C:\Program Files\smartmontools\bin>smartctl -x /dev/sda smartctl 6.2 2013-07-26 r3841 [x86_64-w64-mingw32-win7-sp1] (sf-6.2-1) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Crucial/Micron RealSSD m4/C400/P400 Device Model: M4-CT064M4SSD2 Serial Number: 00000000131109XXXXXX LU WWN Device Id: 5 00a075 109XXXXXX Firmware Version: 070H User Capacity: 64.023.257.088 bytes [64,0 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 6 SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Sun Sep 29 15:17:35 2013 MS SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM level is: 254 (maximum performance) Rd look-ahead is: Enabled Write cache is: Enabled ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 295) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off supp ort. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 4) minutes. Conveyance self-test routine recommended polling time: ( 3) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 100 100 050 - 0 5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0 9 Power_On_Hours -O--CK 100 100 001 - 15 12 Power_Cycle_Count -O--CK 100 100 001 - 373 170 Grown_Failing_Block_Ct PO--CK 100 100 010 - 0 171 Program_Fail_Count -O--CK 100 100 001 - 0 172 Erase_Fail_Count -O--CK 100 100 001 - 0 173 Wear_Leveling_Count PO--CK 100 100 010 - 4 174 Unexpect_Power_Loss_Ct -O--CK 100 100 001 - 14 181 Non4k_Aligned_Access -O---K 100 100 001 - 148 30 118 183 SATA_Iface_Downshift -O--CK 100 100 001 - 0 184 End-to-End_Error PO--CK 100 100 050 - 0 187 Reported_Uncorrect -O--CK 100 100 001 - 0 188 Command_Timeout -O--CK 100 100 001 - 0 189 Factory_Bad_Block_Ct -OSR-- 100 100 001 - 50 194 Temperature_Celsius -O---K 100 100 000 - 0 195 Hardware_ECC_Recovered -O-RCK 100 100 001 - 0 196 Reallocated_Event_Count -O--CK 100 100 001 - 0 197 Current_Pending_Sector -O--CK 100 100 001 - 0 198 Offline_Uncorrectable ----CK 100 100 001 - 0 199 UDMA_CRC_Error_Count -O--CK 100 100 001 - 0 202 Perc_Rated_Life_Used ---RC- 100 100 001 - 0 206 Write_Error_Rate -OSR-- 100 100 001 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 51 Comprehensive SMART error log 0x03 GPL R/O 16383 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 255 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 3449 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0 GPL VS 2000 Device vendor specific log 0xa0 SL VS 208 Device vendor specific log 0xa1-0xbf GPL,SL VS 1 Device vendor specific log 0xc0 GPL VS 80 Device vendor specific log 0xc1-0xdf GPL,SL VS 1 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log size 16383 not supported SMART Error Log Version: 1 No Errors Logged SMART Extended Self-test Log size 3449 not supported SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error # 1 Extended offline Completed without error 00% 15 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 1 (0x0001) SCT Support Level: 0 Device State: Active (0) Current Temperature: 0 Celsius Power Cycle Max Temperature: 0 Celsius Lifetime Max Temperature: 0 Celsius SCT Temperature History Version: 2 Temperature Sampling Period: 10 minutes Temperature Logging Interval: 10 minutes Min/Max recommended Temperature: 0/70 Celsius Min/Max Temperature Limit: -5/75 Celsius Temperature History Size (Index): 478 (373) Index Estimated Time Temperature Celsius 374 2013-09-26 07:40 ? - ... ..(476 skipped). .. - 373 2013-09-29 15:10 ? - SCT Error Recovery Control: Read: 40 (4,0 seconds) Write: 40 (4,0 seconds) Device Statistics (GP Log 0x04) Page Offset Size Value Description 1 ===== = = == General Statistics (rev 2) == 1 0x008 4 373 Lifetime Power-On Resets 1 0x010 4 15 Power-on Hours 1 0x018 6 601415108 Logical Sectors Written 1 0x020 6 12162433 Number of Write Commands 1 0x028 6 929772968 Logical Sectors Read 1 0x030 6 19020596 Number of Read Commands 4 ===== = = == General Errors Statistics (rev 1) == 4 0x008 4 0 Number of Reported Uncorrectable Errors 4 0x010 4 0 Resets Between Cmd Acceptance and Completion 5 ===== = = == Temperature Statistics (rev 1) == 5 0x008 1 0 Current Temperature 5 0x010 1 - Average Short Term Temperature 5 0x018 1 - Average Long Term Temperature 5 0x020 1 0 Highest Temperature 5 0x028 1 0 Lowest Temperature 5 0x030 1 - Highest Average Short Term Temperature 5 0x038 1 - Lowest Average Short Term Temperature 5 0x040 1 - Highest Average Long Term Temperature 5 0x048 1 - Lowest Average Long Term Temperature 5 0x050 4 - Time in Over-Temperature 5 0x058 1 70 Specified Maximum Operating Temperature 5 0x060 4 - Time in Under-Temperature 5 0x068 1 0 Specified Minimum Operating Temperature 6 ===== = = == Transport Statistics (rev 1) == 6 0x008 4 350 Number of Hardware Resets 6 0x010 4 0 Number of ASR Events 6 0x018 4 0 Number of Interface CRC Errors 7 ===== = = == Solid State Device Statistics (rev 1) == 7 0x008 1 3~ Percentage Used Endurance Indicator |_ ~ normalized value SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 4 0 Command failed due to ICRC error 0x000a 4 1 Device-to-host register FISes sent due to a COMRESET C:\Program Files\smartmontools\bin>
