 *    MSP432 DriverLib - v2_20_00_08
 * --COPYRIGHT--,BSD,BSD
 * Copyright (c) 2014, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * --/COPYRIGHT--*/
// Forward declaration of the default fault handlers.
void ResetISR(void);
static void NmiSR(void);
static void FaultISR(void);
static void IntDefaultHandler(void);
// External declaration for the reset handler that is to be called when the
// processor is started
extern void _c_int00(void);
// Linker variable that marks the end of the stack.
extern unsigned long __STACK_END;
// External declarations for the interrupt handlers used by the application.
extern void comp_isr(void);
// The vector table.  Note that the proper constructs must be placed on this to
// ensure that it ends up at physical address 0x0000.0000 or at the start of
// the program if located at a start address other than 0.
#pragma DATA_SECTION(g_pfnVectors, ".intvecs")
void (* const g_pfnVectors[])(void) =
    (void (*)(void))((unsigned long)&__STACK_END),
                                            // The initial stack pointer
    ResetISR,                               // The reset handler
    NmiSR,                                  // The NMI handler
	FaultISR,                               // The hard fault handler, FaultISR
    IntDefaultHandler,                      // The MPU fault handler, IntDefaultHandler
    IntDefaultHandler,                      // The bus fault handler
    IntDefaultHandler,                      // The usage fault handler
    0,                                      // Reserved
    0,                                      // Reserved
    0,                                      // Reserved
    0,                                      // Reserved
    IntDefaultHandler,                      // SVCall handler
    IntDefaultHandler,                      // Debug monitor handler
    0,                                      // Reserved
    IntDefaultHandler,                      // The PendSV handler
    IntDefaultHandler,                      // The SysTick handler
    IntDefaultHandler,                      // PSS ISR
    IntDefaultHandler,                      // CS ISR
    IntDefaultHandler,                      // PCM ISR
    IntDefaultHandler,                      // WDT ISR
    IntDefaultHandler,                      // FPU ISR
    IntDefaultHandler,                      // FLCTL ISR
    comp_isr,                               // COMP_E0_MODULE ISR
    IntDefaultHandler,                      // COMP_E1_MODULE ISR
    IntDefaultHandler,                      // TA0_0 ISR
    IntDefaultHandler,                      // TA0_N ISR
    IntDefaultHandler,                      // TA1_0 ISR
    IntDefaultHandler,                      // TA1_N ISR
    IntDefaultHandler,                      // TA2_0 ISR
    IntDefaultHandler,                      // TA2_N ISR
    IntDefaultHandler,                      // TA3_0 ISR
    IntDefaultHandler,                      // TA3_N ISR
    IntDefaultHandler,                      // EUSCIA0 ISR
    IntDefaultHandler,                      // EUSCIA1 ISR
    IntDefaultHandler,                      // EUSCIA2 ISR
    IntDefaultHandler,                      // EUSCIA3 ISR
    IntDefaultHandler,                      // EUSCIB0 ISR
    IntDefaultHandler,                      // EUSCIB1 ISR
    IntDefaultHandler,                      // EUSCIB2 ISR
    IntDefaultHandler,                      // EUSCIB3 ISR
    IntDefaultHandler,                      // ADC12 ISR
    IntDefaultHandler,                      // T32_INT1 ISR
    IntDefaultHandler,                      // T32_INT2 ISR
    IntDefaultHandler,                      // T32_INTC ISR
    IntDefaultHandler,                      // AES ISR
    IntDefaultHandler,                      // RTC ISR
    IntDefaultHandler,                      // DMA_ERR ISR
    IntDefaultHandler,                      // DMA_INT3 ISR
    IntDefaultHandler,                      // DMA_INT2 ISR
    IntDefaultHandler,                      // DMA_INT1 ISR
    IntDefaultHandler,                      // DMA_INT0 ISR
    IntDefaultHandler,                      // PORT1 ISR
    IntDefaultHandler,                      // PORT2 ISR
    IntDefaultHandler,                      // PORT3 ISR
    IntDefaultHandler,                      // PORT4 ISR
    IntDefaultHandler,                      // PORT5 ISR
    IntDefaultHandler,                              // PORT6 ISR
    IntDefaultHandler,                      // Reserved 41
    IntDefaultHandler,                      // Reserved 42
    IntDefaultHandler,                      // Reserved 43
    IntDefaultHandler,                      // Reserved 44
    IntDefaultHandler,                      // Reserved 45
    IntDefaultHandler,                      // Reserved 46
    IntDefaultHandler,                      // Reserved 47
    IntDefaultHandler,                      // Reserved 48
    IntDefaultHandler,                      // Reserved 49
    IntDefaultHandler,                      // Reserved 50
    IntDefaultHandler,                      // Reserved 51
    IntDefaultHandler,                      // Reserved 52
    IntDefaultHandler,                      // Reserved 53
    IntDefaultHandler,                      // Reserved 54
    IntDefaultHandler,                      // Reserved 55
    IntDefaultHandler,                      // Reserved 56
    IntDefaultHandler,                      // Reserved 57
    IntDefaultHandler,                      // Reserved 58
    IntDefaultHandler,                      // Reserved 59
    IntDefaultHandler,                      // Reserved 60
    IntDefaultHandler,                      // Reserved 61
    IntDefaultHandler,                      // Reserved 62
    IntDefaultHandler,                      // Reserved 63
    IntDefaultHandler                       // Reserved 64
// This is the code that gets called when the processor first starts execution
// following a reset event.  Only the absolutely necessary set is performed,
// after which the application supplied entry() routine is called.  Any fancy
// actions (such as making decisions based on the reset cause register, and
// resetting the bits in that register) are left solely in the hands of the
// application.
void ResetISR(void)
    // Jump to the CCS C Initialization Routine.
    __asm("    .global _c_int00\n"
          "    b.w     _c_int00");
// This is the code that gets called when the processor receives a NMI.  This
// simply enters an infinite loop, preserving the system state for examination
// by a debugger.
    // Enter an infinite loop.
    while(1)
// This is the code that gets called when the processor receives a fault
// interrupt.  This simply enters an infinite loop, preserving the system state
// for examination by a debugger.
    while(1)
// This is the code that gets called when the processor receives an unexpected
    // Go into an infinite loop.
    while(1)
