EDID report generated by SwitchResX Version 4.5.0 (Intel - 64-bit) for display MStar Demo ----------------------------------------------------- ------------------- RAW DATA ------------------------ ----------------------------------------------------- 0 1 2 3 4 5 6 7 8 9 A B C D E F ----------------------------------------------------- 0 | 00 FF FF FF FF FF FF 00 36 74 30 00 01 00 00 00 1 | 0A 14 01 03 80 73 41 78 0A CF 74 A3 57 4C B0 23 2 | 09 48 4C 21 08 00 81 80 45 40 61 40 95 00 01 01 3 | 01 01 01 01 01 01 01 1D 00 72 51 D0 1E 20 6E 28 4 | 55 00 C4 8E 21 00 00 1E 01 1D 80 18 71 1C 16 20 5 | 58 2C 25 00 C4 8E 21 00 00 9E 00 00 00 FC 00 4D 6 | 53 74 61 72 20 44 65 6D 6F 0A 20 20 00 00 00 FD 7 | 00 32 4B 1E 50 12 00 0A 20 20 20 20 20 20 01 38 ----------------------------------------------------- 0 1 2 3 4 5 6 7 8 9 A B C D E F ----------------------------------------------------- 0 | 02 03 2E F2 4D 01 03 84 05 07 10 12 93 14 16 1F 1 | 20 22 26 09 07 07 11 17 50 83 01 00 00 70 03 0C 2 | 00 10 00 B8 2D 20 A0 06 01 41 00 00 00 00 8C 0A 3 | D0 8A 20 E0 2D 10 10 3E 96 00 C4 8E 21 00 00 18 4 | 02 3A 80 18 71 38 2D 40 58 2C 45 00 C4 8E 21 00 5 | 00 9E 01 1D 00 BC 52 D0 1E 20 B8 28 55 40 C4 8E 6 | 21 00 00 1E 01 1D 80 D0 72 1C 16 20 10 2C 25 80 7 | C4 8E 21 00 00 9E 00 00 00 00 00 00 00 00 00 41 ----------------------------------------------------- < 00FFFFFF FFFFFF00 36743000 01000000 0A140103 80734178 0ACF74A3 574CB023 09484C21 08008180 45406140 95000101 01010101 0101011D 007251D0 1E206E28 5500C48E 2100001E 011D8018 711C1620 582C2500 C48E2100 009E0000 00FC004D 53746172 2044656D 6F0A2020 000000FD 00324B1E 5012000A 20202020 20200138 02032EF2 4D010384 05071012 9314161F 20222609 07071117 50830100 0070030C 001000B8 2D20A006 01410000 00008C0A D08A20E0 2D10103E 9600C48E 21000018 023A8018 71382D40 582C4500 C48E2100 009E011D 00BC52D0 1E20B828 5540C48E 2100001E 011D80D0 721C1620 102C2580 C48E2100 009E0000 00000000 00000041 > ----------------------------------------------------- { 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x36, 0x74, 0x30, 0x00, 0x01, 0x00, 0x00, 0x00, 0x0A, 0x14, 0x01, 0x03, 0x80, 0x73, 0x41, 0x78, 0x0A, 0xCF, 0x74, 0xA3, 0x57, 0x4C, 0xB0, 0x23, 0x09, 0x48, 0x4C, 0x21, 0x08, 0x00, 0x81, 0x80, 0x45, 0x40, 0x61, 0x40, 0x95, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x1D, 0x00, 0x72, 0x51, 0xD0, 0x1E, 0x20, 0x6E, 0x28, 0x55, 0x00, 0xC4, 0x8E, 0x21, 0x00, 0x00, 0x1E, 0x01, 0x1D, 0x80, 0x18, 0x71, 0x1C, 0x16, 0x20, 0x58, 0x2C, 0x25, 0x00, 0xC4, 0x8E, 0x21, 0x00, 0x00, 0x9E, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x4D, 0x53, 0x74, 0x61, 0x72, 0x20, 0x44, 0x65, 0x6D, 0x6F, 0x0A, 0x20, 0x20, 0x00, 0x00, 0x00, 0xFD, 0x00, 0x32, 0x4B, 0x1E, 0x50, 0x12, 0x00, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x01, 0x38, 0x02, 0x03, 0x2E, 0xF2, 0x4D, 0x01, 0x03, 0x84, 0x05, 0x07, 0x10, 0x12, 0x93, 0x14, 0x16, 0x1F, 0x20, 0x22, 0x26, 0x09, 0x07, 0x07, 0x11, 0x17, 0x50, 0x83, 0x01, 0x00, 0x00, 0x70, 0x03, 0x0C, 0x00, 0x10, 0x00, 0xB8, 0x2D, 0x20, 0xA0, 0x06, 0x01, 0x41, 0x00, 0x00, 0x00, 0x00, 0x8C, 0x0A, 0xD0, 0x8A, 0x20, 0xE0, 0x2D, 0x10, 0x10, 0x3E, 0x96, 0x00, 0xC4, 0x8E, 0x21, 0x00, 0x00, 0x18, 0x02, 0x3A, 0x80, 0x18, 0x71, 0x38, 0x2D, 0x40, 0x58, 0x2C, 0x45, 0x00, 0xC4, 0x8E, 0x21, 0x00, 0x00, 0x9E, 0x01, 0x1D, 0x00, 0xBC, 0x52, 0xD0, 0x1E, 0x20, 0xB8, 0x28, 0x55, 0x40, 0xC4, 0x8E, 0x21, 0x00, 0x00, 0x1E, 0x01, 0x1D, 0x80, 0xD0, 0x72, 0x1C, 0x16, 0x20, 0x10, 0x2C, 0x25, 0x80, 0xC4, 0x8E, 0x21, 0x00, 0x00, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x41 } ----------------------------------------------------- Valid EDID block #0: checksum