avrdude: Version 6.1, compiled on Mar 13 2014 at 00:09:49 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf" Using Port : usb Using Programmer : dragon_dw avrdude: jtagmkII_dragon_open_dw() avrdude: usbdev_open(): Found AVRDRAGON, serno: 00A200031475 avrdude: usbdev_drain(): flushed 11 characters avrdude: usbdev_drain(): flushed 11 characters avrdude: usbdev_drain(): flushed 11 characters avrdude: jtagmkII_getsync() avrdude: jtagmkII_getsync(): Sending sign-on command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [00] . [00] . [01] . [00] . [00] . [00] . [0e] . [01] . [f3] . [97] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 0 (command_sequence == 0) avrdude: Recv: . [86] . [01] . [ff] . [18] . [07] . [01] . [ff] . [18] . [07] . [07] . [00] . [a2] . [00] . [03] . [14] u [75] A [41] V [56] R [52] D [44] R [52] A [41] G [47] O [4f] N [4e] . [00] Raw message: 0x86 0x01 0xff 0x18 0x07 0x01 0xff 0x18 0x07 0x07 0x00 0xa2 0x00 0x03 0x14 0x75 0x41 0x56 0x52 0x44 0x52 0x41 0x47 0x4f 0x4e 0x00 Sign-on succeeded JTAG ICE mkII sign-on message: Communications protocol version: 1 M_MCU: boot-loader FW version: 255 firmware version: 7.24 hardware version: 1 S_MCU: boot-loader FW version: 255 firmware version: 7.24 hardware version: 7 Serial number: 00:a2:00:03:14:75 Device ID: AVRDRAGON avrdude: jtagmkII_getsync(): Using a 298-byte device descriptor avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [01] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [03] . [00] . [12] T [54] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 1 (command_sequence == 1) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_getsync(): Sending get sync command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] . [02] . [00] . [01] . [00] . [00] . [00] . [0e] . [0f] . [e2] u [75] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 2 (command_sequence == 2) avrdude: Recv: . [80] Raw message: 0x80 OK AVR Part : attiny48 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 5 4 0 no 64 4 0 3600 3600 0xff 0xff Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- flash 65 6 64 0 yes 4096 64 64 4500 4500 0xff 0xff Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : DRAGON_DW Description : Atmel AVR Dragon in debugWire mode avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x01): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [03] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [01] . [d3] . [99] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 3 (command_sequence == 3) avrdude: Recv: . [81] . [01] . [07] Raw message: 0x81 0x01 0x07 parameter values: 0x01 0x07 avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x02): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [04] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [02] . [aa] B [42] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 4 (command_sequence == 4) avrdude: Recv: . [81] . [18] . [07] . [18] . [07] Raw message: 0x81 0x18 0x07 0x18 0x07 parameter values: 0x18 0x07 0x18 0x07 M_MCU hardware version: 1 M_MCU firmware version: 7.24 S_MCU hardware version: 7 S_MCU firmware version: 7.24 Serial number: 00:a2:00:03:14:75 avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x06): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [05] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [06] s [73] I [49] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 5 (command_sequence == 5) avrdude: Recv: . [81] . [8c] . [13] Raw message: 0x81 0x8c 0x13 parameter values: 0x8c 0x13 Vtarget : 5.0 V avrdude: jtagmkII_set_devdescr(): Sending set device descriptor command: avrdude: jtagmkII_send(): sending 299 bytes avrdude: Sent: . [1b] . [06] . [00] + [2b] . [01] . [00] . [00] . [0e] . [0c] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] @ [40] . [00] . [04] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [10] . [00] . [00] . [bd] . [f2] . [bd] . [e1] . [bb] . [cf] . [b4] . [00] . [be] . [01] . [b6] . [01] . [bc] . [00] . [bb] . [bf] . [99] . [f9] . [bb] . [af] . [b6] . [01] . [11] . [00] . [00] @ [40] . [00] . [00] . [00] . [00] . [00] . [00] . [01] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [de] [ [5b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 6 (command_sequence == 6) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_setparm() avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x09, 1 bytes): avrdude: jtagmkII_send(): sending 3 bytes avrdude: Sent: . [1b] . [07] . [00] . [03] . [00] . [00] . [00] . [0e] . [02] . [09] . [00] . [b0] A [41] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 7 (command_sequence == 7) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: jtagmkII_reset(): Sending stop command: avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [08] . [00] . [02] . [00] . [00] . [00] . [0e] . [0a] . [01] . [06] . [e7] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 8 (command_sequence == 8) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude: AVR device initialized and ready to accept instructions Reading | avrdude: jtagmkII_read_byte(.., signature, 0x0, ...) avrdude: jtagmkII_read_byte(.., signature, 0x1, ...) avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x1d): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [09] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [1d] . [0e] . [a7] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 65535 (command_sequence == 9) avrdude: jtagmkII_recv(): got asynchronous event avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 9 (command_sequence == 9) avrdude: Recv: . [81] . [09] . [92] Raw message: 0x81 0x09 0x92 parameter values: 0x09 0x92 ################avrdude: jtagmkII_read_byte(.., signature, 0x2, ...) avrdude: jtagmkII_getparm() avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x1d): avrdude: jtagmkII_send(): sending 2 bytes avrdude: Sent: . [1b] . [0a] . [00] . [02] . [00] . [00] . [00] . [0e] . [03] . [1d] . [09] q [71] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 10 (command_sequence == 10) avrdude: Recv: . [81] . [09] . [92] Raw message: 0x81 0x09 0x92 parameter values: 0x09 0x92 ################################## | 100% 0.01s avrdude: Device signature = 0x1e9209 avrdude: jtagmkII_read_byte(.., lfuse, 0x0, ...) avrdude: safemode read 1, lfuse value: 2a avrdude: jtagmkII_read_byte(.., lfuse, 0x0, ...) avrdude: safemode read 2, lfuse value: 2a avrdude: jtagmkII_read_byte(.., lfuse, 0x0, ...) avrdude: safemode read 3, lfuse value: 2a avrdude: safemode: Fuse reading not support by programmer. Safemode disabled. avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: Chip erase not supported in debugWire mode avrdude: reading input file "Labornetzgeraet.hex" avrdude: input file Labornetzgeraet.hex auto detected as Intel Hex avrdude: writing flash (1876 bytes): Writing | avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 0 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [0b] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [13] . [c0] " [22] . [c0] ! [21] . [c0] [20] . [c0] . [1f] . [c0] { [7b] . [c1] . [1d] . [c0] . [1c] . [c0] K [4b] . [c2] # [23] . [c3] . [86] . [c2] . [18] . [c0] . [eb] . [c0] . [16] . [c0] . [15] . [c0] . [14] . [c0] . [13] . [c0] . [12] . [c0] . [11] . [c0] . [10] . [c0] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d1] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a4] 1 [31] . [e4] . [c9] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 11 (command_sequence == 11) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 64 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [0c] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [00] . [00] . [00] . [b1] . [07] . [e1] . [f7] 4 [34] . [d1] . [84] . [c3] . [db] . [cf] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [a4] . [e2] . [b0] . [e0] . [e4] . [e2] . [f0] . [e0] . [80] . [81] . [88] b [62] . [8c] . [93] . [ee] . [e4] . [f0] . [e0] . [88] . [e2] . [80] . [83] . [ec] . [e4] . [f0] . [e0] . [81] . [e5] . [80] . [83] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] T [54] . [c9] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 12 (command_sequence == 12) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 128 