OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm") /* Internal Memory Map*/ MEMORY { rom (rx) : ORIGIN = 0x08000000, LENGTH = 0x00040000 ram (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00010000 } _eram = 0x20000000 + 0x00010000; SECTIONS { .text : { KEEP(*(.isr_vector)) *(.text*) KEEP(*(.init)) KEEP(*(.fini)) /* .ctors */ *crtbegin.o(.ctors) *crtbegin?.o(.ctors) *(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors) *(SORT(.ctors.*)) *(.ctors) /* .dtors */ *crtbegin.o(.dtors) *crtbegin?.o(.dtors) *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors) *(SORT(.dtors.*)) *(.dtors) *(.rodata*) KEEP(*(.eh_fram e*)) } > rom .ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } > rom __exidx_start = .; .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) } > rom __exidx_end = .; __etext = .; /* _sidata is used in coide startup code */ _sidata = __etext; .data : AT (__etext) { __data_start__ = .; /* _sdata is used in coide startup code */ _sdata = __data_start__; *(vtable) *(.data*) . = ALIGN(4); /* preinit data */ PROVIDE_HIDDEN (__preinit_array_start = .); KEEP(*(.preinit_array)) PROVIDE_HIDDEN (__preinit_array_end = .); . = ALIGN(4); /* init data */ PROVIDE_HIDDEN (__init_array_start = .); KEEP(*(SORT(.init_array.*))) KEEP(*(.init_array)) PROVIDE_HIDDEN (__init_array_end = .); . = ALIGN(4); /* finit data */ PROVIDE_HIDDEN (__fini_array_start = .); KEEP(*(SORT(.fini_array.*))) KEEP(*(.fini_array)) PROVIDE_HIDDEN (__fini_array_end = .); KEEP(*(.jcr*)) . = ALIGN(4); /* All data end */ __data_end__ = .; /* _edata is used in coide startup code */ _edata = __data_end__; } > ram .bss : { . = ALIGN(4); __bss_start__ = .; _sbss = __bss_start__; *(.bss*) *(COMMON) . = ALIGN(4); __bss_end__ = .; _ebss = __bss_end__; } > ram .heap (COPY): { __end__ = .; _end = __end__; end = __end__; *(.heap*) __HeapLimit = .; } > ram /* .stack_dummy section doesn't contains any symbols. It is only * used for linker to calculate size of stack sections, and assign * values to stack symbols later */ .co_stack (NOLOAD): { . = ALIGN(8); *(.co_stack .co_stack.*) } > ram /* Set stack top to end of ram , and stack limit move down by * size of stack_dummy section */ __StackTop = ORIGIN(ram ) + LENGTH(ram ); __StackLimit = __StackTop - SIZEOF(.co_stack); PROVIDE(__stack = __StackTop); /* Check if data + heap + stack exceeds ram limit */ ASSERT(__StackLimit >= __HeapLimit, "region ram overflowed with stack") }