ok Valid EDID block #1: checksum ok ----------------------------------------------------- ------------------- MAIN EDID BLOCK ----------------- ----------------------------------------------------- EDID Version........1.3 Manufacturer........MST (3674) Product ID..........48 (0030) Serial Number.......00000001 Manufactured........Week 10 of year 2010 Max H Size..........115 cm Max V Size..........65 cm Gamma...............2,20 Display Supported Features: --------------------------- Display type: ------------- RGB 4:4:4 & YCrCb 4:4:4 Color Encoding Formats Display is non continuous frequency Default color space is not sRGB standard Preferred timing mode includes Native Pixel Format Input signal & sync: -------------------- Digital Input Color Bit Depth is undefined Digital Interface is not defined Color info: ----------- Red x = 0,640 Green x = 0,300 Blue x = 0,138 White x = 0,282 Red y = 0,340 Green y = 0,690 Blue y = 0,038 White y = 0,297 Established Timings: -------------------- 640 x 480 @ 60Hz 800 x 600 @ 60Hz 1024 x 768 @ 60Hz Manufacturer Reserved Timings: ------------------------------ Standard Timing Identification: ------------------------------- #0: 1280 x 1024 @ 60Hz (8180) #1: 800 x 600 @ 60Hz (4540) #2: 1024 x 768 @ 60Hz (6140) #3: 1440 x 900 @ 60Hz (9500) Monitor Description blocks: --------------------------- Descriptor #0 - Timing definition: Mode = 1280 x 720 @ 60,000Hz Pixel Clock............. 74,25 MHz Non-Interlaced Horizontal Vertical Active.................. 1280 pixels 720 lines Front Porch............. 110 pixels 5 lines Sync Width.............. 40 pixels 5 lines Back Porch.............. 220 pixels 20 lines Blanking................ 370 pixels 30 lines Total................... 1650 pixels 750 lines Scan Rate............... 45,000 kHz 60,000 Hz Image Size.............. 708 mm 398 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Descriptor #1 - Timing definition: Mode = 1920 x 540 @ 60,053Hz Pixel Clock............. 74,25 MHz Interlaced Horizontal Vertical Active.................. 1920 pixels 540 lines Front Porch............. 88 pixels 2 lines Sync Width.............. 44 pixels 5 lines Back Porch.............. 148 pixels 15 lines Blanking................ 280 pixels 22 lines Total................... 2200 pixels 562 lines Scan Rate............... 33,750 kHz 60,053 Hz Image Size.............. 708 mm 398 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Descriptor #2 - Monitor name: MStar Demo Descriptor #3 - Monitor limits: Horizontal frequency range.......30-80 kHz Vertical frequency range.........50-75 Hz Maximum bandwidth range..........180 MHz GTF supported ----------------------------------------------------- ------------ EXTENSION EDID BLOCK 1 --------------- ----------------------------------------------------- CEA-EXT: CEA 861 Series Extension: ---------------------------------- Revision:..............................3 First DTD block at offset..............42 Display Supports: Underscan on PC modes Basic audio YCbCr 4:4:4 YCbCr 4:2:2 Data Block Collection #1 - Type 2 Video Type: standard CEA Timings #1: 640 x 480p @ 59.94/60Hz - 4:3 - 'DMT0659' (1) #2: 720 x 480p @ 59.94/60Hz - 16:9 - '480pH' (3) #3: 1280 x 720p @ 59.94/60Hz - 16:9 - '720p' (is native) (4) #4: 1920 x 1080i @ 59.94/60Hz - 16:9 - '1080i' (5) #5: 720(1440) x 480i @ 59.94/60Hz - 16:9 - '480iH' (7) #6: 1920 x 1080p @ 59.94/60Hz - 16:9 - '1080p' (16) #7: 720 x 576p @ 50Hz - 16:9 - '576pH' (18) #8: 1280 x 720p @ 50Hz - 16:9 - '720p50' (is native) (19) #9: 1920 x 1080i @ 50Hz - 16:9 - '1080i25' (20) #10: 720(1440) x 576i @ 50Hz - 16:9 - '576iH' (22) #11: 1920 x 1080p @ 50Hz - 16:9 - '1080p50' (31) #12: 1920 x 1080p @ 23.98/24Hz - 16:9 - '1080p24' (32) #13: 1920 x 1080p @ 29.97/30Hz - 16:9 - '1080p30' (34) Data Block Collection #2 - Type 1 Audio Type Block Supported format: Linear Pulse Code Modulation (LPCM), on 2 channels Supported freq: 32kHz, 44.1kHz, 48kHz Supported sample sizes: 16 bit, 20 bit, 24 bit Supported format: AC3, on 2 channels Supported freq: 32kHz, 44.1kHz, 48kHz, 96kHz Maximum bitrate: 640kHz Data Block Collection #3 - Type 4 Speaker allocation data block Front Left / Front Right Front Left High / Front Right High Data Block Collection #4 - Type 3 Vendor specific Identifier Found HDMI IEEE Registration Identifier CEC physical address........... 1.0.0.0 Supports AI (ACP, ISRC)........ Yes Supports 48bpp color depth..... No Supports 36bpp color depth..... Yes Supports 30bpp color depth..... Yes Supports YCbCr 4:4:4........... Yes Supports dual-link DVI......... No Maximum TMDS clock............. 225 MHz HDMI video capabilities........ Yes Supports 3D.................... Yes 3D formats supported on mandatory formats 3D formats also supported on all 2D VICs: Frame packing Reserved - 9 Reserved - 10 Additional 3D information: 640 x 480p @ 59.94/60Hz - 4:3 - 'DMT0659' also supports Reserved - 10 Detailed Timing Blocks - 2 are native Detailed Timing Block #1 - Timing definition: Mode = 720 x 480 @ 59,940Hz Pixel Clock............. 27,00 MHz Non-Interlaced Horizontal Vertical Active.................. 720 pixels 480 lines Front Porch............. 16 pixels 9 lines Sync Width.............. 62 pixels 6 lines Back Porch.............. 60 pixels 30 lines Blanking................ 138 pixels 45 lines Total................... 858 pixels 525 lines Scan Rate............... 31,469 kHz 59,940 Hz Image Size.............. 708 mm 398 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Negative vertical polarity * Negative horizontal polarity Detailed Timing Block #2 - Timing definition: Mode = 1920 x 1080 @ 60,000Hz Pixel Clock............. 148,50 MHz Interlaced Horizontal Vertical Active.................. 1920 pixels 1080 lines Front Porch............. 88 pixels 4 lines Sync Width.............. 44 pixels 5 lines Back Porch.............. 148 pixels 36 lines Blanking................ 280 pixels 45 lines Total................... 2200 pixels 1125 lines Scan Rate............... 67,500 kHz 60,000 Hz Image Size.............. 708 mm 398 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Detailed Timing Block #3 - Timing definition: Mode = 1280 x 720 @ 50,000Hz Pixel Clock............. 74,25 MHz Non-Interlaced Horizontal Vertical Active.................. 1280 pixels 720 lines Front Porch............. 440 pixels 5 lines Sync Width.............. 40 pixels 5 lines Back Porch.............. 220 pixels 20 lines Blanking................ 700 pixels 30 lines Total................... 1980 pixels 750 lines Scan Rate............... 37,500 kHz 50,000 Hz Image Size.............. 708 mm 398 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity Detailed Timing Block #4 - Timing definition: Mode = 1920 x 540 @ 50,044Hz Pixel Clock............. 74,25 MHz Interlaced Horizontal Vertical Active.................. 1920 pixels 540 lines Front Porch............. 528 pixels 2 lines Sync Width.............. 44 pixels 5 lines Back Porch.............. 148 pixels 15 lines Blanking................ 720 pixels 22 lines Total................... 2640 pixels 562 lines Scan Rate............... 28,125 kHz 50,044 Hz Image Size.............. 708 mm 398 mm Border.................. 0 pixels 0 lines Sync: Digital separate with * Positive vertical polarity * Positive horizontal polarity
