;****STK 500 LEDS und Switch demonstration .include "8515def.inc" .def Temp = r16 ; Temporaray register .def Delay = r17 ; Delay variabble 1 .def Delay2 = r18 ; Delay variable 2 ;****Initialization RESET: ser Temp out DDRB, Temp ;Set PORTB to output ;Test input/output LOOP: out PORTB, temp ;Update LEDS sbis PIND, 0x00 ;If (Port D, pin0 == 0) inc Temp ;then count LEDS one down sbis PIND, 0x01 ;If (Port D, pin1 == 0) dec Temp ;then count LEDS one up sbis PIND, 0x02 ;If (Port D, pin2 == 0) ror Temp ;then rotate LEDS one right sbis PIND, 0x03 ;If PortD, pin 3 == 0) rol Temp ;then rotate LEDS one left sbis PIND, 0x04 ;If Port D, pin 4 == 0) com Temp ;then invert all LEDS and add 1 sbis PIND, 0x06 ; If (Port d, pin6 == 0) swap Temp ;then swap nibbles of LEDS ;****Now wait a while to make LED change visible DLY: dec Delay brne DLY dec Delay 2 brne DLY rjmp LOOP ;repeat loop forever
