' ------------------------------------------------------------------------------ ' ------------------------------------------------------------------------------ ' ----[This file receive arrays from LabView ]-- ' ----[This happens in a loop. For each element of both arrays, there is a ]-- ' ----[step. ]-- ' ----[A digital PID controller is implemented ]-- ' ----[Once the upload is done, the control loop is starded and the pressure ]-- ' ----[time values are send to LabView via the serial port buffer. ]-- ' ------------------------------------------------------------------------------ ' ------------------------------------------------------------------------------ ' ----[Guillaume Bugnard ]------------------------------------------------- ' ----[27/08/2007 ]------------------------------------------------- ' ----[Masterthesis ETH Zurich]------------------------------------------------- ' ------------------------------------------------------------------------------ ' ------------------------------------------------------------------------------ ' ------------------------------------------------------------------------------ ' ----[Define the properties of the micro-controller]--------------------------- ' ------------------------------------------------------------------------------ $regfile = "m64def.dat" ' def file for ATmega16 $baud = 9600 '9600 $crystal = 16000000 ' 16MHz cristal ' ------------------------------------------------------------------------------ ' ----[Configure the watchdog]-------------------------------------------------- ' ------------------------------------------------------------------------------ Config Watchdog = 128 'Reset program after 16[ms] Stop Watchdog ' ------------------------------------------------------------------------------ ' ----[Define the internal memory allocation]----------------------------------- ' ------------------------------------------------------------------------------ $hwstack = 256 $swstack = 256 $framesize = 256 ' ------------------------------------------------------------------------------ ' ----[Open COM1 for data transfer to PC]----------------------------------- ' ------------------------------------------------------------------------------ Open "comd.1:9600,8,n,1,inverted" For Output As #1 ' ------------------------------------------------------------------------------ ' ----[Define the port for input in the terminal]------------------------------- ' ------------------------------------------------------------------------------ Config Porte.0 = Input Config Porte.1 = Output Config Serialin = Buffered , Size = 128 Config Serialout = Buffered , Size = 128 ' ------------------------------------------------------------------------------ ' ----[Configure the LCD screen]------------------------------------------------ ' ------------------------------------------------------------------------------ Config Lcdpin = Pin , Db4 = Portf.3 , Db5 = Portf.2 , Db6 = Portf.1 , Db7 = Portf.0 , E = Porta.1 , Rs = Porta.2 Config Lcd = 20 * 4 Config Lcdbus = 4 ' ------------------------------------------------------------------------------ ' ----[Start the Analog->Digital converter]------------------------------------- ' ------------------------------------------------------------------------------ Config Adc = Single , Prescaler = 32 , Reference = Internal , Start Adc ' ------------------------------------------------------------------------------ ' ----[Configure the PWM signal maker]------------------------------------------ ' ------------------------------------------------------------------------------ ' set direction of Ports. 0=input, 1=output: Ddra = &B00001110 ' set portA direction Ddrb = &B10010000 ' set portB direction 'Ddrc = &B11111111 ' PortC = Output (Addres/data-bus) 'Ddrd = &B11111110 ' set portD direction Ddrf = &B00001111 Config Timer0 = Pwm , Prescale = 64 , Compare Pwm = Clear Down ' ------------------------------------------------------------------------------ ' ----[Declare variables]------------------------------------------------------- ' ------------------------------------------------------------------------------ '1. For the timer2 counter Dim Cnt As Word Dim T As Single T = 0.0 Dim Intervaltime As Integer Intervaltime = 16.0 'interval time in [ms] 'Dim Stopbyte As Byte 'Stopbyte = 0 '2. For the Upload of the pressure law arrays Dim Arraydim As Integer Dim Buffer As String * 10 Arraydim = 100 Dim Arraytime(100) As Single Dim Arraypressure(100) As Single Dim Dimensionlaw As Integer Dim Timeend As Single 'End of the experiment Dim