Version 4 SHEET 1 1460 1096 WIRE -48 224 -144 224 WIRE 112 224 32 224 WIRE 224 224 176 224 WIRE 288 224 224 224 WIRE -144 272 -144 224 WIRE 224 272 224 224 WIRE -144 384 -144 352 WIRE 224 384 224 352 WIRE -112 768 64 592 FLAG -144 384 0 FLAG 288 224 out IOPIN 288 224 Out FLAG 224 384 0 SYMBOL res -64 240 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R1 SYMATTR Value 1k SYMBOL voltage -144 256 R0 WINDOW 123 24 132 Left 2 WINDOW 39 0 0 Left 2 WINDOW 3 36 83 Left 2 SYMATTR Value2 AC 1 SYMATTR Value 0 SYMATTR InstName V1 SYMBOL cap 112 240 R270 WINDOW 0 32 32 VTop 2 WINDOW 3 0 32 VBottom 2 SYMATTR InstName C2 SYMATTR Value 1µ SYMBOL ind 208 256 R0 SYMATTR InstName L1 SYMATTR Value 1 TEXT -168 64 Left 2 !.ac dec 10000 10 1k TEXT -160 128 Left 2 ;Bandpass with fc=1/(2*pi*sqrt(L*C)) TEXT -160 -192 Left 2 ;Bandpass Corner Frequencies with MEASURE TEXT -136 512 Left 2 ;Ir(freq) TEXT 312 816 Left 2 ;freq TEXT 152 640 Left 2 ;-3dB TEXT 40 544 Left 2 ;max TEXT -168 -136 Left 2 !.options meascplxfmt=polar\n.MEAS AC Imax MAX I(R1)\n.MEAS AC fc FIND freq WHEN mag(I(R1))=Imax*0.9999999\n.MEAS AC fu WHEN mag(I(R1))=Imax/sqrt(2) rise=1\n.MEAS AC fo WHEN mag(I(R1))=Imax/sqrt(2) fall=1\n.MEAS AC bw param fo-fu TEXT -72 640 Left 2 ;-3dB TEXT -8 680 Left 2 ;fu TEXT 120 680 Left 2 ;fo TEXT 56 624 Left 2 ;fc TEXT -176 912 Left 2 ;View -> SPICE Error Log\n \nimax: MAX(i(r1))=(0.000999999,0.00531187°) FROM 10 TO 1000\nfc: freq=(159.122,0°) at 159.122\nfu: mag(i(r1))=imax/sqrt(2) AT 98.3631\nfo: mag(i(r1))=imax/sqrt(2) AT 257.518\nbw: fo-fu=(159.155,0°) LINE Normal 256 768 64 592 LINE Normal 256 768 256 768 LINE Normal 304 816 -128 816 LINE Normal 288 832 304 816 LINE Normal 304 816 288 832 LINE Normal 288 800 304 816 RECTANGLE Normal 384 848 -176 464 CIRCLE Normal 80 576 48 608 CIRCLE Normal 149 631 117 663 CIRCLE Normal 21 631 -11 663