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [0d] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [80] . [00] . [00] . [00] . [89] . [83] . [ee] . [e4] . [f0] . [e0] . [89] . [81] . [80] . [83] . [ed] . [e4] . [f0] . [e0] . [80] . [81] . [88] # [23] . [dc] . [f7] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [89] . [83] . [80] . [91] . [0b] . [01] . [88] / [2f] . [90] . [e0] . [9c] . [01] / [2f] _ [5f] ? [3f] O [4f] . [80] . [91] . [0a] . [01] . [88] / [2f] . [90] . [e0] ( [28] . [17] . [0c] . [f1] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 13 (command_sequence == 13) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 192 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [0e] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [00] . [00] . [00] 9 [39] . [07] A [41] . [f0] . [80] . [91] . [0a] . [01] . [88] # [23] 1 [31] . [f4] . [80] . [91] . [0b] . [01] . [89] 0 [30] . [11] . [f4] . [1a] . [82] . [16] . [c0] . [80] . [91] . [0b] . [01] . [88] / [2f] . [90] . [e0] . [fc] . [01] . [e0] P [50] . [ff] O [4f] . [89] . [81] . [80] . [83] . [80] . [91] . [0b] . [01] . [8f] _ [5f] . [80] . [93] . [0b] . [01] . [80] . [91] . [0b] . [01] . [8a] 0 [30] . [10] . [f0] . [10] . [92] . [0b] . [01] . [d3] . [8e] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 14 (command_sequence == 14) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 256 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [0f] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [01] . [00] . [00] . [81] . [e0] . [8a] . [83] . [8a] . [81] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [9a] . [83] . [89] . [83] . [f8] . [94] . [90] . [91] . [0a] . [01] . [80] . [91] . [0b] . [01] . [98] . [17] . [11] . [f4] . [1b] . [82] . [19] . [c0] . [80] . [91] . [0a] . [01] . [88] / [2f] . [90] . [e0] . [fc] . [01] . [e0] P [50] . [ff] O [4f] . [1b] $ [24] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 15 (command_sequence == 15) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 320 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [10] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [01] . [00] . [00] . [80] . [81] . [e9] . [81] . [fa] . [81] . [80] . [83] . [80] . [91] . [0a] . [01] . [8f] _ [5f] . [80] . [93] . [0a] . [01] . [80] . [91] . [0a] . [01] . [8a] 0 [30] . [10] . [f0] . [10] . [92] . [0a] . [01] x [78] . [94] . [81] . [e0] . [8b] . [83] . [8b] . [81] . [0f] . [90] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [e1] . [e6] . [f0] . [e0] . [03] . [12] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 16 (command_sequence == 16) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 384 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [11] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [80] . [01] . [00] . [00] . [10] . [82] . [e7] . [e2] . [f0] . [e0] . [80] . [e8] . [80] . [83] . [ed] . [e2] . [f0] . [e0] . [81] . [e0] . [80] . [83] . [ea] . [e2] . [f0] . [e0] . [80] . [81] . [ea] . [e2] . [f0] . [e0] . [10] . [82] . [eb] . [e2] . [f0] . [e0] . [80] . [81] . [eb] . [e2] . [f0] . [e0] . [10] . [82] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] ) [29] . [c7] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 17 (command_sequence == 17) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 448 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [12] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [01] . [00] . [00] . [8b] . [83] . [19] . [82] . [0b] . [c0] . [1a] . [82] . [03] . [c0] . [8a] . [81] . [8f] _ [5f] . [8a] . [83] . [8a] . [81] . [84] 6 [36] . [d4] . [f3] . [89] . [81] . [8f] _ [5f] . [89] . [83] . [99] . [81] . [8b] . [81] . [98] . [17] . [8c] . [f3] . [0f] . [90] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] O [4f] . [93] [20] . [f2] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 18 (command_sequence == 18) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 512 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [13] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [02] . [00] . [00] _ [5f] . [93] o [6f] . [93] . [7f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [19] . [82] . [eb] . [e2] . [f0] . [e0] . [80] . [81] . [89] . [83] . [eb] . [e2] . [f0] . [e0] . [90] . [81] . [8c] . [ef] . [89] ' [27] . [83] y [79] . [89] . [83] . [89] . [e3] . [1e] . [df] . [89] . [81] . [1c] . [df] . [89] . [81] [ [5b] . [bb] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 19 (command_sequence == 19) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 576 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [14] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [02] . [00] . [00] - [2d] . [df] . [eb] . [e3] . [f0] . [e0] . [80] . [81] . [eb] . [e3] . [f0] . [e0] . [10] . [82] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [e5] . [e4] . [f0] . [e0] . [10] . [82] . [a8] . [e6] . [b0] . [e0] . [e8] . [e6] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [8c] . [93] . [0f] . [90] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [7f] . [91] . [cb] . [ab] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 20 (command_sequence == 20) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 640 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [15] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [80] . [02] . [00] . [00] o [6f] . [91] _ [5f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [f8] . [94] i [69] . [df] . [1e] . [d0] + [2b] . [d2] . [d2] . [de] x [78] . [94] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [ec] . [df] . [ce] . [01] . [02] . [96] . [98] . [0e] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 21 (command_sequence == 21) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 704 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [16] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [02] . [00] . [00] ' [27] . [df] . [88] # [23] . [d9] . [f3] . [80] . [e3] . [d6] . [de] . [ea] . [81] . [fb] . [81] . [80] . [81] . [89] . [83] . [89] . [81] . [88] # [23] . [91] . [f3] . [83] . [e1] . [cd] . [de] . [ef] . [cf] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [e8] . [e6] . [f0] . [e0] . [84] . [e0] . [80] . [83] . [ad] . [e6] . [b0] . [e0] . [ed] . [e6] . [f0] . [e0] . [80] . [81] . [83] i [69] . [8c] . [93] . [cf] . [91] . [df] . [91] [20] . [f0] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 22 (command_sequence == 22) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 768 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [17] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [03] . [00] . [00] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] . [8f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [e8] . [e6] . [f0] . [e0] . [80] . [81] . [e8] . [e6] . [f0] . [e0] . [10] . [82] . [e6] . [e4] . [f0] . [e0] . [10] . [82] . [a5] . [e4] . [b0] . [e0] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [8c] . [93] . [b6] . [9e] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 23 (command_sequence == 23) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 832 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [18] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [03] . [00] . [00] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [8f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [89] . [83] . [89] . [81] . [8f] ? [3f] . [19] . [f0] . [89] . [81] . [80] . [93] . [0c] . [01] . [80] . [91] . [0c] . [01] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [0a] [ [5b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 24 (command_sequence == 24) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 896 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [19] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [80] . [03] . [00] . [00] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [89] . [83] . [89] . [81] . [8f] ? [3f] . [19] . [f0] . [89] . [81] . [80] . [93] . [0d] . [01] . [80] . [91] . [0d] . [01] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [19] . [82] . [e9] . [e2] . [f0] . [e0] . [80] . [81] . [88] / [2f] . [90] . [e0] . [85] p [70] . [90] p [70] . [00] . [97] . [11] . [f4] G [47] c [63] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 25 (command_sequence == 25) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 960 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [1a] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [03] . [00] . [00] . [83] . [e0] . [89] . [83] . [e9] . [e2] . [f0] . [e0] . [80] . [81] . [88] / [2f] . [90] . [e0] . [86] p [70] . [90] p [70] . [00] . [97] ! [21] . [f4] . [89] . [81] . [91] . [e0] . [89] ' [27] . [89] . [83] . [89] . [81] . [bc] . [df] . [80] . [e0] . [cc] . [df] . [e5] . [e4] . [f0] . [e0] . [82] . [e0] . [80] . [83] . [e8] . [e4] . [f0] . [e0] . [8c] . [e7] . [80] . [83] . [ae] . [e6] . [b0] . [e0] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [ec] . [10] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 26 (command_sequence == 26) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1024 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [1b] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [04] . [00] . [00] . [84] ` [60] . [8c] . [93] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [f8] . [94] . [8f] . [ef] . [b1] . [df] . [89] . [83] . [89] . [81] . [81] p [70] . [ad] . [df] x [78] . [94] . [89] . [81] . [85] . [95] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [a8] . [e8] . [b0] . [e0] . [e4] . [e8] . [88] . [b3] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 27 (command_sequence == 27) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1088 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [1c] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [04] . [00] . [00] . [f0] . [e0] . [80] . [81] . [91] . [81] . [01] . [96] . [11] . [96] . [9c] . [93] . [8e] . [93] . [e0] . [e8] . [f0] . [e0] . [80] . [ec] . [80] . [83] . [e1] . [e8] . [f0] . [e0] . [81] . [e8] . [80] . [83] . [e6] . [e3] . [f0] . [e0] . [80] . [e2] . [80] . [83] . [ef] . [e6] . [f0] . [e0] . [82] . [e2] . [80] . [83] . [10] . [92] . [11] . [01] . [10] . [92] . [12] . [01] . [a4] . [e2] . [b0] . [e0] . [e4] . [e2] . [f0] . [e0] . [80] . [81] . [9b] . [8b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 28 (command_sequence == 28) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1152 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [1d] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [80] . [04] . [00] . [00] . [80] h [68] . [8c] . [93] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [80] . [91] . [12] . [01] . [88] # [23] . [e1] . [f3] . [10] . [92] . [12] . [01] . [80] . [91] . [10] . [01] . [cf] . [91] . [df] . [91] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] 7 [37] / [2f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 29 (command_sequence == 29) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1216 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [1e] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [04] . [00] . [00] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [aa] . [e8] . [b0] . [e0] . [e6] . [e8] . [f0] . [e0] . [80] . [81] . [91] . [81] . [8f] Q [51] . [9b] O [4f] . [11] . [96] . [9c] . [93] . [8e] . [93] . [10] . [92] . [13] . [01] . [81] . [e0] . [80] . [93] . [0f] . [01] . [e6] . [e3] . [f0] . [e0] . [84] . [e0] . [80] . [83] . [e3] . [e2] . [f0] . [e0] . [80] . [81] . [88] / [2f] . [90] . [e0] . [80] q [71] . [90] p [70] . [00] . [97] ! [21] . [f4] . [d6] o [6f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 30 (command_sequence == 30) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1280 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] . [1f] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [05] . [00] . [00] . [ef] . [e6] . [f0] . [e0] . [86] . [e0] . [80] . [83] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] O [4f] . [93] _ [5f] . [93] o [6f] . [93] . [7f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [cf] ? [3f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 31 (command_sequence == 31) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1344 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] [20] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [05] . [00] . [00] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [e3] . [e2] . [f0] . [e0] . [80] . [81] . [89] . [83] . [80] . [91] . [0f] . [01] . [88] # [23] . [f9] . [f0] . [89] . [81] . [88] / [2f] . [90] . [e0] . [80] q [71] . [90] p [70] . [00] . [97] 9 [39] . [f0] . [80] . [91] . [13] . [01] . [90] . [91] . [0f] . [01] . [89] + [2b] . [80] . [93] . [13] . [01] . [80] . [91] . [0f] . [01] . [88] . [0f] y [79] . [c0] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 32 (command_sequence == 32) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1408 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] ! [21] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [80] . [05] . [00] . [00] . [80] . [93] . [0f] . [01] . [aa] . [e8] . [b0] . [e0] . [ea] . [e8] . [f0] . [e0] . [80] . [81] . [91] . [81] . [8f] [ [5b] . [9c] O [4f] . [11] . [96] . [9c] . [93] . [8e] . [93] . [1a] . [c0] . [81] . [e0] . [80] . [93] . [12] . [01] . [80] . [91] . [13] . [01] . [80] . [93] . [10] . [01] . [e6] . [e3] . [f0] . [e0] . [80] . [e2] . [80] . [83] . [ef] . [e6] . [f0] . [e0] . [82] . [e2] . [80] . [83] . [80] . [91] . [10] . [01] . [8a] 1 [31] . [c3] . [ba] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 33 (command_sequence == 33) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1472 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] " [22] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [05] . [00] . [00] 8 [38] . [f0] . [80] . [91] . [10] . [01] . [8f] 7 [37] . [18] . [f4] . [80] . [91] . [10] . [01] . [14] . [d0] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [7f] . [91] o [6f] . [91] _ [5f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] { [7b] . [9b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 34 (command_sequence == 34) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1536 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] # [23] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [06] . [00] . [00] . [de] . [b7] . [89] . [83] . [80] . [91] . [11] . [01] . [88] # [23] . [e1] . [f7] . [89] . [81] . [80] . [95] . [80] . [93] . [0e] . [01] . [8a] . [e0] . [80] . [93] . [11] . [01] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [9a] . [83] . [89] . [83] . [0a] . [c0] . [e9] . [81] . [fa] . [81] [20] . [81] . [89] . [81] . [9a] . [81] . [01] . [96] . [9a] . [83] J [4a] ' [27] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 35 (command_sequence == 35) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1600 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] $ [24] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [06] . [00] . [00] . [89] . [83] . [82] / [2f] . [d9] . [df] . [e9] . [81] . [fa] . [81] . [80] . [81] . [88] # [23] . [89] . [f7] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [1a] . [82] . [19] . [82] . [a8] . [e8] . [17] . [9a] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 36 (command_sequence == 36) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1664 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] % [25] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [80] . [06] . [00] . [00] . [b0] . [e0] . [e8] . [e8] . [f0] . [e0] . [80] . [81] . [91] . [81] . [8f] [ [5b] . [9c] O [4f] . [11] . [96] . [9c] . [93] . [8e] . [93] . [80] . [91] . [11] . [01] . [89] . [83] . [89] . [81] . [88] # [23] . [d1] . [f0] . [89] . [81] . [81] P [50] . [89] . [83] . [89] . [81] . [80] . [93] . [11] . [01] . [80] . [e8] . [8a] . [83] . [89] . [81] . [89] 0 [30] y [79] . [f0] . [80] . [91] . [0e] . [01] . [88] / [2f] . [90] . [e0] . [81] p [70] R [52] K [4b] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 37 (command_sequence == 37) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1728 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] & [26] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [06] . [00] . [00] . [90] p [70] . [00] . [97] . [11] . [f4] . [80] . [ec] . [8a] . [83] . [80] . [91] . [0e] . [01] . [86] . [95] . [80] . [93] . [0e] . [01] . [e0] . [e8] . [f0] . [e0] . [8a] . [81] . [80] . [83] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] P [50] . [b3] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 38 (command_sequence == 38) avrdude: Recv: . [80] Raw message: 0x80 OK #avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1792 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] ' [27] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] . [00] . [07] . [00] . [00] . [cd] . [b7] . [de] . [b7] . [e4] . [e6] . [f0] . [e0] . [80] . [81] . [e4] . [e6] . [f0] . [e0] . [10] . [82] . [a5] . [e4] . [b0] . [e0] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [88] ` [60] . [8c] . [93] . [e7] . [e4] . [f0] . [e0] . [80] . [e5] . [80] . [83] . [ae] . [e6] . [b0] . [e0] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [82] ` [60] . [8c] . [93] . [e6] . [e4] . [f0] . [e0] . [10] . [82] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [97] . [86] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 