U-Boot 2011.09-00000-gf54ce7f-dirty (Dec 20 2011 - 12:36:29) DRAM: 128 MiB NAND: NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit) 64 MiB Bad block table at page 1120, version 0x01 Bad block table at page 1152, version 0x01 nand_read_bbt: Bad block at 0x0000003d0000 nand_read_bbt: Bad block at 0x0000031b8000 In: serial Out: serial Err: serial Net: natsemi: EEPROM contents: d008 0400 0b34 00f3 0000 0000 0000 8c00 c8f9 4c41 0000 aa70 natsemi: MAC-Address: 0:18:F3:91:83:98 dp83815#0 Welcome to the pollinux board v1.1 Hit any key to stop autoboot: 0 Loading from nand0, offset 0x94000 Image Name: Elecard Linux 2.6 Created: 2011-12-07 16:01:46 UTC Image Type: MIPS Elecard Linux Kernel Image (gzip compressed) Data Size: 3233500 Bytes = 3.1 MiB Load Address: 80060000 Entry Point: 803a9000 ## Booting kernel from Legacy Image at 82000000 ... Image Name: Elecard Linux 2.6 Created: 2011-12-07 16:01:46 UTC Image Type: MIPS Elecard Linux Kernel Image (gzip compressed) Data Size: 3233500 Bytes = 3.1 MiB Load Address: 80060000 Entry Point: 803a9000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Starting kernel ... Determined physical RAM map: memory: 07000000 @ 00000000 (usable) Initrd not found or empty - disabling initrd Built 1 zonelists. Total pages: 28448 Kernel command line: console=ttyS1,38400n8 stb810_display=pal ip=$(ip) nomainapp=1 root=/dev/sda1 rw Primary instruction cache 16kB, physically tagged, 2-way, linesize 32 bytes. Primary data cache 16kB, 4-way, linesize 32 bytes. Synthesized TLB refill handler (23 instructions). Synthesized TLB load handler fastpath (32 instructions). Synthesized TLB store handler fastpath (32 instructions). Synthesized TLB modify handler fastpath (31 instructions). PID hash table entries: 512 (order: 9, 2048 bytes) Using 250.714 MHz high precision timer. Linux version 2.6.21.3PNX8550 (root@smithy) (gcc version 4.0.0 (DENX ELDK 4.0 4.0.0)) #1743 Fri Feb 11 10:49:15 OMST 2011 Setting initial splash screen display mode SD (50Hz) CPU revision is: 00061200 Determined physical RAM map: memory: 07000000 @ 00000000 (usable) Initrd not found or empty - disabling initrd Built 1 zonelists. Total pages: 28448 Kernel command line: console=ttyS1,38400n8 stb810_display=pal ip=$(ip) nomainapp=1 root=/dev/sda1 rw Primary instruction cache 16kB, physically tagged, 2-way, linesize 32 bytes. Primary data cache 16kB, 4-way, linesize 32 bytes. Synthesized TLB refill handler (23 instructions). Synthesized TLB load handler fastpath (32 instructions). Synthesized TLB store handler fastpath (32 instructions). Synthesized TLB modify handler fastpath (31 instructions). PID hash table entries: 512 (order: 9, 2048 bytes) Using 250.714 MHz high precision timer. Console: colour dummy device 80x25 Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 107648k/114688k available (2841k kernel code, 6996k reserved, 518k data, 2044k init, 0k highmem) Mount-cache hash table entries: 512 NET: Registered protocol family 16 registering PCI controller with io_map_base unset SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Time: MIPS clocksource has been installed. NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered NTFS driver 2.1.28 [Flags: R/O]. JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc. io scheduler noop registered io scheduler anticipatory registered (default) Register GPIO SPI device Serial: PNX8XXX driver $Revision: 1.2 $ pnx8xxx-uart: ttyS0 at MMIO 0xbbe4a000 (irq = 27) is a PNX8XXX pnx8xxx-uart: ttyS1 at MMIO 0xbbe4b000 (irq = 28) is a PNX8XXX natsemi dp8381x driver, version 2.1, Sept 11, 2006 originally by Donald Becker http://www.scyld.com/network/natsemi.html 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder PCI: Enabling device 0000:00:0a.0 (0006 -> 0007) natsemi eth0: NatSemi DP8381[56] at 0x20092000 (0000:00:0a.0), 00:18:f3:91:83:98, IRQ 55, port TP. Driver for NAND Flash on the PNX8550 XIO bus (Mar 15 2010-17:54:27) Auto detected a >= 64MByte device on a 8 bit bus NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit) Scanning device for bad blocks Bad eraseblock 244 at 0x003d0000 Bad eraseblock 3182 at 0x031b8000 Creating 8 MTD partitions on "NAND 64MiB 3,3V 8-bit": 0x00000000-0x00004000 : "microBTM" 0x00004000-0x00084000 : "U-Boot" 