  * @file    TIM/TIM9_OCToggle/stm32f10x_it.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main Interrupt Service Routines.
  *          This file provides template for all exceptions handler and peripherals
  *          interrupt service routine.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_it.h"
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup TIM9_OCToggle
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
uint16_t capture = 0;
extern __IO uint16_t CCR1Val;
extern __IO uint16_t CCR2Val;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/*            Cortex-M3 Processor Exceptions Handlers                         */
  * @brief  This function handles NMI exception.
  * @param  None
  * @retval None
void NMI_Handler(void)
  * @brief  This function handles Hard Fault exception.
  * @param  None
  * @retval None
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
  * @brief  This function handles Memory Manage exception.
  * @param  None
  * @retval None
void MemManage_Handler(void)
  /* Go to infinite loop when Memory Manage exception occurs */
  while (1)
  * @brief  This function handles Bus Fault exception.
  * @param  None
  * @retval None
void BusFault_Handler(void)
  /* Go to infinite loop when Bus Fault exception occurs */
  while (1)
  * @brief  This function handles Usage Fault exception.
  * @param  None
  * @retval None
void UsageFault_Handler(void)
  /* Go to infinite loop when Usage Fault exception occurs */
  while (1)
  * @brief  This function handles Debug Monitor exception.
  * @param  None
  * @retval None
void DebugMon_Handler(void)
  * @brief  This function handles SVCall exception.
  * @param  None
  * @retval None
void SVC_Handler(void)
  * @brief  This function handles PendSV_Handler exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
/*            STM32F10x Peripherals Interrupt Handlers                        */
  * @brief  This function handles TIM1 Break and TIM9 interrupts request.
  * @param  None
  * @retval None
void TIM1_BRK_TIM9_IRQHandler(void)
  /* TIM9_CH1 toggling with frequency = 366.2 Hz */
  if (TIM_GetITStatus(TIM9, TIM_IT_CC1) != RESET)
    TIM_ClearITPendingBit(TIM9, TIM_IT_CC1 );
    capture = TIM_GetCapture1(TIM9);
    TIM_SetCompare1(TIM9, capture + CCR1Val );
  /* TIM9_CH2 toggling with frequency = 732.4 Hz */
  if (TIM_GetITStatus(TIM9, TIM_IT_CC2) != RESET)
    TIM_ClearITPendingBit(TIM9, TIM_IT_CC2);
    capture = TIM_GetCapture2(TIM9);
    TIM_SetCompare2(TIM9, capture + CCR2Val);
/*  Add here the Interrupt Handler for the used peripheral(s) (PPP), for the  */
/*  available peripheral interrupt handler's name please refer to the startup */
/*  file (startup_stm32f10x_xx.s).                                            */
  * @brief  This function handles PPP interrupt request.
  * @param  None
  * @retval None
/*void PPP_IRQHandler(void)
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
