Open On-Chip Debugger 0.7.0 (2013-10-22-08:31) Licensed under GNU GPL v2 For bug reports, read http://openocd.sourceforge.net/doc/doxygen/bugs.html Warn : Adapter driver 'usbprog' did not declare which transports it allows; assuming legacy JTAG-only Info : only one transport option; autoselect 'jtag' tms sequence is long adapter speed: 1000 kHz adapter_nsrst_delay: 100 jtag_ntrst_delay: 100 cortex_m3 reset_config sysresetreq usb_set_debug: Setting debugging level to 10 (on) usb_os_init: Found USB VFS at /dev/bus/usb usb_os_find_busses: Found 006 usb_os_find_busses: Found 005 usb_os_find_busses: Found 004 usb_os_find_busses: Found 003 usb_os_find_busses: Found 002 usb_os_find_busses: Found 001 usb_os_find_devices: Found 001 on 006 skipping descriptor 0x30 skipped 1 class/vendor specific endpoint descriptors usb_os_find_devices: Found 001 on 005 usb_os_find_devices: Found 001 on 004 skipping descriptor 0x30 skipped 1 class/vendor specific endpoint descriptors usb_os_find_devices: Found 003 on 003 usb_os_find_devices: Found 002 on 003 usb_os_find_devices: Found 001 on 003 error obtaining child information: Inappropriate ioctl for device usb_os_find_devices: Found 007 on 002 skipping descriptor 0x0 skipped 1 class/vendor specific endpoint descriptors Descriptor data still left usb_os_find_devices: Found 002 on 002 usb_os_find_devices: Found 001 on 002 error obtaining child information: Inappropriate ioctl for device usb_os_find_devices: Found 006 on 001 skipped 1 class/vendor specific interface descriptors usb_os_find_devices: Found 005 on 001 skipped 1 class/vendor specific interface descriptors skipped 1 class/vendor specific interface descriptors usb_os_find_devices: Found 004 on 001 skipped 1 class/vendor specific interface descriptors skipped 1 class/vendor specific interface descriptors usb_os_find_devices: Found 003 on 001 usb_os_find_devices: Found 002 on 001 usb_os_find_devices: Found 001 on 001 error obtaining child information: Inappropriate ioctl for device error obtaining child information: Inappropriate ioctl for device error obtaining child information: Inappropriate ioctl for device Info : USB JTAG Interface ready! Info : This adapter doesn't support configurable speed Error: JTAG scan chain interrogation failed: all zeroes Error: Check JTAG interface, timings, target power, etc. Error: Trying to use configured scan chain anyway... Error: stm32f1x.cpu: IR capture error; saw 0x00 not 0x01 Warn : Bypassing JTAG setup events due to errors Warn : Invalid ACK 0 in JTAG-DP transaction Polling target stm32f1x.cpu failed, GDB will be halted. Polling again in 100ms Polling target stm32f1x.cpu failed, GDB will be halted. Polling again in 300ms Polling target stm32f1x.cpu failed, GDB will be halted. Polling again in 700ms Polling target stm32f1x.cpu failed, GDB will be halted. Polling again in 1500ms Polling target stm32f1x.cpu failed, GDB will be halted. Polling again in 3100ms Polling target stm32f1x.cpu failed, GDB will be halted. Polling again in 6300ms Polling target stm32f1x.cpu failed, GDB will be halted. Polling again in 6300ms
