  This is a library for the Adafruit 1.8" SPI display.
  This library works with the Adafruit 1.8" TFT Breakout w/SD card
  ----> http://www.adafruit.com/products/358
  as well as Adafruit raw 1.8" TFT display
  ----> http://www.adafruit.com/products/618
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include "Adafruit_ST7735.h"
#include <avr/pgmspace.h>
#include <limits.h>
#include "pins_arduino.h"
#include "wiring_private.h"
#include <SPI.h>
inline uint16_t swapcolor(uint16_t x) {
  return (x << 11) | (x & 0x07E0) | (x >> 11);
// Constructor when using software SPI.  All output pins are configurable.
Adafruit_ST7735::Adafruit_ST7735(uint8_t cs, uint8_t rs, uint8_t sid,
 uint8_t sclk, uint8_t rst) : Adafruit_GFX(ST7735_TFTWIDTH, ST7735_TFTHEIGHT)
  _cs   = cs;
  _rs   = rs;
  _sid  = sid;
  _sclk = sclk;
  _rst  = rst;
  hwSPI = false;
// Constructor when using hardware SPI.  Faster, but must use SPI pins
// specific to each board type (e.g. 11,13 for Uno, 51,52 for Mega, etc.)
Adafruit_ST7735::Adafruit_ST7735(uint8_t cs, uint8_t rs, uint8_t rst) :
  _cs   = cs;
  _rs   = rs;
  _rst  = rst;
  hwSPI = true;
  _sid  = _sclk = 0;
inline void Adafruit_ST7735::spiwrite(uint8_t c) {
  //Serial.println(c, HEX);
  if (hwSPI) {
    SPI.transfer(c);
  } else {
    // Fast SPI bitbang swiped from LPD8806 library
    for(uint8_t bit = 0x80; bit; bit >>= 1) {
      if(c & bit) *dataport |=  datapinmask;
      else        *dataport &= ~datapinmask;
      *clkport |=  clkpinmask;
      *clkport &= ~clkpinmask;
void Adafruit_ST7735::writecommand(uint8_t c) {
  *rsport &= ~rspinmask;
  *csport &= ~cspinmask;
  //Serial.print("C ");
  spiwrite(c);
  *csport |= cspinmask;
void Adafruit_ST7735::writedata(uint8_t c) {
  *rsport |=  rspinmask;
  //Serial.print("D ");
  spiwrite(c);
// Rather than a bazillion writecommand() and writedata() calls, screen
// initialization commands and arguments are organized in these tables
// stored in PROGMEM.  The table may look bulky, but that's mostly the
// formatting -- storage-wise this is hundreds of bytes more compact
// than the equivalent code.  Companion function follows.
#define DELAY 0x80
PROGMEM const static unsigned char
  Bcmd[] = {                  // Initialization commands for 7735B screens
    18,                       // 18 commands in list:
    ST7735_SWRESET,   DELAY,  //  1: Software reset, no args, w/delay
      50,                     //     50 ms delay
    ST7735_SLPOUT ,   DELAY,  //  2: Out of sleep mode, no args, w/delay
      255,                    //     255 = 500 ms delay
    ST7735_COLMOD , 1+DELAY,  //  3: Set color mode, 1 arg + delay:
      0x05,                   //     16-bit color
      10,                     //     10 ms delay
    ST7735_FRMCTR1, 3+DELAY,  //  4: Frame rate control, 3 args + delay:
      0x00,                   //     fastest refresh
      0x06,                   //     6 lines front porch
      0x03,                   //     3 lines back porch
      10,                     //     10 ms delay
    ST7735_MADCTL , 1      ,  //  5: Memory access ctrl (directions), 1 arg:
      0x08,                   //     Row addr/col addr, bottom to top refresh
    ST7735_DISSET5, 2      ,  //  6: Display settings #5, 2 args, no delay:
      0x15,                   //     1 clk cycle nonoverlap, 2 cycle gate
                              //     rise, 3 cycle osc equalize
      0x02,                   //     Fix on VTL
    ST7735_INVCTR , 1      ,  //  7: Display inversion control, 1 arg:
      0x0,                    //     Line inversion
    ST7735_PWCTR1 , 2+DELAY,  //  8: Power control, 2 args + delay:
      0x02,                   //     GVDD = 4.7V
      0x70,                   //     1.0uA
