Reading | ###################################### | 76% 1.40savrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1472 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] @ [40] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [05] . [00] . [00] q [71] A [41] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 64 (command_sequence == 64) avrdude: Recv: . [82] 8 [38] . [f0] . [80] . [91] . [10] . [01] . [8f] 7 [37] . [18] . [f4] . [80] . [91] . [10] . [01] . [14] . [d0] . [0f] . [90] . [cf] . [91 ] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [7f] . [91] o [6f] . [91] _ [5f] . [91] O [4f] . [91] ? [3 f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] Raw message: 0x82 0x38 0xf0 0x80 0x91 0x10 0x01 0x8f 0x37 0x18 0xf4 0x80 0x91 0x10 0x01 0x14 0xd0 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x7f 0x91 0x6f 0x91 0x5f 0x91 0x4f 0x91 0x3f 0x91 0x2f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 memory contents: 0x38 0xf0 0x80 0x91 0x10 0x01 0x8f 0x37 0x18 0xf4 0x80 0x91 0x10 0x 01 0x14 0xd0 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x 91 0x9f 0x91 0x8f 0x91 0x7f 0x91 0x6f 0x91 0x5f 0x91 0x4f 0x91 0x3f 0x91 0x2f 0x 91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x 92 0xcd 0xb7 Reading | ######################################## | 80% 1.46savrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1536 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] A [41] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [06] . [00] . [00] . [c3] . [85] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 65 (command_sequence == 65) avrdude: Recv: . [82] . [de] . [b7] . [89] . [83] . [80] . [91] . [11] . [01] . [88] # [23] . [e1] . [f7] . [89] . [81] . [80] . [95] . [80] . [93] . [0e] . [01 ] . [8a] . [e0] . [80] . [93] . [11] . [01] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [d e] . [b7] . [9a] . [83] . [89] . [83] . [0a] . [c0] . [e9] . [81] . [fa] . [81] [20] . [81] . [89] . [81] . [9a] . [81] . [01] . [96] . [9a] . [83] Raw message: 0x82 0xde 0xb7 0x89 0x83 0x80 0x91 0x11 0x01 0x88 0x23 0xe1 0xf7 0x89 0x81 0x80 0x95 0x80 0x93 0x0e 0x01 0x8a 0xe0 0x80 0x93 0x11 0x01 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x9a 0x83 0x89 0x83 0x0a 0xc0 0xe9 0x81 0xfa 0x81 0x20 0x81 0x89 0x81 0x9a 0x81 0x01 0x96 0x9a 0x83 memory contents: 0xde 0xb7 0x89 0x83 0x80 0x91 0x11 0x01 0x88 0x23 0xe1 0xf7 0x89 0x 81 0x80 0x95 0x80 0x93 0x0e 0x01 0x8a 0xe0 0x80 0x93 0x11 0x01 0x0f 0x90 0xcf 0x 91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x9a 0x 83 0x89 0x83 0x0a 0xc0 0xe9 0x81 0xfa 0x81 0x20 0x81 0x89 0x81 0x9a 0x81 0x01 0x 96 0x9a 0x83 Reading | ########################################## | 83% 1.52savrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1600 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] B [42] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [06] . [00] . [00] e [65] . [a3] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 66 (command_sequence == 66) avrdude: Recv: . [82] . [89] . [83] . [82] / [2f] . [d9] . [df] . [e9] . [81] . [fa] . [81] . [80] . [81] . [88] # [23] . [89] . [f7] . [0f] . [90] . [0f] . [90 ] . [cf] . [91] . [df] . [91] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] . [8f] . [93] . [9f] . [93] . [af] . [93] . [b f] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [1a] . [82] . [19] . [82] . [a8] . [e8] Raw message: 0x82 0x89 0x83 0x82 0x2f 0xd9 0xdf 0xe9 0x81 0xfa 0x81 0x80 0x81 0x88 0x23 0x89 0xf7 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x1a 0x82 0x19 0x82 0xa8 0xe8 memory contents: 0x89 0x83 0x82 0x2f 0xd9 0xdf 0xe9 0x81 0xfa 0x81 0x80 0x81 0x88 0x 23 0x89 0xf7 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x 92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x 93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x1a 0x82 0x19 0x 82 0xa8 0xe8 Reading | ########################################### | 86% 1.58savrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1664 