# GCC-AVR standard Makefile part 3
# Based on Volker Oth's makefiles of jan.2000
# Modified and merged by AVRfreaks.net for smoother integration with AVR Studio,
# and easier comprehension for the average user (nov.2001). Minor errors corrected.
###### BLOCK 1) define some variables based on the AVR base path in $(AVR) #######
	CC	= avr-gcc
	AS	= avr-gcc -x assembler-with-cpp	
	RM	= rm -f
	RN	= mv
	OUT	= coff
	ELFCOF	= elfcoff
	CP	= cp
	BIN	= avr-objcopy
	SIZE	= avr-size
	INCDIR	= .
	LIBDIR	= $(AVR)/avr/lib
	SHELL   = $(AVR)/bin/sh.exe
###### BLOCK 2) output format can be srec, ihex (avrobj is always created) #######
	FORMAT = ihex	
###### BLOCK 3) define all project specific object files ######
	OBJ	= $(ASRC:.s=.o) $(SRC:.c=.o) 
	CPFLAGS += -mmcu=$(MCU)
	ASFLAGS += -mmcu=$(MCU)
	LDFLAGS += -mmcu=$(MCU)
###### BLOCK 4) this defines the aims of the make process ######
all:	$(TRG).obj $(TRG).elf $(TRG).hex  $(TRG).cof $(TRG).eep $(TRG).ok
###### BLOCK 5) compile: instructions to create assembler and/or object files from C source ######
%.o : %.c 
	$(CC) -c $(CPFLAGS) -I$(INCDIR) $< -o $@
%.s : %.c
	$(CC) -S $(CPFLAGS) -I$(INCDIR) $< -o $@
###### BLOCK 6) assemble: instructions to create object file from assembler files ######
%.o : %.s
	$(AS) -c $(ASFLAGS) -I$(INCDIR) $< -o $@
###### BLOCK 7)  link: instructions to create elf output file from object files ######
%.elf: $(OBJ)
	$(CC) $(OBJ) $(LIB) $(LDFLAGS) -o $@
###### BLOCK 8) create avrobj file from elf output file ######
%.obj: %.elf
	$(BIN) -O avrobj -R .eeprom $< $@
###### BLOCK 9) create bin (.hex and .eep) files from elf output file ######
%.hex: %.elf
	$(BIN) -O $(FORMAT) -R .eeprom $< $@
%.eep: %.elf
	$(BIN) -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 -O $(FORMAT) $< $@
%.cof: %.elf
	$(ELFCOF) $< $(OUT) $@ $*.sym
	$(CP) $(OUT)/$@ .
	$(CP) $(OUT)/* .
#	$(CP) $(OUT)\\*sym .
#	$(CP) $(OUT)\\*S .
###### BLOCK 10) If all other steps compile ok then echo "Errors: none" ######
%ok:
	$(SIZE) $(TRG).elf
	@echo "Errors: none" 
###### BLOCK 11)  make instruction to delete created files ######
clean:
	$(RM) $(OBJ)
	$(RM) $(SRC:.c=.s)
	$(RM) $(SRC:.c=.lst)
	$(RM) $(TRG).map
	$(RM) $(TRG).elf
	$(RM) $(TRG).cof
	$(RM) $(TRG).obj
	$(RM) $(TRG).a90
	$(RM) $(TRG).hex
	$(RM) $(TRG).sym
	$(RM) $(TRG).eep
	$(RM) $(TRG).hex
	$(RM) $(OUT)/*	
	$(RM) *.bak
	$(RM) *.log
size:
	$(SIZE) $(TRG).elf