      10,                     //     10 ms delay
    ST7735_PWCTR2 , 1      ,  //  9: Power control, 1 arg, no delay:
      0x05,                   //     VGH = 14.7V, VGL = -7.35V
    ST7735_PWCTR3 , 2      ,  // 10: Power control, 2 args, no delay:
      0x01,                   //     Opamp current small
      0x02,                   //     Boost frequency
    ST7735_VMCTR1 , 2+DELAY,  // 11: Power control, 2 args + delay:
      0x3C,                   //     VCOMH = 4V
      0x38,                   //     VCOML = -1.1V
      10,                     //     10 ms delay
    ST7735_PWCTR6 , 2      ,  // 12: Power control, 2 args, no delay:
      0x11, 0x15,
    ST7735_GMCTRP1,16      ,  // 13: Magical unicorn dust, 16 args, no delay:
      0x09, 0x16, 0x09, 0x20, //     (seriously though, not sure what
      0x21, 0x1B, 0x13, 0x19, //      these config values represent)
      0x17, 0x15, 0x1E, 0x2B,
      0x04, 0x05, 0x02, 0x0E,
    ST7735_GMCTRN1,16+DELAY,  // 14: Sparkles and rainbows, 16 args + delay:
      0x0B, 0x14, 0x08, 0x1E, //     (ditto)
      0x22, 0x1D, 0x18, 0x1E,
      0x1B, 0x1A, 0x24, 0x2B,
      0x06, 0x06, 0x02, 0x0F,
      10,                     //     10 ms delay
    ST7735_CASET  , 4      ,  // 15: Column addr set, 4 args, no delay:
      0x00, 0x02,             //     XSTART = 2
      0x00, 0x81,             //     XEND = 129
    ST7735_RASET  , 4      ,  // 16: Row addr set, 4 args, no delay:
      0x00, 0x02,             //     XSTART = 1
      0x00, 0x81,             //     XEND = 160
    ST7735_NORON  ,   DELAY,  // 17: Normal display on, no args, w/delay
      10,                     //     10 ms delay
    ST7735_DISPON ,   DELAY,  // 18: Main screen turn on, no args, w/delay
      255 },                  //     255 = 500 ms delay
  Rcmd1[] = {                 // Init for 7735R, part 1 (red or green tab)
    15,                       // 15 commands in list:
    ST7735_SWRESET,   DELAY,  //  1: Software reset, 0 args, w/delay
      150,                    //     150 ms delay
    ST7735_SLPOUT ,   DELAY,  //  2: Out of sleep mode, 0 args, w/delay
      255,                    //     500 ms delay
    ST7735_FRMCTR1, 3      ,  //  3: Frame rate ctrl - normal mode, 3 args:
      0x01, 0x2C, 0x2D,       //     Rate = fosc/(1x2+40) * (LINE+2C+2D)
    ST7735_FRMCTR2, 3      ,  //  4: Frame rate control - idle mode, 3 args:
    ST7735_FRMCTR3, 6      ,  //  5: Frame rate ctrl - partial mode, 6 args:
      0x01, 0x2C, 0x2D,       //     Dot inversion mode
      0x01, 0x2C, 0x2D,       //     Line inversion mode
    ST7735_INVCTR , 1      ,  //  6: Display inversion ctrl, 1 arg, no delay:
      0x07,                   //     No inversion
    ST7735_PWCTR1 , 3      ,  //  7: Power control, 3 args, no delay:
      0xA2,
      0x02,                   //     -4.6V
      0x84,                   //     AUTO mode
    ST7735_PWCTR2 , 1      ,  //  8: Power control, 1 arg, no delay:
      0xC5,                   //     VGH25 = 2.4C VGSEL = -10 VGH = 3 * AVDD
    ST7735_PWCTR3 , 2      ,  //  9: Power control, 2 args, no delay:
      0x0A,                   //     Opamp current small
      0x00,                   //     Boost frequency
    ST7735_PWCTR4 , 2      ,  // 10: Power control, 2 args, no delay:
      0x8A,                   //     BCLK/2, Opamp current small & Medium low
      0x2A,
    ST7735_PWCTR5 , 2      ,  // 11: Power control, 2 args, no delay:
      0x8A, 0xEE,
    ST7735_VMCTR1 , 1      ,  // 12: Power control, 1 arg, no delay:
      0x0E,
    ST7735_INVOFF , 0      ,  // 13: Don't invert display, no args, no delay
    ST7735_MADCTL , 1      ,  // 14: Memory access control (directions), 1 arg:
