* vim:sw=8:ts=8:si:et
* To use the above modeline in vim you must have "set modeline" in your .vimrc
* Author: Guido Socher
* Copyright: GPL V2
* See http://www.gnu.org/licenses/gpl.html
* Ethernet remote device and sensor
* UDP and HTTP interface
url looks like this http://baseurl/password/command
or http://baseurl/password/
* Title: Microchip ENC28J60 Ethernet Interface Driver
* Chip type : ATMEGA88 with ENC28J60
* Note: there is a version number in the text. Search for tuxgraphics
* modified: 2011-01-07
* Author : awake
* Copyright: GPL V2
* http://www.icdev.com.cn/?2213/
* Host chip: ADUC7026
#include "..\main\include.h"
#define PSTR(s) s
u8 st[10];
//extern void delay_ms(u8 ms);
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static u8 mymac[6] =
0x54, 0x55, 0x58, 0x10, 0x00, 0x24
static u8 myip[4] =
192, 168, 2, 100
// base url (you can put a DNS name instead of an IP addr. if you have
// a DNS server (baseurl must end in "/"):
static char baseurl[] = "http://192.168.2.100/";
static u16 mywwwport = 80; // listen port for tcp/www (max range 1-254)
// or on a different port:
//static char baseurl[]="http://10.0.0.24:88/";
//static u16 mywwwport =88; // listen port for tcp/www (max range 1-254)
static u16 myudpport = 1200; // listen port for udp
// how did I get the mac addr? Translate the first 3 numbers into ascii is: TUX
#define BUFFER_SIZE 1500//400 64---1518
static u8 buf[BUFFER_SIZE + 1]; //»º³åÇø
// the password string (only the first 5 char checked), (only a-z,0-9,_ characters):
static char password[] = "888"; // must not be longer than 9 char
u8 verify_password(char* str)
// the first characters of the received string are
// a simple password/cookie:
if (strncmp(password, str, sizeof(password)-1) == 0)
return(1);
return(0);
// takes a string of the form password/commandNumber and analyse it
// return values: -1 invalid password, otherwise command number
// -2 no command given but password valid
u8 analyse_get_url(char* str)
u8 i = 0;
if (verify_password(str) == 0)
return((u8)-1);
// find first "/"
// passw not longer than 9 char:
while (*str && i<10 && *str>',' && *str < '{')
if (*str == '/')
str++;
break;
i++;
str++;
if (*str <0x3a && *str> 0x2f)
// is a ASCII number, return it
return(*str - 0x30);
return((u8)-2);
// prepare the webpage by writing the data to the tcp send buffer
buf on_off¿ª¹Ø
u16 print_webpage_2(u8* buf, u8 on_off)
u16 plen;
plen = fill_tcp_data_p(buf, 0, PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\nPragma: no-cache\r\n\r\n"));
plen = fill_tcp_data_p(buf, plen, PSTR("
LED:"));
plen = fill_tcp_data_p(buf, plen, "
plen = fill_tcp_data_p(buf, plen, "");
plen = fill_tcp_data_p(buf, plen, " LED 1 | ");
plen = fill_tcp_data_p(buf, plen, " LED 2 | ");
plen = fill_tcp_data_p(buf, plen, " LED 3 | ");
plen = fill_tcp_data_p(buf, plen, "AN/AUS | ");
plen = fill_tcp_data_p(buf, plen, "" );
plen = fill_tcp_data_p(buf, plen, "AUS | ");
plen = fill_tcp_data_p(buf, plen, PSTR("STM32F103 WEBSERVER
plen = fill_tcp_data_p(buf, plen, PSTR("AN/AUS | "));
//plen = fill_tcp_data_p(buf, plen, "AN/AUS | ");
return(plen); */
u16 print_webpage(u8* buf, u8 on_off)
u16 plen;
plen = fill_tcp_data_p(buf, plen, PSTR(""));
// the url looks like this http://baseurl/password/command
plen = fill_tcp_data(buf, plen, baseurl);
plen = fill_tcp_data(buf, plen, password);
//LED1 AUS
if (on_off == 0)
plen = fill_tcp_data_p(buf, plen, PSTR("AN | "));
//LED 1 AN
if (on_off == 1)
plen = fill_tcp_data_p(buf, plen, PSTR("AUS | "));
//LED 2 AUS
if (on_off == 2)
//LED 2 AN
if (on_off == 3)
//LED 3 AUS
if (on_off == 4)
//LED 3 AN
if (on_off == 5)
return(plen);
int simple_server(void)
u16 plen;
u16 dat_p;
u8 i = 1;
u8 cmd_pos = 0;
u8 cmd;
u8 payloadlen = 0;
char str[30];
char cmdval;
// Del_1ms(100);
/*initialize enc28j60*/
enc28j60Init(mymac);
str[0]=(char)enc28j60getrev(); //IDºÅ
init_ip_arp_udp_tcp(mymac, myip, mywwwport); //?«MAC IP wwwportµØÖ·×°µ?Ö?¶?µØ
//Ö?Ê?µÆ×?̬:0x476 is PHLCON LEDA(ÂÌ)=links status, LEDB(ºì)=receive/transmit
// enc28j60PhyWrite(PHLCON, 0x7a4);
enc28j60PhyWrite(PHLCON, 0x476);
enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
// Del_1ms(20);
//init the ethernet/ip layer:
while (1)
// get the next new packet:
plen = enc28j60PacketReceive(BUFFER_SIZE, buf);
//USART_DMASendData(USART1,buf,plen);
/*plen will be unequal to zero if there is a valid packet (without crc error) */
if (plen == 0)
continue;
// arp is broadcast if unknown but a host may also
// verify the mac address by sending it to
// a unicast address.
