  * @file    Templates/system_stm32f7xx.c
  * @author  MCD Application Team , Benny Zinke
  * @version V1.0.1
  * @date    06-October-2015
  * @brief   CMSIS Cortex-M7 Device Peripheral Access Layer System Source File.
  *   This file provides two functions and one global variable to be called from
  *   user application:
  *      - SystemInit(): This function is called at startup just after reset and
  *                      before branch to main program. This call is made inside
  *                      the "startup_stm32f7xx.s" file.
  *      - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
  *                                  by the user application to setup the SysTick
  *                                  timer or configure other parameters.
  *      - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
  *                                 be called whenever the core clock is changed
  *                                 during program execution.
  * Changes:
  * SystemInit_ExtMemCtl() now working for the STM32F7-DISCO
  * @attention
  * <h2><center>&copy; COPYRIGHT 2015 STMicroelectronics</center></h2>
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/** @addtogroup CMSIS
/** @addtogroup stm32f7xx_system
/** @addtogroup STM32F7xx_System_Private_Includes
#include "stm32f7xx.h"
#if !defined  (HSE_VALUE)
  #define HSE_VALUE    ((uint32_t)25000000) /*!< Default value of the External oscillator in Hz */
#endif /* HSE_VALUE */
#if !defined  (HSI_VALUE)
  #define HSI_VALUE    ((uint32_t)16000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
/** @addtogroup STM32F7xx_System_Private_TypesDefinitions
/** @addtogroup STM32F7xx_System_Private_Defines
/************************* Miscellaneous Configuration ************************/
/*!< Uncomment the following line if you need to use external SRAM or SDRAM mounted
     on EVAL board as data memory  */
/* #define DATA_IN_ExtSRAM */
#define DATA_IN_ExtSDRAM
#if defined(DATA_IN_ExtSRAM) && defined(DATA_IN_ExtSDRAM)
 #error "Please select DATA_IN_ExtSRAM or DATA_IN_ExtSDRAM "
#endif /* DATA_IN_ExtSRAM && DATA_IN_ExtSDRAM */
/*!< Uncomment the following line if you need to relocate your vector Table in
     Internal SRAM. */
/* #define VECT_TAB_SRAM */
#define VECT_TAB_OFFSET  0x00 /*!< Vector Table base offset field.
                                   This value must be a multiple of 0x200. */
/** @addtogroup STM32F7xx_System_Private_Macros
/** @addtogroup STM32F7xx_System_Private_Variables
  /* This variable is updated in three ways:
      1) by calling CMSIS function SystemCoreClockUpdate()
      2) by calling HAL API function HAL_RCC_GetHCLKFreq()
      3) each time HAL_RCC_ClockConfig() is called to configure the system clock frequency
         Note: If you use this function to configure the system clock; then there
               is no need to call the 2 first functions listed above, since SystemCoreClock
               variable is updated automatically.
  uint32_t SystemCoreClock = 16000000;
  __IO const uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
/** @addtogroup STM32F7xx_System_Private_FunctionPrototypes
#if defined (DATA_IN_ExtSRAM) || defined (DATA_IN_ExtSDRAM)
  static void SystemInit_ExtMemCtl(void);
#endif /* DATA_IN_ExtSRAM || DATA_IN_ExtSDRAM */
/** @addtogroup STM32F7xx_System_Private_Functions
  * @brief  Setup the microcontroller system
  *         Initialize the Embedded Flash Interface, the PLL and update the
  *         SystemFrequency variable.
  * @param  None
  * @retval None
void SystemInit(void)
  /* FPU settings ------------------------------------------------------------*/
  #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
    SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2));  /* set CP10 and CP11 Full Access */
  #endif
  /* Reset the RCC clock configuration to the default reset state ------------*/
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset CFGR register */
  RCC->CFGR = 0x00000000;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset PLLCFGR register */
  RCC->PLLCFGR = 0x24003010;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Disable all interrupts */
  RCC->CIR = 0x00000000;
  SystemInit_ExtMemCtl();
  /* Configure the Vector Table location add offset address ------------------*/
#ifdef VECT_TAB_SRAM
  SCB->VTOR = SRAM1_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
#else
  SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
#endif
   * @brief  Update SystemCoreClock variable according to Clock Register Values.
  *         The SystemCoreClock variable contains the core clock (HCLK), it can
  *         be used by the user application to setup the SysTick timer or configure
  *         other parameters.
