Version 4 SHEET 1 2168 752 WIRE -80 -192 -144 -192 WIRE 80 -192 -80 -192 WIRE 208 -192 80 -192 WIRE 272 -192 208 -192 WIRE -144 -160 -144 -192 WIRE 80 -160 80 -192 WIRE -80 -128 -80 -192 WIRE 80 -16 80 -80 WIRE 80 0 80 -16 WIRE -288 16 -320 16 WIRE -144 16 -144 -80 WIRE -144 16 -224 16 WIRE -96 16 -144 16 WIRE -80 16 -80 -64 WIRE -80 16 -96 16 WIRE -64 16 -80 16 WIRE 32 16 16 16 WIRE -144 32 -144 16 WIRE 272 32 272 -192 WIRE -368 112 -432 112 WIRE -320 112 -320 16 WIRE -320 112 -368 112 WIRE -144 144 -144 112 WIRE -144 144 -208 144 WIRE -80 144 -144 144 WIRE 32 144 0 144 WIRE 80 144 80 96 WIRE 80 144 32 144 WIRE 96 144 80 144 WIRE 176 144 160 144 WIRE -144 176 -144 144 WIRE 80 192 80 144 WIRE -320 272 -320 112 WIRE -288 272 -320 272 WIRE -144 272 -144 256 WIRE -144 272 -224 272 WIRE -96 272 -144 272 WIRE -80 272 -96 272 WIRE -64 272 -80 272 WIRE 32 272 16 272 WIRE 80 304 80 288 WIRE 176 320 176 144 WIRE -432 336 -432 112 WIRE -208 336 -208 144 WIRE 272 336 272 112 WIRE -80 352 -80 272 WIRE -144 368 -144 272 WIRE 80 368 80 304 WIRE -432 480 -432 416 WIRE -208 480 -208 400 WIRE -208 480 -432 480 WIRE -144 480 -144 448 WIRE -144 480 -208 480 WIRE -80 480 -80 416 WIRE -80 480 -144 480 WIRE 80 480 80 448 WIRE 80 480 -80 480 WIRE 176 480 176 400 WIRE 176 480 80 480 WIRE 272 480 272 416 WIRE 272 480 176 480 WIRE 80 528 80 480 FLAG 80 528 0 FLAG 32 144 Drain FLAG 80 -16 Sp FLAG 80 304 Sn FLAG -96 16 Gp FLAG -96 272 Gn FLAG 208 -192 +Ub FLAG 176 144 out FLAG -368 112 in SYMBOL nmos 32 192 R0 SYMATTR InstName Mn SYMATTR Value IRFP240 SYMBOL pmos 32 96 M180 SYMATTR InstName Mp SYMATTR Value IRFP9240 SYMBOL Misc\\EuropeanResistor 64 -176 R0 SYMATTR InstName R1 SYMATTR Value 390m SYMBOL Misc\\EuropeanResistor 64 464 M180 WINDOW 0 31 76 Left 2 WINDOW 3 31 40 Left 2 SYMATTR InstName R2 SYMATTR Value 270m SYMBOL Misc\\EuropeanResistor 32 0 R90 WINDOW 0 5 56 VBottom 2 WINDOW 3 27 56 VTop 2 SYMATTR InstName R3 SYMATTR Value 100R SYMBOL Misc\\EuropeanResistor 32 256 R90 WINDOW 0 5 56 VBottom 2 WINDOW 3 27 56 VTop 2 SYMATTR InstName R4 SYMATTR Value 100R SYMBOL Misc\\EuropeanResistor 16 128 R90 WINDOW 0 5 56 VBottom 2 WINDOW 3 27 56 VTop 2 SYMATTR InstName R5 SYMATTR Value 10K SYMBOL voltage 272 320 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V1 SYMATTR Value 120 SYMBOL Misc\\EuropeanResistor -160 16 R0 SYMATTR InstName R6 SYMATTR Value 1.2Meg SYMBOL Misc\\EuropeanResistor -160 160 R0 SYMATTR InstName R7 SYMATTR Value 1.2Meg SYMBOL Misc\\EuropeanResistor -160 -176 R0 SYMATTR InstName R8 SYMATTR Value 91k SYMBOL Misc\\EuropeanResistor -160 352 R0 SYMATTR InstName R9 SYMATTR Value 91k SYMBOL cap 160 128 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 30 32 VTop 2 SYMATTR InstName C4 SYMATTR Value 470µ SYMBOL cap -224 0 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C5 SYMATTR Value 100n SYMATTR SpiceLine V=100 SYMBOL cap -224 256 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C6 SYMATTR Value 100n SYMBOL voltage -432 320 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 WINDOW 3 12 130 Left 2 SYMATTR Value SINE(0 {Uin} 400) SYMATTR InstName V2 SYMBOL voltage 272 16 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V3 SYMATTR Value SINE(0 0) SYMBOL Misc\\EuropeanResistor 160 304 R0 SYMATTR InstName Rl SYMATTR Value {Rl} SYMBOL cap -192 400 R180 WINDOW 0 24 56 Left 2 WINDOW 3 24 8 Left 2 SYMATTR InstName C2 SYMATTR Value 10µ SYMATTR SpiceLine V=100V SYMBOL zener -96 -64 M180 WINDOW 0 24 64 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D1 SYMATTR Value BZX84C6V2L SYMBOL zener -96 416 M180 WINDOW 0 24 64 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D2 SYMATTR Value BZX84C6V2L TEXT -832 552 Left 2 !.tran 0 15m 5m 1m TEXT 192 296 Left 2 ;Speaker TEXT -616 520 Left 2 !.lib irfp9240.lib TEXT -408 528 Left 2 ;http://www.vishay.com/mosfets/list/product-91239/ TEXT -376 416 Left 2 ;PA_GND TEXT -616 544 Left 2 !.lib opamp.sub TEXT 288 144 Left 2 ;ripple_gen. TEXT -632 -288 Left 2 !.step dec param Uin 150m 1.5 10\n.step param Rl list 20 8 1m TEXT -136 560 Left 2 ;Opamps: PSRR (Ub-Durchgriff) und die Steuersignale sitzen dann auf ihrem jeweils richtigem\nMassebezug auf.\n1. Ohne Signal am Drain die halbe Betriebsspannung einstellen.\nDas ist der Uth abgleich.\n2. Mit kleinem Signal den geringsten Ruhestrom ermitteln,\nes sollen keine Übernahmeverzerrungen auftreten.\n(Es sei denn, Du willst das.)\n3. Die Emitterwiderstände so auswählen, dass bei nahezu\nVollaussteuerung unten und oben gleich viel "Luft" ist.\nSiehe raw dazu. Das ist der Abgleich auf identische Steilheit.\nmos_ota_amp_D_raw_003.PNG TEXT -632 -320 Left 2 ;.step param Uin list 1.5 3 TEXT -216 -336 Left 2 ;.temp 15 65 TEXT -80 -392 Left 2 !.meas Pout avg V(out)*I(Rl) TEXT -80 -368 Left 2 ;.meas Ptotp avg (V(Drain)-V(Sp))*Id(Mp) TEXT -80 -344 Left 2 ;.meas Ptotn avg (V(Drain)-V(Sn))*Id(Mn) TEXT -80 -304 Left 2 ;.meas Ptot avg (V(Drain)-V(Sp))*Id(Mp) + (V(Drain)-V(Sn))*Id(Mn)
