avr-dump: device "AT90S2313"
register
r00xFF , 11111111b , 255 , "."r80xFF , 11111111b , 255 , "."r160x15 , 00010101b , 21 , "."r240xEF , 11101111b , 239 , "."
r10xFF , 11111111b , 255 , "."r90xFF , 11111111b , 255 , "."r170xFF , 11111111b , 255 , "."r250xFF , 11111111b , 255 , "."
r20xFF , 11111111b , 255 , "."r100xFF , 11111111b , 255 , "."r180xFF , 11111111b , 255 , "."r260xFF , 11111111b , 255 , "."
r30xEF , 11101111b , 239 , "."r110xFF , 11111111b , 255 , "."r190xFF , 11111111b , 255 , "."r270xFF , 11111111b , 255 , "."
r40xFF , 11111111b , 255 , "."r120xFF , 11111111b , 255 , "."r200xFF , 11111111b , 255 , "."r280xFF , 11111111b , 255 , "."
r50xFF , 11111111b , 255 , "."r130xFF , 11111111b , 255 , "."r210xFF , 11111111b , 255 , "."r290x33 , 00110011b , 51 , "3"
r60xFF , 11111111b , 255 , "."r140xFF , 11111111b , 255 , "."r220xFF , 11111111b , 255 , "."r300x22 , 00100010b , 34 , """
r70xFF , 11111111b , 255 , "."r150xFF , 11111111b , 255 , "."r230xFF , 11111111b , 255 , "."r310x11 , 00010001b , 17 , "."
ports
0x28ACSRACD=0AC0=0ACI=1ACIE=0ACIC=0ACIS1=0ACIS0=0analog comparator
0x29UBRR0x19 , 00011001b , 25 , "."UART baud rate register
0x2AUCRRXCIE=0TXCIE=0UDRIE=0RXEN=0TXEN=1CHR9=0RXB8=1TXB8=0UART control register
0x2BUSRRXC=0TXC=0UDRE=0FE=0OR=0UART status register
0x2CUDR0x00 , 00000000b , 0 , "."UART I/O data register
0x30PIND0x7C , 01111100b , 124 , "|"port d input
0x31DDRD0x00 , 00000000b , 0 , "."port d direction register
0x32PORTD0x00 , 00000000b , 0 , "."port d output/pullup
0x36PINB0x16 , 00010110b , 22 , "."port b input
0x37DDRB0xFF , 11111111b , 255 , "."port b direction register
0x38PORTB0x16 , 00010110b , 22 , "."port b output/pullup
0x3CEECREEMWE=0EEWE=0EERE=0EEPROM control
0x3DEEDR0x00 , 00000000b , 0 , "."EEPROM data register
0x3EEEAR0x00 , 00000000b , 0 , "."EEPROM adress register
0x41WDTCRWDTOE=0WDE=0WDP2=0WDP1=0WDP0=0watchdog timer control
0x44ICR1L0x00 , 00000000b , 0 , "."timer/counter1- low(input capture register)
0x45ICR1H0x00 , 00000000b , 0 , "."timer/counter1- high(input capture register)
0x4AOCR1AL0x00 , 00000000b , 0 , "."timer/counter1- low(compare register)
0x4BOCR1AH0x00 , 00000000b , 0 , "."timer/counter1- high(compare register)
0x4CTCNT1L0x00 , 00000000b , 0 , "."timer/counter1- low(counter register)
0x4DTCNT1H0x00 , 00000000b , 0 , "."timer/counter1- high(counter register)
0x4ETCCR1BICNC1=0ICES1=0CTC1=0CS12=0CS11=0CS10=0timer/counter1 control register
0x4FTCCR1ACOM1A1=0COM1A0=0PWM11=0PWM10=0timer/counter1 control register
0x52TCNT00x00 , 00000000b , 0 , "."timer/counter0 (8bits)
0x53TCCR0CS02=0CS01=0CS00=0timer prescale register
0x55MCUCRSE=0SM=0ISC11=0ISC10=0ISC01=1ISC00=1MCU control
0x58TIFRTOV1=0OCF1A=0ICF1=0TOV0=0timer interrupt flags
0x59TIMSKTOIE1=0OCIE1A=0TICIE1=0TOIE0=0timer interupt mask
0x5AGIFRINTF1=0INTF0=0interrupt flags
0x5BGIMSKINT1=0INT0=1interrupt mask
0x5DSPL0xDB , 11011011b , 219 , "."low(stack pointer)
0x5FSREGI=0T=0H=0S=0V=0N=0Z=0C=0flag register
memory
0x600x00 , 00000000b , 0 , "."0x800x20 , 00100000b , 32 , " "0xA00x00 , 00000000b , 0 , "."0xC00x00 , 00000000b , 0 , "."
