#!/usr/bin/python
import smbus
# Adafruit_I2C Class
class Adafruit_I2C :
  @staticmethod
  def getPiRevision():
    "Gets the version number of the Raspberry Pi board"
    # Courtesy quick2wire-python-api
    # https://github.com/quick2wire/quick2wire-python-api
    try:
      with open('/proc/cpuinfo','r') as f:
        for line in f:
          if line.startswith('Revision'):
            return 1 if line.rstrip()[-1] in ['1','2'] else 2
    except:
      return 0
  @staticmethod
  def getPiI2CBusNumber():
    # Gets the I2C bus number /dev/i2c#
    return 1 if Adafruit_I2C.getPiRevision() > 1 else 0
  def __init__(self, address, busnum=-1, debug=False):
    self.address = address
    # By default, the correct I2C bus is auto-detected using /proc/cpuinfo
    # Alternatively, you can hard-code the bus version below:
    # self.bus = smbus.SMBus(0); # Force I2C0 (early 256MB Pi's)
    # self.bus = smbus.SMBus(1); # Force I2C1 (512MB Pi's)
      busnum if busnum >= 0 else Adafruit_I2C.getPiI2CBusNumber())
    self.debug = debug
  def reverseByteOrder(self, data):
    "Reverses the byte order of an int (16-bit) or long (32-bit) value"
    # Courtesy Vishal Sapre
    byteCount = len(hex(data)[2:].replace('L','')[::2])
    val       = 0
    for i in range(byteCount):
      val    = (val << 8) | (data & 0xff)
      data >>= 8
    return val
  def errMsg(self):
    print "Error accessing 0x%02X: Check your I2C address" % self.address
    return -1
  def write8(self, reg, value):
    "Writes an 8-bit value to the specified register/address"
    try:
      self.bus.write_byte_data(self.address, reg, value)
      if self.debug:
        print "I2C: Wrote 0x%02X to register 0x%02X" % (value, reg)
    except IOError, err:
      return self.errMsg()
  def write16(self, reg, value):
    "Writes a 16-bit value to the specified register/address pair"
    try:
      self.bus.write_word_data(self.address, reg, value)
      if self.debug:
        print ("I2C: Wrote 0x%02X to register pair 0x%02X,0x%02X" %
         (value, reg, reg+1))
  def writeList(self, reg, list):
    "Writes an array of bytes using I2C format"
    try:
      if self.debug:
        print "I2C: Writing list to register 0x%02X:" % reg
        print list
      self.bus.write_i2c_block_data(self.address, reg, list)
  def readList(self, reg, length):
    "Read a list of bytes from the I2C device"
    try:
      results = self.bus.read_i2c_block_data(self.address, reg, length)
      if self.debug:
        print ("I2C: Device 0x%02X returned the following from reg 0x%02X" %
         (self.address, reg))
        print results
      return results
  def readU8(self, reg):
    "Read an unsigned byte from the I2C device"
    try:
      result = self.bus.read_byte_data(self.address, reg)
      if self.debug:
        print ("I2C: Device 0x%02X returned 0x%02X from reg 0x%02X" %
         (self.address, result & 0xFF, reg))
      return result
  def readS8(self, reg):
    "Reads a signed byte from the I2C device"
    try:
      if result > 127: result -= 256
      if self.debug:
      return result
  def readU16(self, reg):
    "Reads an unsigned 16-bit value from the I2C device"
    try:
      result = self.bus.read_word_data(self.address,reg)
      if (self.debug):
        print "I2C: Device 0x%02X returned 0x%04X from reg 0x%02X" % (self.address, result & 0xFFFF, reg)
      return result
  def readS16(self, reg):
    "Reads a signed 16-bit value from the I2C device"
    try:
      if (self.debug):
      return result
if __name__ == '__main__':
  try:
    bus = Adafruit_I2C(address=0)
    print "Default I2C bus is accessible"
  except:
    print "Error accessing default I2C bus"