  * @note   Each time the core clock (HCLK) changes, this function must be called
  *         to update SystemCoreClock variable value. Otherwise, any configuration
  *         based on this variable will be incorrect.
  * @note   - The system frequency computed by this function is not the real
  *           frequency in the chip. It is calculated based on the predefined
  *           constant and the selected clock source:
  *           - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(*)
  *           - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(**)
  *           - If SYSCLK source is PLL, SystemCoreClock will contain the HSE_VALUE(**)
  *             or HSI_VALUE(*) multiplied/divided by the PLL factors.
  *         (*) HSI_VALUE is a constant defined in stm32f7xx.h file (default value
  *             16 MHz) but the real value may vary depending on the variations
  *             in voltage and temperature.
  *         (**) HSE_VALUE is a constant defined in stm32f7xx.h file (default value
  *              25 MHz), user has to ensure that HSE_VALUE is same as the real
  *              frequency of the crystal used. Otherwise, this function may
  *              have wrong result.
  *         - The result of this function could be not correct when using fractional
  *           value for HSE crystal.
  * @param  None
  * @retval None
void SystemCoreClockUpdate(void)
  uint32_t tmp = 0, pllvco = 0, pllp = 2, pllsource = 0, pllm = 2;
  /* Get SYSCLK source -------------------------------------------------------*/
  tmp = RCC->CFGR & RCC_CFGR_SWS;
  switch (tmp)
    case 0x00:  /* HSI used as system clock source */
      SystemCoreClock = HSI_VALUE;
      break;
    case 0x04:  /* HSE used as system clock source */
      SystemCoreClock = HSE_VALUE;
      break;
    case 0x08:  /* PLL used as system clock source */
      /* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N
         SYSCLK = PLL_VCO / PLL_P
      pllsource = (RCC->PLLCFGR & RCC_PLLCFGR_PLLSRC) >> 22;
      pllm = RCC->PLLCFGR & RCC_PLLCFGR_PLLM;
      if (pllsource != 0)
        /* HSE used as PLL clock source */
        pllvco = (HSE_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
      else
        /* HSI used as PLL clock source */
        pllvco = (HSI_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
      pllp = (((RCC->PLLCFGR & RCC_PLLCFGR_PLLP) >>16) + 1 ) *2;
      SystemCoreClock = pllvco/pllp;
      break;
    default:
      break;
  /* Compute HCLK frequency --------------------------------------------------*/
  /* Get HCLK prescaler */
  tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
  /* HCLK frequency */
  SystemCoreClock >>= tmp;
  * @brief  Setup the external memory controller.
  *         Called in startup_stm32f7xx.s before jump to main.
  *         This function configures the external memories (SRAM/SDRAM)
  *         This SRAM/SDRAM will be used as program data memory (including heap and stack).
  * @param  None
  * @retval None
#if defined (DATA_IN_ExtSDRAM)
  register uint32_t tmpreg = 0, timeout = 0xFFFF;
  register __IO uint32_t index;
  /* Enable GPIOC, GPIOD, GPIOE, GPIOF, GPIOG, GPIOH interface clock */
  RCC->AHB1ENR |= 0x000000FC;
   * PC3  - FMC_SDCKE0
  GPIOC->AFR[0]	 = 0x0000C000;
  GPIOC->AFR[1]  = 0x00000000;
  /* Configure PDx pins in Alternate function mode (AF12) */
  GPIOC->MODER   = 0x00000080;
