<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="53" name="tPadExt" color="7" fill="1" visible="no" active="no"/>
<layer number="54" name="bPadExt" color="1" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="SMD-Form" color="7" fill="1" visible="yes" active="yes"/>
<layer number="102" name="FangPad" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="DIS-Form" color="7" fill="1" visible="yes" active="yes"/>
<layer number="110" name="ursprung" color="7" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="no" active="yes"/>
<layer number="231" name="Eagle3D_PG1" color="14" fill="1" visible="yes" active="yes"/>
<layer number="232" name="Eagle3D_PG2" color="14" fill="2" visible="yes" active="yes"/>
<layer number="233" name="Eagle3D_PG3" color="14" fill="4" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="tfbs_stecker+stifte">
<packages>
<package name="STIFT">
<wire x1="-1.27" y1="0.3302" x2="-1.27" y2="-0.3302" width="0.3048" layer="21"/>
<wire x1="-1.27" y1="-0.3302" x2="1.27" y2="-0.3302" width="0.3048" layer="21"/>
<wire x1="1.27" y1="-0.3302" x2="1.27" y2="0.3302" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0.3302" x2="-1.27" y2="0.3302" width="0.3048" layer="21"/>
<pad name="1" x="0" y="0" drill="1.3" diameter="1.905" shape="long"/>
<text x="-2.54" y="-2.2352" size="1.27" layer="25">&gt;name</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;value</text>
</package>
<package name="STIFT_KLEIN">
<pad name="P$1" x="0" y="0" drill="1.3" diameter="2.1844"/>
</package>
</packages>
<symbols>
<symbol name="BUCHSE">
<wire x1="-1.27" y1="1.27" x2="1.27" y2="-1.27" width="0" layer="23"/>
<wire x1="1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0" layer="23"/>
<wire x1="3.81" y1="1.27" x2="3.81" y2="-1.27" width="0.3048" layer="94" curve="180"/>
<wire x1="3.81" y1="1.27" x2="5.08" y2="1.27" width="0.3048" layer="94"/>
<wire x1="3.81" y1="-1.27" x2="5.08" y2="-1.27" width="0.3048" layer="94"/>
<text x="5.715" y="-0.635" size="1.27" layer="95">&gt;name</text>
<pin name="1" x="-5.08" y="0" visible="off"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="STIFT" prefix="BU" uservalue="yes">
<gates>
<gate name="G$1" symbol="BUCHSE" x="0" y="0"/>
</gates>
<devices>
<device name="DICK" package="STIFT">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="DÜNN" package="STIFT_KLEIN">
<connects>
<connect gate="G$1" pin="1" pad="P$1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="tfbs_passiv">
<packages>
<package name="E_10MM">
<wire x1="0" y1="0" x2="3.81" y2="0" width="0.254" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-2.54" width="0.254" layer="21"/>
<wire x1="3.81" y1="-2.54" x2="5.08" y2="-2.54" width="0.254" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.254" layer="21"/>
<wire x1="5.08" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="0" width="0.254" layer="21"/>
<wire x1="6.35" y1="0" x2="10.16" y2="0" width="0.254" layer="21"/>
<wire x1="6.35" y1="2.54" x2="6.35" y2="-2.54" width="0.254" layer="21"/>
<circle x="5.08" y="0" radius="6.35" width="0.127" layer="21"/>
<pad name="+" x="0" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="10.16" y="0" drill="0.8128" diameter="2.159"/>
<text x="2.4638" y="-8.3312" size="1.27" layer="27">&gt;VALUE</text>
<text x="2.4638" y="6.9088" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="E_5MM">
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-2.54" x2="0" y2="-2.54" width="0.254" layer="21"/>
<wire x1="0" y1="-2.54" x2="0" y2="2.54" width="0.254" layer="21"/>
<wire x1="0" y1="2.54" x2="-1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-2.54" width="0.254" layer="21"/>
<circle x="0" y="0" radius="4.016" width="0.127" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="2.159"/>
<text x="-3.8862" y="-5.7912" size="1.27" layer="27">&gt;VALUE</text>
<text x="-3.8862" y="4.3688" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="E_12,5MM">
<wire x1="0" y1="0" x2="5.08" y2="0" width="0.254" layer="21"/>
<wire x1="5.08" y1="0" x2="5.08" y2="-2.54" width="0.254" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="6.35" y2="-2.54" width="0.254" layer="21"/>
<wire x1="6.35" y1="-2.54" x2="6.35" y2="2.54" width="0.254" layer="21"/>
<wire x1="6.35" y1="2.54" x2="5.08" y2="2.54" width="0.254" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="0" width="0.254" layer="21"/>
<wire x1="7.62" y1="0" x2="12.7" y2="0" width="0.254" layer="21"/>
<wire x1="7.62" y1="2.54" x2="7.62" y2="-2.54" width="0.254" layer="21"/>
<pad name="-" x="12.7" y="0" drill="0.8128" diameter="2.159"/>
<text x="3.7338" y="3.0988" size="1.27" layer="25">&gt;NAME</text>
<text x="3.7338" y="-4.5212" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="E_25MM">
<wire x1="0" y1="0" x2="11.43" y2="0" width="0.254" layer="21"/>
<wire x1="11.43" y1="0" x2="11.43" y2="5.08" width="0.254" layer="21"/>
<wire x1="11.43" y1="5.08" x2="12.7" y2="5.08" width="0.254" layer="21"/>
<wire x1="12.7" y1="5.08" x2="12.7" y2="-5.08" width="0.254" layer="21"/>
<wire x1="12.7" y1="-5.08" x2="11.43" y2="-5.08" width="0.254" layer="21"/>
<wire x1="11.43" y1="-5.08" x2="11.43" y2="0" width="0.254" layer="21"/>
<wire x1="13.97" y1="5.08" x2="13.97" y2="0" width="0.254" layer="21"/>
<wire x1="13.97" y1="0" x2="25.4" y2="0" width="0.254" layer="21"/>
<wire x1="13.97" y1="0" x2="13.97" y2="-5.08" width="0.254" layer="21"/>
<pad name="-" x="25.4" y="0" drill="0.8128" diameter="2.54"/>
<pad name="+" x="0" y="0" drill="0.6096" diameter="2.54"/>
<text x="15.1638" y="3.0988" size="1.27" layer="25">&gt;NAME</text>
<text x="15.1638" y="1.1938" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="E_30MM">
<wire x1="0" y1="0" x2="13.97" y2="0" width="0.3048" layer="21"/>
<wire x1="31.75" y1="0" x2="16.51" y2="0" width="0.3048" layer="21"/>
<wire x1="13.97" y1="5.08" x2="15.24" y2="5.08" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.08" x2="15.24" y2="5.08" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.08" x2="13.97" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="13.97" y1="5.08" x2="13.97" y2="-5.08" width="0.3048" layer="21"/>
<wire x1="16.51" y1="5.08" x2="16.51" y2="-5.08" width="0.3048" layer="21"/>
<pad name="-" x="31.75" y="0" drill="0.6096" diameter="2.54"/>
<text x="17.78" y="2.54" size="1.27" layer="25">&gt;name</text>
<text x="17.78" y="0.635" size="1.27" layer="27">&gt;value</text>
</package>
<package name="E_35MM">
<wire x1="0" y1="0" x2="17.78" y2="0" width="0.3048" layer="21"/>
<wire x1="17.78" y1="0" x2="17.78" y2="7.62" width="0.3048" layer="21"/>
<wire x1="17.78" y1="7.62" x2="19.05" y2="7.62" width="0.3048" layer="21"/>
<wire x1="19.05" y1="-7.62" x2="19.05" y2="7.62" width="0.3048" layer="21"/>
<wire x1="19.05" y1="-7.62" x2="17.78" y2="-7.62" width="0.3048" layer="21"/>
<wire x1="17.78" y1="0" x2="17.78" y2="-7.62" width="0.3048" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.32" y2="0" width="0.3048" layer="21"/>
<wire x1="20.32" y1="0" x2="39.37" y2="0" width="0.3048" layer="21"/>
<wire x1="20.32" y1="0" x2="20.32" y2="-7.62" width="0.3048" layer="21"/>
<pad name="-" x="39.37" y="0" drill="0.6096" diameter="2.54"/>
<text x="22.86" y="5.08" size="1.27" layer="25">&gt;name</text>
<text x="22.86" y="2.54" size="1.27" layer="27">&gt;value</text>
</package>
<package name="E_45MM">
<wire x1="0" y1="0" x2="22.86" y2="0" width="0.3048" layer="21"/>
<wire x1="22.86" y1="8.89" x2="22.86" y2="0" width="0.3048" layer="21"/>
<wire x1="22.86" y1="8.89" x2="24.13" y2="8.89" width="0.3048" layer="21"/>
<wire x1="24.13" y1="-8.89" x2="24.13" y2="8.89" width="0.3048" layer="21"/>
<wire x1="24.13" y1="-8.89" x2="22.86" y2="-8.89" width="0.3048" layer="21"/>
<wire x1="22.86" y1="0" x2="22.86" y2="-8.89" width="0.3048" layer="21"/>
<wire x1="25.4" y1="8.89" x2="25.4" y2="0" width="0.3048" layer="21"/>
<wire x1="25.4" y1="0" x2="49.53" y2="0" width="0.3048" layer="21"/>
<wire x1="25.4" y1="0" x2="25.4" y2="-8.89" width="0.3048" layer="21"/>
<wire x1="49.53" y1="-0.635" x2="49.53" y2="0" width="0.3048" layer="21"/>