0x610x40 , 01000000b , 64 , "@"0x810x20 , 00100000b , 32 , " "0xA10x88 , 10001000b , 136 , "."0xC10x00 , 00000000b , 0 , "."
0x620x02 , 00000010b , 2 , "."0x820x00 , 00000000b , 0 , "."0xA20x00 , 00000000b , 0 , "."0xC20x00 , 00000000b , 0 , "."
0x630x00 , 00000000b , 0 , "."0x830x00 , 00000000b , 0 , "."0xA30x00 , 00000000b , 0 , "."0xC30x04 , 00000100b , 4 , "."
0x640x00 , 00000000b , 0 , "."0x840x00 , 00000000b , 0 , "."0xA40x00 , 00000000b , 0 , "."0xC40x00 , 00000000b , 0 , "."
0x650x00 , 00000000b , 0 , "."0x850x00 , 00000000b , 0 , "."0xA50x00 , 00000000b , 0 , "."0xC50x00 , 00000000b , 0 , "."
0x660x1C , 00011100b , 28 , "."0x860x04 , 00000100b , 4 , "."0xA60x00 , 00000000b , 0 , "."0xC60x00 , 00000000b , 0 , "."
0x670xC0 , 11000000b , 192 , "."0x870x12 , 00010010b , 18 , "."0xA70x08 , 00001000b , 8 , "."0xC70x00 , 00000000b , 0 , "."
0x680x00 , 00000000b , 0 , "."0x880x00 , 00000000b , 0 , "."0xA80x00 , 00000000b , 0 , "."0xC80x0A , 00001010b , 10 , "."
0x690x00 , 00000000b , 0 , "."0x890x00 , 00000000b , 0 , "."0xA90x08 , 00001000b , 8 , "."0xC90x00 , 00000000b , 0 , "."
0x6A0x00 , 00000000b , 0 , "."0x8A0x00 , 00000000b , 0 , "."0xAA0x20 , 00100000b , 32 , " "0xCA0x00 , 00000000b , 0 , "."
0x6B0x00 , 00000000b , 0 , "."0x8B0x04 , 00000100b , 4 , "."0xAB0x00 , 00000000b , 0 , "."0xCB0xB2 , 10110010b , 178 , "."
0x6C0x00 , 00000000b , 0 , "."0x8C0x00 , 00000000b , 0 , "."0xAC0x00 , 00000000b , 0 , "."0xCC0xB1 , 10110001b , 177 , "."
0x6D0x00 , 00000000b , 0 , "."0x8D0x00 , 00000000b , 0 , "."0xAD0x00 , 00000000b , 0 , "."0xCD0xB0 , 10110000b , 176 , "."
0x6E0x08 , 00001000b , 8 , "."0x8E0x00 , 00000000b , 0 , "."0xAE0x20 , 00100000b , 32 , " "0xCE0xAF , 10101111b , 175 , "."
0x6F0x48 , 01001000b , 72 , "H"0x8F0x00 , 00000000b , 0 , "."0xAF0x00 , 00000000b , 0 , "."0xCF0xAE , 10101110b , 174 , "."
0x700x08 , 00001000b , 8 , "."0x900x01 , 00000001b , 1 , "."0xB00x00 , 00000000b , 0 , "."0xD00xAD , 10101101b , 173 , "."
0x710x40 , 01000000b , 64 , "@"0x910x00 , 00000000b , 0 , "."0xB10x00 , 00000000b , 0 , "."0xD10xAC , 10101100b , 172 , "."
0x720xA0 , 10100000b , 160 , "."0x920x00 , 00000000b , 0 , "."0xB20x00 , 00000000b , 0 , "."0xD20xAB , 10101011b , 171 , "."
0x730x00 , 00000000b , 0 , "."0x930x00 , 00000000b , 0 , "."0xB30x00 , 00000000b , 0 , "."0xD30xAA , 10101010b , 170 , "."
0x740x00 , 00000000b , 0 , "."0x940x00 , 00000000b , 0 , "."0xB40x00 , 00000000b , 0 , "."0xD40xA9 , 10101001b , 169 , "."