      0xC8,                   //     row addr/col addr, bottom to top refresh
    ST7735_COLMOD , 1      ,  // 15: set color mode, 1 arg, no delay:
      0x05 },                 //     16-bit color
  Rcmd2green[] = {            // Init for 7735R, part 2 (green tab only)
    2,                        //  2 commands in list:
    ST7735_CASET  , 4      ,  //  1: Column addr set, 4 args, no delay:
      0x00, 0x02,             //     XSTART = 0
      0x00, 0x7F+0x02,        //     XEND = 127
    ST7735_RASET  , 4      ,  //  2: Row addr set, 4 args, no delay:
      0x00, 0x01,             //     XSTART = 0
      0x00, 0x9F+0x01 },      //     XEND = 159
  Rcmd2red[] = {              // Init for 7735R, part 2 (red tab only)
      0x00, 0x00,             //     XSTART = 0
      0x00, 0x7F,             //     XEND = 127
      0x00, 0x9F },           //     XEND = 159
  Rcmd3[] = {                 // Init for 7735R, part 3 (red or green tab)
    4,                        //  4 commands in list:
    ST7735_GMCTRP1, 16      , //  1: Magical unicorn dust, 16 args, no delay:
      0x02, 0x1c, 0x07, 0x12,
      0x37, 0x32, 0x29, 0x2d,
      0x29, 0x25, 0x2B, 0x39,
      0x00, 0x01, 0x03, 0x10,
    ST7735_GMCTRN1, 16      , //  2: Sparkles and rainbows, 16 args, no delay:
      0x03, 0x1d, 0x07, 0x06,
      0x2E, 0x2C, 0x29, 0x2D,
      0x2E, 0x2E, 0x37, 0x3F,
      0x00, 0x00, 0x02, 0x10,
    ST7735_NORON  ,    DELAY, //  3: Normal display on, no args, w/delay
      10,                     //     10 ms delay
    ST7735_DISPON ,    DELAY, //  4: Main screen turn on, no args w/delay
      100 },                  //     100 ms delay
  Gcmd[] = {                  // Initialization commands for 7735B screens
    19,                       // 18 commands in list:
      50,                     //     50 ms delay
      100,                    //     255 = 500 ms delay
    0x26 , 1,  			// 3: Set default gamma
      0x04,                     //     16-bit color
    0xb1, 2,              	// 4: Frame Rate
      0x0b,
      0x14,
    0xc0, 2,                    // 5: VRH1[4:0] & VC[2:0]
      0x08,
      0x00,
    0xc1, 1,                    // 6: BT[2:0]
      0x05,
    0xc5, 2,                    // 7: VMH[6:0] & VML[6:0]
      0x41,
      0x30,
    0xc7, 1,                    // 8: LCD Driving control
      0xc1,
    0xEC, 1,                    // 9: Set pumping color freq
      0x1b,
    0x3a , 1 + DELAY,  	        // 10: Set color format
      0x55,                     //     16-bit color
      100,
    0x2a, 4,                    // 11: Set Column Address
      0x00,
      0x00,
      0x00,
      0x7f,
    0x2b, 4,                    // 12: Set Page Address
      0x00,
      0x00,
      0x00,
      0x9f,
    0x36, 1,                    // 12+1: Set Scanning Direction
      0xc8,
    0xb7, 1,			// 14: Set Source Output Direciton
      0x00,
    0xf2, 1,			// 15: Enable Gamma bit
      0x00,
    0xe0, 15 + DELAY,		// 16: magic
      0x28, 0x24, 0x22, 0x31,
      0x2b, 0x0e, 0x53, 0xa5,
      0x42, 0x16, 0x18, 0x12,
      0x1a, 0x14, 0x03,
      50,
    0xe1, 15 + DELAY,		// 17: more magic
      0x17, 0x1b, 0x1d, 0x0e,
      0x14, 0x11, 0x2c, 0xa5,
      0x3d, 0x09, 0x27, 0x2d,
      0x25, 0x2b, 0x3c,
      50,
      10,                     //     10 ms delay
      255 };                  //     255 = 500 ms delay
// Companion code to the above tables.  Reads and issues
// a series of LCD commands stored in PROGMEM byte array.
void Adafruit_ST7735::commandList(const uint8_t *addr) {
  uint8_t  numCommands, numArgs;
  uint16_t ms;
  numCommands = pgm_read_byte(addr++);   // Number of commands to follow
  while(numCommands--) {                 // For each command...
