>avrdude -p attiny48 -P usb -c dragon_isp -U hfuse:w:0xDF:m -vvvv avrdude: Version 6.1, compiled on Mar 13 2014 at 00:09:49 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf" Using Port : usb Using Programmer : dragon_isp avrdude: stk500v2_dragon_isp_open() avrdude: usbdev_open(): Found AVRDRAGON, serno: 00A200031475 avrdude: jtagmkII_getsync() avrdude: jtagmkII_getsync(): Sending sign-on command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [00] . [00] . [01] . [00] . [00] . [00] . [0e] . [01] . [f3] . [97] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 0 (command_sequence == 0) avrdude: Recv: . [86] . [01] . [ff] . [18] . [07] . [01] . [ff] . [18] . [07] . [07] . [00] . [a2] . [00] . [03] . [14] u [75] A [41] V [56] R [52] D [44] R [52 ] A [41] G [47] O [4f] N [4e] . [00] Raw message: 0x86 0x01 0xff 0x18 0x07 0x01 0xff 0x18 0x07 0x07 0x00 0xa2 0x00 0x03 0x14 0x75 0x41 0x56 0x52 0x44 0x52 0x41 0x47 0x4f 0x4e 0x00 Sign-on succeeded JTAG ICE mkII sign-on message: Communications protocol version: 1 M_MCU: boot-loader FW version: 255 firmware version: 7.24 hardware version: 1 S_MCU: boot-loader FW version: 255 firmware version: 7.24 hardware version: 7 Serial number: 00:a2:00:03:14:75 Device ID: AVRDRAGON avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [01] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [03] . [03] . [89] f [66] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 1 (command_sequence == 1) avrdude: Recv: . [a0] Raw message: 0xa0 FAILED avrdude: jtagmkII_setparm(): bad response to set parameter command: RSP_FAILED avrdude: jtagmkII_getsync(): ISP activation failed, trying debugWire avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [02] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [03] . [00] { [7b] [20] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 2 (command_sequence == 2) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_reset(): Sending reset command: avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [03] . [00] . [02] . [00] . [00] . [00] . [0e] . [0b] . [04] . [be] . [00] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 3 (command_sequence == 3) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: Target prepared for ISP, signed off. avrdude: Now retrying without power-cycling the target. avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [04] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [03] . [03] 2 [32] . [fa] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 4 (command_sequence == 4) avrdude: Recv: . [a0] Raw message: 0xa0 FAILED avrdude: jtagmkII_setparm(): bad response to set parameter command: RSP_FAILED avrdude: jtagmkII_getsync(): ISP activation failed, trying debugWire avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [05] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [03] . [00] . [8e] . [e4] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 5 (command_sequence == 5) avrdude: Recv: . [ac] Raw message: 0xac unknown message 0xac avrdude: jtagmkII_setparm(): bad response to set parameter command: RSP_DEBUGWIR E_SYNC_FAILED avrdude: failed to sync with the AVR Dragon in ISP mode avrdude done. Thank you.