  /* Configure PDx pins speed to 50 MHz (FastSpeed) */
  GPIOC->OSPEEDR = 0x00000080;
  /* Configure PDx pins Output type to push-pull */
  GPIOC->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PCx pins */
  GPIOC->PUPDR   = 0x00000040;
   * PD0  - FMC_D2
   * PD1  - FMC_D3
   * PD3  - FMC_CLK
   * PD8  - FMC_D13
   * PD9  - FMC_D14
   * PD10 - FMC_D15
   * PD14 - FMC_D0
   * PD15 - FMC_D1
  /* Connect PDx pins to FMC Alternate function */
  GPIOD->AFR[0]  = 0x0000C0CC;
  GPIOD->AFR[1]  = 0xCC000CCC;
  GPIOD->MODER   = 0xA02A008A;
  GPIOD->OSPEEDR = 0xA02A008A;
  GPIOD->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PDx pins */
  GPIOD->PUPDR   = 0x50150045;
   * PE0  - FMC_NBL0
   * PE1  - FMC_NBL1
   * PE7  - FMC_D4
   * PE8  - FMC_D5
   * PE9  - FMC_D6
   * PE10 - FMC_D7
   * PE11 - FMC_D8
   * PE12 - FMC_D9
   * PE13 - FMC_D10
   * PE14 - FMC_D11
   * PE15 - FMC_D12
  /* Connect PEx pins to FMC Alternate function */
  GPIOE->AFR[0]  = 0xC00000CC;
  GPIOE->AFR[1]  = 0xCCCCCCCC;
  /* Configure PEx pins in Alternate function mode (AF12) */
  GPIOE->MODER   = 0xAAAA800A;
  /* Configure PEx pins speed to 50 MHz */
  GPIOE->OSPEEDR = 0xAAAA800A;
  /* Configure PEx pins Output type to push-pull */
  GPIOE->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PEx pins */
  GPIOE->PUPDR   = 0x55554005;
   * PF0  - FMC_A0
   * PF1  - FMC_A1
   * PF2  - FMC_A2
   * PF3  - FMC_A3
   * PF4  - FMC_A4
   * PF5  - FMC_A5
   * PF11 - FMC_SDNRAS
   * PF12 - FMC_A6
   * PF13 - FMC_A7
   * PF14 - FMC_A8
   * PF15 - FMC_A9
  /* Connect PFx pins to FMC Alternate function */
  GPIOF->AFR[0]  = 0x00CCCCCC;
  GPIOF->AFR[1]  = 0xCCCCC000;
  /* Configure PFx pins in Alternate function mode (AF12)*/
  GPIOF->MODER   = 0xAA800AAA;
  /* Configure PFx pins speed to 50 MHz */
  GPIOF->OSPEEDR = 0xAA800AAA;
  /* Configure PFx pins Output type to push-pull */
  GPIOF->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PFx pins */
  GPIOF->PUPDR   = 0x55400555;
   * PG0  - FMC_A10
   * PG1  - FMC_A11
   * PG4  - FMC_BA0
   * PG5  - FMC_BA1
   * PG8  - FMC_SDCLK
   * PG15 - FMC_SDNCAS
  /* Connect PGx pins to FMC Alternate function */
  GPIOG->AFR[0]  = 0x00CC00CC;
  GPIOG->AFR[1]  = 0xC000000C;
  /* Configure PGx pins in Alternate function mode */
  GPIOG->MODER   = 0x80020A0A;
  /* Configure PGx pins speed to 50 MHz */
  GPIOG->OSPEEDR = 0x80020A0A;
  /* Configure PGx pins Output type to push-pull */
  GPIOG->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PGx pins */
  GPIOG->PUPDR   = 0x40010505;
   * PH3  - FMC_SDNE0
   * PH5  - FMC_SDNWE
  /* Connect PHx pins to FMC Alternate function */
  GPIOH->AFR[0]  = 0x00C0C000;
  GPIOH->AFR[1]  = 0x00000000;
  /* Configure PHx pins in Alternate function mode */
  GPIOH->MODER   = 0x00000880;
  /* Configure PHx pins speed to 50 MHz */
  GPIOH->OSPEEDR = 0x00000880;
  /* Configure PHx pins Output type to push-pull */
  GPIOH->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PHx pins */
  GPIOH->PUPDR   = 0x00000440;
/*-- FMC Configuration ------------------------------------------------------*/
  /* Enable the FMC interface clock */
  RCC->AHB3ENR |= 0x00000001;
   * SDCR1:
   * RPIPE	- No HCLK delay		(Read Pipe)
   * BURST	- Single Read Burst	(Burst Read)
   * SDCLK	- period = 2x HCLK	(Clock Config)
   * WP		- allowed			(Write Protection)
   * CAS	- 2 cycles			(CAS Latency)
