* WARNING : please consider following remarks before usage * * 1) All models are a tradeoff between accuracy and complexity (ie. simulation * time). * 2) Macromodels are not a substitute to breadboarding, they rather confirm the * validity of a design approach and help to select surrounding component values. * * 3) A macromodel emulates the NOMINAL performance of a TYPICAL device within * SPECIFIED OPERATING CONDITIONS (ie. temperature, supply voltage, etc.). * Thus the macromodel is often not as exhaustive as the datasheet, its goal * is to illustrate the main parameters of the product. * * 4) Data issued from macromodels used outside of its specified conditions * (Vcc, Temperature, etc) or even worse: outside of the device operating * conditions (Vcc, Vicm, etc) are not reliable in any way. * **************************************************************************** **** **** TSV99X Spice macromodel subckt **** **** Revision Date: 10/06/08 **** *********** CONNECTIONS: **** INVERTING INPUT **** | NON-INVERTING INPUT **** | | OUTPUT **** | | | POSITIVE POWER SUPPLY **** | | | | NEGATIVE POWER SUPPLY **** | | | | | **** | | | | | .SUBCKT TSV99X VM VP VS VCCP VCCN HILIM_ICCN NET0477 0 V_OUTVLIM_LOW 235 HILIM_ICCP NET0437 0 V_OUTVLIM_HIGH -235 M_NMOS2 VO_DIFF_MINUS VM VEE_N VCCN_ENHANCED MOS_N L={L} W={W} M_NMOS1 VO_DIFF_PLUS NET0158 VEE_N VCCN_ENHANCED MOS_N L={L} W={W} IEE_N VEE_N VCCN_ENHANCED DC {IEE} V_OUTVLIM_LOW NET0372 NET0373 DC -770m VVLIM_LOW_VB NET0109 NET0110 DC -770m VREADIO NET0481 VS DC 0 VOS NET0158 VP DC 0 VPROT_IN_P_VCCP NET0123 NET0134 DC {V_DPROT} V_ENHANCE_VCCN VCCN_ENHANCED VCCN DC -360m VVLIM_HIGH_VB NET0180 NET0153 DC -770m V_ENHANCE_VCCP VCCP_ENHANCED VCCP DC -500m VPROT_IN_M_VCCN NET0116 NET0192 DC {V_DPROT} VPROT_IN_P_VCCN NET0115 NET096 DC {V_DPROT} VPROT_IN_M_VCCP NET0190 NET0135 DC {V_DPROT} V_OUTVLIM_HIGH NET0397 NET0375 DC -770m DILIM_ICCN NET0402 VB_3 DIODE_ILIM DVLIM_HIGH_VB VB NET0180 DIODE_VLIM DPROT_IN_M_VCCP VM NET0135 DIODE_VLIM DILIM_SOURCE VB_3 VB_3_SOURCE DIODE_ILIM D_OUTVLIM_LOW NET0373 VB_3 DIODE_VLIM DVLIM_LOW_VB NET0110 VB DIODE_VLIM DILIM_SINK VB_3_SINK VB_3 DIODE_ILIM D_OUTVLIM_HIGH VB_3 NET0397 DIODE_VLIM DILIM_ICCP VB_3 NET0395 DIODE_ILIM DPROT_IN_M_VCCN NET0116 VM DIODE_VLIM DPROT_IN_P_VCCP