source .gdbinit .gdbinit: No such file or directory. target remote localhost:3333 Remote debugging using localhost:3333 main () at main.c:21 21 PIO_PER = 0x00000038; /*enable uC pin (RXD1) as PIO */ monitor reset init ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 TRST/SRST error ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 error: -104 in procedure 'reset' monitor arm7_9 force_hw_breakpoints enable ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 Polling target failed, GDB will be halted. Polling again in 6300ms arm7_9 force_hw_breakpoints enable: command requires more arguments in procedure 'arm7_9' monitor arm7_9 fast_memory_access disable fast memory access is disabled symbol-file main.out Reading symbols from C:\arm_toolchain\OlimexODS\examples\led_on_off\main.out...done. monitor flash write_image erase unlock main.bin 0x00100000 auto erase enabled auto unlock enabled ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 failed erasing sectors 0 to 0 in procedure 'flash' monitor sleep 100 ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 Polling target failed, GDB will be halted. Polling again in 6300ms fast memory access is enabled monitor arm7_9 fast_memory_access enable ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 TRST/SRST error ftdi_write_data: usb bulk write failed couldn't write MPSSE commands to FT2232 error: -104 in procedure 'reset' monitor reset halt thbreak main Hardware assisted breakpoint 1 at 0x100300: file main.c, line 21. continue Continuing. stepi ignored. GDB will now fetch the register state from the target. Program received signal SIGINT, Interrupt. main () at main.c:21 21 PIO_PER = 0x00000038; /*enable uC pin (RXD1) as PIO */
