<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.6.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="DISPLAY_164">
<wire x1="87" y1="0" x2="0" y2="0" width="0.254" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="60" width="0.254" layer="21"/>
<wire x1="0" y1="60" x2="87" y2="60" width="0.254" layer="21"/>
<wire x1="87" y1="60" x2="87" y2="0" width="0.254" layer="21"/>
<circle x="2.6" y="57.4" radius="2.236065625" width="0.254" layer="21"/>
<circle x="2.27" y="2.27" radius="2" width="0.254" layer="21"/>
<circle x="84.77" y="2.27" radius="2" width="0.254" layer="21"/>
<circle x="84.1" y="57.4" radius="2.236065625" width="0.254" layer="21"/>
<smd name="P2" x="12.7" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P1" x="10.16" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P3" x="15.24" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P4" x="17.78" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P5" x="20.32" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P6" x="22.86" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P7" x="25.4" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P8" x="27.94" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P9" x="30.48" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P10" x="33.02" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P11" x="35.56" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P12" x="38.1" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P13" x="40.64" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P14" x="43.18" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P15" x="45.72" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<smd name="P16" x="48.26" y="58.42" dx="1.27" dy="0.635" layer="1" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="DISPLAY">
<wire x1="-22.86" y1="7.62" x2="-22.86" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-22.86" y1="-10.16" x2="22.86" y2="-10.16" width="0.254" layer="94"/>
<wire x1="22.86" y1="-10.16" x2="22.86" y2="7.62" width="0.254" layer="94"/>
<wire x1="22.86" y1="7.62" x2="-22.86" y2="7.62" width="0.254" layer="94"/>
<text x="-15.24" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<text x="5.08" y="10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="E" x="-27.94" y="5.08" length="middle"/>
<pin name="RW" x="-27.94" y="2.54" length="middle"/>
<pin name="RS" x="-27.94" y="0" length="middle"/>
<pin name="VDD" x="-27.94" y="-2.54" length="middle"/>
<pin name="V0" x="-27.94" y="-7.62" length="middle"/>
<pin name="VSS" x="-27.94" y="-5.08" length="middle"/>
<pin name="VLED" x="27.94" y="0" length="middle" rot="R180"/>
<pin name="VLSS" x="27.94" y="5.08" length="middle" rot="R180"/>
<pin name="DB0" x="-15.24" y="-15.24" length="middle" rot="R90"/>
<pin name="DB1" x="-10.16" y="-15.24" length="middle" rot="R90"/>
<pin name="DB2" x="-5.08" y="-15.24" length="middle" rot="R90"/>
<pin name="DB3" x="0" y="-15.24" length="middle" rot="R90"/>
<pin name="DB4" x="5.08" y="-15.24" length="middle" rot="R90"/>
<pin name="DB5" x="10.16" y="-15.24" length="middle" rot="R90"/>
<pin name="DB6" x="15.24" y="-15.24" length="middle" rot="R90"/>
<pin name="DB7" x="20.32" y="-15.24" length="middle" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="EA_W164BL-NLW">
<gates>
<gate name="G$1" symbol="DISPLAY" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DISPLAY_164">
<connects>
<connect gate="G$1" pin="DB0" pad="P7"/>
<connect gate="G$1" pin="DB1" pad="P8"/>
<connect gate="G$1" pin="DB2" pad="P9"/>
<connect gate="G$1" pin="DB3" pad="P10"/>
<connect gate="G$1" pin="DB4" pad="P11"/>
<connect gate="G$1" pin="DB5" pad="P12"/>
<connect gate="G$1" pin="DB6" pad="P13"/>
<connect gate="G$1" pin="DB7" pad="P14"/>
<connect gate="G$1" pin="E" pad="P6"/>
<connect gate="G$1" pin="RS" pad="P4"/>
<connect gate="G$1" pin="RW" pad="P5"/>
<connect gate="G$1" pin="V0" pad="P3"/>
<connect gate="G$1" pin="VDD" pad="P2"/>
<connect gate="G$1" pin="VLED" pad="P15"/>
<connect gate="G$1" pin="VLSS" pad="P16"/>
<connect gate="G$1" pin="VSS" pad="P1"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