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] C [43] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [06] . [00] . [00] . [b3] . [88] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 67 (command_sequence == 67) avrdude: Recv: . [82] . [b0] . [e0] . [e8] . [e8] . [f0] . [e0] . [80] . [81] . [91] . [81] . [8f] [ [5b] . [9c] O [4f] . [11] . [96] . [9c] . [93] . [8e] . [93 ] . [80] . [91] . [11] . [01] . [89] . [83] . [89] . [81] . [88] # [23] . [d1] . [f0] . [89] . [81] . [81] P [50] . [89] . [83] . [89] . [81] . [80] . [93] . [1 1] . [01] . [80] . [e8] . [8a] . [83] . [89] . [81] . [89] 0 [30] y [79] . [f0] . [80] . [91] . [0e] . [01] . [88] / [2f] . [90] . [e0] . [81] p [70] Raw message: 0x82 0xb0 0xe0 0xe8 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x5b 0x9c 0x4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x80 0x91 0x11 0x01 0x89 0x83 0x89 0x81 0x88 0x23 0xd1 0xf0 0x89 0x81 0x81 0x50 0x89 0x83 0x89 0x81 0x80 0x93 0x11 0x01 0x80 0xe8 0x8a 0x83 0x89 0x81 0x89 0x30 0x79 0xf0 0x80 0x91 0x0e 0x01 0x88 0x2f 0x90 0xe0 0x81 0x70 memory contents: 0xb0 0xe0 0xe8 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x5b 0x9c 0x 4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x80 0x91 0x11 0x01 0x89 0x83 0x89 0x81 0x88 0x 23 0xd1 0xf0 0x89 0x81 0x81 0x50 0x89 0x83 0x89 0x81 0x80 0x93 0x11 0x01 0x80 0x e8 0x8a 0x83 0x89 0x81 0x89 0x30 0x79 0xf0 0x80 0x91 0x0e 0x01 0x88 0x2f 0x90 0x e0 0x81 0x70 Reading | ############################################# | 90% 1.64savrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1728 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] D [44] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [06] . [00] . [00] ) [29] . [ee] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 68 (command_sequence == 68) avrdude: Recv: . [82] . [90] p [70] . [00] . [97] . [11] . [f4] . [80] . [ec] . [8a] . [83] . [80] . [91] . [0e] . [01] . [86] . [95] . [80] . [93] . [0e] . [01 ] . [e0] . [e8] . [f0] . [e0] . [8a] . [81] . [80] . [83] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [a f] . [91] . [9f] . [91] . [8f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] Raw message: 0x82 0x90 0x70 0x00 0x97 0x11 0xf4 0x80 0xec 0x8a 0x83 0x80 0x91 0x0e 0x01 0x86 0x95 0x80 0x93 0x0e 0x01 0xe0 0xe8 0xf0 0xe0 0x8a 0x81 0x80 0x83 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 memory contents: 0x90 0x70 0x00 0x97 0x11 0xf4 0x80 0xec 0x8a 0x83 0x80 0x91 0x0e 0x 01 0x86 0x95 0x80 0x93 0x0e 0x01 0xe0 0xe8 0xf0 0xe0 0x8a 0x81 0x80 0x83 0x0f 0x 90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x 91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x 93 0x00 0xd0 Reading | ############################################### | 93% 1.70savrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1792 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] E [45] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [07] . [00] . [00] # [23] . [9f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 69 (command_sequence == 69) avrdude: Recv: . [82] . [cd] . [b7] . [de] . [b7] . [e4] . [e6] . [f0] . [e0] . [80] . [81] . [e4] . [e6] . [f0] . [e0] . [10] . [82] . [a5] . [e4] . [b0] . [e0 ] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [88] ` [60] . [8c] . [93] . [e7] . [e4] . [f0] . [e0] . [80] . [e5] . [80] . [83] . [ae] . [e6] . [b0] . [e0] . [e e] . [e6] . [f0] . [e0] . [80] . [81] . [82] ` [60] . [8c] . [93] . [e6] . [e4] . [f0] . [e0] . [10] . [82] . [e5] . [e4] . [f0] . [e0] . [80] . [81] Raw message: 0x82 0xcd 0xb7 0xde 0xb7 0xe4 0xe6 0xf0 0xe0 0x80 0x81 0xe4 0xe6 0xf0 0xe0 0x10 0x82 0xa5 0xe4 0xb0 0xe0 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0x88 0x60 0x8c 0x93 0xe7 0xe4 0xf0 0xe0 0x80 0xe5 0x80 0x83 0xae 0xe6 0xb0 0xe0 0xee 0xe6 0xf0 0xe0 0x80 0x81 0x82 0x60 0x8c 0x93 0xe6 0xe4 0xf0 0xe0 0x10 0x82 0xe5 0xe4 0xf0 0xe0 0x80 0x81 memory contents: 0xcd 0xb7 0xde 0xb7 