<wire x1="7.62" y1="10.16" x2="40.64" y2="10.16" width="0.127" layer="21"/>
<wire x1="40.64" y1="10.16" x2="40.64" y2="-10.16" width="0.127" layer="21"/>
<wire x1="7.62" y1="-10.16" x2="7.62" y2="10.16" width="0.127" layer="21"/>
<wire x1="7.62" y1="-10.16" x2="40.64" y2="-10.16" width="0.127" layer="21"/>
<pad name="-" x="49.53" y="0" drill="0.6096" diameter="2.54"/>
<text x="26.67" y="3.81" size="1.27" layer="25">&gt;name</text>
<text x="26.67" y="1.27" size="1.27" layer="27">&gt;value</text>
</package>
<package name="E_15MM">
<wire x1="6.35" y1="3.81" x2="7.62" y2="3.81" width="0.254" layer="21"/>
<wire x1="7.62" y1="3.81" x2="7.62" y2="-3.81" width="0.254" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="6.35" y2="-3.81" width="0.254" layer="21"/>
<wire x1="6.35" y1="-3.81" x2="6.35" y2="0" width="0.254" layer="21"/>
<wire x1="0" y1="0" x2="6.35" y2="0" width="0.254" layer="21"/>
<wire x1="6.35" y1="0" x2="6.35" y2="3.81" width="0.254" layer="21"/>
<wire x1="8.89" y1="3.81" x2="8.89" y2="0" width="0.254" layer="21"/>
<wire x1="8.89" y1="0" x2="15.24" y2="0" width="0.254" layer="21"/>
<wire x1="8.89" y1="0" x2="8.89" y2="-3.81" width="0.254" layer="21"/>
<pad name="-" x="15.24" y="0" drill="0.6096" diameter="2.54"/>
<text x="9.4234" y="1.1684" size="1.27" layer="25">&gt;NAME</text>
<text x="9.525" y="-1.905" size="1.27" layer="27">&gt;value</text>
</package>
<package name="E_10MM_GROß">
<wire x1="-5.08" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="5.08" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="1.27" y2="-2.54" width="0.254" layer="21"/>
<circle x="0" y="0" radius="17.8252" width="0.127" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8128" diameter="3.81"/>
<pad name="-" x="5.08" y="0" drill="0.8128" diameter="3.81"/>
<text x="-2.6162" y="-8.3312" size="1.27" layer="27">&gt;VALUE</text>
<text x="-2.6162" y="6.9088" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="E_2,5MM">
<wire x1="0" y1="-2.54" x2="1.27" y2="-2.54" width="0.254" layer="21"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="2.54" width="0.254" layer="21"/>
<wire x1="1.27" y1="2.54" x2="0" y2="2.54" width="0.254" layer="21"/>
<wire x1="0" y1="2.54" x2="0" y2="-2.54" width="0.254" layer="21"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="-2.54" width="0.254" layer="21"/>
<circle x="1.27" y="0" radius="4.016" width="0.127" layer="21"/>
<text x="-2.6162" y="-5.7912" size="1.27" layer="27">&gt;VALUE</text>
<text x="-2.6162" y="4.3688" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="C_2,5MM">
<wire x1="1.651" y1="-1.016" x2="1.651" y2="0" width="0.2032" layer="21"/>
<wire x1="2.54" y1="0" x2="1.651" y2="0" width="0.2032" layer="21"/>
<wire x1="1.651" y1="0" x2="1.651" y2="1.016" width="0.2032" layer="21"/>
<wire x1="0.889" y1="0" x2="0.889" y2="1.016" width="0.2032" layer="21"/>
<wire x1="0.889" y1="-1.0414" x2="0.889" y2="-0.0254" width="0.2032" layer="21"/>
<wire x1="0.889" y1="0" x2="0.0254" y2="0" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="0.8" diameter="1.6764"/>
<pad name="2" x="2.54" y="0" drill="0.8" diameter="1.6764"/>
<text x="-1.27" y="1.6002" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.8448" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="C_5MM">
<wire x1="0" y1="0" x2="1.905" y2="0" width="0.2032" layer="21"/>
<wire x1="1.905" y1="0" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="0" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="3.175" y2="0" width="0.2032" layer="21"/>
<wire x1="5.08" y1="0" x2="3.175" y2="0" width="0.2032" layer="21"/>
<wire x1="3.175" y1="0" x2="3.175" y2="1.27" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="0.8" diameter="2"/>
<pad name="2" x="5.08" y="0" drill="0.8" diameter="2"/>
<text x="0.635" y="1.5748" size="1.27" layer="25">&gt;NAME</text>
<text x="0.635" y="-2.8448" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="C_10MM">
<wire x1="0" y1="0" x2="4.445" y2="0" width="0.3048" layer="21"/>
<wire x1="4.445" y1="1.27" x2="4.445" y2="0" width="0.3048" layer="21"/>
<wire x1="5.715" y1="0" x2="10.16" y2="0" width="0.3048" layer="21"/>
<wire x1="4.445" y1="0" x2="4.445" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="5.715" y2="0" width="0.3048" layer="21"/>
<wire x1="5.715" y1="0" x2="5.715" y2="1.27" width="0.3048" layer="21"/>
<pad name="1" x="0" y="0" drill="0.8" diameter="2.54"/>
<pad name="2" x="10.16" y="0" drill="0.8" diameter="2.54"/>
<text x="3.0988" y="-3.2512" size="1.27" layer="27">&gt;VALUE</text>
<text x="3.0988" y="1.8288" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="C_12,5MM">
<wire x1="0" y1="0" x2="5.715" y2="0" width="0.3048" layer="21"/>
<wire x1="5.715" y1="1.27" x2="5.715" y2="0" width="0.3048" layer="21"/>
<wire x1="6.985" y1="0" x2="12.7" y2="0" width="0.3048" layer="21"/>
<wire x1="5.715" y1="0" x2="5.715" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="6.985" y2="0" width="0.3048" layer="21"/>
<wire x1="6.985" y1="0" x2="6.985" y2="1.27" width="0.3048" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.905" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="14.605" y2="-2.54" width="0.127" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="14.605" y2="2.54" width="0.127" layer="21"/>
<wire x1="14.605" y1="2.54" x2="-1.905" y2="2.54" width="0.127" layer="21"/>
<pad name="2" x="12.7" y="0" drill="0.8" diameter="2.54"/>
<text x="7.5438" y="0.5588" size="1.27" layer="25">&gt;NAME</text>
<text x="7.5438" y="-1.9812" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="C_15MM">
<wire x1="-7.62" y1="0" x2="-0.635" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="0" width="0.3048" layer="21"/>
<wire x1="0.635" y1="0" x2="7.62" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0.635" y2="0" width="0.3048" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="1.27" width="0.3048" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-9.525" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="9.525" y2="-2.54" width="0.127" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="9.525" y2="2.54" width="0.127" layer="21"/>
<wire x1="9.525" y1="2.54" x2="-9.525" y2="2.54" width="0.127" layer="21"/>
<pad name="2" x="7.62" y="0" drill="1" diameter="2.54"/>
<pad name="1" x="-7.62" y="0" drill="1" diameter="2.54"/>
<text x="1.1938" y="0.5588" size="1.27" layer="25">&gt;NAME</text>
<text x="1.1938" y="-1.9812" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="C_22,5MM">
<wire x1="-11.43" y1="0" x2="-0.635" y2="0" width="0.3048" layer="21"/>
<wire x1="0.635" y1="0" x2="11.43" y2="0" width="0.3048" layer="21"/>
<wire x1="-13.97" y1="3.81" x2="-13.97" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-13.97" y1="-3.81" x2="13.97" y2="-3.81" width="0.127" layer="21"/>
<wire x1="13.97" y1="-3.81" x2="13.97" y2="3.81" width="0.127" layer="21"/>
<wire x1="13.97" y1="3.81" x2="-13.97" y2="3.81" width="0.127" layer="21"/>
<pad name="2" x="11.43" y="0" drill="1" diameter="2.54"/>
<pad name="1" x="-11.43" y="0" drill="1" diameter="2.54"/>
</package>
<package name="C_27,5MM">
<wire x1="-13.97" y1="0" x2="-0.635" y2="0" width="0.3048" layer="21"/>
<wire x1="0.635" y1="0" x2="13.97" y2="0" width="0.3048" layer="21"/>
<wire x1="-16.51" y1="5.715" x2="-16.51" y2="-5.715" width="0.127" layer="21"/>
<wire x1="-16.51" y1="-5.715" x2="16.51" y2="-5.715" width="0.127" layer="21"/>
<wire x1="16.51" y1="-5.715" x2="16.51" y2="5.715" width="0.127" layer="21"/>
<wire x1="16.51" y1="5.715" x2="-16.51" y2="5.715" width="0.127" layer="21"/>
<pad name="2" x="13.97" y="0" drill="1" diameter="2.54"/>
<pad name="1" x="-13.97" y="0" drill="1" diameter="2.54"/>
</package>
<package name="C_37,5">
<wire x1="-19.05" y1="0" x2="-0.635" y2="0" width="0.3048" layer="21"/>
<wire x1="0.635" y1="0" x2="19.05" y2="0" width="0.3048" layer="21"/>
<wire x1="-21.59" y1="8.255" x2="-21.59" y2="-8.255" width="0.127" layer="21"/>
<wire x1="-21.59" y1="-8.255" x2="21.59" y2="-8.255" width="0.127" layer="21"/>
