| [06/06/2014 16:27:19] |
| 9619 | IRP_MJ_CREATE - Opens a COM port |
| STATUS_SUCCESS |
| | Opened by: |
| | | C:\WINDOWS\system32\ntvdm.exe |
| 9621 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_GET_BAUD_RATE - Returns the baud rate that is currently set for a COM port |
| | | BaudRate - 300 |
| 9623 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_GET_LINE_CONTROL - Request returns information about the line control set for a COM port |
| | | StopBits - 0 (1 stop bit) |
| | | Parity - 0 (NO_PARITY) |
| | | WordLength - 5 |
| 9625 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_GET_CHARS - Request returns the special characters that Serial uses with handshake flow control |
| | | EofChar - 0 |
| | | ErrorChar - 0 |
| | | BreakChar - 0 |
| | | EventChar - 0 |
| | | XonChar - 0 |
| | | XoffChar - 0 |
| 9627 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_GET_HANDFLOW - Request returns information about the configuration of the handshake flow control set for a COM port |
| | | ControlHandShake - 0x01 (SERIAL_DTR_CONTROL) |
| | | FlowReplace - 0x40 (SERIAL_RTS_CONTROL) |
| | | XonLimit - 2048 |
| | | XoffLimit - 512 |
| 9629 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | BaudRate - 300 |
| 9631 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9633 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | EofChar - 0 |
| | | ErrorChar - 0 |
| | | BreakChar - 0 |
| | | EventChar - 0 |
| | | XonChar - 0 |
| | | XoffChar - 0 |
| 9635 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | XonLimit - 2048 |
| | | XoffLimit - 512 |
| 9637 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_BAUD_RATE - Request sets the baud rate on a COM port. Serial verifies the specified baud rate |
| | | BaudRate - 300 |
| 9639 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_CLR_RTS - Request clears the RTS control signal |
| 9641 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_CLR_DTR - Request clears the DTR control signal. |
| 9643 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_LINE_CONTROL - Request sets the line control register |
| | | WordLength - 5 |
| 9645 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_CHARS - Request sets the special characters that Serial uses for handshake flow control |
| | | EofChar - 0 |
| | | ErrorChar - 0 |
| | | BreakChar - 0 |
| | | EventChar - 0 |
| | | XonChar - 17 |
| | | XoffChar - 19 |
| 9647 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_HANDFLOW - Request sets the configuration of handshake flow control |
| | | ControlHandShake - 0x00 |
| | | FlowReplace - 0x00 |
| | | XonLimit - 2048 |
| | | XoffLimit - 512 |
| 9649 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_LSRMST_INSERT - Request enables or disables the insertion of information about line status and modem status in the receive data stream |
| | | LSRMST_INSERT - 0x00000000 |
| 9651 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_QUEUE_SIZE - Request sets the size of the internal receive buffer |
| | | InSize - 8192 |
| | | OutSize - 100 |
| 9653 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_GET_TIMEOUTS - Returns the timeout values that Serial uses with read and write requests |
| | | ReadIntervalTimeout - -1 |
| | | ReadTotalTimeoutMultiplier - 0 |
| | | ReadTotalTimeoutConstant - 0 |
| | | WriteTotalTimeoutMultiplier - 20 |
| | | WriteTotalTimeoutConstant - 0 |
| 9655 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_TIMEOUTS - Request sets the timeout value's that the driver uses with read and write requests |
| 9657 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_DTR - Request sets DTR |
| 9659 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_RTS - Request sets RTS |
| 9661 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9664 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_WAIT_MASK - Request configures Serial to notify a client after the occurrence of any one of a specified set of wait events |
| | | Mask - 0x000001b9 (EV_CTS | EV_DSR | EV_ERR | EV_RING | EV_RLSD | EV_RXCHAR) |
| 9666 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 8 |
| 9668 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 8 |
| 9670 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | StopBits - 2 (2 stop bits) |
| | | WordLength - 8 |
| 9672 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | BaudRate - 300 |
| 9674 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_BREAK_ON - Sets the line control break signal active |
| 9675 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_WAIT_ON_MASK - Request is used to wait for the occurrence of any wait event specified by using an IOCTL_SERIAL_SET_WAIT_MASK request |
| | | Mask - 0x00000010 (EV_DSR) |
| 9677 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_GET_MODEMSTATUS - Request updates the modem status, and returns the value of the modem status register before the update |
| | | Modem Status - 0x00000020 (MS_DSR_ON) |
| 9679 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9682 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9684 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9685 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9687 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9689 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | Mask - 0x00000001 (EV_RXCHAR) |
| 9691 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | fe þ |
| 9693 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9695 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| [06/06/2014 16:27:20] |
| 9697 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 31 1 |
| 9699 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9701 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9703 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 36 6 |
| 9705 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9707 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9709 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 32 2 |
| 9711 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9713 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9715 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 36 6 |
| 9717 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9719 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9721 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 33 3 |
| 9723 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9725 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9727 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 39 9 |
| 9729 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9731 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9733 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 35 5 |
| 9735 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9737 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9739 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 30 0 |
| 9741 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9743 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9745 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 36 6 |
| 9747 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9749 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9751 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 30 0 |
| 9753 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9755 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9757 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 36 6 |
| 9759 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9761 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9763 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 31 1 |
| 9765 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9767 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9769 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 34 4 |
| 9771 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9773 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9775 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 35 5 |
| 9777 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9779 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9781 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 33 3 |
| 9783 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9785 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9787 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| | | 0d . |
| 9789 | IRP_MJ_READ - Transfers data from a COM port to a client |
| STATUS_SUCCESS |
| 9792 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | IOCTL_SERIAL_SET_BREAK_OFF - Request sets the line control break signal inactive |
| 9794 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 8 |
| 9796 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_INVALID_PARAMETER |
| | | WordLength - 5 |
| 9798 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 8 |
| 9800 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 8 |
| 9802 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | BaudRate - 300 |
| 9804 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | BaudRate - 300 |
| 9806 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 8 |
| 9808 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | EofChar - 0 |
| | | ErrorChar - 0 |
| | | BreakChar - 0 |
| | | EventChar - 0 |
| | | XonChar - 17 |
| | | XoffChar - 19 |
| 9810 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | XonLimit - 4096 |
| | | XoffLimit - 1024 |
| 9812 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | BaudRate - 300 |
| 9814 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9816 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9818 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9820 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | EofChar - 0 |
| | | ErrorChar - 0 |
| | | BreakChar - 0 |
| | | EventChar - 0 |
| | | XonChar - 0 |
| | | XoffChar - 0 |
| 9822 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | XonLimit - 2048 |
| | | XoffLimit - 512 |
| 9824 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9826 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| 9828 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | BaudRate - 300 |
| 9830 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9832 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9834 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9836 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9838 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9840 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | WordLength - 5 |
| 9842 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | BaudRate - 300 |
| 9844 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | Mask - 0x00000000 |
| 9845 | IRP_MJ_DEVICE_CONTROL - Request operates a serial port |
| STATUS_SUCCESS |
| | | Mask - 0x00000000 |
| [06/06/2014 16:27:25] |
| 9847 | IRP_MJ_CLOSE - Close a COM port |
| STATUS_SUCCESS |