0x00084000-0x0008c000 : "Env" 0x0008c000-0x00094000 : "bbt" 0x00094000-0x00894000 : "Linux" 0x00894000-0x03b94000 : "ROMFS" 0x03c00000-0x03ff8000 : "WinCE" 0x03ff8000-0x04000000 : "Info" ehci_hcd 0000:00:09.2: EHCI Host Controller ehci_hcd 0000:00:09.2: new USB bus registered, assigned bus number 1 ehci_hcd 0000:00:09.2: irq 55, io mem 0x20093200 ehci_hcd 0000:00:09.2: USB 2.0 started, EHCI 0.95, driver 10 Dec 2004 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 4 ports detected pnx8550-ohci pnx8550-ohci: PNX8550 OHCI pnx8550-ohci pnx8550-ohci: new USB bus registered, assigned bus number 2 pnx8550-ohci pnx8550-ohci: irq 13, io mem 0x1be48000 usb usb2: configuration #1 chosen from 1 choice hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected ohci_hcd 0000:00:09.0: OHCI Host Controller ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 3 ohci_hcd 0000:00:09.0: irq 55, io mem 0x20090000 usb 1-1: new high speed USB device using ehci_hcd and address 2 usb usb3: configuration #1 chosen from 1 choice hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected usb 1-1: configuration #1 chosen from 1 choice ohci_hcd 0000:00:09.1: OHCI Host Controller ohci_hcd 0000:00:09.1: new USB bus registered, assigned bus number 4 ohci_hcd 0000:00:09.1: irq 55, io mem 0x20091000 usb usb4: configuration #1 chosen from 1 choice hub 4-0:1.0: USB hub found hub 4-0:1.0: 2 ports detected USB Universal Host Controller Interface driver v3.0 Initializing USB Mass Storage driver... scsi0 : SCSI emulation for USB Mass Storage devices usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice i2c /dev entries driver TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Bridge firewalling registered 802.1Q VLAN Support v1.8 Ben Greear All bugs added by David S. Miller ieee80211: 802.11 data/management/control stack, git-1.1.13 ieee80211: Copyright (C) 2004-2005 Intel Corporation eth0: DSPCFG accepted after 0 usec. eth0: link up. eth0: Setting full-duplex based on negotiated link capability. Sending DHCP requests .<5>eth0: increased tx threshold, txcfg 0xd0f01004. .<5>scsi 0:0:0:0: Direct-Access Intenso Micro Line PMAP PQ: 0 ANSI: 6 SCSI device sda: 7595520 512-byte hdwr sectors (3889 MB) sda: Write Protect is off sda: assuming drive cache: write through SCSI device sda: 7595520 512-byte hdwr sectors (3889 MB) sda: Write Protect is off sda: assuming drive cache: write through sda: sda1 sd 0:0:0:0: Attached scsi removable disk sda .... timed out! IP-Config: Reopening network devices... eth0: DSPCFG accepted after 0 usec. eth0: link up. eth0: Setting full-duplex based on negotiated link capability. Sending DHCP requests .<5>eth0: increased tx threshold, txcfg 0xd0f01004. ., OK IP-Config: Got DHCP answer from 192.168.2.1, my address is 192.168.2.132 IP-Config: Complete: device=eth0, addr=192.168.2.132, mask=255.255.255.0, gw=192.168.2.1, host=192.168.2.132, domain=, nis-domain=(none), bootserver=192.168.2.1, rootserver=192.168.2.1, rootpath= Freeing unused kernel memory: 2044k freed Algorithmics/MIPS FPU Emulator v1.5 Loading profile... done Mount fstab... done Remount / read-write... done Mounting new Root. enabling SATA modules...sata_sil 0000:00:08.0: Applying R_ERR on DMA activate FIS errata fix ata1: SATA max UDMA/100 cmd 0xc0058080 ctl 0xc005808a bmdma 0xc0058000 irq 55 ata2: SATA max UDMA/100 cmd 0xc00580c0 ctl 0xc00580ca bmdma 0xc0058008 irq 55 scsi1 : sata_sil ata1: SATA link down (SStatus 0 SControl 310) scsi2 : sata_sil ata2: SATA link down (SStatus 0 SControl 310) done Creating device nodes...done Setup mdev as hotplug handler... done Set log level... Populate /dev... Load luddite and gpio/mmio/rtc...Get display mode and load i2c and fb modules... Detect GPIO function...done Get System ID... Restore hotplug handler... done Restore log level... Unloading modules... Shutting down RTC driver Shutting down PNX8550 MMIO Driver Shutting down PNX8550 GPIO driver Shutting down NXP /proc entries driver done done Mount nfs root /dev/sda1... kjournald starting. Commit interval 5 seconds EXT3 FS on sda1, internal journal EXT3-fs: recovery complete. EXT3-fs: mounted filesystem with ordered data mode. done Switch root switch_root: Kernel panic - not syncing: Attempted to kill init! Bad init '/sbin/init'