<wire x1="21.59" y1="-8.255" x2="21.59" y2="8.255" width="0.127" layer="21"/>
<wire x1="21.59" y1="8.255" x2="-21.59" y2="8.255" width="0.127" layer="21"/>
<pad name="2" x="19.05" y="0" drill="1" diameter="2.54"/>
<pad name="1" x="-19.05" y="0" drill="1" diameter="2.54"/>
</package>
<package name="C_37,5MM_BREIT">
<wire x1="-21.59" y1="17.145" x2="-21.59" y2="-17.145" width="0.127" layer="21"/>
<wire x1="-21.59" y1="-17.145" x2="21.59" y2="-17.145" width="0.127" layer="21"/>
<wire x1="21.59" y1="-17.145" x2="21.59" y2="17.145" width="0.127" layer="21"/>
<wire x1="21.59" y1="17.145" x2="-21.59" y2="17.145" width="0.127" layer="21"/>
</package>
<package name="R_7,5MM">
<wire x1="0" y1="0" x2="1.27" y2="0" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="6.35" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="6.35" y1="-1.27" x2="6.35" y2="0" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="6.35" y2="0" width="0.3048" layer="21"/>
<wire x1="6.35" y1="0" x2="6.35" y2="1.27" width="0.3048" layer="21"/>
<wire x1="6.35" y1="1.27" x2="1.27" y2="1.27" width="0.3048" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.3048" layer="21"/>
<pad name="2" x="7.62" y="0" drill="0.8" diameter="2.54"/>
<text x="1.27" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R_10MM">
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.3048" layer="21"/>
<wire x1="2.54" y1="0" x2="2.54" y2="1.27" width="0.3048" layer="21"/>
<wire x1="2.54" y1="1.27" x2="7.62" y2="1.27" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="1.27" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="10.16" y2="0" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="2.54" y1="-1.27" x2="7.62" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="2.54" y1="-1.27" x2="2.54" y2="0" width="0.3048" layer="21"/>
<text x="3.175" y="-0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R_15MM">
<wire x1="1.27" y1="0" x2="1.27" y2="1.27" width="0.3048" layer="21"/>
<wire x1="1.27" y1="1.27" x2="13.97" y2="1.27" width="0.3048" layer="21"/>
<wire x1="13.97" y1="1.27" x2="13.97" y2="0" width="0.3048" layer="21"/>
<wire x1="13.97" y1="-1.27" x2="1.27" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="13.97" y1="0" x2="15.24" y2="0" width="0.3048" layer="21"/>
<wire x1="13.97" y1="0" x2="13.97" y2="-1.27" width="0.3048" layer="21"/>
<pad name="1" x="0" y="0" drill="1" diameter="2.54"/>
<pad name="2" x="15.24" y="0" drill="1" diameter="2.54"/>
<text x="2.54" y="-0.635" size="1.27" layer="25">&gt;name</text>
<text x="2.54" y="-3.175" size="1.27" layer="27">&gt;value</text>
</package>
<package name="R_25MM">
<wire x1="1.27" y1="0" x2="1.27" y2="3.175" width="0.3048" layer="21"/>
<wire x1="1.27" y1="3.175" x2="24.13" y2="3.175" width="0.3048" layer="21"/>
<wire x1="24.13" y1="3.175" x2="24.13" y2="0" width="0.3048" layer="21"/>
<wire x1="24.13" y1="-3.175" x2="1.27" y2="-3.175" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-3.175" width="0.3048" layer="21"/>
<wire x1="24.13" y1="0" x2="25.4" y2="0" width="0.3048" layer="21"/>
<wire x1="24.13" y1="0" x2="24.13" y2="-3.175" width="0.3048" layer="21"/>
<pad name="2" x="25.4" y="0" drill="1" diameter="2.54"/>
<text x="9.525" y="0.635" size="1.27" layer="25">&gt;name</text>
<text x="8.89" y="-1.905" size="1.27" layer="27">&gt;value</text>
</package>
<package name="D_7,5MM">
<wire x1="7.61" y1="0" x2="4.44" y2="0" width="0.3048" layer="21"/>
<wire x1="4.44" y1="-0.64" x2="4.44" y2="0" width="0.3048" layer="21"/>
<wire x1="4.44" y1="0" x2="2.845" y2="-0.64" width="0.3048" layer="21"/>
<wire x1="2.845" y1="-0.64" x2="2.845" y2="0.64" width="0.3048" layer="21"/>
<wire x1="2.845" y1="0.64" x2="4.44" y2="0" width="0.3048" layer="21"/>
<wire x1="4.44" y1="0" x2="-0.01" y2="0" width="0.3048" layer="21"/>
<wire x1="4.44" y1="0" x2="4.44" y2="0.64" width="0.3048" layer="21"/>
<wire x1="1.93" y1="-0.945" x2="1.93" y2="0.945" width="0.127" layer="21"/>
<wire x1="1.93" y1="0.945" x2="5.71" y2="0.945" width="0.127" layer="21"/>
<wire x1="5.71" y1="0.945" x2="5.71" y2="-0.945" width="0.127" layer="21"/>
<wire x1="5.71" y1="-0.945" x2="1.93" y2="-0.945" width="0.127" layer="21"/>
<pad name="K" x="7.61" y="0" drill="0.8" diameter="1.9304" rot="R180"/>
<pad name="A" x="-0.01" y="0" drill="0.8" diameter="1.9304" rot="R180"/>
<text x="-0.0662" y="-3.2512" size="1.27" layer="27">&gt;VALUE</text>
<text x="-0.0662" y="1.8288" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="D_12,5MM">
<wire x1="-1.27" y1="0" x2="3.81" y2="0" width="0.3048" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="1.27" width="0.3048" layer="21"/>
<wire x1="3.81" y1="1.27" x2="6.35" y2="0" width="0.3048" layer="21"/>
<wire x1="6.35" y1="0" x2="3.81" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="3.81" y1="-1.27" x2="3.81" y2="0" width="0.3048" layer="21"/>
<wire x1="6.35" y1="1.27" x2="6.35" y2="0" width="0.3048" layer="21"/>
<wire x1="6.35" y1="0" x2="6.35" y2="-1.27" width="0.3048" layer="21"/>
<wire x1="6.35" y1="0" x2="11.43" y2="0" width="0.3048" layer="21"/>
<wire x1="2.54" y1="1.6404" x2="7.62" y2="1.6404" width="0.127" layer="21"/>
<wire x1="7.62" y1="1.6404" x2="7.62" y2="-1.6668" width="0.127" layer="21"/>
<wire x1="7.62" y1="-1.6668" x2="2.54" y2="-1.6668" width="0.127" layer="21"/>
<wire x1="2.54" y1="-1.6668" x2="2.54" y2="1.6404" width="0.127" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="1.3" diameter="2.54"/>
<pad name="K" x="11.43" y="0" drill="1.3" diameter="2.54"/>
<text x="2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="TO-220">
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.254" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="-5.08" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-1.27" x2="-5.08" y2="1.905" width="0.254" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="1.905" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="5.08" y2="1.905" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="2.54" width="0.254" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.27" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.2" diameter="2.1844"/>
<pad name="2" x="2.54" y="0" drill="1.2" diameter="2.1844"/>
<text x="-2.54" y="0" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="ELKO">
<wire x1="1.27" y1="2.54" x2="1.27" y2="0" width="0.3048" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-2.54" width="0.3048" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="0" width="0.3048" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-2.54" width="0.3048" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="0" y2="-2.54" width="0.3048" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="2.54" width="0.3048" layer="94"/>
<wire x1="0" y1="2.54" x2="-1.27" y2="2.54" width="0.3048" layer="94"/>
<text x="-2.6416" y="3.0734" size="1.27" layer="95">&gt;NAME</text>
<text x="-2.6416" y="-4.5466" size="1.27" layer="27">&gt;VALUE</text>
<text x="-2.54" y="-5.08" size="1.27" layer="96">&gt;VALUE</text>
<pin name="+" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="-" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="C">
<wire x1="0.635" y1="2.54" x2="0.635" y2="0" width="0.3048" layer="94"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-2.54" width="0.3048" layer="94"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="0" width="0.3048" layer="94"/>
<wire x1="-2.54" y1="0" x2="-0.635" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-2.54" width="0.3048" layer="94"/>
<text x="-2.6416" y="-4.5466" size="1.27" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="R">
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="-1.27" width="0.3048" layer="94"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.3048" layer="94"/>
<wire x1="2.54" y1="-1.27" x2="2.54" y2="1.27" width="0.3048" layer="94"/>
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.3048" layer="94"/>
<text x="-2.6416" y="1.8034" size="1.27" layer="95">&gt;NAME</text>
<text x="-2.6416" y="-3.2766" size="1.27" layer="27">&gt;VALUE</text>