39 (command_sequence == 39) avrdude: Recv: . [80] Raw message: 0x80 OK ##avrdude: jtagmkII_paged_write(.., flash, 64, 64) avrdude: jtagmkII_paged_write(): block_size at addr 1856 is 64 avrdude: jtagmkII_paged_write(): Sending write memory command: avrdude: jtagmkII_send(): sending 74 bytes avrdude: Sent: . [1b] ( [28] . [00] J [4a] . [00] . [00] . [00] . [0e] . [04] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [07] . [00] . [00] . [e5] . [e4] . [f0] . [e0] . [10] . [82] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [f8] . [94] . [ff] . [cf] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [f3] . [fa] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 40 (command_sequence == 40) avrdude: Recv: . [80] Raw message: 0x80 OK ## | 100% 3.74s avrdude: 1876 bytes of flash written avrdude: verifying flash memory against Labornetzgeraet.hex: avrdude: load data flash data from input file Labornetzgeraet.hex: avrdude: input file Labornetzgeraet.hex auto detected as Intel Hex avrdude: input file Labornetzgeraet.hex contains 1876 bytes avrdude: reading on-chip flash data: Reading | avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 0 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] ) [29] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [00] . [00] . [00] $ [24] . [e1] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 41 (command_sequence == 41) avrdude: Recv: . [82] . [13] . [c0] " [22] . [c0] ! [21] . [c0] [20] . [c0] . [1f] . [c0] { [7b] . [c1] . [1d] . [c0] . [1c] . [c0] K [4b] . [c2] # [23] . [c3] . [86] . [c2] . [18] . [c0] . [eb] . [c0] . [16] . [c0] . [15] . [c0] . [14] . [c0] . [13] . [c0] . [12] . [c0] . [11] . [c0] . [10] . [c0] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d1] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a4] 1 [31] Raw message: 0x82 0x13 0xc0 0x22 0xc0 0x21 0xc0 0x20 0xc0 0x1f 0xc0 0x7b 0xc1 0x1d 0xc0 0x1c 0xc0 0x4b 0xc2 0x23 0xc3 0x86 0xc2 0x18 0xc0 0xeb 0xc0 0x16 0xc0 0x15 0xc0 0x14 0xc0 0x13 0xc0 0x12 0xc0 0x11 0xc0 0x10 0xc0 0x11 0x24 0x1f 0xbe 0xcf 0xef 0xd1 0xe0 0xde 0xbf 0xcd 0xbf 0x11 0xe0 0xa0 0xe0 0xb1 0xe0 0x01 0xc0 0x1d 0x92 0xa4 0x31 memory contents: 0x13 0xc0 0x22 0xc0 0x21 0xc0 0x20 0xc0 0x1f 0xc0 0x7b 0xc1 0x1d 0xc0 0x1c 0xc0 0x4b 0xc2 0x23 0xc3 0x86 0xc2 0x18 0xc0 0xeb 0xc0 0x16 0xc0 0x15 0xc0 0x14 0xc0 0x13 0xc0 0x12 0xc0 0x11 0xc0 0x10 0xc0 0x11 0x24 0x1f 0xbe 0xcf 0xef 0xd1 0xe0 0xde 0xbf 0xcd 0xbf 0x11 0xe0 0xa0 0xe0 0xb1 0xe0 0x01 0xc0 0x1d 0x92 0xa4 0x31 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 64 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] * [2a] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [00] . [00] . [00] . [82] . [c7] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 42 (command_sequence == 42) avrdude: Recv: . [82] . [b1] . [07] . [e1] . [f7] 4 [34] . [d1] . [84] . [c3] . [db] . [cf] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [a4] . [e2] . [b0] . [e0] . [e4] . [e2] . [f0] . [e0] . [80] . [81] . [88] b [62] . [8c] . [93] . [ee] . [e4] . [f0] . [e0] . [88] . [e2] . [80] . [83] . [ec] . [e4] . [f0] . [e0] . [81] . [e5] . [80] . [83] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] Raw message: 0x82 0xb1 0x07 0xe1 0xf7 0x34 0xd1 0x84 0xc3 0xdb 0xcf 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xa4 0xe2 0xb0 0xe0 0xe4 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x62 0x8c 0x93 0xee 0xe4 0xf0 0xe0 0x88 0xe2 0x80 0x83 0xec 0xe4 0xf0 0xe0 0x81 0xe5 0x80 0x83 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 memory contents: 0xb1 0x07 0xe1 0xf7 0x34 0xd1 0x84 0xc3 0xdb 0xcf 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xa4 0xe2 0xb0 0xe0 0xe4 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x62 0x8c 0x93 0xee 0xe4 0xf0 0xe0 0x88 0xe2 0x80 0x83 0xec 0xe4 0xf0 0xe0 0x81 0xe5 0x80 0x83 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 128 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] + [2b] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [00] . [00] . [00] T [54] . [ec] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 43 (command_sequence == 43) avrdude: Recv: . [82] . [89] . [83] . [ee] . [e4] . [f0] . [e0] . [89] . [81] . [80] . [83] . [ed] . [e4] . [f0] . [e0] . [80] . [81] . [88] # [23] . [dc] . [f7] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [89] . [83] . [80] . [91] . [0b] . [01] . [88] / [2f] . [90] . [e0] . [9c] . [01] / [2f] _ [5f] ? [3f] O [4f] . [80] . [91] . [0a] . [01] . [88] / [2f] . [90] . [e0] ( [28] . [17] Raw message: 0x82 0x89 0x83 0xee 0xe4 0xf0 0xe0 0x89 0x81 0x80 0x83 0xed 0xe4 0xf0 0xe0 0x80 0x81 0x88 0x23 0xdc 0xf7 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x89 0x83 0x80 0x91 0x0b 0x01 0x88 0x2f 0x90 0xe0 0x9c 0x01 0x2f 0x5f 0x3f 0x4f 0x80 0x91 0x0a 0x01 0x88 0x2f 0x90 0xe0 0x28 0x17 memory contents: 0x89 0x83 0xee 0xe4 0xf0 0xe0 0x89 0x81 0x80 0x83 0xed 0xe4 0xf0 0xe0 0x80 0x81 0x88 0x23 0xdc 0xf7 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x89 0x83 0x80 0x91 0x0b 0x01 0x88 0x2f 0x90 0xe0 0x9c 0x01 0x2f 0x5f 0x3f 0x4f 0x80 0x91 0x0a 0x01 0x88 0x2f 0x90 0xe0 0x28 0x17 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 192 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] , [2c] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [00] . [00] . [00] . [ce] . [8a] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 44 (command_sequence == 44) avrdude: Recv: . [82] 9 [39] . [07] A [41] . [f0] . [80] . [91] . [0a] . [01] . [88] # [23] 1 [31] . [f4] . [80] . [91] . [0b] . [01] . [89] 0 [30] . [11] . [f4] . [1a] . [82] . [16] . [c0] . [80] . [91] . [0b] . [01] . [88] / [2f] . [90] . [e0] . [fc] . [01] . [e0] P [50] . [ff] O [4f] . [89] . [81] . [80] . [83] . [80] . [91] . [0b] . [01] . [8f] _ [5f] . [80] . [93] . [0b] . [01] . [80] . [91] . [0b] . [01] . [8a] 0 [30] . [10] . [f0] . [10] . [92] . [0b] . [01] Raw message: 0x82 0x39 0x07 0x41 0xf0 0x80 0x91 0x0a 0x01 0x88 0x23 0x31 0xf4 0x80 0x91 0x0b 0x01 0x89 0x30 0x11 0xf4 0x1a 0x82 0x16 0xc0 0x80 0x91 0x0b 0x01 0x88 0x2f 0x90 0xe0 0xfc 0x01 0xe0 0x50 0xff 0x4f 0x89 0x81 0x80 0x83 0x80 0x91 0x0b 0x01 0x8f 0x5f 0x80 0x93 0x0b 0x01 0x80 0x91 0x0b 0x01 0x8a 0x30 0x10 0xf0 0x10 0x92 0x0b 0x01 memory contents: 0x39 0x07 0x41 0xf0 0x80 0x91 0x0a 0x01 0x88 0x23 0x31 0xf4 0x80 0x91 0x0b 0x01 0x89 0x30 0x11 0xf4 0x1a 0x82 0x16 0xc0 0x80 0x91 0x0b 0x01 0x88 0x2f 0x90 0xe0 0xfc 0x01 0xe0 0x50 0xff 0x4f 0x89 0x81 0x80 0x83 0x80 0x91 0x0b 0x01 0x8f 0x5f 0x80 0x93 0x0b 0x01 0x80 0x91 0x0b 0x01 0x8a 0x30 0x10 0xf0 0x10 0x92 0x0b 0x01 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 256 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] - [2d] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [01] . [00] . [00] . [c4] . [fb] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 45 (command_sequence == 45) avrdude: Recv: . [82] . [81] . [e0] . [8a] . [83] . [8a] . [81] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [9a] . [83] . [89] . [83] . [f8] . [94] . [90] . [91] . [0a] . [01] . [80] . [91] . [0b] . [01] . [98] . [17] . [11] . [f4] . [1b] . [82] . [19] . [c0] . [80] . [91] . [0a] . [01] . [88] / [2f] . [90] . [e0] . [fc] . [01] . [e0] P [50] . [ff] O [4f] Raw message: 0x82 0x81 0xe0 0x8a 0x83 0x8a 0x81 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x9a 0x83 0x89 0x83 0xf8 0x94 0x90 0x91 0x0a 0x01 0x80 0x91 0x0b 0x01 0x98 0x17 0x11 0xf4 0x1b 0x82 0x19 0xc0 0x80 0x91 0x0a 0x01 0x88 0x2f 0x90 0xe0 0xfc 0x01 0xe0 0x50 0xff 0x4f memory contents: 0x81 0xe0 0x8a 0x83 0x8a 0x81 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x9a 0x83 0x89 0x83 0xf8 0x94 0x90 0x91 0x0a 0x01 0x80 0x91 0x0b 0x01 0x98 0x17 0x11 0xf4 0x1b 0x82 0x19 0xc0 0x80 0x91 0x0a 0x01 0x88 0x2f 0x90 0xe0 0xfc 0x01 0xe0 0x50 0xff 0x4f ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 320 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] . [2e] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [01] . [00] . [00] b [62] . [dd] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 46 (command_sequence == 46) avrdude: Recv: . [82] . [80] . [81] . [e9] . [81] . [fa] . [81] . [80] . [83] . [80] . [91] . [0a] . [01] . [8f] _ [5f] . [80] . [93] . [0a] . [01] . [80] . [91] . [0a] . [01] . [8a] 0 [30] . [10] . [f0] . [10] . [92] . [0a] . [01] x [78] . [94] . [81] . [e0] . [8b] . [83] . [8b] . [81] . [0f] . [90] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [e1] . [e6] . [f0] . [e0] Raw message: 0x82 0x80 0x81 0xe9 0x81 0xfa 0x81 0x80 0x83 0x80 0x91 0x0a 0x01 0x8f 0x5f 0x80 0x93 0x0a 0x01 0x80 0x91 0x0a 0x01 0x8a 0x30 0x10 0xf0 0x10 0x92 0x0a 0x01 0x78 0x94 0x81 0xe0 0x8b 0x83 0x8b 0x81 0x0f 0x90 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0xe1 0xe6 0xf0 0xe0 memory contents: 0x80 0x81 0xe9 0x81 0xfa 0x81 0x80 0x83 0x80 0x91 0x0a 0x01 0x8f 0x5f 0x80 0x93 0x0a 0x01 0x80 0x91 0x0a 0x01 0x8a 0x30 0x10 0xf0 0x10 0x92 0x0a 0x01 0x78 0x94 0x81 0xe0 0x8b 0x83 0x8b 0x81 0x0f 0x90 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0xe1 0xe6 0xf0 0xe0 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 384 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] / [2f] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [01] . [00] . [00] . [b4] . [f6] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 47 (command_sequence == 47) avrdude: Recv: . [82] . [10] . [82] . [e7] . [e2] . [f0] . [e0] . [80] . [e8] . [80] . [83] . [ed] . [e2] . [f0] . [e0] . [81] . [e0] . [80] . [83] . [ea] . [e2] . [f0] . [e0] . [80] . [81] . [ea] . [e2] . [f0] . [e0] . [10] . [82] . [eb] . [e2] . [f0] . [e0] . [80] . [81] . [eb] . [e2] . [f0] . [e0] . [10] . [82] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] Raw message: 0x82 0x10 0x82 0xe7 0xe2 0xf0 0xe0 0x80 0xe8 0x80 0x83 0xed 0xe2 0xf0 0xe0 0x81 0xe0 0x80 0x83 0xea 0xe2 0xf0 0xe0 0x80 0x81 0xea 0xe2 0xf0 0xe0 0x10 0x82 0xeb 0xe2 0xf0 0xe0 0x80 0x81 0xeb 0xe2 0xf0 0xe0 0x10 0x82 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 memory contents: 0x10 0x82 0xe7 0xe2 0xf0 0xe0 0x80 0xe8 0x80 0x83 0xed 0xe2 0xf0 0xe0 0x81 0xe0 0x80 0x83 0xea 0xe2 0xf0 0xe0 0x80 0x81 0xea 0xe2 0xf0 0xe0 0x10 0x82 0xeb 0xe2 0xf0 0xe0 0x80 0x81 0xeb 0xe2 0xf0 0xe0 0x10 0x82 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 448 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 0 [30] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [01] . [00] . [00] . [b7] . [18] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 48 (command_sequence == 48) avrdude: Recv: . [82] . [8b] . [83] . [19] . [82] . [0b] . [c0] . [1a] . [82] . [03] . [c0] . [8a] . [81] . [8f] _ [5f] . [8a] . [83] . [8a] . [81] . [84] 6 [36] . [d4] . [f3] . [89] . [81] . [8f] _ [5f] . [89] . [83] . [99] . [81] . [8b] . [81] . [98] . [17] . [8c] . [f3] . [0f] . [90] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] O [4f] . [93] Raw message: 0x82 0x8b 0x83 0x19 0x82 0x0b 0xc0 0x1a 0x82 0x03 0xc0 0x8a 0x81 0x8f 0x5f 0x8a 0x83 0x8a 0x81 0x84 0x36 0xd4 0xf3 0x89 0x81 0x8f 0x5f 0x89 0x83 0x99 0x81 0x8b 0x81 0x98 0x17 0x8c 0xf3 0x0f 0x90 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x2f 0x93 0x3f 0x93 0x4f 0x93 memory contents: 0x8b 0x83 0x19 0x82 0x0b 0xc0 0x1a 0x82 0x03 0xc0 0x8a 0x81 0x8f 0x5f 0x8a 0x83 0x8a 0x81 0x84 0x36 0xd4 0xf3 0x89 0x81 0x8f 0x5f 0x89 0x83 0x99 0x81 0x8b 0x81 0x98 0x17 0x8c 0xf3 0x0f 0x90 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x2f 0x93 0x3f 0x93 0x4f 0x93 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 512 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 1 [31] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [02] . [00] . [00] . [05] . [dc] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 49 (command_sequence == 49) avrdude: Recv: . [82] _ [5f] . [93] o [6f] . [93] . [7f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [19] . [82] . [eb] . [e2] . [f0] . [e0] . [80] . [81] . [89] . [83] . [eb] . [e2] . [f0] . [e0] . [90] . [81] . [8c] . [ef] . [89] ' [27] . [83] y [79] . [89] . [83] . [89] . [e3] . [1e] . [df] . [89] . [81] . [1c] . [df] . [89] . [81] Raw message: 0x82 0x5f 0x93 0x6f 0x93 0x7f 0x93 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x19 0x82 0xeb 0xe2 0xf0 0xe0 0x80 0x81 0x89 0x83 0xeb 0xe2 0xf0 0xe0 0x90 0x81 0x8c 0xef 0x89 0x27 0x83 0x79 0x89 0x83 0x89 0xe3 0x1e 0xdf 0x89 0x81 0x1c 0xdf 0x89 0x81 memory contents: 0x5f 0x93 0x6f 0x93 0x7f 0x93 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x19 0x82 0xeb 0xe2 0xf0 0xe0 0x80 0x81 0x89 0x83 0xeb 0xe2 0xf0 0xe0 0x90 0x81 0x8c 0xef 0x89 0x27 0x83 0x79 0x89 0x83 0x89 0xe3 0x1e 0xdf 0x89 0x81 0x1c 0xdf 0x89 0x81 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 576 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 2 [32] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [02] . [00] . [00] . [a3] . [fa] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 50 (command_sequence == 50) avrdude: Recv: . [82] - [2d] . [df] . [eb] . [e3] . [f0] . [e0] . [80] . [81] . [eb] . [e3] . [f0] . [e0] . [10] . [82] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [e5] . [e4] . [f0] . [e0] . [10] . [82] . [a8] . [e6] . [b0] . [e0] . [e8] . [e6] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [8c] . [93] . [0f] . [90] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [7f] . [91] Raw message: 0x82 0x2d 0xdf 0xeb 0xe3 0xf0 0xe0 0x80 0x81 0xeb 0xe3 0xf0 0xe0 0x10 0x82 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0xe5 0xe4 0xf0 0xe0 0x10 0x82 0xa8 0xe6 0xb0 0xe0 0xe8 0xe6 0xf0 0xe0 0x80 0x81 0x84 0x60 0x8c 0x93 0x0f 0x90 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x7f 0x91 memory contents: 0x2d 0xdf 0xeb 0xe3 0xf0 0xe0 0x80 0x81 0xeb 0xe3 0xf0 0xe0 0x10 0x82 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0xe5 0xe4 0xf0 0xe0 0x10 0x82 0xa8 0xe6 0xb0 0xe0 0xe8 0xe6 0xf0 0xe0 0x80 0x81 0x84 0x60 0x8c 0x93 0x0f 0x90 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x7f 0x91 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 640 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 3 [33] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [02] . [00] . [00] u [75] . [d1] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 51 (command_sequence == 51) avrdude: Recv: . [82] o [6f] . [91] _ [5f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [f8] . [94] i [69] . [df] . [1e] . [d0] + [2b] . [d2] . [d2] . [de] x [78] . [94] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [ec] . [df] . [ce] . [01] . [02] . [96] Raw message: 0x82 0x6f 0x91 0x5f 0x91 0x4f 0x91 0x3f 0x91 0x2f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xf8 0x94 0x69 0xdf 0x1e 0xd0 0x2b 0xd2 0xd2 0xde 0x78 0x94 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xec 0xdf 0xce 0x01 0x02 0x96 memory contents: 0x6f 0x91 0x5f 0x91 0x4f 0x91 0x3f 0x91 0x2f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xf8 0x94 0x69 0xdf 0x1e 0xd0 0x2b 0xd2 0xd2 0xde 0x78 0x94 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xec 0xdf 0xce 0x01 0x02 0x96 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 704 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 4 [34] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [02] . [00] . [00] . [ef] . [b7] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 52 (command_sequence == 52) avrdude: Recv: . [82] ' [27] . [df] . [88] # [23] . [d9] . [f3] . [80] . [e3] . [d6] . [de] . [ea] . [81] . [fb] . [81] . [80] . [81] . [89] . [83] . [89] . [81] . [88] # [23] . [91] . [f3] . [83] . [e1] . [cd] . [de] . [ef] . [cf] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [e8] . [e6] . [f0] . [e0] . [84] . [e0] . [80] . [83] . [ad] . [e6] . [b0] . [e0] . [ed] . [e6] . [f0] . [e0] . [80] . [81] . [83] i [69] . [8c] . [93] . [cf] . [91] . [df] . [91] Raw message: 0x82 0x27 0xdf 0x88 0x23 0xd9 0xf3 0x80 0xe3 0xd6 0xde 0xea 0x81 0xfb 0x81 0x80 0x81 0x89 0x83 0x89 0x81 0x88 0x23 0x91 0xf3 0x83 0xe1 0xcd 0xde 0xef 0xcf 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xe8 0xe6 0xf0 0xe0 0x84 0xe0 0x80 0x83 0xad 0xe6 0xb0 0xe0 0xed 0xe6 0xf0 0xe0 0x80 0x81 0x83 0x69 0x8c 0x93 0xcf 0x91 0xdf 0x91 memory contents: 0x27 0xdf 0x88 0x23 0xd9 0xf3 0x80 0xe3 0xd6 0xde 0xea 0x81 0xfb 0x81 0x80 0x81 0x89 0x83 0x89 0x81 0x88 0x23 0x91 0xf3 0x83 0xe1 0xcd 0xde 0xef 0xcf 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xe8 0xe6 0xf0 0xe0 0x84 0xe0 0x80 0x83 0xad 0xe6 0xb0 0xe0 0xed 0xe6 0xf0 0xe0 0x80 0x81 0x83 0x69 0x8c 0x93 0xcf 0x91 0xdf 