0xe4 0xe6 0xf0 0xe0 0x80 0x81 0xe4 0xe6 0xf0 0x e0 0x10 0x82 0xa5 0xe4 0xb0 0xe0 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0x88 0x60 0x8c 0x 93 0xe7 0xe4 0xf0 0xe0 0x80 0xe5 0x80 0x83 0xae 0xe6 0xb0 0xe0 0xee 0xe6 0xf0 0x e0 0x80 0x81 0x82 0x60 0x8c 0x93 0xe6 0xe4 0xf0 0xe0 0x10 0x82 0xe5 0xe4 0xf0 0x e0 0x80 0x81 Reading | ################################################ | 96% 1.76savrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1856 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] F [46] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [07] . [00] . [00] . [85] . [b9] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 70 (command_sequence == 70) avrdude: Recv: . [82] . [e5] . [e4] . [f0] . [e0] . [10] . [82] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [f8] . [94] . [ff] . [cf ] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [f f] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] Raw message: 0x82 0xe5 0xe4 0xf0 0xe0 0x10 0x82 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xf8 0x94 0xff 0xcf 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff memory contents: 0xe5 0xe4 0xf0 0xe0 0x10 0x82 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x 91 0x08 0x95 0xf8 0x94 0xff 0xcf 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0x ff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0x ff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0x ff 0xff 0xff Reading | ################################################## | 100% 1.82s avrdude: avr_read(): skipping page 30: no interesting data avrdude: avr_read(): skipping page 31: no interesting data avrdude: avr_read(): skipping page 32: no interesting data avrdude: avr_read(): skipping page 33: no interesting data avrdude: avr_read(): skipping page 34: no interesting data avrdude: avr_read(): skipping page 35: no interesting data avrdude: avr_read(): skipping page 36: no interesting data avrdude: avr_read(): skipping page 37: no interesting data avrdude: avr_read(): skipping page 38: no interesting data avrdude: avr_read(): skipping page 39: no interesting data avrdude: avr_read(): skipping page 40: no interesting data avrdude: avr_read(): skipping page 41: no interesting data avrdude: avr_read(): skipping page 42: no interesting data avrdude: avr_read(): skipping page 43: no interesting data avrdude: avr_read(): skipping page 44: no interesting data avrdude: avr_read(): skipping page 45: no interesting data avrdude: avr_read(): skipping page 46: no interesting data avrdude: avr_read(): skipping page 47: no interesting data avrdude: avr_read(): skipping page 48: no interesting data avrdude: avr_read(): skipping page 49: no interesting data avrdude: avr_read(): skipping page 50: no interesting data avrdude: avr_read(): skipping page 51: no interesting data avrdude: avr_read(): skipping page 52: no interesting data avrdude: avr_read(): skipping page 53: no interesting data avrdude: avr_read(): skipping page 54: no interesting data avrdude: avr_read(): skipping page 55: no interesting data avrdude: avr_read(): skipping page 56: no interesting data avrdude: avr_read(): skipping page 57: no interesting data avrdude: avr_read(): skipping page 58: no interesting data avrdude: avr_read(): skipping page 59: no interesting data avrdude: avr_read(): skipping page 60: no interesting data avrdude: avr_read(): skipping page 61: no interesting data avrdude: avr_read(): skipping page 62: no interesting data avrdude: avr_read(): skipping page 63: no interesting data avrdude: verifying ... avrdude: 1876 bytes of flash verified avrdude: jtagmkII_close() avrdude: jtagmkII_close(): Sending sign-off command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] G [47] . [00] . [01] . [00] . [00] . [00] . [0e] . [00] . [85] . [7f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 71 (command_sequence == 71) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude done. Thank you.