<text x="-2.6416" y="-3.2766" size="1.27" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="DIODE">
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.3048" layer="94"/>
<wire x1="0" y1="-1.27" x2="2.54" y2="0" width="0.3048" layer="94"/>
<wire x1="2.54" y1="0" x2="0" y2="1.27" width="0.3048" layer="94"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="0" width="0.3048" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-1.27" width="0.3048" layer="94"/>
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-1.27" width="0.3048" layer="94"/>
<text x="-1.3716" y="1.8034" size="1.27" layer="95">&gt;NAME</text>
<text x="-1.3716" y="-3.2766" size="1.27" layer="27">&gt;VALUE</text>
<text x="-1.27" y="-3.81" size="1.27" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="K" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ELKO" prefix="C" uservalue="yes">
<gates>
<gate name="G$1" symbol="ELKO" x="0" y="0"/>
</gates>
<devices>
<device name="10MM" package="E_10MM">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<technologies>
</technologies>
</device>
<device name="5MM" package="E_5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="12,5MM" package="E_12,5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="25MM" package="E_25MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="30MM" package="E_30MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="35MM" package="E_35MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="45MM" package="E_45MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15MM" package="E_15MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10MM_GROß" package="E_10MM_GROß">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2,5MM" package="E_2,5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="KONDENSATOR" prefix="C" uservalue="yes">
<gates>
<gate name="G$1" symbol="C" x="0" y="0"/>
</gates>
<devices>
<device name="2,5MM" package="C_2,5MM">
<connects>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="5MM" package="C_5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10MM" package="C_10MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="12,5MM" package="C_12,5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15MM" package="C_15MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22,5MM" package="C_22,5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27,5MM" package="C_27,5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37,5MM" package="C_37,5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37,5MM_BREIT" package="C_37,5MM_BREIT">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="WIDERSTAND" prefix="R" uservalue="yes">
<gates>
<gate name="G$1" symbol="R" x="0" y="0"/>
</gates>
<devices>
<device name="7,5MM" package="R_7,5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10MM" package="R_10MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15MM" package="R_15MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="25MM" package="R_25MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE" prefix="D" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIODE" x="0" y="0"/>
</gates>
<devices>
<device name="7,5MM" package="D_7,5MM">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="K" pad="K"/>
</connects>
<technologies>
</technologies>
</device>
<device name="12,5MM" package="D_12,5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO-220" package="TO-220">
<connects>
<connect gate="G$1" pin="A" pad="2"/>
<connect gate="G$1" pin="K" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="tfbs_kt_projekte">
<packages>
<package name="SO08">
<description>&lt;b&gt;Small Outline IC&lt;/b&gt;</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
<package name="TO220">
<description>&lt;b&gt;&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.2" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.2" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.2" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<pad name="1" x="-2.54" y="0" drill="1.2" diameter="2.0066"/>
<pad name="2" x="0" y="0" drill="1.2" diameter="2.0066"/>
<pad name="3" x="2.54" y="0" drill="1.2" diameter="2.0066"/>
</package>
<package name="TO-220_HV">
<wire x1="5.08" y1="-1.27" x2="1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-5.08" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-3.81" width="0.127" layer="21"/>
<wire x1="1.27" y1="-3.81" x2="1.27" y2="-1.27" width="0.127" layer="21"/>
<pad name="2" x="0" y="-2.54" drill="1.2" diameter="2.1844"/>
<pad name="3" x="2.54" y="0" drill="1.2" diameter="2.1844"/>
<text x="-3.175" y="3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DPAK">
<description>3-lead &lt;b&gt;SMD PACKAGE&lt;/b&gt;</description>
<wire x1="3.1496" y1="-3.0226" x2="3.1496" y2="2.9718" width="0.1524" layer="21"/>
<wire x1="-3.2004" y1="2.9718" x2="-3.2004" y2="-3.0226" width="0.1524" layer="21"/>
<wire x1="-1.7272" y1="3.5306" x2="1.7018" y2="3.5306" width="1.016" layer="51"/>
<wire x1="-3.2004" y1="2.9718" x2="-2.4638" y2="2.9718" width="0.1524" layer="21"/>
<wire x1="3.1496" y1="2.9718" x2="2.4638" y2="2.9718" width="0.1524" layer="21"/>
<wire x1="2.4638" y1="2.9718" x2="-2.4638" y2="2.9718" width="0.1524" layer="51"/>
<wire x1="3.1496" y1="-3.0226" x2="-3.2004" y2="-3.0226" width="0.1524" layer="21"/>
<smd name="4" x="0" y="3.3528" dx="4.826" dy="4.191" layer="1"/>
<smd name="3" x="2.2098" y="-4.9276" dx="1.6002" dy="2.9972" layer="1"/>
<smd name="1" x="-2.2606" y="-4.9276" dx="1.6002" dy="2.9972" layer="1"/>
<text x="-2.54" y="-0.508" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.413" y="-2.8448" size="0.6096" layer="51">1</text>
<text x="-0.2032" y="-2.8448" size="0.6096" layer="51">2</text>
<text x="1.9812" y="-2.8448" size="0.6096" layer="51">3</text>
<text x="-0.3302" y="2.159" size="0.6096" layer="51">4</text>
<rectangle x1="-2.6416" y1="-5.7404" x2="-1.8796" y2="-3.0734" layer="51"/>
<rectangle x1="1.8288" y1="-5.7404" x2="2.5908" y2="-3.0734" layer="51"/>
<rectangle x1="-0.381" y1="-3.8354" x2="0.381" y2="-3.0734" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="LTC1624">
<wire x1="10.16" y1="10.16" x2="10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="10.16" y1="-10.16" x2="-10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-10.16" x2="-10.16" y2="10.16" width="0.254" layer="94"/>
<wire x1="-10.16" y1="10.16" x2="10.16" y2="10.16" width="0.254" layer="94"/>
<pin name="SENS-" x="-15.24" y="7.62" length="middle"/>
<pin name="ITH" x="-15.24" y="2.54" length="middle"/>
<pin name="FB" x="-15.24" y="-2.54" length="middle"/>
<pin name="GND" x="-15.24" y="-7.62" length="middle" direction="pwr"/>
<pin name="SW" x="15.24" y="-7.62" length="middle" rot="R180"/>
<pin name="TG" x="15.24" y="-2.54" length="middle" rot="R180"/>
<pin name="BOOST" x="15.24" y="2.54" length="middle" rot="R180"/>
<pin name="VIN" x="15.24" y="7.62" length="middle" direction="in" rot="R180"/>
</symbol>
<symbol name="IGFET-EN-GDS">
<wire x1="-2.54" y1="-2.54" x2="-1.2192" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="0.762" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-0.762" width="0.254" layer="94"/>
<wire x1="0" y1="3.683" x2="0" y2="1.397" width="0.254" layer="94"/>
<wire x1="1.905" y1="0.635" x2="0.635" y2="0" width="0.254" layer="94"/>
<wire x1="1.905" y1="-0.635" x2="0.635" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0.635" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.397" x2="0" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.143" y1="2.54" x2="-1.143" y2="-2.54" width="0.254" layer="94"/>
<text x="-6.35" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<text x="-6.35" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<pin name="D" x="5.08" y="2.54" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="S" x="5.08" y="-2.54" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="G" x="-5.08" y="-2.54" visible="off" length="short" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LTC1624" prefix="IC">