NET0158 NET0134 DIODE_VLIM DPROT_IN_P_VCCN NET0115 NET0158 DIODE_VLIM CGATE_VM_PARASITIC VM VREF 7p CGATE_VP_PARASITIC VP VREF 7p CCOMP VB VB_2 {Ccomp} CBD2_PARASITIC VO_DIFF_MINUS VCCN_ENHANCED 7p CGD2_PARASITIC VO_DIFF_MINUS VM 200.0f CBD1_PARASITIC VO_DIFF_PLUS VCCN_ENHANCED 7p CDIFF_PARASITIC VO_DIFF_PLUS VO_DIFF_MINUS 200.0f CGD1_PARASITIC VO_DIFF_PLUS NET0158 200.0f E_ICCSAT_LOW ICC_OUT_LOW 0 POLY(1) VCCP VCCN 0.0023261764705882347 +-5.5705882352941006E-5 5.294117647058802E-6 EMEAS_VOUT_DIFF VOUT_DIFF 0 VO_DIFF_PLUS VO_DIFF_MINUS 1.0 EVLIM_HIGH_VB NET0153 0 VCCP 0 1.0 E_VDEP_SOURCE_1 VAL_VDEP_SOURCE 0 VALUE={ 174.5 -5000*I(VreadIo)} EVLIM_LOW_VB NET0109 0 VCCN 0 1.0 *Eldo: *E_RO1_VOL RO1_VOL 0 PWL(1) VCCP VCCN ( 2.5 , 14 ) ( 3.3 , 11 ) ( 5.0 , 7.5 ) *PSpice: E_RO1_VOL RO1_VOL 0 VALUE={TABLE(V(VCCP,VCCN), 2.5 , 14 , 3.3 , 11 , 5.0 , 7.5 )} E2_REF NET0238 0 VCCN 0 1.0 E_VDEP_SINK_1 VAL_VDEP_SINK 0 VALUE={ -159.5 -5000*I(VreadIo)} *Eldo: *E_VDEP_SINK_2 VAL_VDEP_SINK_FILTERED 0 *+VALUE={VALIF(V(val_vdep_sink)<=0 , 0 , V(val_vdep_sink))} *PSpice: E_VDEP_SINK_2 VAL_VDEP_SINK_FILTERED 0 +VALUE={IF(V(val_vdep_sink)<=0 , 0 , V(val_vdep_sink))} E_ICCSAT_HIGH ICC_OUT_HIGH 0 POLY(1) VCCP VCCN 0.0023261764705882347 +-5.5705882352941006E-5 5.294117647058802E-6 E_VREF VREF 0 NET0250 0 1.0 *Eldo: *E_RO1_VOH RO1_VOH 0 PWL(1) VCCP VCCN ( 2.5 , 14 ) ( 3.3 , 11 ) ( 5.0 , 7.5 ) *PSpice: E_RO1_VOH RO1_VOH 0 VALUE={TABLE(V(VCCP,VCCN), 2.5 , 14 , 3.3 , 11 , 5.0 , 7.5 )} *Eldo: *E_VDEP_SOURCE_3 VDEP_SOURCE 0 VALUE={VALIF( abs(I(VreadIo))<1m , 0 , *+V(val_vdep_source_filtered))} *PSpice: E_VDEP_SOURCE_3 VDEP_SOURCE 0 VALUE={IF( abs(I(VreadIo))<1m , 0 , +V(val_vdep_source_filtered))} EILIM_ICCP NET0395 NET0437 VB_3 0 1.0 EILIM_SINK VB_3_SINK VDEP_SINK VB_3 0 1.0 EILIM_ICCN NET0402 NET0477 VB_3 0 1.0 EILIM_SOURCE VB_3_SOURCE VDEP_SOURCE VB_3 0 1.0 *Eldo: *E_RO1 VB_3 NET0481 VALUE={VALIF(I(VreadIo)>0, *+V(Ro1_Voh)*I(VreadIo),V(Ro1_Vol)*I(VreadIo))} *E_VDEP_SINK_3 VDEP_SINK 0 VALUE={VALIF( abs(I(VreadIo))<1m , 0 , *+V(val_vdep_sink_filtered))} *PSpice: E_RO1 VB_3 NET0481 VALUE={IF(I(VreadIo)>0, +V(Ro1_Voh)*I(VreadIo),V(Ro1_Vol)*I(VreadIo))} E_VDEP_SINK_3 VDEP_SINK 0 VALUE={IF( abs(I(VreadIo))<1m , 0 , +V(val_vdep_sink_filtered))} E1_REF NET0210 0 VCCP 0 1.0 EVLIM_LOW_VOUT