0x750x80 , 10000000b , 128 , "."0x950x00 , 00000000b , 0 , "."0xB50x00 , 00000000b , 0 , "."0xD50xA8 , 10101000b , 168 , "."
0x760x00 , 00000000b , 0 , "."0x960x00 , 00000000b , 0 , "."0xB60x00 , 00000000b , 0 , "."0xD60xA7 , 10100111b , 167 , "."
0x770x04 , 00000100b , 4 , "."0x970x80 , 10000000b , 128 , "."0xB70x00 , 00000000b , 0 , "."0xD70xA6 , 10100110b , 166 , "."
0x780x00 , 00000000b , 0 , "."0x980x00 , 00000000b , 0 , "."0xB80x00 , 00000000b , 0 , "."0xD80xA5 , 10100101b , 165 , "."
0x790x00 , 00000000b , 0 , "."0x990x00 , 00000000b , 0 , "."0xB90x00 , 00000000b , 0 , "."0xD90xA4 , 10100100b , 164 , "."
0x7A0x00 , 00000000b , 0 , "."0x9A0x02 , 00000010b , 2 , "."0xBA0x00 , 00000000b , 0 , "."0xDA0xA3 , 10100011b , 163 , "."
0x7B0x40 , 01000000b , 64 , "@"0x9B0x00 , 00000000b , 0 , "."0xBB0x40 , 01000000b , 64 , "@"0xDB0xA2 , 10100010b , 162 , "."
0x7C0x00 , 00000000b , 0 , "."0x9C0x04 , 00000100b , 4 , "."0xBC0x82 , 10000010b , 130 , "."0xDC0x00 , 00000000b , 0 , "."
0x7D0x00 , 00000000b , 0 , "."0x9D0x00 , 00000000b , 0 , "."0xBD0x00 , 00000000b , 0 , "."0xDD0x8E , 10001110b , 142 , "."
0x7E0x00 , 00000000b , 0 , "."0x9E0x00 , 00000000b , 0 , "."0xBE0x00 , 00000000b , 0 , "."0xDE0x00 , 00000000b , 0 , "."
0x7F0x00 , 00000000b , 0 , "."0x9F0x02 , 00000010b , 2 , "."0xBF0x80 , 10000000b , 128 , "."0xDF0x33 , 00110011b , 51 , "3"
eeprom
0x000xFF , 11111111b , 255 , "."0x200xFF , 11111111b , 255 , "."0x400xFF , 11111111b , 255 , "."0x600xFF , 11111111b , 255 , "."
0x010xFF , 11111111b , 255 , "."0x210xFF , 11111111b , 255 , "."0x410xFF , 11111111b , 255 , "."0x610xFF , 11111111b , 255 , "."
0x020xFF , 11111111b , 255 , "."0x220xFF , 11111111b , 255 , "."0x420xFF , 11111111b , 255 , "."0x620xFF , 11111111b , 255 , "."
0x030xFF , 11111111b , 255 , "."0x230xFF , 11111111b , 255 , "."0x430xFF , 11111111b , 255 , "."0x630xFF , 11111111b , 255 , "."
0x040xFF , 11111111b , 255 , "."0x240xFF , 11111111b , 255 , "."0x440xFF , 11111111b , 255 , "."0x640xFF , 11111111b , 255 , "."
0x050xFF , 11111111b , 255 , "."0x250xFF , 11111111b , 255 , "."0x450xFF , 11111111b , 255 , "."0x650xFF , 11111111b , 255 , "."
0x060xFF , 11111111b , 255 , "."0x260xFF , 11111111b , 255 , "."0x460xFF , 11111111b , 255 , "."0x660xFF , 11111111b , 255 , "."
0x070xFF , 11111111b , 255 , "."0x270xFF , 11111111b , 255 , "."0x470xFF , 11111111b , 255 , "."0x670xFF , 11111111b , 255 , "."
0x080xFF , 11111111b , 255 , "."0x280xFF , 11111111b , 255 , "."0x480xFF , 11111111b , 255 , "."0x680xFF , 11111111b , 255 , "."
0x090xFF , 11111111b , 255 , "."0x290xFF , 11111111b , 255 , "."0x490xFF , 11111111b , 255 , "."0x690xFF , 11111111b , 255 , "."
