=== Simulation (Elapsed: 12 sec) === ### Starting build procedure for model: arduino_led ### Generating code into build folder: C:\Users\Name\Documents\MATLAB\arduino_led_ert_rtw ### Invoking Target Language Compiler on arduino_led.rtw ### Using System Target File: C:\Program Files\MATLAB\R2015b\rtw\c\ert\ert.tlc ### Loading TLC function libraries ### Initial pass through model to cache user defined code ### Caching model source code ### Writing header file arduino_led.h ### Writing header file arduino_led_types.h ### Writing header file rtwtypes.h . ### Writing header file multiword_types.h ### Writing source file arduino_led.c ### Writing header file arduino_led_private.h ### Writing source file arduino_led_data.c ### Writing header file rtmodel.h . ### Writing source file ert_main.c ### TLC code generation complete. ### Generating TLC interface API. ### Creating data type transition file arduino_led_dt.h .### Evaluating PostCodeGenCommand specified in the model ### Using toolchain: Arduino ARM v1.6.1 | gmake (64-bit Windows) ### Creating 'C:\Users\Name\Documents\MATLAB\arduino_led_ert_rtw\arduino_led.mk' ... ### Building 'arduino_led': C:\PROGRA~1\MATLAB\R2015b\bin\win64\gmake -f arduino_led.mk all C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "arduino_led.o" "arduino_led.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "arduino_led_data.o" "arduino_led_data.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "ext_svr.o" "C:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common/ext_svr.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "updown.o" "C:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common/updown.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "ext_work.o" "C:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common/ext_work.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "rtiostream_utils.o" "C:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils/rtiostream_utils.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "dtostrf.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/avr/dtostrf.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "cortex_handlers.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/cortex_handlers.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "hooks.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/hooks.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "iar_calls_sam3.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/iar_calls_sam3.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "itoa.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/itoa.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "syscalls_sam3.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/syscalls_sam3.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "WInterrupts.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/WInterrupts.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "wiring.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/wiring.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "wiring_analog.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/wiring_analog.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "wiring_digital.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/wiring_digital.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-gcc -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "wiring_shift.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/wiring_shift.c" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "abi.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/abi.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "IPAddress.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/IPAddress.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "new.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/new.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "Print.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/Print.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "Reset.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/Reset.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "RingBuffer.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/RingBuffer.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "Stream.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/Stream.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "UARTClass.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/UARTClass.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "USARTClass.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/USARTClass.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "CDC.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/USB/CDC.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "HID.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/USB/HID.cpp" C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -fno-threadsafe-statics -fno-rtti -fno-exceptions -Os -c -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -DARDUINO=161 -MD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER='"Unknown"' -DUSB_PRODUCT='"Arduino Due"' -D_RUNONTARGETHARDWARE_BUILD_ -D_ROTH_DUE_ -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DON_TARGET_WAIT_FOR_START=1 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMW_TIMERID=9 -DMW_TIMERCOUNT=65625 -DMW_SAM_CLOCKID=TC_CMR_TCCLKS_TIMER_CLOCK4 -D_RTT_BAUDRATE_SERIAL0_=115200 -D_RTT_BAUDRATE_SERIAL1_=115200 -D_RTT_BAUDRATE_SERIAL2_=115200 -D_RTT_BAUDRATE_SERIAL3_=115200 -D_RTT_ANALOG_REF_=0 -DONESTEPFCN=1 -DEXT_MODE=1 -DTERMFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DON_TARGET_WAIT_FOR_START=1 -DEXIT_FAILURE=1 -DEXTMODE_DISABLEPRINTF -DEXTMODE_DISABLETESTING -DEXTMODE_DISABLE_ARGS_PROCESSING=1 -DRT -DSTACK_SIZE=64 -DMODEL=arduino_led -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/include -IC:/MATLAB/SupportPackages/R2015b/arduinobase/toolbox/target/supportpackages/arduinobase/blocks/sfcn/include -IC:/Users/Name/Documents/MATLAB/arduino_led_ert_rtw -IC:/Users/Name/Documents/MATLAB -IC:/PROGRA~1/MATLAB/R2015b/extern/include -IC:/PROGRA~1/MATLAB/R2015b/simulink/include -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2015b/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2015b/toolbox/coder/rtiostream/src/utils -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/libsam -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/CMSIS/Include -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/system/CMSIS/Device/ATMEL -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino -IC:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/variants/arduino_due_x -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../include -IC:/MATLAB/SupportPackages/R2015b/arduino/toolbox/target/supportpackages/arduinotarget/registry/../scheduler/include -o "USBCore.o" "C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/USB/USBCore.cpp" :0:13: error: initializer fails to determine size of 'STRING_PRODUCT' C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/USB/USBCore.cpp:69:34: note: in expansion of macro 'USB_PRODUCT' const uint8_t STRING_PRODUCT[] = USB_PRODUCT; ^ :0:13: error: array must be initialized with a brace-enclosed initializer C:/MATLAB/SupportPackages/R2015b/arduino-1.6.1/hardware/arduino/sam/cores/arduino/USB/USBCore.cpp:69:34: note: in expansion of macro 'USB_PRODUCT' const uint8_t STRING_PRODUCT[] = USB_PRODUCT; ^ gmake: *** [USBCore.o] Error 1 ### Build procedure for model: 'arduino_led' aborted due to an error. Error: Error(s) encountered while building "arduino_led": ### Failed to generate all binary outputs.