    writecommand(pgm_read_byte(addr++)); //   Read, issue command
    numArgs  = pgm_read_byte(addr++);    //   Number of args to follow
    ms       = numArgs & DELAY;          //   If hibit set, delay follows args
    numArgs &= ~DELAY;                   //   Mask out delay bit
    while(numArgs--) {                   //   For each argument...
      writedata(pgm_read_byte(addr++));  //     Read, issue argument
    if(ms) {
      ms = pgm_read_byte(addr++); // Read post-command delay time (ms)
      if(ms == 255) ms = 500;     // If 255, delay for 500 ms
      delay(ms);
// Initialization code common to both 'B' and 'R' type displays
void Adafruit_ST7735::commonInit(const uint8_t *cmdList) {
  colstart  = rowstart = 0; // May be overridden in init func
  pinMode(_rs, OUTPUT);
  pinMode(_cs, OUTPUT);
  csport    = portOutputRegister(digitalPinToPort(_cs));
  cspinmask = digitalPinToBitMask(_cs);
  rsport    = portOutputRegister(digitalPinToPort(_rs));
  rspinmask = digitalPinToBitMask(_rs);
  if(hwSPI) { // Using hardware SPI
    SPI.begin();
#if defined(ARDUINO_ARCH_SAM)
    SPI.setClockDivider(24); // 4 MHz (half speed)
#else
    SPI.setClockDivider(SPI_CLOCK_DIV4); // 4 MHz (half speed)
#endif
    SPI.setBitOrder(MSBFIRST);
    SPI.setDataMode(SPI_MODE0);
  } else {
    pinMode(_sclk, OUTPUT);
    pinMode(_sid , OUTPUT);
    clkport     = portOutputRegister(digitalPinToPort(_sclk));
    clkpinmask  = digitalPinToBitMask(_sclk);
    dataport    = portOutputRegister(digitalPinToPort(_sid));
    datapinmask = digitalPinToBitMask(_sid);
  // toggle RST low to reset; CS low so it'll listen to us
  if (_rst) {
    pinMode(_rst, OUTPUT);
    digitalWrite(_rst, HIGH);
    delay(500);
    digitalWrite(_rst, LOW);
    delay(500);
    delay(500);
  if(cmdList) commandList(cmdList);
// Initialization for ST7735B screens
void Adafruit_ST7735::initB(void) {
  commonInit(Bcmd);
void Adafruit_ST7735::initG(void) {
  commonInit(Gcmd);
// Initialization for ST7735R screens (green or red tabs)
void Adafruit_ST7735::initR(uint8_t options) {
  commonInit(Rcmd1);
  if(options == INITR_GREENTAB) {
    commandList(Rcmd2green);
    colstart = 2;
    rowstart = 1;
  } else {
    // colstart, rowstart left at default '0' values
    commandList(Rcmd2red);
  commandList(Rcmd3);
  tabcolor = options;
void Adafruit_ST7735::setAddrWindow(uint8_t x0, uint8_t y0, uint8_t x1,
 uint8_t y1) {
  writecommand(ST7735_CASET); // Column addr set
  writedata(0x00);
  writedata(x0+colstart);     // XSTART
  writedata(0x00);
  writedata(x1+colstart);     // XEND
  writecommand(ST7735_RASET); // Row addr set
  writedata(0x00);
  writedata(y0+rowstart);     // YSTART
  writedata(0x00);
  writedata(y1+rowstart);     // YEND
  writecommand(ST7735_RAMWR); // write to RAM
void Adafruit_ST7735::pushColor(uint16_t color) {
  if (tabcolor == INITR_BLACKTAB)   color = swapcolor(color);
  spiwrite(color >> 8);
  spiwrite(color);
void Adafruit_ST7735::drawPixel(int16_t x, int16_t y, uint16_t color) {
  if((x < 0) ||(x >= _width) || (y < 0) || (y >= _height)) return;
  setAddrWindow(x,y,x+1,y+1);
  spiwrite(color);
void Adafruit_ST7735::drawFastHblock(uint8_t *data, uint16_t cnt) {
	cnt *= 2;		// two bytes / pixel
	for (; cnt>0; cnt--) {
