$regfile = "M8def.dat" $crystal = 8000000 $baud = 19200 $hwstack = 200 $swstack = 200 $framesize = 400 Config Scl = Portb.7 Config Sda = Portb.5 Declare Sub Read_mag Dim Tmp_magx(2) As Byte Dim Tmp_magy(2) As Byte Dim Tmp_magz(2) As Byte Dim Temp As Byte Dim Magx As Integer Dim Magy As Integer Dim Magz As Integer Dim Magxx As Single Dim Magyy As Single Dim Magzz As Single Wait 4 I2cinit ' -------------- TO DO --------------------------------------------------------- '1. Reset MPU9150: write 0x80 to 0x6B (D107) (PWR_MGMT_1), address 0x68 '2. Disable sleep: write 0x01 to 0x6B (PWR_MGMT_1), address 0x68 '3. Setup I2C Bypass: write 0x02 to 0x37(D55) (INT_PIN_CFG), address 0x68 '4. Set mag to single measurement: write 0x01 to 0x0A (CNTL), address 0x0C '5. read mag: Read 6 bytes from 0x03 (HXL), address 0x0C '1. --- (107) Power Management 1 RESET --- I2cstart I2cwbyte &HD0 'HEX Schreibadresse MPU-9150 I2cwbyte 107 'DEZ Register 107 Power Management 1 I2cwbyte &B10000000 'BIN Reset / No Sleep / No Cycle / Temp_Sens: Dis / Clock Source: Z-Gyro I2cstop '2. --- (107) Power Management 1 DISABLE SLEEP (wake up) --- I2cstart I2cwbyte &HD0 I2cwbyte 107 I2cwbyte &B00000001 I2cstop '3. --- (55) INT_PIN_CFG BYPASS --- I2cstart I2cwbyte &HD0 I2cwbyte 55 'DEZ Register 55 INT_PIN_CFG I2cwbyte &B00000010 'BIN Bypass enabled I2cstop '4. Set mag to single measurement: write 0x01 to 0x0A (CNTL), address 0x0C '5. read mag: Read 6 bytes from 0x03 (HXL), address 0x0C End Sub Read_mag() I2cstart I2cwbyte &HD0 I2cwbyte 3 'HEX Start XL,XH,YL,YH,ZL,ZH I2crepstart I2cwbyte &HD1 I2crbyte Tmp_magx(1) , Ack I2crbyte Tmp_magx(2) , Ack I2crbyte Tmp_magy(1) , Ack I2crbyte Tmp_magy(2) , Ack I2crbyte Tmp_magz(1) , Ack I2crbyte Tmp_magz(2) , Nack I2cstop End Sub