if (eth_type_is_arp_and_my_ip(buf, plen))
make_arp_answer_from_request(buf);
//USART_DMASendText(USART1,"make_arp_answer_from_request\n");
continue;
// check if ip packets are for us:
if (eth_type_is_ip_and_my_ip(buf, plen) == 0)
continue;
if (buf[IP_PROTO_P] == IP_PROTO_ICMP_V &&
buf[ICMP_TYPE_P] == ICMP_TYPE_ECHOREQUEST_V)
// a ping packet, let's send pong
make_echo_reply_from_request(buf, plen);
//USART_DMASendText(USART1,"make_echo_reply_from_request\n");
continue;
// tcp port www start, compare only the lower byte
if (buf[IP_PROTO_P] == IP_PROTO_TCP_V &&
buf[TCP_DST_PORT_H_P] == 0 &&
buf[TCP_DST_PORT_L_P] == mywwwport)
if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V)
make_tcp_synack_from_syn(buf);
// make_tcp_synack_from_syn does already send the syn,ack
continue;
if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V)
init_len_info(buf); // init some data structures
// we can possibly have no data, just ack:
dat_p = get_tcp_data_pointer();
if (dat_p == 0)
if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V)
// finack, answer with ack
make_tcp_ack_from_any(buf);
// just an ack with no data, wait for next packet
continue;
if (strncmp("GET ", (char *) &(buf[dat_p]), 4) != 0)
// head, post and other methods:
// for possible status codes see:
// http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
plen = fill_tcp_data_p(buf, 0, PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n200 OK
goto SENDTCP;
if (strncmp("/ ", (char *) &(buf[dat_p + 4]), 2) == 0)
plen = fill_tcp_data_p(buf, 0, PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"));
plen = fill_tcp_data_p(buf, plen, PSTR("Usage: "));
plen = fill_tcp_data_p(buf, plen, PSTR("password
//plen = fill_tcp_data_p(buf, plen, PSTR("http://192.168.2.100/888"));
goto SENDTCP;
cmd = analyse_get_url((char *) &(buf[dat_p + 5]));
if (cmd ==(u8)-1)
plen = fill_tcp_data_p(buf, 0, PSTR("HTTP/1.0 401 Unauthorized\r\nContent-Type: text/html\r\n\r\n401 Unauthorized
goto SENDTCP;
if (cmd == 0)
//GPIO_SetBits(GPIOF,GPIO_Pin_6);
//GPIO_SetBits(GPIOF,GPIO_Pin_7);
//GPIO_SetBits(GPIOF,GPIO_Pin_8);
//GPIO_SetBits(GPIOF,GPIO_Pin_9);
GPIO_SetBits(GPIOF,GPIO_Pin_10);
i = 0;
st[0] = 0;
if (cmd == 1)
//GPIO_ResetBits(GPIOF,GPIO_Pin_6);
//GPIO_ResetBits(GPIOF,GPIO_Pin_7);
//GPIO_ResetBits(GPIOF,GPIO_Pin_8);
//GPIO_ResetBits(GPIOF,GPIO_Pin_9);
GPIO_ResetBits(GPIOF,GPIO_Pin_10);
i = 1;
st[1] = 1;
if (cmd == 2)
//GPIO_SetBits(GPIOF,GPIO_Pin_10);
i = 2;
st[2] = 2;
if (cmd == 3)
//GPIO_ResetBits(GPIOF,GPIO_Pin_10);
i = 3;
st[3] = 3;
if (cmd == 4)
i = 4;
st[4] = 4;
if (cmd == 5)
i = 5;
st[5] = 5;
// if (cmd==-2) or any other value
// just display the status:
plen = print_webpage(buf, (i));
SENDTCP :
make_tcp_ack_from_any(buf); // send ack for http get
make_tcp_ack_with_data(buf, plen); // send data
continue;
// tcp port www end
// udp start, we listen on udp port 1200=0x4B0
if (buf[IP_PROTO_P] == IP_PROTO_UDP_V &&
buf[UDP_DST_PORT_H_P] == 4 &&
buf[UDP_DST_PORT_L_P] == 0xb0)
payloadlen = buf[UDP_LEN_L_P] - UDP_HEADER_LEN;
// you must sent a string starting with v
// e.g udpcom version 10.0.0.24
if (verify_password((char *) &(buf[UDP_DATA_P])))
// find the first comma which indicates
// the start of a command:
cmd_pos = 0;
while (cmd_pos < payloadlen)
cmd_pos++;
if (buf[UDP_DATA_P + cmd_pos] == ',')
cmd_pos++; // put on start of cmd
break;
// a command is one char and a value. At
// least 3 characters long. It has an '=' on
// position 2:
if (cmd_pos<2 ||
cmd_pos>payloadlen - 3 ||
buf[UDP_DATA_P + cmd_pos + 1] != '=')
strcpy(str, "e=no_cmd");
goto ANSWER;
// supported commands are
// t=1 t=0 t=?
if (buf[UDP_DATA_P + cmd_pos] == 't')
cmdval = buf[UDP_DATA_P + cmd_pos + 2];
if (cmdval == '1')
//PORTD|= (1<
