Found JTAG ICE, serno: 00B00000296A AVaRICE version 2.6, May 15 2007 17:07:24 Defaulting JTAG bitrate to 1 MHz. Make sure that the target frequency is at least 4 MHz or you will likely encounter failures controlling the target. Attempting synchronisation at bitrate 19200 command[0x01, 1]: 01 Found JTAG ICE, serno: 00B00000296A recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x1c recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 28 bytes read: 86 01 ff 21 04 00 ff 21 04 01 00 b0 00 00 29 6a 4a 54 41 47 49 43 45 6d 6b 49 49 00 recv: 0x12 recv: 0xd8 CRC OK Got message seqno 0 (command_sequence == 0) response: 86 01 FF 21 04 00 FF 21 04 01 00 B0 00 00 29 6A 4A 54 41 47 49 43 45 6D 6B 49 49 00 JTAG ICE mkII sign-on message: Communications protocol version: 1 M_MCU: boot-loader FW version: 255 firmware version: 4.33 hardware version: 0 S_MCU: boot-loader FW version: 255 firmware version: 4.33 hardware version: 1 command[0x02, 1]: 02 03 01 recv: 0x1b recv: 0x01 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xcd recv: 0x83 CRC OK Got message seqno 1 (command_sequence == 1) response: 80 command[0x0a, 1]: 0A 01 recv: 0x1b recv: 0x02 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x1d recv: 0x09 CRC OK Got message seqno 2 (command_sequence == 2) response: 80 Automatic device detection: command[0x03, 1]: 03 0E recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 4b 00 00 00 00 recv: 0x80 recv: 0xab CRC OK Got message seqno 65535 (command_sequence == 3) got asynchronous event: 0xe0 recv: 0x1b recv: 0x03 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 81 3f 30 40 b9 recv: 0x34 recv: 0xfc CRC OK Got message seqno 3 (command_sequence == 3) response: 81 3F 30 40 B9 JTAG id = 0xB940303F : Ver = 0xb : Device = 0x9403 : Manuf = 0x1f Looking for device: atmega16 command[0x0c, 1]: 0C FF 6F FF FF FE FF FD FF 00 00 00 00 01 00 00 00 8F 26 B6 FD FE FF BD FA 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 31 57 00 80 00 04 80 1F 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E 3D 80 00 00 00 01 00 00 01 00 60 00 00 00 00 00 1C 00 recv: 0x1b recv: 0x04 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xac recv: 0x14 CRC OK Got message seqno 4 (command_sequence == 4) response: 80 command[0x14, 1]: 14 recv: 0x1b recv: 0x05 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x13 recv: 0x95 CRC OK Got message seqno 5 (command_sequence == 5) response: 80 command[0x13, 1]: 13 recv: 0x1b recv: 0x06 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xc3 recv: 0x1f CRC OK Got message seqno 6 (command_sequence == 6) response: 80 command[0x15, 1]: 15 recv: 0x1b recv: 0x07 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x7c recv: 0x9e CRC OK Got message seqno 7 (command_sequence == 7) response: 80 command[0x02, 1]: 02 07 05 recv: 0x1b recv: 0x08 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xce recv: 0x2f CRC OK Got message seqno 8 (command_sequence == 8) response: 80 command[0x14, 1]: 14 recv: 0x1b recv: 0x09 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x71 recv: 0xae CRC OK Got message seqno 9 (command_sequence == 9) response: 80 jtagRead command[0x05, 1]: 05 B3 01 00 00 00 00 00 00 00 recv: 0x1b recv: 0x0a recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 ff recv: 0x01 recv: 0x20 CRC OK Got message seqno 10 (command_sequence == 10) response: 82 FF jtagRead command[0x05, 1]: 05 B2 03 00 00 00 00 00 00 00 recv: 0x1b recv: 0x0b recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 ff 19 ff recv: 0xa5 recv: 0x84 CRC OK Got message seqno 11 (command_sequence == 11) response: 82 FF 19 FF command[0x15, 1]: 15 recv: 0x1b recv: 0x0c recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x10 recv: 0x39 CRC OK Got message seqno 12 (command_sequence == 12) response: 80 command[0x0b, 1]: 0B 01 recv: 0x1b recv: 0x0d recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xaf recv: 0xb8 CRC OK Got message seqno 13 (command_sequence == 13) response: 80 command[0x02, 1]: 02 09 00 recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 00 00 00 00 00 recv: 0x4e recv: 0x2d CRC OK Got message seqno 65535 (command_sequence == 14) got asynchronous event: 0xe0 recv: 0x1b recv: 0x0e recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x7f recv: 0x32 CRC OK Got message seqno 14 (command_sequence == 14) response: 80 command[0x0b, 1]: 0B 01 recv: 0x1b recv: 0x0f recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xc0 recv: 0xb3 CRC OK Got message seqno 15 (command_sequence == 15) response: 80 Flash page size: 0x80 EEPROM page size: 0x4 Getting section contents, addr=0x0 size=0xc0 FLASH Image create: Adding .text at addr 0x0 size 192 (0xc0) command[0x14, 1]: 14 recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 00 00 00 00 00 recv: 0x4e recv: 0x2d CRC OK Got message seqno 65535 (command_sequence == 16) got asynchronous event: 0xe0 recv: 0x1b recv: 0x10 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x0a recv: 0x59 CRC OK Got message seqno 16 (command_sequence == 16) response: JTAG config starting. Found a device: JTAGICEmkII Serial number: 00:b0:00:00:29:6a Reported JTAG device ID: 0x9403 Configured for device ID: 0x9403 atmega16 -- Matched with atmega16 JTAG config complete. Erasing program memory. Erase complete. Preparing the target device for On Chip Debugging. Disabling lock bits: LockBits -> 0xff Enabling on-chip debugging: Extended Fuse byte -> 0xff High Fuse byte -> 0x19 Low Fuse byte -> 0xff Downloading FLASH image to target.80 Writing page at addr 0x0000 size 0x80 jtagWrite command[0x04, 1]: 04 B0 80 00 00 00 00 00 00 00 0C 94 2A 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 11 24 1F BE CF E5 D4 E0 DE BF CD BF 10 E0 A0 E6 B0 E0 E0 EC F0 E0 02 C0 05 90 0D 92 A0 36 B1 07 D9 F7 10 E0 A0 E6 B0 E0 01 C0 1D 92 recv: 0x1b recv: 0x11 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xb5 .recv: 0xd8 CRC OK Got message seqno 17 (command_sequence == 17) response: 80 Writing page at addr 0x0080 size 0x80 jtagWrite command[0x04, 1]: 04 B0 80 00 00 00 80 00 00 00 A0 36 B1 07 E1 F7 0E 94 49 00 0C 94 5F 00 0C 94 00 00 CF 93 DF 93 CD B7 DE B7 21 97 0F B6 F8 94 DE BF 0F BE CD BF EA E3 F0 E0 8F EF 80 83 EB E3 F0 E0 8F E0 80 83 E1 E3 F0 E0 10 82 FF CF FF CF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 recv: 0x1b recv: 0x12 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x65 recv: 0x52 . CRC OK Got message seqno 18 (command_sequence == 18) response: 80 command[0x15, 1]: 15 recv: 0x1b recv: 0x13 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xda recv: 0xd3 CRC OK Got message seqno 19 (command_sequence == 19) response: 80 command[0x0b, 1]: 0B 01 recv: 0x1b recv: 0x14 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xd4 recv: 0x4f CRC OK Got message seqno 20 (command_sequence == 20) response: 80 GDB: ->GDB: GDB: ->GDB: GDB: ->GDB: GDB: ->GDB: S05 GDB: ->GDB: GDB: ->GDB: GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 00 00 00 00 00 recv: 0x4e recv: 0x2d CRC OK Got message seqno 65535 (command_sequence == 21) got asynchronous event: 0xe0 recv: 0x1b recv: 0x15 recv: 0x00 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 e2 16 08 12 05 60 11 a8 48 08 50 00 02 a0 b1 00 06 08 f0 0a 81 e0 0f 89 60 00 5a 04 31 00 recv: 0x6a recv: 0x30 CRC OK Got message seqno 21 (command_sequence == 21) response: 82 00 00 E2 16 08 12 05 60 11 A8 48 08 50 00 02 A0 B1 00 06 08 F0 0A 81 E0 0F 89 60 00 5A 04 31 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x16 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 00 00 00 recv: 0x8c recv: 0xc9 CRC OK Got message seqno 22 (command_sequence == 22) response: 82 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x17 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 00 00 00 00 recv: 0x47 recv: 0xdc CRC OK Got message seqno 23 (command_sequence == 23) response: 84 00 00 00 00 PC = 0 ->GDB: 0000e2160812056011a84808500002a0b1000608f00a81e00f8960005a04310000000000000000 GDB: ->GDB: GDB: ->GDB: GDB: GDB: Write 34 bytes to 0x0 jtagWrite Detected GDB "load" command, erasing flash. command[0x13, 1]: 13 recv: 0x1b recv: 0x18 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xb6 recv: 0x74 CRC OK Got message seqno 24 (command_sequence == 24) response: 80 command[0x04, 1]: 04 A0 22 00 00 00 00 00 00 00 0C 94 2A 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 recv: 0x1b recv: 0x19 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x09 recv: 0xf5 CRC OK Got message seqno 25 (command_sequence == 25) response: 80 ->GDB: OK GDB: GDB: Write 33 bytes to 0x22 jtagWrite command[0x04, 1]: 04 A0 20 00 00 00 22 00 00 00 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 recv: 0x1b recv: 0x1a recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xd9 recv: 0x7f CRC OK Got message seqno 26 (command_sequence == 26) response: 80 ->GDB: OK GDB: GDB: Write 33 bytes to 0x43 jtagWrite command[0x04, 1]: 04 A0 22 00 00 00 42 00 00 00 C5 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 0C 94 47 00 