RomBOOT main RTTC MR: 32768 VR: 0 Ignore command! command=79 Call Menu ...  ATMEL DataFlash LOADER VER 1.03 Aug 27 2007 13:23:08 *--------------------------------------* DataFlash[33Mhz]:AT45DB642 Nb pages: 008192 Page Size: 001056 Size=08650752 bytes Logical address: 0xC0000000 *--------------------------------------* 1: Read Dataflash [addr] 2: Start UBOOT [C0008000 => 20000000] *--------------------------------------* Enter: rStartBoot RTTC MR: 32768 VR: 1 Load UBOOT from dataflash[c0008000] to SDRAM[23f00000] PLLA[200MHz], MCK[100Mhz] ==> Start UBOOT Probe cs=14 Probe cs=6 Probe cs=3 Probe cs=-1 AT91F_SpiWrite : Error Timeout U-Boot 1.1.4 (Feb 11 2011 - 17:11:07) DRAM: 64 MB NAND:NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (0`d0< NAND 64MiB 3,3V 8-bit) NAND bus width 16 instead 8 bit 0 MiB Probe cs=14 Probe cs=6 Probe cs=3 Probe cs=0 DataFlash:AT45DB642 Nb pages: 8192 Page Size: 1056 Size= 8650752 bytes Logical address: 0xC0000000 Area 0: C0000000 to C0003FFF (RO) Area 1: C0004000 to C0007FFF Area 2: C0008000 to C0037FFF (RO) Area 3: C0038000 to C083FFFF DataFlash:AT45DB642 Nb pages: 8192 Page Size: 1056 Size= 8650752 bytes Logical address: 0xD0000000 Area 0: D0000000 to D0003FFF (RO) Area 1: D0004000 to D0007FFF Area 2: D0008000 to D0037FFF (RO) Area 3: D0038000 to D083FFFF drv_lcd_init [LCD] Initializing LCD frambuffer FRAMECFG=19200 FRAMECFG+BURST=-16758016 CLKVAL=7 In: serial Out: serial Err: serial dm9000 i/o: 0x30000000, id: 0x90000a46 No ethadr! Hit any key to stop autoboot: 1  0 ## Booting image at 20000000 ... Image Name: Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3028672 Bytes = 2.9 MB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK OK Starting kernel ... Linux version 2.6.19-rc6-smp (root@BOHLANG) (gcc version 3.4.1 20040714 (TimeSys 3.4.1-7)) #927 Tue Jun 7 08:58:44 CEST 2011 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 Machine: Atmel AT91SAM9261-EK Ignoring unrecognised tag 0x54410008 Memory policy: ECC disabled, Data cache writeback Clocks: CPU 198 MHz, master 99 MHz, main 18.432 MHz CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets Built 1 zonelists. Total pages: 16256 Kernel command line: mem=64M console=/dev/ttyS0,115200 root=/dev/mtdblock0 rootfstype=jffs2 rootflags=noatime AT91: 96 gpio irqs in 3 banks PID hash table entries: 256 (order: 8, 1024 bytes) Console init Console: colour dummy device 80x30 Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 61824KB available (2308K code, 602K data, 168K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 512 (order: -1, 2048 bytes) TCP established hash table entries: 2048 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 2048 bind 1024) TCP reno registered NetWinder Floating Point Emulator V0.97 (double precision) JFFS2 version 2.2. (NAND) (SUMMARY) (C) 2001-2006 Red Hat, Inc. yaffs Feb 11 2011 15:30:08 Installing. io scheduler noop registered io scheduler anticipatory registered (default) io scheduler deadline registered io scheduler cfq registered atmel_lcdfb_check_var atmel_lcdfb_check_var: resolution: 320x240 pixclk: 5850000 Hz bpp: 24 clk: 99328000 Hz atmel_lcdfb_resize_framebuffer atmel_lcdfb atmel_lcdfb.0: 225KiB frame buffer at 23d00000 (mapped at ffc00000) atmel_lcdfb_update_dma start Stage Update Console: switching to colour frame buffer device 40x30 atmel_lcdfb atmel_lcdfb.0: Driver $Revision: 1.4 $ GPBR Driver v0.1 at91 atmega168 driver init atmega168_driver=0xc02a9398 SPI ATMEGA168 Driver v0.1 at91 pid driver init PID Driver v1.0.20071119 at91 ad7718 driver init SPI AD Driver v1.0.20071122 at91 at_t6816 driver init spi_register_driver misc_register SPI ATLSS Driver v1.0.20071122 atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL atmel_usart.1: ttyS1 at MMIO 0xfffb0000 (irq = 6) is a ATMEL_SERIAL RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize dm9000 Ethernet Driver eth%d: Invalid ethernet MAC address. Please set using ifconfig eth0: dm9000 at c485e000,c4865044 IRQ 107 MAC: 00:00:00:00:00:00 NFTL driver: nftlcore.c $Revision: 1.1 $, nftlmount.c $Revision: 1.1 $ NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit) Scanning device for bad blocks Bad eraseblock 1112 at 0x01160000 Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit": 0x00000000-0x02000000 : "ROOT" 0x02000000-0x04000000 : "RESERVE" atmel_spi atmel_spi.0: Atmel SPI Controller at 0xfffc8000 (irq 12) mtd_dataflash spi0.14: AT45DB642x (8448 KBytes) mtd_dataflash spi0.6: AT45DB642x (8448 KBytes) at_t6816_probe at_t6816 - Using 1 MHz SPI... atmega_probe Atmega168 - Using 1000000 Hz SPI... