Version 4 SHEET 1 6664 1652 WIRE 336 -656 320 -656 WIRE 496 -656 416 -656 WIRE 496 -624 496 -656 WIRE 496 -624 432 -624 WIRE 560 -624 496 -624 WIRE 560 -608 560 -624 WIRE 560 -512 560 -528 WIRE 560 -512 432 -512 WIRE 560 -496 560 -512 WIRE 432 -400 432 -512 WIRE 496 -400 432 -400 WIRE 560 -400 560 -416 WIRE 560 -400 496 -400 WIRE -128 -368 -160 -368 WIRE 80 -368 -128 -368 WIRE 128 -368 80 -368 WIRE 192 -368 128 -368 WIRE 320 -368 320 -656 WIRE 320 -368 288 -368 WIRE 496 -368 496 -400 WIRE 624 -368 496 -368 WIRE 816 -368 624 -368 WIRE 896 -368 816 -368 WIRE 944 -368 896 -368 WIRE 128 -336 128 -368 WIRE 496 -336 496 -368 WIRE 896 -336 896 -368 WIRE 320 -320 320 -368 WIRE 816 -272 816 -368 WIRE 496 -256 496 -272 WIRE 128 -224 128 -272 WIRE 320 -224 320 -256 WIRE 240 -192 240 -304 WIRE 496 -160 496 -176 WIRE 896 -128 896 -256 WIRE 80 -32 80 -368 WIRE 112 -32 80 -32 WIRE 336 -32 192 -32 WIRE 704 -32 336 -32 WIRE 736 -32 704 -32 WIRE 240 16 240 -112 WIRE 624 16 624 -368 WIRE 736 16 736 -32 WIRE 816 48 816 -192 WIRE 816 48 768 48 WIRE 336 64 336 -32 WIRE 336 64 304 64 WIRE -160 96 -160 -368 WIRE 240 144 240 112 WIRE 624 144 624 96 WIRE 624 144 240 144 WIRE 816 176 816 48 WIRE 240 192 240 144 WIRE -160 288 -160 176 WIRE 240 288 240 256 WIRE 736 288 736 80 WIRE 816 288 816 256 FLAG -160 288 0 FLAG 496 -160 0 FLAG 736 288 0 FLAG 240 288 0 FLAG 816 288 0 FLAG 944 -368 OUT FLAG -128 -368 IN FLAG 896 -128 0 FLAG 704 -32 X1A FLAG 128 -224 0 FLAG 320 -224 0 SYMBOL voltage -160 80 R0 WINDOW 123 0 0 Left 2 WINDOW 39 24 124 Left 2 SYMATTR SpiceLine Rser=0 SYMATTR InstName V1 SYMATTR Value PULSE(48 48 0 10m) SYMBOL npn 304 16 M0 WINDOW 0 -2 114 Left 2 WINDOW 3 -48 141 Left 2 SYMATTR InstName Q2 SYMATTR Value 2N5550 SYMBOL schottky 336 -256 R180 WINDOW 0 -41 38 Left 2 WINDOW 3 -118 -3 Left 2 SYMATTR InstName D1 SYMATTR Value MBRS1100 SYMATTR Description Diode SYMATTR Type diode SYMBOL res 208 -16 M270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R1 SYMATTR Value 22K SYMBOL res 256 -96 R180 WINDOW 0 57 82 Left 2 WINDOW 3 47 45 Left 2 SYMATTR InstName R2 SYMATTR Value 2.2K SYMBOL res 832 272 R180 WINDOW 0 36 76 Left 2 WINDOW 3 36 40 Left 2 SYMATTR InstName R4 SYMATTR Value 22K SYMBOL pnp 288 -304 M270 WINDOW 0 155 145 VLeft 2 WINDOW 3 126 146 VLeft 2 SYMATTR InstName Q1 SYMATTR Value FZT953_ZTX SYMBOL Misc\\EuropeanPolcap 112 -336 R0 SYMATTR InstName C1 SYMATTR Value 100µ SYMATTR SpiceLine Rser=500m SYMBOL Misc\\EuropeanPolcap 480 -336 R0 SYMATTR InstName C2 SYMATTR Value 47µ SYMATTR SpiceLine Rser=100m SYMBOL res 880 -352 R0 SYMATTR InstName R5 SYMATTR Value 39 SYMBOL res 320 -640 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R6 SYMATTR Value 800m SYMBOL ind 544 -512 R0 SYMATTR InstName L1 SYMATTR Value 1m SYMBOL ind 544 -512 M180 WINDOW 0 36 80 Left 2 WINDOW 3 36 40 Left 2 SYMATTR InstName L3 SYMATTR Value Flux={(L-Ls)*Is}*pwrs(tanh(pwrs(x/{Is},{n})),{1/n})+{Ls}*x SYMBOL res 832 -176 R180 WINDOW 0 36 76 Left 2 WINDOW 3 36 40 Left 2 SYMATTR InstName R3 SYMATTR Value 68K SYMBOL TLV431_AS 752 16 M0 WINDOW 3 -210 44 Left 2 SYMATTR InstName U2 SYMBOL LED 224 192 R0 SYMATTR InstName D2 SYMBOL res 512 -160 R180 WINDOW 0 -47 74 Left 2 WINDOW 3 -42 43 Left 2 SYMATTR InstName R7 SYMATTR Value .33 SYMBOL res 608 112 M180 WINDOW 0 -51 73 Left 2 WINDOW 3 -48 37 Left 2 SYMATTR InstName R8 SYMATTR Value 22K TEXT -152 -616 Left 2 !.tran 0 0.6m 0 uic TEXT 48 -528 Left 2 !.lib FZT953_ZTX.mod TEXT 648 -584 Left 2 !.param L=1.3m Ls=1.3m/6 Is=950m n=4 TEXT 648 -608 Left 2 ;Fastron 09HCP-102X-50 (1mH) TEXT 1160 -408 Left 2 ;coil TEXT 480 -568 Left 2 ;sat TEXT 480 -456 Left 2 ;lin TEXT 1072 -328 Left 2 !.ic V(out)=5.1 TEXT 984 -104 Left 2 ;load TEXT 400 -688 Left 2 ;(coil DC resistance) LINE Normal 384 -448 416 -448 2 LINE Normal 384 -560 384 -448 2 LINE Normal 416 -560 384 -560 2 RECTANGLE Normal 1216 -704 304 -384 2 RECTANGLE Normal 1040 -80 848 -352 2