0x91 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 768 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 5 [35] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [03] . [00] . [00] . [e5] . [c6] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 53 (command_sequence == 53) avrdude: Recv: . [82] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] . [8f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [e8] . [e6] . [f0] . [e0] . [80] . [81] . [e8] . [e6] . [f0] . [e0] . [10] . [82] . [e6] . [e4] . [f0] . [e0] . [10] . [82] . [a5] . [e4] . [b0] . [e0] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [8c] . [93] Raw message: 0x82 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xe8 0xe6 0xf0 0xe0 0x80 0x81 0xe8 0xe6 0xf0 0xe0 0x10 0x82 0xe6 0xe4 0xf0 0xe0 0x10 0x82 0xa5 0xe4 0xb0 0xe0 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0x84 0x60 0x8c 0x93 memory contents: 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xe8 0xe6 0xf0 0xe0 0x80 0x81 0xe8 0xe6 0xf0 0xe0 0x10 0x82 0xe6 0xe4 0xf0 0xe0 0x10 0x82 0xa5 0xe4 0xb0 0xe0 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0x84 0x60 0x8c 0x93 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 832 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 6 [36] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [03] . [00] . [00] C [43] . [e0] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 54 (command_sequence == 54) avrdude: Recv: . [82] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [8f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [89] . [83] . [89] . [81] . [8f] ? [3f] . [19] . [f0] . [89] . [81] . [80] . [93] . [0c] . [01] . [80] . [91] . [0c] . [01] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] Raw message: 0x82 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x89 0x83 0x89 0x81 0x8f 0x3f 0x19 0xf0 0x89 0x81 0x80 0x93 0x0c 0x01 0x80 0x91 0x0c 0x01 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 memory contents: 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x89 0x83 0x89 0x81 0x8f 0x3f 0x19 0xf0 0x89 0x81 0x80 0x93 0x0c 0x01 0x80 0x91 0x0c 0x01 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 896 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 7 [37] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [03] . [00] . [00] . [95] . [cb] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 55 (command_sequence == 55) avrdude: Recv: . [82] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [89] . [83] . [89] . [81] . [8f] ? [3f] . [19] . [f0] . [89] . [81] . [80] . [93] . [0d] . [01] . [80] . [91] . [0d] . [01] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [19] . [82] . [e9] . [e2] . [f0] . [e0] . [80] . [81] . [88] / [2f] . [90] . [e0] . [85] p [70] . [90] p [70] . [00] . [97] . [11] . [f4] Raw message: 0x82 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x89 0x83 0x89 0x81 0x8f 0x3f 0x19 0xf0 0x89 0x81 0x80 0x93 0x0d 0x01 0x80 0x91 0x0d 0x01 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x19 0x82 0xe9 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x2f 0x90 0xe0 0x85 0x70 0x90 0x70 0x00 0x97 0x11 0xf4 memory contents: 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x89 0x83 0x89 0x81 0x8f 0x3f 0x19 0xf0 0x89 0x81 0x80 0x93 0x0d 0x01 0x80 0x91 0x0d 0x01 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0x19 0x82 0xe9 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x2f 0x90 0xe0 0x85 0x70 0x90 0x70 0x00 0x97 0x11 0xf4 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 960 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 8 [38] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [03] . [00] . [00] w [77] - [2d] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 56 (command_sequence == 56) avrdude: Recv: . [82] . [83] . [e0] . [89] . [83] . [e9] . [e2] . [f0] . [e0] . [80] . [81] . [88] / [2f] . [90] . [e0] . [86] p [70] . [90] p [70] . [00] . [97] ! [21] . [f4] . [89] . [81] . [91] . [e0] . [89] ' [27] . [89] . [83] . [89] . [81] . [bc] . [df] . [80] . [e0] . [cc] . [df] . [e5] . [e4] . [f0] . [e0] . [82] . [e0] . [80] . [83] . [e8] . [e4] . [f0] . [e0] . [8c] . [e7] . [80] . [83] . [ae] . [e6] . [b0] . [e0] . [ee] . [e6] . [f0] . [e0] . [80] . [81] Raw message: 0x82 0x83 0xe0 0x89 0x83 0xe9 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x2f 0x90 0xe0 0x86 0x70 0x90 0x70 0x00 0x97 0x21 0xf4 0x89 0x81 0x91 0xe0 0x89 0x27 0x89 0x83 0x89 0x81 0xbc 0xdf 0x80 0xe0 0xcc 0xdf 0xe5 0xe4 0xf0 0xe0 0x82 0xe0 0x80 0x83 0xe8 0xe4 0xf0 0xe0 0x8c 0xe7 0x80 0x83 0xae 0xe6 0xb0 0xe0 0xee 0xe6 0xf0 0xe0 0x80 0x81 memory contents: 0x83 0xe0 0x89 0x83 0xe9 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x2f 0x90 0xe0 0x86 0x70 0x90 0x70 0x00 0x97 0x21 0xf4 0x89 0x81 0x91 0xe0 0x89 0x27 0x89 0x83 0x89 0x81 0xbc 0xdf 0x80 0xe0 0xcc 0xdf 0xe5 0xe4 0xf0 0xe0 0x82 0xe0 0x80 0x83 0xe8 0xe4 0xf0 0xe0 0x8c 0xe7 0x80 0x83 0xae 0xe6 0xb0 0xe0 0xee 0xe6 0xf0 0xe0 0x80 0x81 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1024 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] 9 [39] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [04] . [00] . [00] . [a4] . [8a] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 57 (command_sequence == 57) avrdude: Recv: . [82] . [84] ` [60] . [8c] . [93] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [f8] . [94] . [8f] . [ef] . [b1] . [df] . [89] . [83] . [89] . [81] . [81] p [70] . [ad] . [df] x [78] . [94] . [89] . [81] . [85] . [95] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [a8] . [e8] . [b0] . [e0] . [e4] . [e8] Raw message: 0x82 0x84 0x60 0x8c 0x93 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xf8 0x94 0x8f 0xef 0xb1 0xdf 0x89 0x83 0x89 0x81 0x81 0x70 0xad 0xdf 0x78 0x94 0x89 0x81 0x85 0x95 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xa8 0xe8 0xb0 0xe0 0xe4 0xe8 memory contents: 0x84 0x60 0x8c 0x93 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xf8 0x94 0x8f 0xef 0xb1 0xdf 0x89 0x83 0x89 0x81 0x81 0x70 0xad 0xdf 0x78 0x94 0x89 0x81 0x85 0x95 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xa8 0xe8 0xb0 0xe0 0xe4 0xe8 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1088 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] : [3a] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [04] . [00] . [00] . [02] . [ac] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 58 (command_sequence == 58) avrdude: Recv: . [82] . [f0] . [e0] . [80] . [81] . [91] . [81] . [01] . [96] . [11] . [96] . [9c] . [93] . [8e] . [93] . [e0] . [e8] . [f0] . [e0] . [80] . [ec] . [80] . [83] . [e1] . [e8] . [f0] . [e0] . [81] . [e8] . [80] . [83] . [e6] . [e3] . [f0] . [e0] . [80] . [e2] . [80] . [83] . [ef] . [e6] . [f0] . [e0] . [82] . [e2] . [80] . [83] . [10] . [92] . [11] . [01] . [10] . [92] . [12] . [01] . [a4] . [e2] . [b0] . [e0] . [e4] . [e2] . [f0] . [e0] . [80] . [81] Raw message: 0x82 0xf0 0xe0 0x80 0x81 0x91 0x81 0x01 0x96 0x11 0x96 0x9c 0x93 0x8e 0x93 0xe0 0xe8 0xf0 0xe0 0x80 0xec 0x80 0x83 0xe1 0xe8 0xf0 0xe0 0x81 0xe8 0x80 0x83 0xe6 0xe3 0xf0 0xe0 0x80 0xe2 0x80 0x83 0xef 0xe6 0xf0 0xe0 0x82 0xe2 0x80 0x83 0x10 0x92 0x11 0x01 0x10 0x92 0x12 0x01 0xa4 0xe2 0xb0 0xe0 0xe4 0xe2 0xf0 0xe0 0x80 0x81 memory contents: 0xf0 0xe0 0x80 0x81 0x91 0x81 0x01 0x96 0x11 0x96 0x9c 0x93 0x8e 0x93 0xe0 0xe8 0xf0 0xe0 0x80 0xec 0x80 0x83 0xe1 0xe8 0xf0 0xe0 0x81 0xe8 0x80 0x83 0xe6 0xe3 0xf0 0xe0 0x80 0xe2 0x80 0x83 0xef 0xe6 0xf0 0xe0 0x82 0xe2 0x80 0x83 0x10 0x92 0x11 0x01 0x10 0x92 0x12 0x01 0xa4 0xe2 0xb0 0xe0 0xe4 0xe2 0xf0 0xe0 0x80 0x81 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1152 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] ; [3b] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [04] . [00] . [00] . [d4] . [87] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 59 (command_sequence == 59) avrdude: Recv: . [82] . [80] h [68] . [8c] . [93] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [80] . [91] . [12] . [01] . [88] # [23] . [e1] . [f3] . [10] . [92] . [12] . [01] . [80] . [91] . [10] . [01] . [cf] . [91] . [df] . [91] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] Raw message: 0x82 0x80 0x68 0x8c 0x93 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0x80 0x91 0x12 0x01 0x88 0x23 0xe1 0xf3 0x10 0x92 0x12 0x01 0x80 0x91 0x10 0x01 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 memory contents: 0x80 