(module JTP-1130 (layer F.Cu) (tedit 54DB9816)
  (fp_text reference S (at 0 -6.3) (layer F.SilkS)
    (effects (font (size 1.5 1.5) (thickness 0.15)))
  (fp_text value JTP-1130 (at 0 5) (layer F.SilkS)
  (fp_line (start -1.5 2.6) (end -1.8 2.6) (layer F.SilkS) (width 0.15))
  (fp_line (start 1.5 2.6) (end 1.8 2.6) (layer F.SilkS) (width 0.15))
  (fp_line (start 1.5 -2.6) (end 1.8 -2.6) (layer F.SilkS) (width 0.15))
  (fp_line (start -1.5 -2.6) (end -1.8 -2.6) (layer F.SilkS) (width 0.15))
  (fp_line (start 0 0.8) (end -0.7 -1) (layer F.SilkS) (width 0.15))
  (fp_line (start 0 2.6) (end 0 0.8) (layer F.SilkS) (width 0.15))
  (fp_line (start 0 -2.6) (end 0 -0.8) (layer F.SilkS) (width 0.15))
  (fp_line (start 1.5 2.6) (end -1.5 2.6) (layer F.SilkS) (width 0.15))
  (fp_line (start -1.5 -2.6) (end 1.5 -2.6) (layer F.SilkS) (width 0.15))
  (fp_circle (center 0 0) (end 1.75 0) (layer F.SilkS) (width 0.15))
  (fp_line (start -2 -3) (end 2 -3) (layer F.SilkS) (width 0.15))
  (fp_line (start -2 3) (end 2 3) (layer F.SilkS) (width 0.15))
  (fp_line (start -3 -0.5) (end -3 0.5) (layer F.SilkS) (width 0.15))
  (fp_line (start 3 -0.5) (end 3 0.5) (layer F.SilkS) (width 0.15))
  (pad 1 thru_hole circle (at 3.25 2.25) (size 2 2) (drill 1.1) (layers *.Cu *.Mask F.SilkS))
  (pad 1 thru_hole circle (at -3.25 2.25) (size 2 2) (drill 1.1) (layers *.Cu *.Mask F.SilkS))
  (pad 2 thru_hole circle (at 3.25 -2.25) (size 2 2) (drill 1.1) (layers *.Cu *.Mask F.SilkS))
  (pad 2 thru_hole circle (at -3.25 -2.25) (size 2 2) (drill 1.1) (layers *.Cu *.Mask F.SilkS))