  	spiwrite(*data++);
void Adafruit_ST7735::drawFastVLine(int16_t x, int16_t y, int16_t h,
 uint16_t color) {
  // Rudimentary clipping
  if((x >= _width) || (y >= _height)) return;
  if((y+h-1) >= _height) h = _height-y;
  setAddrWindow(x, y, x, y+h-1);
  uint8_t hi = color >> 8, lo = color;
  while (h--) {
    spiwrite(hi);
    spiwrite(lo);
void Adafruit_ST7735::drawFastHLine(int16_t x, int16_t y, int16_t w,
  uint16_t color) {
  if((x+w-1) >= _width)  w = _width-x;
  setAddrWindow(x, y, x+w-1, y);
  while (w--) {
    spiwrite(hi);
    spiwrite(lo);
void Adafruit_ST7735::fillScreen(uint16_t color) {
  fillRect(0, 0,  _width, _height, color);
// fill a rectangle
void Adafruit_ST7735::fillRect(int16_t x, int16_t y, int16_t w, int16_t h,
  uint16_t color) {
  // rudimentary clipping (drawChar w/big text requires this)
  if((x + w - 1) >= _width)  w = _width  - x;
  if((y + h - 1) >= _height) h = _height - y;
  setAddrWindow(x, y, x+w-1, y+h-1);
  for(y=h; y>0; y--) {
    for(x=w; x>0; x--) {
      spiwrite(hi);
      spiwrite(lo);
#define MADCTL_MY  0x80
#define MADCTL_MX  0x40
#define MADCTL_MV  0x20
#define MADCTL_ML  0x10
#define MADCTL_RGB 0x08
#define MADCTL_MH  0x04
void Adafruit_ST7735::setRotation(uint8_t m) {
  writecommand(ST7735_MADCTL);
  rotation = m % 4; // can't be higher than 3
  switch (rotation) {
   case 0:
    writedata(MADCTL_MX | MADCTL_MY | MADCTL_RGB);
    _width  = ST7735_TFTWIDTH;
    _height = ST7735_TFTHEIGHT;
    break;
   case 1:
    writedata(MADCTL_MY | MADCTL_MV | MADCTL_RGB);
    _width  = ST7735_TFTHEIGHT;
    _height = ST7735_TFTWIDTH;
    break;
   case 2:
    writedata(MADCTL_RGB);
    break;
   case 3:
    writedata(MADCTL_MX | MADCTL_MV | MADCTL_RGB);
    break;
void Adafruit_ST7735::invertDisplay(boolean i) {
  writecommand(i ? ST7735_INVON : ST7735_INVOFF);
////////// stuff not actively being used, but kept for posterity
 uint8_t Adafruit_ST7735::spiread(void) {
 uint8_t r = 0;
 if (_sid > 0) {
 r = shiftIn(_sid, _sclk, MSBFIRST);
 } else {
 //SID_DDR &= ~_BV(SID);
 //int8_t i;
 //for (i=7; i>=0; i--) {
 //  SCLK_PORT &= ~_BV(SCLK);
 //  r <<= 1;
 //  r |= (SID_PIN >> SID) & 0x1;
 //  SCLK_PORT |= _BV(SCLK);
 //SID_DDR |= _BV(SID);
 return r;
 void Adafruit_ST7735::dummyclock(void) {
 if (_sid > 0) {
 digitalWrite(_sclk, LOW);
 digitalWrite(_sclk, HIGH);
 } else {
 //SCLK_PORT |= _BV(SCLK);
 uint8_t Adafruit_ST7735::readdata(void) {
 *portOutputRegister(rsport) |= rspin;
 *portOutputRegister(csport) &= ~ cspin;
 uint8_t r = spiread();
 *portOutputRegister(csport) |= cspin;
 return r;
 uint8_t Adafruit_ST7735::readcommand8(uint8_t c) {
 digitalWrite(_rs, LOW);
 spiwrite(c);
 digitalWrite(_rs, HIGH);
 pinMode(_sid, INPUT); // input!
 digitalWrite(_sid, LOW); // low
 spiread();
 pinMode(_sid, OUTPUT); // back to output
 return r;
 uint16_t Adafruit_ST7735::readcommand16(uint8_t c) {
 if (_cs)
 digitalWrite(_cs, LOW);
 spiwrite(c);
 uint16_t r = spiread();
 r <<= 8;
 r |= spiread();
 if (_cs)
 digitalWrite(_cs, HIGH);
 return r;
 uint32_t Adafruit_ST7735::readcommand32(uint8_t c) {
 if (_cs)
 spiwrite(c);
 dummyclock();
 dummyclock();
 uint32_t r = spiread();
 r <<= 8;
 r |= spiread();
 r <<= 8;
 r |= spiread();
 r <<= 8;
 r |= spiread();
 if (_cs)
 return r;