<gates>
<gate name="G$1" symbol="LTC1624" x="0" y="0"/>
</gates>
<devices>
<device name="S8" package="SO08">
<connects>
<connect gate="G$1" pin="BOOST" pad="7"/>
<connect gate="G$1" pin="FB" pad="3"/>
<connect gate="G$1" pin="GND" pad="4"/>
<connect gate="G$1" pin="ITH" pad="2"/>
<connect gate="G$1" pin="SENS-" pad="1"/>
<connect gate="G$1" pin="SW" pad="5"/>
<connect gate="G$1" pin="TG" pad="6"/>
<connect gate="G$1" pin="VIN" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="IRF510" prefix="Q" uservalue="yes">
<description>&lt;b&gt;N-Channel Enhancement MOSFET&lt;/b&gt; (HEXFET); 100V; 5,6A; 0,54Ohm</description>
<gates>
<gate name="G$1" symbol="IGFET-EN-GDS" x="0" y="0"/>
</gates>
<devices>
<device name="LIEGEND" package="TO220">
<connects>
<connect gate="G$1" pin="D" pad="2"/>
<connect gate="G$1" pin="G" pad="1"/>
<connect gate="G$1" pin="S" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="STEHEND" package="TO-220">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="HV" package="TO-220_HV">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DPAK" package="DPAK">
<connects>
<connect gate="G$1" pin="D" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="tfbs_versorg">
<packages>
</packages>
<symbols>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="VCC">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="VCC" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" prefix="GND">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="*">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="VCC" prefix="P+">
<gates>
<gate name="VCC" symbol="VCC" x="0" y="0"/>
</gates>
<devices>
<device name="*">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="wuerth-elektronik">
<description>&lt;BR&gt;WE eiSos -- EMC &amp; Inductive Solutions&lt;br&gt;&lt;Hr&gt;
&lt;BR&gt;&lt;BR&gt;
&lt;TABLE BORDER=0 CELLSPACING=0 CELLPADDING=0&gt;
&lt;TR&gt;
&lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;&lt;BR&gt;&lt;br&gt;
      &amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; &amp;nbsp;&lt;BR&gt;
       &lt;BR&gt;
       &lt;BR&gt;
       &lt;BR&gt;&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
&lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;&lt;br&gt;
      -----&lt;BR&gt;
      -----&lt;BR&gt;
      -----&lt;BR&gt;
      -----&lt;BR&gt;
      -----&lt;BR&gt;&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt; &lt;FONT FACE=ARIAL SIZE=3&gt;&lt;br&gt;
      ---------------------------&lt;BR&gt;
&lt;B&gt;&lt;I&gt;&lt;span style='font-size:26pt;
  color:#FF6600;'&gt;WE &lt;/span&gt;&lt;/i&gt;&lt;/b&gt;
&lt;BR&gt;
      ---------------------------&lt;BR&gt;&lt;b&gt;Würth Elektronik&lt;/b&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ---------O---&lt;BR&gt;
      ----O--------&lt;BR&gt;
      ---------O---&lt;BR&gt;&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
       &lt;BR&gt;
       &lt;BR&gt;
       &lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;B&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;More than you expect&lt;BR&gt;&lt;BR&gt;&lt;BR&gt;&lt;/B&gt;
&lt;HR&gt;&lt;BR&gt;
&lt;b&gt;Würth Elektronik eiSos GmbH &amp; Co. KG&lt;/b&gt;&lt;br&gt;
Max-Eyth-Str.1&lt;br&gt;
D-74638 Waldenburg&lt;br&gt;
&lt;br&gt;
Tel: +49 (0)7942-945-0&lt;br&gt;
Fax:+49 (0)7942-945-400&lt;br&gt;
&lt;br&gt;
&lt;a href="http://www.we-online.com"&gt;http://www.we-online.com&lt;/a&gt;&lt;br&gt;
&lt;a href="mailto:eisos@we-online.de"&gt;eisos@we-online.de&lt;/a&gt; &lt;BR&gt;&lt;BR&gt;
&lt;br&gt;&lt;HR&gt;&lt;BR&gt;
Neither CadSoft nor WE-eiSos does warrant that this library is error-free or &lt;br&gt;
that it meets your specific requirements.&lt;br&gt;&lt;BR&gt;
Please contact us for more information.&lt;br&gt;&lt;BR&gt;&lt;br&gt;
&lt;hr&gt;
Version 4,   July 12th 2005
&lt;HR&gt;
Copyright: Würth Elektronik eiSos</description>
<packages>
<package name="WE-PD_L/XL/XXL">
<description>SMD-Shielded Power Inductor</description>
<wire x1="4.95" y1="0" x2="-4.95" y2="0" width="0.3048" layer="51"/>
<wire x1="-6" y1="-6" x2="6" y2="-6" width="0.127" layer="21"/>
<wire x1="6" y1="-6" x2="6" y2="6" width="0.127" layer="51"/>
<wire x1="6" y1="6" x2="-6" y2="6" width="0.127" layer="21"/>
<wire x1="-6" y1="6" x2="-6" y2="-6" width="0.127" layer="51"/>
<smd name="1" x="-4.95" y="0" dx="5.4" dy="2.9" layer="1" rot="R90"/>
<smd name="2" x="4.95" y="0" dx="5.4" dy="2.9" layer="1" rot="R90"/>
<text x="-3.81" y="-7.62" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="6.35" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5" y1="-1.3" x2="0.5" y2="1.3" layer="21" rot="R90"/>
</package>
<package name="WE-PD_S/M">
<wire x1="-3.2" y1="0" x2="3.2" y2="0" width="0.127" layer="51"/>
<wire x1="-3.65" y1="-3.65" x2="3.65" y2="-3.65" width="0.127" layer="21"/>
<wire x1="3.65" y1="-3.65" x2="3.65" y2="3.65" width="0.127" layer="51"/>
<wire x1="3.65" y1="3.65" x2="-3.65" y2="3.65" width="0.127" layer="21"/>
<wire x1="-3.65" y1="3.65" x2="-3.65" y2="-3.65" width="0.127" layer="51"/>
<smd name="1" x="-3.2" y="0" dx="2.2" dy="1.6" layer="1" rot="R90"/>
<smd name="2" x="3.2" y="0" dx="2.2" dy="1.6" layer="1" rot="R90"/>
<text x="-3.175" y="3.81" size="1.27" layer="27">&gt;VALUE</text>
<text x="-3.175" y="-5.08" size="1.27" layer="25">&gt;NAME</text>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="21" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="-L">
<text x="-3.81" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-1.27" y1="-2.54" x2="1.27" y2="2.54" layer="94" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="WE-PD" prefix="L" uservalue="yes">
<description>SMD-Shielded Power Inductors WE-PD
Is recommended for the application with switching
regulators from National Semiconductor, Linear Technology,
Texas Instruments and Fairchild Semiconductor
- Magnetically shielded version which results in a low leakage field
- High storage capacity
- Low self-losses
-- Switching regulators with low operating voltages
  (computer, laptop, mobile phones, pagers)
-- Integrated DC/DC-converter</description>
<gates>
<gate name="G$1" symbol="-L" x="0" y="0"/>
</gates>
<devices>
<device name="_L/XL/XXL" package="WE-PD_L/XL/XXL">
<connects>
<connect gate="G$1" pin="1" pad="2"/>
<connect gate="G$1" pin="2" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_S/M" package="WE-PD_S/M">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="sch_smd">
<packages>
<package name="1206">
<wire x1="-0.9144" y1="0.9144" x2="0.9144" y2="0.9144" width="0.3048" layer="21"/>
<wire x1="0.9144" y1="0.9144" x2="0.9144" y2="-0.9144" width="0.3048" layer="21"/>
<wire x1="0.9144" y1="-0.9144" x2="-0.9144" y2="-0.9144" width="0.3048" layer="21"/>
<wire x1="-0.9144" y1="-0.9144" x2="-0.9144" y2="0.9144" width="0.3048" layer="21"/>
<smd name="P$204" x="1.7272" y="-0.0508" dx="1.7018" dy="1.905" layer="1"/>
<smd name="P$205" x="-1.7272" y="0" dx="1.7018" dy="1.905" layer="1"/>
<text x="-2.54" y="1.2446" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.5654" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="0805">
<wire x1="-0.635" y1="0.635" x2="0.635" y2="0.635" width="0.3048" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.635" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="-0.635" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="-0.635" y2="0.635" width="0.3048" layer="21"/>
<smd name="1" x="1.1938" y="0" dx="1.397" dy="1.6002" layer="1"/>
<smd name="2" x="-1.1938" y="0" dx="1.397" dy="1.6002" layer="1"/>
<text x="-1.8542" y="0.9906" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.8796" y="-2.3622" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="R">
<text x="-2.54" y="-3.81" size="1.27" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="C">
</symbol>
</symbols>
<devicesets>
<deviceset name="R_1206" prefix="R" uservalue="yes">
<gates>
</gates>
<devices>
<device name="" package="1206">
<connects>
<connect gate="G$1" pin="1" pad="P$204"/>
<connect gate="G$1" pin="2" pad="P$205"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C_0805" prefix="C" uservalue="yes">