NET0372 0 VCCN 0 1.0 *Eldo: *E_VDEP_SOURCE_2 VAL_VDEP_SOURCE_FILTERED 0 *+VALUE={VALIF(V(val_vdep_source)>=0, 0, V(val_vdep_source))} *PSpice: E_VDEP_SOURCE_2 VAL_VDEP_SOURCE_FILTERED 0 +VALUE={IF(V(val_vdep_source)>=0, 0, V(val_vdep_source))} EVLIM_HIGH_VOUT NET0375 0 VCCP 0 1.0 R_ICCSAT_HIGH ICC_OUT_HIGH 0 1K R_ICCSAT_LOW ICC_OUT_LOW 0 1K RPROT_IN_P_VCCP NET0123 VCCP 15K RPROT_IN_M_VCCP VCCP NET0190 15K RD1 VCCP_ENHANCED VO_DIFF_PLUS {RD} RD2 VCCP_ENHANCED VO_DIFF_MINUS {RD} RO2_1 VREF VB_2 {Ro2_1} R1_REF NET0210 NET0250 1Meg RO2_2 VB_3 VB_2 {Ro2_2} R1 VB VREF {R1} RPROT_IN_M_VCCN VCCN NET0192 15K R2_REF NET0250 NET0238 1Meg RPROT_IN_P_VCCN NET096 VCCN 15K *Eldo: *G_IOUT_SOUCED VCCP 0 VALUE={VALIF(I(VreadIo)>0, I(VreadIo),0)} *G_ICCSAT_OUTLOW VCCP VCCN VALUE={VALIF(I(V_OUTVLIM_LOW)>1u , *+V(Icc_out_low) , 0)} *G_ICCSAT_OUTHIGH VCCP VCCN VALUE={VALIF(I(V_OUTVLIM_HIGH)>1u , *+V(Icc_out_high), 0)} *G_IOUT_SINKED VCCN 0 VALUE={VALIF(I(VreadIo)>0, 0, I(VreadIo))} *PSpice: G_IOUT_SOUCED VCCP 0 VALUE={IF(I(VreadIo)>0, I(VreadIo),0)} G_ICCSAT_OUTLOW VCCP VCCN VALUE={IF(I(V_OUTVLIM_LOW)>1u , +V(Icc_out_low) , 0)} G_ICCSAT_OUTHIGH VCCP VCCN VALUE={IF(I(V_OUTVLIM_HIGH)>1u , +V(Icc_out_high), 0)} G_IOUT_SINKED VCCN 0 VALUE={IF(I(VreadIo)>0, 0, I(VreadIo))} G_I_VB VB_2 VREF POLY(1) VB VREF 7.773528173127232E-19 +0.010310813241023556 0 0.1401392933601382 GM1 VREF VB VOUT_DIFF 0 {1/RD} G_ICC VCCP VCCN POLY(1) VCCP VCCN 6.380235294117639E-4 +5.570588235294159E-5 -5.294117647058884E-6 .ENDS *** End of subcircuit definition. .PARAM RD=1k .PARAM Ccomp=3.4p .PARAM IEE=35.8u .PARAM W=25u .PARAM L=2u .PARAM gm_mos=0.0004733346976081021 .PARAM A0=97.93103448E3 .PARAM Ro=17587.2 .PARAM GB=11m .PARAM Ro1=11 .PARAM Ro2_2=1e-3 .PARAM Ro2_1={Ro - Ro2_2 - Ro1} .PARAM R1={A0/(gm_mos*GB*Ro2_1)} .PARAM V_DPROT=0.6 *Eldo: *.MODEL MOS_N NMOS LEVEL=1 MODTYPE=ELDO VTO=+0.65 KP=500E-6 *.MODEL DIODE_VLIM D LEVEL=1 MODTYPE=ELDO IS=0.8E-15 *.MODEL DIODE_ILIM D LEVEL=1 MODTYPE=ELDO IS=0.8E-15 *.MODEL DX D LEVEL=1 MODTYPE=ELDO IS=1E-14 *PSpice: .MODEL MOS_N NMOS LEVEL=1 VTO=+0.65 KP=500E-6 .MODEL DIODE_VLIM D LEVEL=1 IS=0.8E-15 .MODEL DIODE_ILIM D LEVEL=1 IS=0.8E-15 .MODEL DX D LEVEL=1 IS=1E-14 ***********************************************************************************