0x0a0xFF , 11111111b , 255 , "."0x2a0xFF , 11111111b , 255 , "."0x4a0xFF , 11111111b , 255 , "."0x6a0xFF , 11111111b , 255 , "."
0x0b0xFF , 11111111b , 255 , "."0x2b0xFF , 11111111b , 255 , "."0x4b0xFF , 11111111b , 255 , "."0x6b0xFF , 11111111b , 255 , "."
0x0c0xFF , 11111111b , 255 , "."0x2c0xFF , 11111111b , 255 , "."0x4c0xFF , 11111111b , 255 , "."0x6c0xFF , 11111111b , 255 , "."
0x0d0xFF , 11111111b , 255 , "."0x2d0xFF , 11111111b , 255 , "."0x4d0xFF , 11111111b , 255 , "."0x6d0xFF , 11111111b , 255 , "."
0x0e0xFF , 11111111b , 255 , "."0x2e0xFF , 11111111b , 255 , "."0x4e0xFF , 11111111b , 255 , "."0x6e0xFF , 11111111b , 255 , "."
0x0f0xFF , 11111111b , 255 , "."0x2f0xFF , 11111111b , 255 , "."0x4f0xFF , 11111111b , 255 , "."0x6f0xFF , 11111111b , 255 , "."
0x100xFF , 11111111b , 255 , "."0x300xFF , 11111111b , 255 , "."0x500xFF , 11111111b , 255 , "."0x700xFF , 11111111b , 255 , "."
0x110xFF , 11111111b , 255 , "."0x310xFF , 11111111b , 255 , "."0x510xFF , 11111111b , 255 , "."0x710xFF , 11111111b , 255 , "."
0x120xFF , 11111111b , 255 , "."0x320xFF , 11111111b , 255 , "."0x520xFF , 11111111b , 255 , "."0x720xFF , 11111111b , 255 , "."
0x130xFF , 11111111b , 255 , "."0x330xFF , 11111111b , 255 , "."0x530xFF , 11111111b , 255 , "."0x730xFF , 11111111b , 255 , "."
0x140xFF , 11111111b , 255 , "."0x340xFF , 11111111b , 255 , "."0x540xFF , 11111111b , 255 , "."0x740xFF , 11111111b , 255 , "."
0x150xFF , 11111111b , 255 , "."0x350xFF , 11111111b , 255 , "."0x550xFF , 11111111b , 255 , "."0x750xFF , 11111111b , 255 , "."
0x160xFF , 11111111b , 255 , "."0x360xFF , 11111111b , 255 , "."0x560xFF , 11111111b , 255 , "."0x760xFF , 11111111b , 255 , "."
0x170xFF , 11111111b , 255 , "."0x370xFF , 11111111b , 255 , "."0x570xFF , 11111111b , 255 , "."0x770xFF , 11111111b , 255 , "."
0x180xFF , 11111111b , 255 , "."0x380xFF , 11111111b , 255 , "."0x580xFF , 11111111b , 255 , "."0x780xFF , 11111111b , 255 , "."
0x190xFF , 11111111b , 255 , "."0x390xFF , 11111111b , 255 , "."0x590xFF , 11111111b , 255 , "."0x790xFF , 11111111b , 255 , "."
0x1a0xFF , 11111111b , 255 , "."0x3a0xFF , 11111111b , 255 , "."0x5a0xFF , 11111111b , 255 , "."0x7a0xFF , 11111111b , 255 , "."
0x1b0xFF , 11111111b , 255 , "."0x3b0xFF , 11111111b , 255 , "."0x5b0xFF , 11111111b , 255 , "."0x7b0xFF , 11111111b , 255 , "."
0x1c0xFF , 11111111b , 255 , "."0x3c0xFF , 11111111b , 255 , "."0x5c0xFF , 11111111b , 255 , "."0x7c0xFF , 11111111b , 255 , "."
0x1d0xFF , 11111111b , 255 , "."0x3d0xFF , 11111111b , 255 , "."0x5d0xFF , 11111111b , 255 , "."0x7d0xFF , 11111111b , 255 , "."
0x1e0xFF , 11111111b , 255 , "."0x3e0xFF , 11111111b , 255 , "."0x5e0xFF , 11111111b , 255 , "."0x7e0xFF , 11111111b , 255 , "."
0x1f0xFF , 11111111b , 255 , "."0x3f0xFF , 11111111b , 255 , "."0x5f0xFF , 11111111b , 255 , "."0x7f0xFF , 11111111b , 255 , "."
