletasks()
                    else:
                             T1 = ('Kollektor_Winter:'+ str(float(255-buffer[11])/-10))
   elif  byte == 0x88:
      buffer[0] = 0x88
           byte_holen()
           buffer[x] = byte
      if buffer[1] == 0:
         if buffer[2] == 0x19:
            for x in range (3,33):
              byte_holen()
              buffer[x] = byte
            if  buffer[3] == 0:
                 crc_testen(31)
#                 print crc_test
                    if buffer[4] != 255:
                             T3 = ('Aussentemperatur:' + str('          '))
                             Label(mGui,text=T3).grid(row=3,column=0,sticky=W)
                             T3 = ('Aussentemperatur:' + str(float(buffer[4]*256+buffer[5])/10))
                    else:
                             T3 = ('Aussentemperatur_Winter:' + str(float(255-buffer[5])/-10))
         elif  buffer[2] == 0x18:
                byte_holen()
                buffer[x] = byte
              if  buffer[3] == 0:
                 crc_testen(29)
 #                print crc_test
                             T4 = ('geforderte Vorlauftemperatur:'+ str('     '))
#                             print T4
                             Label(mGui,text=T4).grid(row=4,column=0,sticky=W)
                             T4 = ('geforderte Vorlauftemperatur:'+ str(int(buffer[4])))
                             T5 = ('aktuelle Vorlauftemperatur:' + str(float(buffer[5]*256+buffer[6])/10))
                             Label(mGui,text=T5).grid(row=5,column=0,sticky=W)
                             luefter = buffer[11] and 0xb0
                             if luefter == 0xb0:
                                 Label(mGui,text='Luefter Brenner an!').grid(row=8,column=0,sticky=W)
                                 buffer[11] = 0
                             else: Label(mGui,text='                                             ').grid(row=8,column=0,sticky=W)
   elif byte == 0x98:
      buffer[0] = 0x98
           byte_holen()
           buffer[x] = byte
      if buffer[1] == 0:
            for x in range (3,23):
              byte_holen()
              buffer[x] = byte
            if  buffer[3] == 0:
              if buffer[5]== 0x6f:
                 crc_testen(15)
 #                print crc_test
                             T6 = ('gewuenschte Raumtemperatur:' + str(float(buffer[8]*256+buffer[9])/10))
                             Label(mGui,text=T6).grid(row=6,column=0,sticky=W)
                             T7 = ('aktuelle Raumtemperatur:'+ str(float(buffer[10]*256+buffer[11])/10))
                             Label(mGui,text=T7).grid(row=7,column=0,sticky=W)
mGui.geometry("300x200")
mGui.title('Junkers CSW14')
haupt()