0x68 0x8c 0x93 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0x80 0x91 0x12 0x01 0x88 0x23 0xe1 0xf3 0x10 0x92 0x12 0x01 0x80 0x91 0x10 0x01 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1216 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] < [3c] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [04] . [00] . [00] N [4e] . [e1] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 60 (command_sequence == 60) avrdude: Recv: . [82] . [cf] . [93] . [cd] . [b7] . [de] . [b7] . [aa] . [e8] . [b0] . [e0] . [e6] . [e8] . [f0] . [e0] . [80] . [81] . [91] . [81] . [8f] Q [51] . [9b] O [4f] . [11] . [96] . [9c] . [93] . [8e] . [93] . [10] . [92] . [13] . [01] . [81] . [e0] . [80] . [93] . [0f] . [01] . [e6] . [e3] . [f0] . [e0] . [84] . [e0] . [80] . [83] . [e3] . [e2] . [f0] . [e0] . [80] . [81] . [88] / [2f] . [90] . [e0] . [80] q [71] . [90] p [70] . [00] . [97] ! [21] . [f4] Raw message: 0x82 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xaa 0xe8 0xb0 0xe0 0xe6 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x51 0x9b 0x4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x10 0x92 0x13 0x01 0x81 0xe0 0x80 0x93 0x0f 0x01 0xe6 0xe3 0xf0 0xe0 0x84 0xe0 0x80 0x83 0xe3 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x2f 0x90 0xe0 0x80 0x71 0x90 0x70 0x00 0x97 0x21 0xf4 memory contents: 0xcf 0x93 0xcd 0xb7 0xde 0xb7 0xaa 0xe8 0xb0 0xe0 0xe6 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x51 0x9b 0x4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x10 0x92 0x13 0x01 0x81 0xe0 0x80 0x93 0x0f 0x01 0xe6 0xe3 0xf0 0xe0 0x84 0xe0 0x80 0x83 0xe3 0xe2 0xf0 0xe0 0x80 0x81 0x88 0x2f 0x90 0xe0 0x80 0x71 0x90 0x70 0x00 0x97 0x21 0xf4 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1280 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] = [3d] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [05] . [00] . [00] D [44] . [90] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 61 (command_sequence == 61) avrdude: Recv: . [82] . [ef] . [e6] . [f0] . [e0] . [86] . [e0] . [80] . [83] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] O [4f] . [93] _ [5f] . [93] o [6f] . [93] . [7f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] Raw message: 0x82 0xef 0xe6 0xf0 0xe0 0x86 0xe0 0x80 0x83 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x2f 0x93 0x3f 0x93 0x4f 0x93 0x5f 0x93 0x6f 0x93 0x7f 0x93 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 memory contents: 0xef 0xe6 0xf0 0xe0 0x86 0xe0 0x80 0x83 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x2f 0x93 0x3f 0x93 0x4f 0x93 0x5f 0x93 0x6f 0x93 0x7f 0x93 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1344 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] > [3e] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [05] . [00] . [00] . [e2] . [b6] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 62 (command_sequence == 62) avrdude: Recv: . [82] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] . [de] . [b7] . [e3] . [e2] . [f0] . [e0] . [80] . [81] . [89] . [83] . [80] . [91] . [0f] . [01] . [88] # [23] . [f9] . [f0] . [89] . [81] . [88] / [2f] . [90] . [e0] . [80] q [71] . [90] p [70] . [00] . [97] 9 [39] . [f0] . [80] . [91] . [13] . [01] . [90] . [91] . [0f] . [01] . [89] + [2b] . [80] . [93] . [13] . [01] . [80] . [91] . [0f] . [01] . [88] . [0f] Raw message: 0x82 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xe3 0xe2 0xf0 0xe0 0x80 0x81 0x89 0x83 0x80 0x91 0x0f 0x01 0x88 0x23 0xf9 0xf0 0x89 0x81 0x88 0x2f 0x90 0xe0 0x80 0x71 0x90 0x70 0x00 0x97 0x39 0xf0 0x80 0x91 0x13 0x01 0x90 0x91 0x0f 0x01 0x89 0x2b 0x80 0x93 0x13 0x01 0x80 0x91 0x0f 0x01 0x88 0x0f memory contents: 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 0xde 0xb7 0xe3 0xe2 0xf0 0xe0 0x80 0x81 0x89 0x83 0x80 0x91 0x0f 0x01 0x88 0x23 0xf9 0xf0 0x89 0x81 0x88 0x2f 0x90 0xe0 0x80 0x71 0x90 0x70 0x00 0x97 0x39 0xf0 0x80 0x91 0x13 0x01 0x90 0x91 0x0f 0x01 0x89 0x2b 0x80 0x93 0x13 0x01 0x80 0x91 0x0f 0x01 0x88 0x0f #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1408 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] ? [3f] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [05] . [00] . [00] 4 [34] . [9d] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 63 (command_sequence == 63) avrdude: Recv: . [82] . [80] . [93] . [0f] . [01] . [aa] . [e8] . [b0] . [e0] . [ea] . [e8] . [f0] . [e0] . [80] . [81] . [91] . [81] . [8f] [ [5b] . [9c] O [4f] . [11] . [96] . [9c] . [93] . [8e] . [93] . [1a] . [c0] . [81] . [e0] . [80] . [93] . [12] . [01] . [80] . [91] . [13] . [01] . [80] . [93] . [10] . [01] . [e6] . [e3] . [f0] . [e0] . [80] . [e2] . [80] . [83] . [ef] . [e6] . [f0] . [e0] . [82] . [e2] . [80] . [83] . [80] . [91] . [10] . [01] . [8a] 1 [31] Raw message: 0x82 0x80 0x93 0x0f 0x01 0xaa 0xe8 0xb0 0xe0 0xea 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x5b 0x9c 0x4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x1a 0xc0 0x81 0xe0 0x80 0x93 0x12 0x01 0x80 0x91 0x13 0x01 0x80 0x93 0x10 0x01 0xe6 0xe3 0xf0 0xe0 0x80 0xe2 0x80 0x83 0xef 0xe6 0xf0 0xe0 0x82 0xe2 0x80 0x83 0x80 0x91 0x10 0x01 0x8a 0x31 memory contents: 0x80 0x93 0x0f 0x01 0xaa 0xe8 0xb0 0xe0 0xea 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x5b 0x9c 0x4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x1a 0xc0 0x81 0xe0 0x80 0x93 0x12 0x01 0x80 0x91 0x13 0x01 0x80 0x93 0x10 0x01 0xe6 0xe3 0xf0 0xe0 0x80 0xe2 0x80 0x83 0xef 0xe6 0xf0 0xe0 0x82 0xe2 0x80 0x83 0x80 0x91 0x10 0x01 0x8a 0x31 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1472 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] @ [40] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [05] . [00] . [00] q [71] A [41] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 64 (command_sequence == 64) avrdude: Recv: . [82] 8 [38] . [f0] . [80] . [91] . [10] . [01] . [8f] 7 [37] . [18] . [f4] . [80] . [91] . [10] . [01] . [14] . [d0] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [7f] . [91] o [6f] . [91] _ [5f] . [91] O [4f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [0f] . [92] . [cd] . [b7] Raw message: 0x82 0x38 0xf0 0x80 0x91 0x10 0x01 0x8f 0x37 0x18 0xf4 0x80 0x91 0x10 0x01 0x14 0xd0 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x7f 0x91 0x6f 0x91 0x5f 0x91 0x4f 0x91 0x3f 0x91 0x2f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 memory contents: 0x38 0xf0 0x80 0x91 0x10 0x01 0x8f 0x37 0x18 0xf4 0x80 0x91 0x10 0x01 0x14 0xd0 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x7f 0x91 0x6f 0x91 0x5f 0x91 0x4f 0x91 0x3f 0x91 0x2f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x0f 0x92 0xcd 0xb7 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1536 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] A [41] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [06] . [00] . [00] . [c3] . [85] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 65 (command_sequence == 65) avrdude: Recv: . [82] . [de] . [b7] . [89] . [83] . [80] . [91] . [11] . [01] . [88] # [23] . [e1] . [f7] . [89] . [81] . [80] . [95] . [80] . [93] . [0e] . [01] . [8a] . [e0] . [80] . [93] . [11] . [01] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [9a] . [83] . [89] . [83] . [0a] . [c0] . [e9] . [81] . [fa] . [81] [20] . [81] . [89] . [81] . [9a] . [81] . [01] . [96] . [9a] . [83] Raw message: 0x82 0xde 0xb7 0x89 0x83 0x80 0x91 0x11 0x01 0x88 0x23 0xe1 0xf7 0x89 0x81 0x80 0x95 0x80 0x93 0x0e 0x01 0x8a 0xe0 0x80 0x93 0x11 0x01 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x9a 0x83 0x89 0x83 0x0a 0xc0 0xe9 0x81 0xfa 0x81 0x20 0x81 0x89 0x81 0x9a 0x81 0x01 0x96 0x9a 0x83 memory contents: 0xde 0xb7 0x89 0x83 0x80 0x91 0x11 0x01 0x88 0x23 0xe1 0xf7 0x89 0x81 0x80 0x95 0x80 0x93 0x0e 0x01 0x8a 0xe0 0x80 0x93 0x11 0x01 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x9a 0x83 0x89 0x83 0x0a 0xc0 0xe9 0x81 0xfa 0x81 0x20 0x81 0x89 0x81 0x9a 0x81 0x01 0x96 0x9a 0x83 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1600 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] B [42] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [06] . [00] . [00] e [65] . [a3] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 66 (command_sequence == 66) avrdude: Recv: . [82] . [89] . [83] . [82] / [2f] . [d9] . [df] . [e9] . [81] . [fa] . [81] . [80] . [81] . [88] # [23] . [89] . [f7] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [ef] . [93] . [ff] . [93] . [df] . [93] . [cf] . [93] . [00] . [d0] . [cd] . [b7] . [de] . [b7] . [1a] . [82] . [19] . [82] . [a8] . [e8] Raw