N As Integer '3. For the results (interpolated pressure) Dim J As Integer J = 1 Dim Numberstep As Integer Numberstep = Arraydim '4. For the transfer of the data from the controller to the PC Dim K As Integer '5. For the import of the pressure value from the sensor Dim Druckbuffer As Word Dim Druck As Single Dim Drucktemp As Single Dim Gainpressure As Single '6. For the control signal Dim R As Single R = 0.0 Dim U As Single U = 0.0 Dim Y As Single Y = 0.0 Dim E1 As Single Dim E2 As Single Dim E3 As Single E1 = 0.0 E2 = 0.0 E3 = 0.0 '7. PID parameters Dim Kp As Single 'P parameter Dim Ki As Single 'I parameter Dim Kd As Single 'D parameter Dim Timesampling As Single Timesampling = Intervaltime / 1000.0 Dim Sumik As Single Sumik = 0 '8. Motor parameters Dim Direction As Byte Direction = 0 '9. Pressure and time number to string conversion '10. Interrupts Dim Tim2isrbit As Byte 'Interrupter bit '11. Number of cycles Dim Numbercycle As Integer Dim Cyclecounter As Integer Cyclecounter = 0 ' ------------------------------------------------------------------------------ ' ----[Configure timer]--------------------------------------------------------- ' ------------------------------------------------------------------------------ Const Timer2reload = 250 Const Timerstart = 6 Config Timer2 = Timer , Prescale = 1024 Load Timer2 , Timer2reload On Ovf2 Tim2_isr Enable Ovf2 Enable Interrupts 'start timer2 Stop Timer2 'Add your code here 'Timer value explination ' The timer is a 8Bit timer, it overflows when the timer reaches 256 ' The AVR is running at 16000000Hz, the prescaler is 1024 ' Each tick is 0.064 ms - (1 / CPUSpeed in KHz ) * Prescaler ' The timer needs 250 ticks to reach the required time ( 250 * 0.064 = 16ms) ' The start value for the timer must be set to 6 so that it will overflow at 256 after 250 ticks ' NOTE: The load command does the inversion for you (256-value or 65536-value) ' ------------------------------------------------------------------------------ ' ----[Declare the functions]--------------------------------------------------- ' ------------------------------------------------------------------------------ '1. Declare the function which looks for the index of the wanted value Declare Function Pinterpolated(timein As Single) As Single ' ------------------------------------------------------------------------------ ' ----[A. Main Program]...------------------------------------------------------ ' ------------------------------------------------------------------------------ Main: '1. Hello message '---------------- Cls Cursor Off Noblink Locate 1 , 1 : Lcd "********************" Locate 2 , 1 : Lcd "* Control box 3.3 *" Locate 3 , 1 : Lcd "* G. Bugnard *" Locate 4 , 1 : Lcd "********************" '1.1 The program waits until LabView send a carriage return (frame 1.2) to ' confirm that the buffer has been flushed. Buffer = Waitkey() '1.2 Send a keyword to LabView to tell the box is ready to import the ' pressure law. Print "Ready" Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Ready" '2. Read the Kp value '-------------------- '2.1 Once LabView is ready, the box receive the value for the R0 parameter Input Buffer Kp = Val(buffer) '2.2 The value is printed on the LCD screen Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Kp = " ; Kp Waitms 1000 '2.3 Once done, the keyword R0ok is sent to LabView Print "Kpok" '3. Read the Ki value '-------------------- '3.1 Once LabView is ready, the box receive the value for the Ki parameter Input Buffer Ki = Val(buffer) '3.2 The value is printed on the LCD screen Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Ki = " ; Ki Waitms 1000 '3.3 Once done, the keyword R0ok is sent to LabView Print "Kiok" '4. Read the Kd value '-------------------- '4.1 Once LabView is ready, the box receive the value for the Kd parameter Input Buffer Kd = Val(buffer) '4.2 The value is printed on the LCD screen Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Kd = " ; Kd Waitms 1000 '4.3 Once done, the keyword R0ok is sent to LabView Print "Kdok" '5. Read the Timeend value '------------------------- '5.1 Once LaBiew is ready, the box receive the value for the time end Input Buffer Timeend = Val(buffer) '5.2 The value is printed on the LCD screen Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Time end = " ; Timeend Waitms 1000 '5.3 Once done, the keyword R0ok is sent to LabView Print "Timeok" '6. Read number of element for the pressure law '---------------------------------------------- '6.1 Once LaBiew is ready, the box receive the value for the time end Input