Version 4 SHEET 1 2784 1556 WIRE -80 800 -80 768 WIRE -80 912 -80 880 WIRE -64 0 -64 -32 WIRE -64 112 -64 80 WIRE -64 272 -64 240 WIRE -64 384 -64 352 WIRE -64 528 -64 496 WIRE -64 640 -64 608 WIRE -16 768 -80 768 WIRE 0 240 -64 240 WIRE 0 496 -64 496 WIRE 16 -32 -64 -32 WIRE 208 -32 160 -32 WIRE 320 -32 288 -32 WIRE 320 0 320 -32 WIRE 320 112 320 64 WIRE 400 -32 320 -32 WIRE 544 800 544 768 WIRE 544 912 544 880 WIRE 544 1008 544 976 WIRE 544 1120 544 1088 WIRE 560 0 560 -32 WIRE 560 112 560 80 WIRE 560 272 560 240 WIRE 560 384 560 352 WIRE 560 544 560 512 WIRE 560 656 560 624 WIRE 624 -32 560 -32 WIRE 624 240 560 240 WIRE 624 768 544 768 WIRE 624 976 544 976 WIRE 640 512 560 512 WIRE 1200 -64 1200 -96 WIRE 1200 48 1200 16 WIRE 1200 384 1200 352 WIRE 1200 496 1200 464 WIRE 1248 -96 1200 -96 WIRE 1248 352 1200 352 FLAG -64 112 0 FLAG 16 -32 1 FLAG 560 384 0 FLAG 624 240 ref IOPIN 624 240 Out FLAG 160 -32 1 IOPIN 160 -32 In FLAG 320 112 0 FLAG 400 -32 rc IOPIN 400 -32 Out FLAG -64 640 0 FLAG 0 496 refdb IOPIN 0 496 Out FLAG 560 112 0 FLAG 624 -32 refri IOPIN 624 -32 Out FLAG -80 912 0 FLAG -16 768 bfri IOPIN -16 768 Out FLAG -64 384 0 FLAG 0 240 refdb1 IOPIN 0 240 Out FLAG 544 1120 0 FLAG 624 976 bfri1 FLAG 560 656 0 FLAG 640 512 ref1 IOPIN 640 512 Out FLAG 544 912 0 FLAG 624 768 bfmag FLAG 1200 48 0 FLAG 1248 -96 100 IOPIN 1248 -96 Out FLAG 1200 496 0 FLAG 1248 352 200 IOPIN 1248 352 Out SYMBOL voltage -64 -16 R0 WINDOW 123 24 106 Left 0 WINDOW 39 0 0 Left 0 SYMATTR Value2 AC 1 SYMATTR InstName V1 SYMATTR Value "" SYMBOL res 544 256 R0 SYMATTR InstName Re SYMATTR Value 1k SYMBOL res 192 -16 R270 WINDOW 0 32 56 VTop 0 WINDOW 3 0 56 VBottom 0 SYMATTR InstName R1 SYMATTR Value 1k SYMBOL cap 304 0 R0 SYMATTR InstName C1 SYMATTR Value 80p SYMBOL res -80 512 R0 SYMATTR InstName Re1 SYMATTR Value 1k SYMBOL res 544 -16 R0 SYMATTR InstName Re2 SYMATTR Value 1k SYMBOL res -96 784 R0 SYMATTR InstName Re3 SYMATTR Value 1k SYMBOL res -80 256 R0 SYMATTR InstName Re4 SYMATTR Value 1k SYMBOL bv 544 992 R0 WINDOW 3 24 107 Left 0 SYMATTR InstName B1 SYMATTR Value V=V(1,0) R_I FREQ= (1e6, 0.793, -0.401) (2e6, 0.497, -0.5) (5e6, 0.137, -0.344) (10e6, 0.038, -0.191) SYMBOL Misc\\Epoly 560 528 R0 SYMATTR InstName E1 SYMATTR Value FREQ {V(1,0)}= MAG (1e6, 0.893, -26.7) (2e6, 0.705, -45.2) (5e6, 0.37, -68.3) (10e6, 0.195, -78.7) SYMBOL bv 544 784 R0 SYMATTR InstName B2 SYMATTR Value V=V(1,0) MAG FREQ=(1e6, 0.893, -26.7) (2e6, 0.705, -45.2) (5e6, 0.37, -68.3) (10e6, 0.195, -78.7) SYMBOL res 1184 -80 R0 SYMATTR InstName R2 SYMATTR Value 1 SYMBOL res 1184 368 R0 SYMATTR InstName R3 SYMATTR Value 1k TEXT 720 248 Left 0 !