message: 0x82 0x89 0x83 0x82 0x2f 0xd9 0xdf 0xe9 0x81 0xfa 0x81 0x80 0x81 0x88 0x23 0x89 0xf7 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x1a 0x82 0x19 0x82 0xa8 0xe8 memory contents: 0x89 0x83 0x82 0x2f 0xd9 0xdf 0xe9 0x81 0xfa 0x81 0x80 0x81 0x88 0x23 0x89 0xf7 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0x1f 0x92 0x0f 0x92 0x0f 0xb6 0x0f 0x92 0x11 0x24 0x8f 0x93 0x9f 0x93 0xaf 0x93 0xbf 0x93 0xef 0x93 0xff 0x93 0xdf 0x93 0xcf 0x93 0x00 0xd0 0xcd 0xb7 0xde 0xb7 0x1a 0x82 0x19 0x82 0xa8 0xe8 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1664 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] C [43] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [80] . [06] . [00] . [00] . [b3] . [88] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 67 (command_sequence == 67) avrdude: Recv: . [82] . [b0] . [e0] . [e8] . [e8] . [f0] . [e0] . [80] . [81] . [91] . [81] . [8f] [ [5b] . [9c] O [4f] . [11] . [96] . [9c] . [93] . [8e] . [93] . [80] . [91] . [11] . [01] . [89] . [83] . [89] . [81] . [88] # [23] . [d1] . [f0] . [89] . [81] . [81] P [50] . [89] . [83] . [89] . [81] . [80] . [93] . [11] . [01] . [80] . [e8] . [8a] . [83] . [89] . [81] . [89] 0 [30] y [79] . [f0] . [80] . [91] . [0e] . [01] . [88] / [2f] . [90] . [e0] . [81] p [70] Raw message: 0x82 0xb0 0xe0 0xe8 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x5b 0x9c 0x4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x80 0x91 0x11 0x01 0x89 0x83 0x89 0x81 0x88 0x23 0xd1 0xf0 0x89 0x81 0x81 0x50 0x89 0x83 0x89 0x81 0x80 0x93 0x11 0x01 0x80 0xe8 0x8a 0x83 0x89 0x81 0x89 0x30 0x79 0xf0 0x80 0x91 0x0e 0x01 0x88 0x2f 0x90 0xe0 0x81 0x70 memory contents: 0xb0 0xe0 0xe8 0xe8 0xf0 0xe0 0x80 0x81 0x91 0x81 0x8f 0x5b 0x9c 0x4f 0x11 0x96 0x9c 0x93 0x8e 0x93 0x80 0x91 0x11 0x01 0x89 0x83 0x89 0x81 0x88 0x23 0xd1 0xf0 0x89 0x81 0x81 0x50 0x89 0x83 0x89 0x81 0x80 0x93 0x11 0x01 0x80 0xe8 0x8a 0x83 0x89 0x81 0x89 0x30 0x79 0xf0 0x80 0x91 0x0e 0x01 0x88 0x2f 0x90 0xe0 0x81 0x70 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1728 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] D [44] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [c0] . [06] . [00] . [00] ) [29] . [ee] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 68 (command_sequence == 68) avrdude: Recv: . [82] . [90] p [70] . [00] . [97] . [11] . [f4] . [80] . [ec] . [8a] . [83] . [80] . [91] . [0e] . [01] . [86] . [95] . [80] . [93] . [0e] . [01] . [e0] . [e8] . [f0] . [e0] . [8a] . [81] . [80] . [83] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [ff] . [91] . [ef] . [91] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] . [df] . [93] . [cf] . [93] . [00] . [d0] Raw message: 0x82 0x90 0x70 0x00 0x97 0x11 0xf4 0x80 0xec 0x8a 0x83 0x80 0x91 0x0e 0x01 0x86 0x95 0x80 0x93 0x0e 0x01 0xe0 0xe8 0xf0 0xe0 0x8a 0x81 0x80 0x83 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 memory contents: 0x90 0x70 0x00 0x97 0x11 0xf4 0x80 0xec 0x8a 0x83 0x80 0x91 0x0e 0x01 0x86 0x95 0x80 0x93 0x0e 0x01 0xe0 0xe8 0xf0 0xe0 0x8a 0x81 0x80 0x83 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0xff 0x91 0xef 0x91 0xbf 0x91 0xaf 0x91 0x9f 0x91 0x8f 0x91 0x0f 0x90 0x0f 0xbe 0x0f 0x90 0x1f 0x90 0x18 0x95 0xdf 0x93 0xcf 0x93 0x00 0xd0 #avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1792 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] E [45] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] . [00] . [07] . [00] . [00] # [23] . [9f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 69 (command_sequence == 69) avrdude: Recv: . [82] . [cd] . [b7] . [de] . [b7] . [e4] . [e6] . [f0] . [e0] . [80] . [81] . [e4] . [e6] . [f0] . [e0] . [10] . [82] . [a5] . [e4] . [b0] . [e0] . [e5] . [e4] . [f0] . [e0] . [80] . [81] . [88] ` [60] . [8c] . [93] . [e7] . [e4] . [f0] . [e0] . [80] . [e5] . [80] . [83] . [ae] . [e6] . [b0] . [e0] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [82] ` [60] . [8c] . [93] . [e6] . [e4] . [f0] . [e0] . [10] . [82] . [e5] . [e4] . [f0] . [e0] . [80] . [81] Raw message: 0x82 0xcd 0xb7 0xde 0xb7 0xe4 0xe6 0xf0 0xe0 0x80 0x81 0xe4 0xe6 0xf0 0xe0 0x10 0x82 0xa5 0xe4 0xb0 0xe0 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0x88 0x60 0x8c 0x93 0xe7 0xe4 0xf0 0xe0 0x80 0xe5 0x80 0x83 0xae 0xe6 0xb0 0xe0 0xee 0xe6 0xf0 0xe0 0x80 0x81 0x82 0x60 0x8c 0x93 0xe6 0xe4 0xf0 0xe0 0x10 0x82 0xe5 0xe4 0xf0 0xe0 0x80 0x81 memory contents: 0xcd 0xb7 0xde 0xb7 0xe4 0xe6 0xf0 0xe0 0x80 0x81 0xe4 0xe6 0xf0 0xe0 0x10 0x82 0xa5 0xe4 0xb0 0xe0 0xe5 0xe4 0xf0 0xe0 0x80 0x81 0x88 0x60 0x8c 0x93 0xe7 0xe4 0xf0 0xe0 0x80 0xe5 0x80 0x83 0xae 0xe6 0xb0 0xe0 0xee 0xe6 0xf0 0xe0 0x80 0x81 0x82 0x60 0x8c 0x93 0xe6 0xe4 0xf0 0xe0 0x10 0x82 0xe5 0xe4 0xf0 0xe0 0x80 0x81 ##avrdude: jtagmkII_paged_load(.., flash, 64, 64) avrdude: jtagmkII_paged_load(): block_size at addr 1856 is 64 avrdude: jtagmkII_paged_load(): Sending read memory command: avrdude: jtagmkII_send(): sending 10 bytes avrdude: Sent: . [1b] F [46] . [00] . [0a] . [00] . [00] . [00] . [0e] . [05] . [b0] @ [40] . [00] . [00] . [00] @ [40] . [07] . [00] . [00] . [85] . [b9] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 70 (command_sequence == 70) avrdude: Recv: . [82] . [e5] . [e4] . [f0] . [e0] . [10] . [82] . [0f] . [90] . [0f] . [90] . [cf] . [91] . [df] . [91] . [08] . [95] . [f8] . [94] . [ff] . [cf] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] . [ff] Raw message: 0x82 0xe5 0xe4 0xf0 0xe0 0x10 0x82 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xf8 0x94 0xff 0xcf 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff memory contents: 0xe5 0xe4 0xf0 0xe0 0x10 0x82 0x0f 0x90 0x0f 0x90 0xcf 0x91 0xdf 0x91 0x08 0x95 0xf8 0x94 0xff 0xcf 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff ## | 100% 0.62s avrdude: avr_read(): skipping page 30: no interesting data avrdude: avr_read(): skipping page 31: no interesting data avrdude: avr_read(): skipping page 32: no interesting data avrdude: avr_read(): skipping page 33: no interesting data avrdude: avr_read(): skipping page 34: no interesting data avrdude: avr_read(): skipping page 35: no interesting data avrdude: avr_read(): skipping page 36: no interesting data avrdude: avr_read(): skipping page 37: no interesting data avrdude: avr_read(): skipping page 38: no interesting data avrdude: avr_read(): skipping page 39: no interesting data avrdude: avr_read(): skipping page 40: no interesting data avrdude: avr_read(): skipping page 41: no interesting data avrdude: avr_read(): skipping page 42: no interesting data avrdude: avr_read(): skipping page 43: no interesting data avrdude: avr_read(): skipping page 44: no interesting data avrdude: avr_read(): skipping page 45: no interesting data avrdude: avr_read(): skipping page 46: no interesting data avrdude: avr_read(): skipping page 47: no interesting data avrdude: avr_read(): skipping page 48: no interesting data avrdude: avr_read(): skipping page 49: no interesting data avrdude: avr_read(): skipping page 50: no interesting data avrdude: avr_read(): skipping page 51: no interesting data avrdude: avr_read(): skipping page 52: no interesting data avrdude: avr_read(): skipping page 53: no interesting data avrdude: avr_read(): skipping page 54: no interesting data avrdude: avr_read(): skipping page 55: no interesting data avrdude: avr_read(): skipping page 56: no interesting data avrdude: avr_read(): skipping page 57: no interesting data avrdude: avr_read(): skipping page 58: no interesting data avrdude: avr_read(): skipping page 59: no interesting data avrdude: avr_read(): skipping page 60: no interesting data avrdude: avr_read(): skipping page 61: no interesting data avrdude: avr_read(): skipping page 62: no interesting data avrdude: avr_read(): skipping page 63: no interesting data avrdude: verifying ... avrdude: 1876 bytes of flash verified avrdude: jtagmkII_close() avrdude: jtagmkII_close(): Sending sign-off command: avrdude: jtagmkII_send(): sending 1 bytes avrdude: Sent: . [1b] G [47] . [00] . [01] . [00] . [00] . [00] . [0e] . [00] . [85] . [7f] avrdude: jtagmkII_recv(): avrdude: jtagmkII_recv(): Got message seqno 71 (command_sequence == 71) avrdude: Recv: . [80] Raw message: 0x80 OK avrdude done. Thank you.
