$regfile = "M8def.dat" $crystal = 8000000 $baud = 19200 $hwstack = 200 $swstack = 200 $framesize = 400 Config Scl = Portb.7 Config Sda = Portb.5 Declare Sub Read_gyro Declare Sub Read_acc Dim Tmp_gyrox(2) As Byte Dim Tmp_gyroy(2) As Byte Dim Tmp_gyroz(2) As Byte Dim Tmp_accx(2) As Byte Dim Tmp_accy(2) As Byte Dim Tmp_accz(2) As Byte Dim Gyrox As Integer Dim Gyroy As Integer Dim Gyroz As Integer Dim Accx As Integer Dim Accy As Integer Dim Accz As Integer Dim Gyroxx As Single Dim Gyroyy As Single Dim Gyrozz As Single Dim Accxx As Single Dim Accyy As Single Dim Acczz As Single I2cinit '--- (107) Power Management 1 --- I2cstart 'start condition I2cwbyte &HD0 'write adress of MPU-6050 I2cwbyte 107 'Register 107 Power Management 1 I2cwbyte &B00001011 'No Reset / No Sleep / No Cycle / Temp_Sens: Dis / Clock Source: Z-Gyro I2cstop Do Call Read_gyro Gyrox = Tmp_gyrox(2) * 256 Gyrox = Gyrox + Tmp_gyrox(1) Gyroxx = Gyrox * 0.00059875 Gyroy = Tmp_gyroy(2) * 256 Gyroy = Gyroy + Tmp_gyroy(1) Gyroyy = Gyroy * 0.00059875 Gyroz = Tmp_gyroz(2) * 256 Gyroz = Gyroz + Tmp_gyroz(1) Gyrozz = Gyroz * 0.00059875 Print "Gyrox :" ; Gyroxx Print "Gyroy :" ; Gyroyy Print "Gyroz :" ; Gyrozz Print Call Read_acc Accx = Tmp_accx(2) * 256 Accx = Accx + Tmp_accx(1) Accxx = Accx * 0.00059875 Accy = Tmp_accy(2) * 256 Accy = Accy + Tmp_accy(1) Accyy = Accy * 0.00059875 Accz = Tmp_accz(2) * 256 Accz = Accz + Tmp_accz(1) Acczz = Accz * 0.00059875 Print "Accx :" ; Accxx Print "Accy :" ; Accyy Print "Accz :" ; Acczz Print Chr(27) ; "[1;1f"; Waitms 200 Print Chr(27) ; "[J"; Loop End Sub Read_gyro() I2cstart I2cwbyte &HD0 I2cwbyte 67 I2crepstart I2cwbyte &HD1 I2crbyte Tmp_gyrox(2) , Ack I2crbyte Tmp_gyrox(1) , Ack I2crbyte Tmp_gyroy(2) , Ack I2crbyte Tmp_gyroy(1) , Ack I2crbyte Tmp_gyroz(2) , Ack I2crbyte Tmp_gyroz(1) , Nack I2cstop End Sub Sub Read_acc() I2cstart I2cwbyte &HD0 I2cwbyte 59 I2crepstart I2cwbyte &HD1 I2crbyte Tmp_accx(2) , Ack I2crbyte Tmp_accx(1) , Ack I2crbyte Tmp_accy(2) , Ack I2crbyte Tmp_accy(1) , Ack I2crbyte Tmp_accz(2) , Ack I2crbyte Tmp_accz(1) , Nack I2cstop End Sub