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID failed, retrying ... Atmega168 - Read ID Timeout, using LP1 AD7718 ... Atmega168 nId=0x0 ad7718_probe AD7718 - Using 5 MHz SPI... at91_ohci at91_ohci: AT91 OHCI at91_ohci at91_ohci: new USB bus registered, assigned bus number 1 at91_ohci at91_ohci: irq 20, io mem 0x00500000 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usb 1-1: new full speed USB device using at91_ohci and address 2 usb 1-1: configuration #1 chosen from 1 choice usb 1-2: new full speed USB device using at91_ohci and address 3 usb 1-2: configuration #1 chosen from 1 choice scsi0 : SCSI emulation for USB Mass Storage devices scsi1 : SCSI emulation for USB Mass Storage devices usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver usbhid drivers/usb/input/hid-core.c: v2.6:USB HID core driver mice: PS/2 mouse device common for all mice AD7843e Driver, Version: 0.1.201_20070627 input: SAM926x Touchscreen as /class/input/input0 AT91 Real Time Clock probe. at91_rtc at91_rtc: rtc intf: sysfs at91_rtc at91_rtc: rtc intf: proc at91_rtc at91_rtc: rtc intf: dev (254:0) at91_rtc at91_rtc: rtc core: registered at91_rtc as rtc0 AT91 Real Time Clock driver. Advanced Linux Sound Architecture Driver Version 1.0.13 (Sun Oct 22 08:56:16 2006 UTC). AIC26 - Using 1 MHz SPI CPOL CPHA ... AIC26 HW Init Speed Set to 1 MHz Internal Speaker on! AIC_PG2_AUDIOCTRL1 = 0x0 AIC_PG2_DACGAIN = 0x0 AIC_PG2_AUDIOCTRL2 = 0x4410 AIC_PG2_AUDIOCTRL3 = 0x2803 AIC_PG2_PWRCTRL = 0xacc0 ALSA device list: #0: AT73C213 TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 at91 rtc_read mode=32768 value=12 at91_rtc_readtime(): 1970-00-01 00:00:12 at91_rtc at91_rtc: setting the system clock to 1970-01-01 00:00:12 (12) VFS: Mounted root (jffs2 filesystem). Freeing init memory: 168K scsi 0:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0 CCS scsi 1:0:0:0: Direct-Access Mass Storage Device PQ: 0 ANSI: 0 CCS SCSI device sda: 3862528 512-byte hdwr sectors (1978 MB) sda: Write Protect is off sda: assuming drive cache: write through SCSI device sda: 3862528 512-byte hdwr sectors (1978 MB) sda: Write Protect is off sda: assuming drive cache: write through sda: sda1 SCSI device sdb: 7841791 512-byte hdwr sectors (4015 MB) sdb: Write Protect is off sdb: assuming drive cache: write through SCSI device sdb: 7841791 512-byte hdwr sectors (4015 MB) sdb: Write Protect is off sdb: assuming drive cache: write through sdb: sdb1 sdb: p1 exceeds device capacity sd 0:0:0:0: Attached scsi removable disk sda sd 1:0:0:0: Attached scsi removable disk sdb JFFS2 notice: (239) read_dnode: node CRC failed on dnode at 0xd499c4: read 0xffffffff, calculated 0x4ccb9081 VFS: Can't find a Minix or Minix V2 filesystem on device sda1 VFS: Can't find a Minix or Minix V2 filesystem on device sdb1 JFFS2 notice: (584) check_node_data: wrong data CRC in data node at 0x00f65400: read 0x6a2ccf01, calculated 0xe1c8d020. eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1 INIT: Entering runlevel: 5 1376 inodes 4096 blocks Firstdatazone=47 (47) Zonesize=1024 Maxsize=268966912 APP ... /etc/rc5.d/S20display: 71: //: Permission denied ifconfig ... eth0: link down handle to /dev/mem = 00000003 mptr = 4001b000 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 02 04 01 00 8f 00 00 00 02 04 01 0f 8f 01 0f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SSC_TFMR=f018f SSC_TFMR=1f018f SSC_CR=00000000 SSC_CMR=20000000 SSC_TCMR=0204010f SSC_TFMR=8f010f00 SSC_THR=00000000 SSC_SR=cf000100 SSC_IER=00000000 SSC_IDR=00000000 SSC_IMR=00000000 FSOS=1 SSC_TFMR=000f018f SSC_TFMR=000f018f eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1 eth0: link down eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1 Internal Speaker on! Speed Set to 1 MHz warn: aic26_write_reg_checked timeout Failed cmd: AIC_PG2_PWRCTRL, CDC_PWUP | ASTONE_PWUP | AOUT_HPWR | DAC_PWUP telnetd ... telnetd: starting port: 23; interface: any; login program: /bin/login cp: unable to open `/KBO/Server': Text file busy