* MAG requires (freq, magnitude, degree)\nEfreq1 ref 0 FREQ {V(1,0)}= MAG\n+(1e6, 0.893, -26.7)\n+(2e6, 0.705, -45.2) \n+(5e6, 0.37, -68.3)\n+(10e6, 0.195, -78.7) TEXT -40 -184 Left 0 !.ac lin 10 1e6 10e6 TEXT 616 -584 Left 0 ;Spice lines can be imported from files as well.\n .include filename\nSimply write the netlist into a text file.\nThe only thing required are nodes with the\nsame name on your schematic if you want\ndirectly probe it there.\n \n* MAG requires (freq, magnitude, degree)\nEfreq1 ref 0 FREQ {V(1,0)}= MAG\n+(1e6, 0.893, -26.7)\n+(2e6, 0.705, -45.2) \n+(5e6, 0.37, -68.3)\n+(10e6, 0.195, -78.7) TEXT 112 512 Left 0 !* DB requires (freq, dB, degree)\nEfreq2 refdb 0 FREQ {V(1,0)}= DB\n+(1e6, -0.98, -27)\n+(2e6, -3, -45.2) \n+(5e6, -8.64, -68.3)\n+(10e6, -14.2, -78.7) TEXT -72 -632 Left 0 ;E and B Sources with FREQ-Tables\nHelmut Sennewald, V1.1\n \nThe G and Bi sources have the same syntax.\n \nExxx n1 n2 FREQ {}= [units] \n \nBxxx n1 n2 V= [units] Freq=\n \nPossible Units are MAG, DB, R_I, default is DB\n \n* default if none is DB \n* MAG requires (freq, magnitude, degree)\n* DB requires (freq, dB, degree)\n* R_I requires (freq,real, imag) TEXT 720 -24 Left 0 !* R_I requires (freq,real, imag)\nEfreq3 refri 0 FREQ {V(1,0)}= R_I\n+(1e6, 0.793, -0.401)\n+(2e6, 0.497, -0.5) \n+(5e6, 0.137, -0.344)\n+(10e6, 0.038, -0.191) TEXT 104 792 Left 0 !* R_I requires (freq,real, imag)\nBfreq1 bfri 0 V=V(1) R_I FREQ=\n+(1e6, 0.793, -0.401)\n+(2e6, 0.497, -0.5) \n+(5e6, 0.137, -0.344)\n+(10e6, 0.038, -0.191) TEXT 136 256 Left 0 !* Default requires (freq, dB, degree)\nEfreq20 refdb1 0 FREQ {V(1,0)}= \n+(1e6, -0.98, -27)\n+(2e6, -3, -45.2) \n+(5e6, -8.64, -68.3)\n+(10e6, -14.2, -78.7) TEXT 88 752 Left 0 ;Example with a B-source TEXT 632 304 Left 0 ;MAG TEXT 632 24 Left 0 ;R_I TEXT 24 568 Left 0 ;DB TEXT 16 296 Left 0 ;default TEXT 8 816 Left 0 ;R_I TEXT 624 568 Left 0 ;epoly.asy TEXT 616 1008 Left 0 ;bv.asy TEXT 176 -104 Left 0 ;RC-lowpass Fg=2MHz TEXT 616 808 Left 0 ;bv.asy TEXT 1184 -288 Left 0 !* (Freq, mag, deg)\nBi100 0 100 I=V(1,0) MAG FREQ=\n+ (1e6, 0.893, -26.7)\n+ (2e6, 0.705, -45.2)\n+ (5e6, 0.37, -68.3)\n+ (10e6, 0.195, -78.7) TEXT 616 848 Left 0 ;MAG TEXT 616 1064 Left 0 ;R_I TEXT 1184 -568 Left 0 ;This component can be placed\nin a file named "B100.mag".\n \nThe SPICE multi-line below \ncan then be replaced by\n \n.inc B100.mag TEXT 1184 160 Left 0 !* (Freq, mag, deg)\nBv200 200 0 V=V(1,0) MAG FREQ=\n+ (1e6, 0.893, -26.7)\n+ (2e6, 0.705, -45.2)\n+ (5e6, 0.37, -68.3)\n+ (10e6, 0.195, -78.7) TEXT 1184 120 Left 0 ;The same with a BV-source TEXT 1184 -352 Left 0 ;With a BI-source\nTake care of the output polarity. RECTANGLE Normal 1616 544 1152 -592
