--- gcc/cpplib.h.orig Fri Sep 27 00:25:12 2002 +++ gcc/cpplib.h Tue Jan 6 16:29:25 2004 @@ -626,6 +626,7 @@ #define CPP_N_DECIMAL 0x0100 #define CPP_N_HEX 0x0200 #define CPP_N_OCTAL 0x0400 +#define CPP_N_BINARY 0x0800 #define CPP_N_UNSIGNED 0x1000 /* Properties. */ #define CPP_N_IMAGINARY 0x2000 --- gcc/cppexp.c.orig Sun Aug 3 17:58:06 2003 +++ gcc/cppexp.c Tue Jan 6 16:34:49 2004 @@ -22,6 +22,8 @@ #include "system.h" #include "cpplib.h" #include "cpphash.h" +#include "flags.h" +#include "toplev.h" #define PART_PRECISION (sizeof (cpp_num_part) * CHAR_BIT) #define HALF_MASK (~(cpp_num_part) 0 >> (PART_PRECISION / 2)) @@ -77,6 +79,8 @@ do { cpp_error (pfile, DL_ERROR, msgid); goto syntax_error; } while(0) #define SYNTAX_ERROR2(msgid, arg) \ do { cpp_error (pfile, DL_ERROR, msgid, arg); goto syntax_error; } while(0) +#define SYNTAX_ERROR3(msgid, arg1, arg2) \ + do { cpp_error (pfile, DL_ERROR, msgid, arg1, arg2); goto syntax_error; } while(0) /* Subroutine of cpp_classify_number. S points to a float suffix of length LEN, possibly zero. Returns 0 for an invalid suffix, or a @@ -178,6 +182,11 @@ radix = 16; str++; } + else if ((*str == 'b' || *str == 'B') && (str[1] == '0' || str[1] == '1')) + { + radix = 2; + str++; + } } /* Now scan for a well-formed integer or float. */ @@ -216,7 +225,8 @@ radix = 10; if (max_digit >= radix) - SYNTAX_ERROR2 ("invalid digit \"%c\" in octal constant", '0' + max_digit); + SYNTAX_ERROR3 ("invalid digit \"%c\" in %s constant", '0' + max_digit, + radix == 2? "binary": "octal"); if (float_flag != NOT_FLOAT) { @@ -293,11 +303,15 @@ if ((result & CPP_N_IMAGINARY) && CPP_PEDANTIC (pfile)) cpp_error (pfile, DL_PEDWARN, "imaginary constants are a GCC extension"); + if (radix == 2 && CPP_PEDANTIC (pfile)) + cpp_error (pfile, DL_PEDWARN, "binary constants are a GCC extension"); if (radix == 10) result |= CPP_N_DECIMAL; else if (radix == 16) result |= CPP_N_HEX; + else if (radix == 2) + result |= CPP_N_BINARY; else result |= CPP_N_OCTAL; @@ -348,6 +362,11 @@ else if ((type & CPP_N_RADIX) == CPP_N_HEX) { base = 16; + p += 2; + } + else if ((type & CPP_N_RADIX) == CPP_N_BINARY) + { + base = 2; p += 2; }