Buffer Dimensionlaw = Val(buffer) '6.2 The value is printed on the LCD screen Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Dim. law = " ; Dimensionlaw Waitms 1000 '6.3 Once done, the keyword R0ok is sent to LabView Print "Dimok" '7. Read the gain for the pressure sensor '--------------------------------------------- '7.1 Once LaBiew is ready, the box receive the value for gain Input Buffer Gainpressure = Val(buffer) '7.2 The value is printed on the LCD screen Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Gain = " ; Gainpressure Waitms 1000 '7.3 Once done, the keyword GainOK is sent to LabView Print "Gainok" '8. Read number of cycles '--------------------------------------------- '8.1 Once LabView is ready, the box receive the value for number of cycle Input Buffer Numbercycle = Val(buffer) '8.2 The value is printed on the LCD screen Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Number of cycles = " ; Numbercycle Waitms 1000 '8.3 Once done, the keyword GainOK is sent to LabView Print "Cycleok" '9. Initilize the importation of data '------------------------------------ Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Ready to start" J = 0 Timer2 = 0 Stop Timer2 Wait 1 Goto Importdata 'Start the importion of the pressure law Goto Main ' ------------------------------------------------------------------------------ ' ----[B. Upload the arrays]---------------------------------------------------- ' ------------------------------------------------------------------------------ Importdata: '1 Time '------ '1.1 Print the state on the LCD screen Cls Cursor Off Noblink Lcd "Import time..." '1.2 Tell LabView the box is ready to receive the time vector Print "Time" '1.3 Begin the transfer For N = 1 To Dimensionlaw Input Buffer Arraytime(n) = Val(buffer) Next '2. Pressure '----------- '2.1 Print the stat on the LCD screen Cls Cursor Off Noblink Lcd "Import pressure..." '2.2 Tell LabView the box is ready to receive the pressure vector Print "Pressure" '2.3 Begin the transfer For N = 1 To Dimensionlaw Input Buffer Arraypressure(n) = Val(buffer) Next '3. End '------ Cls Cursor Off Noblink Lcd "Importation done!" Goto Starttimer 'Start the control sequence ' ------------------------------------------------------------------------------ ' ----[C. Interpolate the pressure]--------------------------------------------- ' ------------------------------------------------------------------------------ Starttimer: '1. Write the state on the LCD screen '------------------------------------ Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Imporation done" Locate 2 , 1 : Lcd "Start timer" Waitms 1000 '2. Wait until LabView has flushed the buffer '-------------------------------------------- Buffer = Waitkey() '3. Tell LabView the box is ready to begin the control sequence '-------------------------------------------------------------- Print "Control" Buffer = Waitkey() '4. Once Labview is ready, start the timer which sample the control sequence '--------------------------------------------------------------------------- Cls Cursor Off Noblink Locate 1 , 1 : Lcd "********************" Locate 2 , 1 : Lcd "* Control sequence *" Locate 3 , 1 : Lcd "* *" Locate 4 , 1 : Lcd "********************" Start Timer2 Gosub Controlsequence Return Controlsequence: If Tim2isrbit = 1 Then Gosub Controller 'Print Stopbyte 'Cls 'Locate 1 , 1 : Lcd Druck Reset Tim2isrbit End If Goto Controlsequence ' ------------------------------------------------------------------------------ ' ----[D. Timer increment]------------------------------------------------------ ' ------------------------------------------------------------------------------ Tim2_isr: Set Tim2isrbit Timer2 = Timerstart 'Load Timer2 , Timer2reload Return ' ------------------------------------------------------------------------------ ' ----[E. Write the functions]-------------------------------------------------- ' ------------------------------------------------------------------------------ Function Pinterpolated(timein As Single) As Single Local A As Single Local B As Single Local Temp As Single Local Interpres As Single Local I As Integer Local Itemp As Integer Local Pressureindex As Integer '1. Look in the time array, for the index of the wanted time '----------------------------------------------------------- I = 1 Itemp = Dimensionlaw + 1 Do If Arraytime(i) > Timein Then Pressureindex = I - 1 I = Dimensionlaw + 10 End If Incr I Loop Until I > Itemp I = 1 '2. Compute the interpolation '---------------------------- ' Interpolation schema: ' p(t) = a * t + b ' with: ' ' t_i < t < t_i+1 ' ' p(t_i) - p(t_i+1) ' a = ----------------- ' t_i - t_i+1 ' ' t_i * p(t_i+1) - t_i+1 * p(t_i) ' b = ------------------------------- ' t_i - t_i+1 ' A = Arraypressure(pressureindex) - Arraypressure(pressureindex + 1) Temp = Arraytime(pressureindex) - Arraytime(pressureindex + 1) A = A / Temp 'a ' B = Arraytime(pressureindex) * Arraypressure(pressureindex + 1) Temp = Arraytime(pressureindex + 1) * Arraypressure(pressureindex) B = B - Temp Temp = Arraytime(pressureindex) - Arraytime(pressureindex + 1) B = B / Temp 'b ' Interpres = A * Timein Interpres = Interpres + B 'p(t) = a * t + b ' Pinterpolated = Interpres End Function ' ------------------------------------------------------------------------------ ' ----[F. Get the pressure from the sensor]------------------------------------- ' ------------------------------------------------------------------------------ Get_druck: Druckbuffer = 0 For N = 1 To 3 Druckbuffer = Druckbuffer + Getadc(7) Next N Druckbuffer = Druckbuffer / 3 'Take the average of 3 samples Druck = Druckbuffer Druck = Druck * Gainpressure 'Pressure in [mbar] Return ' ------------------------------------------------------------------------------ ' ----[G. PID controller]------------------------------------------------------- ' ------------------------------------------------------------------------------ Controller: '1. Get the actual pressure in the system '---------------------------------------- Gosub Get_druck '2. Increase the time: '--------------------- T = T + Intervaltime '3. Compute the control values: '------------------------------ '3.1 Scheduled pressure r(t): R = Pinterpolated(t) '3.2 Actual pressure y(t): Y = Druck '3.3 Error signal e(t-2), e(t-1) and e(t) E3 = E2 'e(t-2) E2 = E1 'e(t-1) E1 = R - Y 'e(t) '4. PID controller: '------------------ 'This is the discretization of the PID differential equation: ' du(t) de(t) 1 d^2e(t) ' ----- = K * ( ----- + ---- * e(t) + Td * ------- ) ' dt dt Ti dt^2 ' 'u(k) = ' Kd Kd Kd 'u(k-1) + e(k)*(Kp + Ki * T + ----) - e(k-1)*(Kp + 2 * ----) + e(k-2)*---- ' T T T '\---------------\/---------------/ \---------\/---------/ \----\/-----/ ' Part 1 Part 2 Part 3 '4.1 Part 1: 'Dim T1 As Single 'Dim T2 As Single 'Dim T3 As Single 'Dim T4 As Single 'Dim T5 As Single 'T1 = Ki '* Timesampling 'T2 = Kp + T1 'T3 = Kd '/ Timesampling 'T4 = T2 + T3 'T5 = E1 * T4 'Dim Ut1 As Single 'Ut1 = U + T5 ''4.2 Part 2 'Dim T6 As Single 'Dim T7 As Single 'Dim T8 As Single 'T6 = 2.0 * T3 'T7 = Kp + T6 'T8 = E2 * T7 'Dim Ut2 As Single 'Ut2 = Ut1 - T8 ''4.3 Part 3 'Dim T9 As Single 'T9 = E3 * T3 'Dim Ut3 As Single 'Ut3 = Ut2 + T9 'U = Ut1 '4. PID controller (2nd algorithgm) '------------------------------------------ 'This is the discretisation of the equation: ' de(t) 'u(t) = Kp * e(t) + Ki * Integral( e(n), dn, 0, t) + Kd * ----- ' dt ' 'u(k) = P(k) + I(k) + D(k) ' 'P(k) = Kp * e(k) ' 'I(k) = Ki * dT * e(k) + Ki * dT * e(k-1) ' 'D(k) = Kd * (e(k) - e(k-1))/dT ' '4.1 P(k) Dim Pk As Single Pk = Kp * E1 '4.2 I(k) Dim Ik As Single Dim T1 As Single Dim T2 As Single T1 = Timesampling * E1 T2 = T1 * Ki T1 = Timesampling * E2 Sumik = T1 * Ki Ik = T2 + Sumik '4.3 D(k) Dim Dk As Single Dim T3 As Single Dim T4 As Single T3 = E1 - E2 T4 = T3 / Timesampling Dk = Kd * T4 '4.4 U(k) Dim T5 As Single T5 = Ik + Dk U = Pk + T5 '5. Determine the direction of the motor: '---------------------------------------- If U > 0 Then Direction = 1 Elseif U < 0 Then Direction = 0 End If '6. Take the absolute value of U and limit it [-255,255] '------------------------------------------------------- U = Abs(u) If U > 255 Then U = 255 End If '7. Set the direction and motor speed '--------------------------------- Ocr0 = Round(u) Porta.3 = Direction '8. Send the actual pressure and time to LabView '----------------------------------------------- 'Print "Pressure" ; Y ; "Time" ; T '9. Stop condition '----------------- If T > Timeend Then '9.1 Increase the cycle counter Cyclecounter = Cyclecounter + 1 '9.2 Reset the programm if all the cycles are done: If Cyclecounter = Numbercycle Then '9.2.1 Stop the timer (stop the control) Stop Timer2 '9.2.2 Stop the motor Ocr0 = 0 Porta.3 = 0 '9.2.3 Send a stop message to labview: stop the import of the data Print "Stop" '9.2.4 Print the state on the LCD screend Cls Cursor Off Noblink Locate 1 , 1 : Lcd "Timer stopped" 'Set Stopbyte 'Print Stopbyte '9.2.5 Start the watchdog, to reset the program after 16ms Start Watchdog Waitms 200 Else '9.2.6 If all the cycles are not done, set time to 0 and keep going! T = 0 End If End If Return