<gates>
</gates>
<devices>
<device name="" package="0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="frames">
<description>&lt;b&gt;Frames for Sheet and Layout&lt;/b&gt;</description>
<packages>
</packages>
<symbols>
<symbol name="DINA4_L">
<frame x1="0" y1="0" x2="264.16" y2="180.34" columns="4" rows="4" layer="94" border-left="no" border-top="no" border-right="no" border-bottom="no"/>
</symbol>
<symbol name="DOCFIELD">
<wire x1="0" y1="0" x2="71.12" y2="0" width="0.1016" layer="94"/>
<wire x1="101.6" y1="15.24" x2="87.63" y2="15.24" width="0.1016" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="5.08" width="0.1016" layer="94"/>
<wire x1="0" y1="5.08" x2="71.12" y2="5.08" width="0.1016" layer="94"/>
<wire x1="0" y1="5.08" x2="0" y2="15.24" width="0.1016" layer="94"/>
<wire x1="101.6" y1="15.24" x2="101.6" y2="5.08" width="0.1016" layer="94"/>
<wire x1="71.12" y1="5.08" x2="71.12" y2="0" width="0.1016" layer="94"/>
<wire x1="71.12" y1="5.08" x2="87.63" y2="5.08" width="0.1016" layer="94"/>
<wire x1="71.12" y1="0" x2="101.6" y2="0" width="0.1016" layer="94"/>
<wire x1="87.63" y1="15.24" x2="87.63" y2="5.08" width="0.1016" layer="94"/>
<wire x1="87.63" y1="15.24" x2="0" y2="15.24" width="0.1016" layer="94"/>
<wire x1="87.63" y1="5.08" x2="101.6" y2="5.08" width="0.1016" layer="94"/>
<wire x1="101.6" y1="5.08" x2="101.6" y2="0" width="0.1016" layer="94"/>
<wire x1="0" y1="15.24" x2="0" y2="22.86" width="0.1016" layer="94"/>
<wire x1="101.6" y1="35.56" x2="0" y2="35.56" width="0.1016" layer="94"/>
<wire x1="101.6" y1="35.56" x2="101.6" y2="22.86" width="0.1016" layer="94"/>
<wire x1="0" y1="22.86" x2="101.6" y2="22.86" width="0.1016" layer="94"/>
<wire x1="0" y1="22.86" x2="0" y2="35.56" width="0.1016" layer="94"/>
<wire x1="101.6" y1="22.86" x2="101.6" y2="15.24" width="0.1016" layer="94"/>
<text x="1.27" y="1.27" size="2.54" layer="94" font="vector">Date:</text>
<text x="12.7" y="1.27" size="2.54" layer="94" font="vector">&gt;LAST_DATE_TIME</text>
<text x="72.39" y="1.27" size="2.54" layer="94" font="vector">Sheet:</text>
<text x="86.36" y="1.27" size="2.54" layer="94" font="vector">&gt;SHEET</text>
<text x="88.9" y="11.43" size="2.54" layer="94" font="vector">REV:</text>
<text x="1.27" y="19.05" size="2.54" layer="94" font="vector">TITLE:</text>
<text x="1.27" y="11.43" size="2.54" layer="94" font="vector">Document Number:</text>
<text x="17.78" y="19.05" size="2.54" layer="94" font="vector">&gt;DRAWING_NAME</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="DINA4_L" prefix="FRAME" uservalue="yes">
<description>&lt;b&gt;FRAME&lt;/b&gt;&lt;p&gt;
DIN A4, landscape with extra doc field</description>
<gates>
<gate name="G$1" symbol="DINA4_L" x="0" y="0"/>
<gate name="G$2" symbol="DOCFIELD" x="162.56" y="0" addlevel="must"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="C1" library="tfbs_passiv" deviceset="ELKO" device="5MM" value="100µ"/>
<part name="C2" library="tfbs_passiv" deviceset="ELKO" device="5MM" value="1000µ"/>
<part name="GND2" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND6" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="L1" library="wuerth-elektronik" deviceset="WE-PD" device="_L/XL/XXL"/>
<part name="C4" library="sch_smd" deviceset="C_0805" device="" value="1n"/>
<part name="FRAME1" library="frames" deviceset="DINA4_L" device=""/>
<part name="IC1" library="tfbs_kt_projekte" deviceset="LTC1624" device="S8"/>
<part name="C3" library="sch_smd" deviceset="C_0805" device=""/>
<part name="C5" library="sch_smd" deviceset="C_0805" device="" value="100p"/>
<part name="C6" library="sch_smd" deviceset="C_0805" device="" value="1,5n"/>
<part name="R4" library="sch_smd" deviceset="R_1206" device=""/>
<part name="P+1" library="tfbs_versorg" deviceset="VCC" device="*"/>
<part name="BU1" library="tfbs_stecker+stifte" deviceset="STIFT" device="DICK"/>
<part name="BU2" library="tfbs_stecker+stifte" deviceset="STIFT" device="DICK"/>
<part name="BU3" library="tfbs_stecker+stifte" deviceset="STIFT" device="DICK"/>
<part name="BU4" library="tfbs_stecker+stifte" deviceset="STIFT" device="DICK"/>
<part name="P+2" library="tfbs_versorg" deviceset="VCC" device="*"/>
<part name="GND1" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND8" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="C9" library="tfbs_passiv" deviceset="ELKO" device="5MM" value="1000µ"/>
<part name="GND3" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="L2" library="wuerth-elektronik" deviceset="WE-PD" device="_L/XL/XXL"/>
<part name="C10" library="sch_smd" deviceset="C_0805" device="" value="1n"/>
<part name="IC2" library="tfbs_kt_projekte" deviceset="LTC1624" device="S8"/>
<part name="C11" library="sch_smd" deviceset="C_0805" device=""/>
<part name="C12" library="sch_smd" deviceset="C_0805" device="" value="100p"/>
<part name="C13" library="sch_smd" deviceset="C_0805" device="" value="330p"/>
<part name="R8" library="sch_smd" deviceset="R_1206" device="" value="3k3"/>
<part name="P+3" library="tfbs_versorg" deviceset="VCC" device="*"/>
<part name="GND7" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND4" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND5" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND9" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND10" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND11" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="BU5" library="tfbs_stecker+stifte" deviceset="STIFT" device="DICK"/>
<part name="Q1" library="tfbs_kt_projekte" deviceset="IRF510" device="STEHEND"/>
<part name="Q2" library="tfbs_kt_projekte" deviceset="IRF510" device="STEHEND"/>
<part name="C7" library="tfbs_passiv" deviceset="KONDENSATOR" device="5MM" value="100n"/>
<part name="C14" library="tfbs_passiv" deviceset="KONDENSATOR" device="5MM" value="100n"/>
<part name="R1" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="R5" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="R9" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="R10" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="R2" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="R3" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="D1" library="tfbs_passiv" deviceset="DIODE" device="12,5MM"/>
<part name="D2" library="tfbs_passiv" deviceset="DIODE" device="12,5MM"/>
<part name="R6" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="R7" library="tfbs_passiv" deviceset="WIDERSTAND" device="10MM"/>
<part name="C8" library="tfbs_passiv" deviceset="KONDENSATOR" device="5MM" value="100n"/>
<part name="BU6" library="tfbs_stecker+stifte" deviceset="STIFT" device="DICK"/>
<part name="GND12" library="tfbs_versorg" deviceset="GND" device="*"/>
<part name="GND13" library="tfbs_versorg" deviceset="GND" device="*"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="C1" gate="G$1" x="81.28" y="163.83"/>
<instance part="C2" gate="G$1" x="133.35" y="118.11" rot="R270"/>
<instance part="GND2" gate="1" x="90.17" y="163.83" rot="R90"/>
<instance part="GND6" gate="1" x="133.35" y="133.35" rot="R180"/>
<instance part="L1" gate="G$1" x="113.03" y="130.81"/>
<instance part="C4" gate="G$1" x="85.09" y="147.32" rot="MR90"/>
<instance part="FRAME1" gate="G$1" x="0" y="0"/>
<instance part="FRAME1" gate="G$2" x="162.56" y="0"/>
<instance part="IC1" gate="G$1" x="62.23" y="127"/>
<instance part="C3" gate="G$1" x="85.09" y="124.46" rot="MR90"/>
<instance part="C5" gate="G$1" x="38.1" y="106.68" rot="MR90"/>
<instance part="C6" gate="G$1" x="40.64" y="129.54" rot="MR0"/>
<instance part="R4" gate="G$1" x="30.48" y="129.54" rot="R180"/>
<instance part="P+1" gate="VCC" x="76.2" y="173.99"/>
<instance part="BU1" gate="G$1" x="138.43" y="101.6"/>
<instance part="BU2" gate="G$1" x="138.43" y="91.44"/>
<instance part="BU3" gate="G$1" x="38.1" y="167.64" rot="R180"/>
<instance part="BU4" gate="G$1" x="38.1" y="161.29" rot="R180"/>
<instance part="P+2" gate="VCC" x="45.72" y="167.64" rot="MR90"/>