11 24 1F BE CF E5 D4 E0 DE BF CD BF 10 E0 A0 E6 recv: 0x1b recv: 0x1b recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x66 recv: 0xfe CRC OK Got message seqno 27 (command_sequence == 27) response: 80 ->GDB: OK GDB: GDB: Write 33 bytes to 0x64 jtagWrite command[0x04, 1]: 04 A0 20 00 00 00 64 00 00 00 B0 E0 E0 EC F0 E0 02 C0 05 90 0D 92 A0 36 B1 07 D9 F7 10 E0 A0 E6 B0 E0 01 C0 1D 92 A0 36 B1 07 recv: 0x1b recv: 0x1c recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x68 recv: 0x62 CRC OK Got message seqno 28 (command_sequence == 28) response: 80 ->GDB: OK GDB: GDB: Write 33 bytes to 0x85 jtagWrite command[0x04, 1]: 04 A0 22 00 00 00 84 00 00 00 C5 F7 0E 94 49 00 0C 94 5F 00 0C 94 00 00 CF 93 DF 93 CD B7 DE B7 21 97 0F B6 F8 94 DE BF 0F BE CD BF recv: 0x1b recv: 0x1d recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xd7 recv: 0xe3 CRC OK Got message seqno 29 (command_sequence == 29) response: 80 ->GDB: OK GDB: GDB: Write 26 bytes to 0xA6 jtagWrite command[0x04, 1]: 04 A0 1A 00 00 00 A6 00 00 00 EA E3 F0 E0 8F EF 80 83 EB E3 F0 E0 8F E0 80 83 E1 E3 F0 E0 10 82 FF CF FF CF recv: 0x1b recv: 0x1e recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x07 recv: 0x69 CRC OK Got message seqno 30 (command_sequence == 30) response: 80 ->GDB: OK GDB: GDB: Read 39 bytes from 0x92 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 92 00 00 00 recv: 0x1b recv: 0x1f recv: 0x00 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 f0 e0 10 82 ff cf ff cf f8 94 de bf 0f be cd bf 0f be cd bf ea e3 f0 e0 8f ef 80 83 eb e3 f0 e0 8f e0 80 83 e1 e3 f0 e0 recv: 0xfe recv: 0xff CRC OK Got message seqno 31 (command_sequence == 31) response: 82 F0 E0 10 82 FF CF FF CF F8 94 DE BF 0F BE CD BF 0F BE CD BF EA E3 F0 E0 8F EF 80 83 EB E3 F0 E0 8F E0 80 83 E1 E3 F0 E0 ->GDB: f0e01082ffcfffcff894debf0fbecdbf0fbecdbfeae3f0e08fef8083ebe3f0e08fe08083e1e3f0 GDB: GDB: Read 25 bytes from 0xB9 jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 B8 00 00 00 recv: 0x1b recv: 0x20 recv: 0x00 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 f0 e0 10 82 ff cf ff cf 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 recv: 0xe3 recv: 0x34 CRC OK Got message seqno 32 (command_sequence == 32) response: 82 F0 E0 10 82 FF CF FF CF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ->GDB: e01082ffcfffcf000000000000000000000000000000000000 GDB: BP ADD type: 1 addr: 0x92 ADDED ->GDB: OK GDB: ->GDB: GDB: ->GDB: GDB: updateBreakpoints command[0x11, 1]: 11 01 03 49 00 00 00 03 recv: 0x1b recv: 0x21 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x3d recv: 0x35 CRC OK Got message seqno 33 (command_sequence == 33) response: 80 command[0x1a, 1]: 1A 02 00 00 00 00 recv: 0x1b recv: 0x22 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xed recv: 0xbf CRC OK Got message seqno 34 (command_sequence == 34) response: 80 command[0x1a, 1]: 1A 01 00 00 00 00 recv: 0x1b recv: 0x23 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x52 recv: 0x3e CRC OK Got message seqno 35 (command_sequence == 35) response: 80 command[0x08, 1]: 08 recv: 0x1b recv: 0x24 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x5c recv: 0xa2 CRC OK Got message seqno 36 (command_sequence == 36) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 49 00 00 00 03 recv: 0x93 recv: 0x8f CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x25 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 49 00 00 00 recv: 0x40 recv: 0x0f CRC OK Got message seqno 37 (command_sequence == 37) response: 84 49 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x26 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 00 00 02 recv: 0x51 recv: 0x79 CRC OK Got message seqno 38 (command_sequence == 38) response: 82 00 00 02 ->GDB: T0520:02;21:0000;22:92000000; GDB: BP DEL type: 1 addr: 0x92 REMOVED 0, remaining: 0 ->GDB: OK GDB: command[0x08, 1]: 08 recv: 0x1b recv: 0x27 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x8c recv: 0x28 CRC OK Got message seqno 39 (command_sequence == 39) response: 80 command[0x23, 1]: 23 recv: 0x1b recv: 0x28 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x3e recv: 0x99 CRC OK Got message seqno 40 (command_sequence == 40) response: 80 command[0x00, 1]: 00 recv: 0x1b recv: 0x29 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x81 Download complete. Waiting for connection on port 4242. Connection opened by host 127.0.0.1, port 1087. gdb exited. recv: 0x18 CRC OK Got message seqno 41 (command_sequence == 41) response: 80