<instance part="GND1" gate="1" x="45.72" y="161.29" rot="R90"/>
<instance part="GND8" gate="1" x="130.81" y="91.44" rot="R270"/>
<instance part="C9" gate="G$1" x="132.08" y="31.75" rot="R270"/>
<instance part="GND3" gate="1" x="101.6" y="77.47" rot="R90"/>
<instance part="L2" gate="G$1" x="101.6" y="53.34"/>
<instance part="C10" gate="G$1" x="76.2" y="55.88" rot="MR90"/>
<instance part="IC2" gate="G$1" x="60.96" y="40.64"/>
<instance part="C11" gate="G$1" x="83.82" y="38.1" rot="MR90"/>
<instance part="C12" gate="G$1" x="36.83" y="20.32" rot="MR90"/>
<instance part="C13" gate="G$1" x="39.37" y="43.18" rot="MR0"/>
<instance part="R8" gate="G$1" x="29.21" y="43.18" rot="R180"/>
<instance part="P+3" gate="VCC" x="85.09" y="85.09"/>
<instance part="GND7" gate="1" x="125.73" y="12.7"/>
<instance part="GND4" gate="1" x="43.18" y="33.02" rot="R270"/>
<instance part="GND5" gate="1" x="21.59" y="43.18" rot="R270"/>
<instance part="GND9" gate="1" x="36.83" y="12.7"/>
<instance part="GND10" gate="1" x="83.82" y="30.48"/>
<instance part="GND11" gate="1" x="105.41" y="44.45" rot="R90"/>
<instance part="BU5" gate="G$1" x="137.16" y="44.45"/>
<instance part="Q1" gate="G$1" x="99.06" y="133.35"/>
<instance part="Q2" gate="G$1" x="97.79" y="46.99"/>
<instance part="C7" gate="G$1" x="127" y="118.11" rot="R90"/>
<instance part="C14" gate="G$1" x="125.73" y="31.75" rot="R90"/>
<instance part="R1" gate="G$1" x="95.25" y="60.96" rot="R90"/>
<instance part="R5" gate="G$1" x="90.17" y="60.96" rot="R90"/>
<instance part="R9" gate="G$1" x="96.52" y="146.05" rot="R180"/>
<instance part="R10" gate="G$1" x="96.52" y="139.7" rot="R180"/>
<instance part="R2" gate="G$1" x="120.65" y="123.19" rot="R270"/>
<instance part="R3" gate="G$1" x="120.65" y="110.49" rot="R270"/>
<instance part="D1" gate="G$1" x="104.14" y="109.22" rot="R90"/>
<instance part="D2" gate="G$1" x="111.76" y="49.53"/>
<instance part="R6" gate="G$1" x="119.38" y="36.83" rot="R90"/>
<instance part="R7" gate="G$1" x="119.38" y="24.13" rot="R90"/>
<instance part="C8" gate="G$1" x="90.17" y="77.47"/>
<instance part="BU6" gate="G$1" x="137.16" y="53.34"/>
<instance part="GND12" gate="1" x="128.27" y="53.34" rot="R270"/>
<instance part="GND13" gate="1" x="129.54" y="53.34" rot="R270"/>
</instances>
<busses>
</busses>
<nets>
<net name="GND" class="0">
<segment>
<wire x1="86.36" y1="163.83" x2="87.63" y2="163.83" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="-"/>
<pinref part="GND2" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="L1" gate="G$1" pin="2"/>
<wire x1="118.11" y1="130.81" x2="120.65" y2="130.81" width="0.1524" layer="91"/>
<wire x1="120.65" y1="130.81" x2="120.65" y2="128.27" width="0.1524" layer="91"/>
<wire x1="120.65" y1="130.81" x2="127" y2="130.81" width="0.1524" layer="91"/>
<junction x="120.65" y="130.81"/>
<pinref part="GND6" gate="1" pin="GND"/>
<pinref part="C2" gate="G$1" pin="+"/>
<wire x1="127" y1="130.81" x2="133.35" y2="130.81" width="0.1524" layer="91"/>
<wire x1="133.35" y1="123.19" x2="133.35" y2="130.81" width="0.1524" layer="91"/>
<junction x="133.35" y="130.81"/>
<wire x1="127" y1="123.19" x2="127" y2="130.81" width="0.1524" layer="91"/>
<junction x="127" y="130.81"/>
<pinref part="C7" gate="G$1" pin="2"/>
<pinref part="R2" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="BU4" gate="G$1" pin="1"/>
<pinref part="GND1" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="BU2" gate="G$1" pin="1"/>
<pinref part="GND8" gate="1" pin="GND"/>
</segment>
<segment>
<wire x1="95.25" y1="77.47" x2="99.06" y2="77.47" width="0.1524" layer="91"/>
<pinref part="GND3" gate="1" pin="GND"/>
<pinref part="C8" gate="G$1" pin="2"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="GND"/>
<pinref part="GND4" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="R8" gate="G$1" pin="2"/>
<pinref part="GND5" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="C12" gate="G$1" pin="1"/>
<pinref part="GND9" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="SW"/>
<pinref part="C11" gate="G$1" pin="1"/>
<junction x="83.82" y="33.02"/>
<pinref part="GND10" gate="1" pin="GND"/>
<wire x1="83.82" y1="33.02" x2="76.2" y2="33.02" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="119.38" y1="15.24" x2="119.38" y2="19.05" width="0.1524" layer="91"/>
<wire x1="132.08" y1="15.24" x2="125.73" y2="15.24" width="0.1524" layer="91"/>
<wire x1="125.73" y1="15.24" x2="119.38" y2="15.24" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="-"/>
<wire x1="132.08" y1="26.67" x2="132.08" y2="15.24" width="0.1524" layer="91"/>
<wire x1="125.73" y1="26.67" x2="125.73" y2="15.24" width="0.1524" layer="91"/>
<junction x="125.73" y="15.24"/>
<pinref part="GND7" gate="1" pin="GND"/>
<pinref part="C14" gate="G$1" pin="1"/>
<pinref part="R7" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="GND11" gate="1" pin="GND"/>
<pinref part="Q2" gate="G$1" pin="S"/>
</segment>
<segment>
<pinref part="BU6" gate="G$1" pin="1"/>
<pinref part="GND13" gate="1" pin="GND"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="SENS-"/>
<wire x1="46.99" y1="134.62" x2="44.45" y2="134.62" width="0.1524" layer="91"/>
<wire x1="44.45" y1="134.62" x2="44.45" y2="154.94" width="0.1524" layer="91"/>
<wire x1="44.45" y1="154.94" x2="85.09" y2="154.94" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="85.09" y1="154.94" x2="85.09" y2="152.4" width="0.1524" layer="91"/>
<wire x1="85.09" y1="154.94" x2="104.14" y2="154.94" width="0.1524" layer="91"/>
<junction x="85.09" y="154.94"/>
<wire x1="104.14" y1="154.94" x2="104.14" y2="146.05" width="0.1524" layer="91"/>
<wire x1="104.14" y1="146.05" x2="104.14" y2="139.7" width="0.1524" layer="91"/>
<wire x1="104.14" y1="139.7" x2="101.6" y2="139.7" width="0.1524" layer="91"/>
<wire x1="104.14" y1="135.89" x2="104.14" y2="139.7" width="0.1524" layer="91"/>
<junction x="104.14" y="139.7"/>
<wire x1="101.6" y1="146.05" x2="104.14" y2="146.05" width="0.1524" layer="91"/>
<junction x="104.14" y="146.05"/>
<pinref part="Q1" gate="G$1" pin="D"/>
<pinref part="R9" gate="G$1" pin="1"/>
<pinref part="R10" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="BOOST"/>
<pinref part="C3" gate="G$1" pin="2"/>
<wire x1="85.09" y1="129.54" x2="77.47" y2="129.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="SW"/>
<pinref part="C3" gate="G$1" pin="1"/>
<wire x1="77.47" y1="119.38" x2="85.09" y2="119.38" width="0.1524" layer="91"/>
<pinref part="L1" gate="G$1" pin="1"/>
<wire x1="107.95" y1="130.81" x2="104.14" y2="130.81" width="0.1524" layer="91"/>
<wire x1="104.14" y1="114.3" x2="104.14" y2="119.38" width="0.1524" layer="91"/>
<wire x1="104.14" y1="119.38" x2="104.14" y2="130.81" width="0.1524" layer="91"/>
<wire x1="85.09" y1="119.38" x2="104.14" y2="119.38" width="0.1524" layer="91"/>
<junction x="85.09" y="119.38"/>
<junction x="104.14" y="119.38"/>
<pinref part="Q1" gate="G$1" pin="S"/>
<junction x="104.14" y="130.81"/>
<pinref part="D1" gate="G$1" pin="K"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="TG"/>
<wire x1="77.47" y1="124.46" x2="80.01" y2="124.46" width="0.1524" layer="91"/>
<wire x1="80.01" y1="124.46" x2="80.01" y2="130.81" width="0.1524" layer="91"/>
<wire x1="80.01" y1="130.81" x2="93.98" y2="130.81" width="0.1524" layer="91"/>
<pinref part="Q1" gate="G$1" pin="G"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<wire x1="120.65" y1="118.11" x2="120.65" y2="116.84" width="0.1524" layer="91"/>
<wire x1="120.65" y1="116.84" x2="120.65" y2="115.57" width="0.1524" layer="91"/>
<wire x1="120.65" y1="116.84" x2="90.17" y2="116.84" width="0.1524" layer="91"/>
<wire x1="90.17" y1="116.84" x2="90.17" y2="111.76" width="0.1524" layer="91"/>
<junction x="120.65" y="116.84"/>
<wire x1="90.17" y1="111.76" x2="38.1" y2="111.76" width="0.1524" layer="91"/>
<wire x1="38.1" y1="111.76" x2="38.1" y2="124.46" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="FB"/>
<wire x1="38.1" y1="124.46" x2="46.99" y2="124.46" width="0.1524" layer="91"/>
<pinref part="C5" gate="G$1" pin="2"/>
<junction x="38.1" y="111.76"/>
<pinref part="R2" gate="G$1" pin="2"/>
<pinref part="R3" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="GND"/>
<wire x1="46.99" y1="119.38" x2="46.99" y2="101.6" width="0.1524" layer="91"/>
<wire x1="46.99" y1="101.6" x2="104.14" y2="101.6" width="0.1524" layer="91"/>
<wire x1="104.14" y1="101.6" x2="120.65" y2="101.6" width="0.1524" layer="91"/>
<wire x1="120.65" y1="101.6" x2="120.65" y2="105.41" width="0.1524" layer="91"/>
<wire x1="133.35" y1="101.6" x2="127" y2="101.6" width="0.1524" layer="91"/>
<junction x="120.65" y="101.6"/>
<pinref part="C5" gate="G$1" pin="1"/>
<wire x1="127" y1="101.6" x2="120.65" y2="101.6" width="0.1524" layer="91"/>
<wire x1="46.99" y1="101.6" x2="38.1" y2="101.6" width="0.1524" layer="91"/>
<junction x="46.99" y="101.6"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="25.4" y1="129.54" x2="25.4" y2="101.6" width="0.1524" layer="91"/>
<wire x1="25.4" y1="101.6" x2="38.1" y2="101.6" width="0.1524" layer="91"/>
<junction x="38.1" y="101.6"/>
<wire x1="104.14" y1="106.68" x2="104.14" y2="101.6" width="0.1524" layer="91"/>
<junction x="104.14" y="101.6"/>
<pinref part="C2" gate="G$1" pin="-"/>
<wire x1="133.35" y1="113.03" x2="133.35" y2="101.6" width="0.1524" layer="91"/>
<pinref part="BU1" gate="G$1" pin="1"/>
<junction x="133.35" y="101.6"/>
<wire x1="127" y1="113.03" x2="127" y2="101.6" width="0.1524" layer="91"/>
<junction x="127" y="101.6"/>
<pinref part="C7" gate="G$1" pin="1"/>
<pinref part="R3" gate="G$1" pin="2"/>
<pinref part="D1" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="C6" gate="G$1" pin="2"/>
<pinref part="R4" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="C6" gate="G$1" pin="1"/>
<pinref part="IC1" gate="G$1" pin="ITH"/>
<wire x1="45.72" y1="129.54" x2="46.99" y2="129.54" width="0.1524" layer="91"/>
</segment>
</net>
<net name="VCC" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="VIN"/>
<wire x1="85.09" y1="134.62" x2="77.47" y2="134.62" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="1"/>
<wire x1="85.09" y1="142.24" x2="85.09" y2="139.7" width="0.1524" layer="91"/>
<wire x1="85.09" y1="139.7" x2="85.09" y2="134.62" width="0.1524" layer="91"/>
<wire x1="91.44" y1="139.7" x2="90.17" y2="139.7" width="0.1524" layer="91"/>
<junction x="85.09" y="139.7"/>
<wire x1="90.17" y1="139.7" x2="85.09" y2="139.7" width="0.1524" layer="91"/>
<wire x1="85.09" y1="139.7" x2="76.2" y2="139.7" width="0.1524" layer="91"/>
<wire x1="76.2" y1="139.7" x2="76.2" y2="163.83" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="+"/>
<junction x="76.2" y="163.83"/>
<pinref part="P+1" gate="VCC" pin="VCC"/>
<wire x1="76.2" y1="171.45" x2="76.2" y2="163.83" width="0.1524" layer="91"/>
<wire x1="91.44" y1="146.05" x2="90.17" y2="146.05" width="0.1524" layer="91"/>
<wire x1="90.17" y1="146.05" x2="90.17" y2="139.7" width="0.1524" layer="91"/>
<junction x="90.17" y="139.7"/>
<pinref part="R9" gate="G$1" pin="2"/>
<pinref part="R10" gate="G$1" pin="2"/>
</segment>
<segment>
<pinref part="BU3" gate="G$1" pin="1"/>
<pinref part="P+2" gate="VCC" pin="VCC"/>
</segment>
<segment>
<pinref part="P+3" gate="VCC" pin="VCC"/>
<wire x1="85.09" y1="82.55" x2="85.09" y2="77.47" width="0.1524" layer="91"/>
<junction x="85.09" y="66.04"/>
<pinref part="IC2" gate="G$1" pin="VIN"/>
<wire x1="85.09" y1="77.47" x2="85.09" y2="66.04" width="0.1524" layer="91"/>
<wire x1="85.09" y1="66.04" x2="85.09" y2="48.26" width="0.1524" layer="91"/>
<wire x1="85.09" y1="48.26" x2="76.2" y2="48.26" width="0.1524" layer="91"/>
<pinref part="C10" gate="G$1" pin="1"/>
<wire x1="76.2" y1="50.8" x2="76.2" y2="48.26" width="0.1524" layer="91"/>
<junction x="76.2" y="48.26"/>
<wire x1="85.09" y1="66.04" x2="90.17" y2="66.04" width="0.1524" layer="91"/>
<pinref part="R1" gate="G$1" pin="2"/>
<pinref part="R5" gate="G$1" pin="2"/>
<wire x1="90.17" y1="66.04" x2="95.25" y2="66.04" width="0.1524" layer="91"/>
<junction x="90.17" y="66.04"/>
<pinref part="C8" gate="G$1" pin="1"/>
<junction x="85.09" y="77.47"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="BOOST"/>
<pinref part="C11" gate="G$1" pin="2"/>
<wire x1="83.82" y1="43.18" x2="76.2" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="TG"/>
<wire x1="76.2" y1="38.1" x2="78.74" y2="38.1" width="0.1524" layer="91"/>
<wire x1="78.74" y1="38.1" x2="78.74" y2="44.45" width="0.1524" layer="91"/>
<wire x1="78.74" y1="44.45" x2="92.71" y2="44.45" width="0.1524" layer="91"/>
<pinref part="Q2" gate="G$1" pin="G"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<wire x1="119.38" y1="31.75" x2="119.38" y2="30.48" width="0.1524" layer="91"/>
<wire x1="119.38" y1="30.48" x2="119.38" y2="29.21" width="0.1524" layer="91"/>
<wire x1="119.38" y1="30.48" x2="88.9" y2="30.48" width="0.1524" layer="91"/>
<wire x1="88.9" y1="30.48" x2="88.9" y2="25.4" width="0.1524" layer="91"/>
<junction x="119.38" y="30.48"/>
<wire x1="88.9" y1="25.4" x2="36.83" y2="25.4" width="0.1524" layer="91"/>
<wire x1="36.83" y1="25.4" x2="36.83" y2="38.1" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="FB"/>
<wire x1="36.83" y1="38.1" x2="45.72" y2="38.1" width="0.1524" layer="91"/>
<pinref part="C12" gate="G$1" pin="2"/>
<junction x="36.83" y="25.4"/>
<pinref part="R6" gate="G$1" pin="1"/>
<pinref part="R7" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="C13" gate="G$1" pin="2"/>
<pinref part="R8" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="C13" gate="G$1" pin="1"/>
<pinref part="IC2" gate="G$1" pin="ITH"/>
<wire x1="44.45" y1="43.18" x2="45.72" y2="43.18" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<wire x1="119.38" y1="44.45" x2="119.38" y2="41.91" width="0.1524" layer="91"/>
<wire x1="119.38" y1="44.45" x2="125.73" y2="44.45" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="+"/>
<wire x1="125.73" y1="44.45" x2="132.08" y2="44.45" width="0.1524" layer="91"/>
<wire x1="132.08" y1="36.83" x2="132.08" y2="44.45" width="0.1524" layer="91"/>
<wire x1="125.73" y1="36.83" x2="125.73" y2="44.45" width="0.1524" layer="91"/>
<junction x="125.73" y="44.45"/>
<wire x1="116.84" y1="49.53" x2="119.38" y2="49.53" width="0.1524" layer="91"/>
<wire x1="119.38" y1="49.53" x2="119.38" y2="44.45" width="0.1524" layer="91"/>
<junction x="119.38" y="44.45"/>
<pinref part="BU5" gate="G$1" pin="1"/>
<junction x="132.08" y="44.45"/>
<pinref part="C14" gate="G$1" pin="2"/>
<pinref part="D2" gate="G$1" pin="K"/>
<pinref part="R6" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<wire x1="109.22" y1="49.53" x2="106.68" y2="49.53" width="0.1524" layer="91"/>
<pinref part="L2" gate="G$1" pin="2"/>
<wire x1="106.68" y1="49.53" x2="102.87" y2="49.53" width="0.1524" layer="91"/>
<wire x1="106.68" y1="53.34" x2="106.68" y2="49.53" width="0.1524" layer="91"/>
<junction x="106.68" y="49.53"/>
<pinref part="Q2" gate="G$1" pin="D"/>
<pinref part="D2" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<pinref part="L2" gate="G$1" pin="1"/>
<wire x1="90.17" y1="55.88" x2="90.17" y2="53.34" width="0.1524" layer="91"/>
<wire x1="90.17" y1="53.34" x2="95.25" y2="53.34" width="0.1524" layer="91"/>
<wire x1="95.25" y1="53.34" x2="96.52" y2="53.34" width="0.1524" layer="91"/>
<wire x1="90.17" y1="53.34" x2="81.28" y2="53.34" width="0.1524" layer="91"/>
<junction x="90.17" y="53.34"/>
<pinref part="C10" gate="G$1" pin="2"/>
<wire x1="81.28" y1="53.34" x2="81.28" y2="60.96" width="0.1524" layer="91"/>
<wire x1="81.28" y1="60.96" x2="76.2" y2="60.96" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="SENS-"/>
<wire x1="45.72" y1="48.26" x2="43.18" y2="48.26" width="0.1524" layer="91"/>
<wire x1="43.18" y1="48.26" x2="43.18" y2="60.96" width="0.1524" layer="91"/>
<wire x1="76.2" y1="60.96" x2="43.18" y2="60.96" width="0.1524" layer="91"/>
<junction x="76.2" y="60.96"/>
<wire x1="95.25" y1="55.88" x2="95.25" y2="53.34" width="0.1524" layer="91"/>
<junction x="95.25" y="53.34"/>
<pinref part="R1" gate="G$1" pin="1"/>
<pinref part="R5" gate="G$1" pin="1"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