   * NB		- 4 internal banks	(Number of internal Banks)
   * NWID	- 16 bit			(Memory Data Bus Width)
   * NR		- 12 bit			(Number of Row Address Bits)
   * NC		- 8 bit				(Number of Column Address Bits)
   * SDTR:
   * TRCD	- 2 cycles (Row Column Delay)
   * TRP	- 2 cycles (Row Precharge Delay)
   * TWR	- 2 cycles (Write Recovery Delay)
   * TRC	- 7 cycles (Row Cycle Delay)
   * TRAS	- 4 cycles (Self Refresh Time)
   * TXSR	- 7 cycles (Exit Self Refresh Delay)
   * TMRD	- 2 cycles (Load Mode Register to Active)
  /* Configure and enable SDRAM bank1 */
  FMC_Bank5_6->SDCR[0] = 0x00001954;
  FMC_Bank5_6->SDTR[0] = 0x01116361;
   * SDCMR:
   * MRD	- Content of Mode Register (all zero)
   * NRFS	- 1 Auto-Refresh Cycle
   * CTB1	- issued to SDRAM Bank 1
   * CTB2	- not issued to SDRAM Bank 2
   * MODE	- Clock Configuration Enable
   * SDSR (Compare Value 0x00000020; meaning: wait until he isn't busy anymore):
   * BUSY	- SDRAM Controller is not ready to accept new request
   * MODES2	- Normal Mode
   * MODES1	- Normal Mode
   * RE		- No refresh error has been detected
  /* SDRAM initialization sequence */
  /* Clock enable command */
  FMC_Bank5_6->SDCMR = 0x00000011;
  tmpreg = FMC_Bank5_6->SDSR & 0x00000020;
  while((tmpreg != 0) && (timeout-- > 0))
  /* Delay */
  for (index = 0; index<1000; index++);
   * SDCMR:
   * MODE	- PALL ("All Bank Precharge") Command
  /* PALL command */
  FMC_Bank5_6->SDCMR = 0x00000012;
  timeout = 0xFFFF;
   * SDCMR:
   * NRFS	- 8 Auto-Refresh Cycle
   * MODE	- Auto-Refresh Command
  /* Auto refresh command */
  FMC_Bank5_6->SDCMR = 0x000000F3;
  timeout = 0xFFFF;
   * SDCMR:
   * MRD	- Content of Mode Register (hex 220)
   * MODE	- Load Mode Register
  /* MRD register program */
  FMC_Bank5_6->SDCMR = 0x00044014;
  timeout = 0xFFFF;
  /* Set refresh count */
  tmpreg = FMC_Bank5_6->SDRTR;
  FMC_Bank5_6->SDRTR = (tmpreg | (0x0000050C<<1));
  /* Disable write protection */
  tmpreg = FMC_Bank5_6->SDCR[0];
  FMC_Bank5_6->SDCR[0] = (tmpreg & 0xFFFFFDFF);
#endif /* DATA_IN_ExtSDRAM */
/*-- GPIOs Configuration -----------------------------------------------------*/
   /* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
  RCC->AHB1ENR   |= 0x00000078;
  GPIOD->AFR[0]  = 0x00CCC0CC;
  GPIOD->AFR[1]  = 0xCCCCCCCC;
  /* Configure PDx pins in Alternate function mode */
  GPIOD->MODER   = 0xAAAA0A8A;
  /* Configure PDx pins speed to 100 MHz */
  GPIOD->OSPEEDR = 0xFFFF0FCF;
  GPIOD->PUPDR   = 0x55550545;
  GPIOE->AFR[0]  = 0xC00CC0CC;
  /* Configure PEx pins in Alternate function mode */
  GPIOE->MODER   = 0xAAAA828A;
  /* Configure PEx pins speed to 100 MHz */
  GPIOE->OSPEEDR = 0xFFFFC3CF;
  GPIOE->PUPDR   = 0x55554145;
  GPIOF->AFR[1]  = 0xCCCC0000;
  /* Configure PFx pins in Alternate function mode */
  GPIOF->MODER   = 0xAA000AAA;
  /* Configure PFx pins speed to 100 MHz */
  GPIOF->OSPEEDR = 0xFF000FFF;
  GPIOF->PUPDR   = 0x55000555;
  GPIOG->AFR[0]  = 0x00CCCCCC;
  GPIOG->AFR[1]  = 0x000000C0;
  GPIOG->MODER   = 0x00200AAA;
  /* Configure PGx pins speed to 100 MHz */
  GPIOG->OSPEEDR = 0x00300FFF;
  GPIOG->PUPDR   = 0x00100555;
/*-- FMC/FSMC Configuration --------------------------------------------------*/
  /* Enable the FMC/FSMC interface clock */
  /* Configure and enable Bank1_SRAM2 */
  FMC_Bank1->BTCR[4]  = 0x00001091;
  FMC_Bank1->BTCR[5]  = 0x00110212;
  FMC_Bank1E->BWTR[4] = 0x0FFFFFFF;
#endif /* DATA_IN_ExtSRAM */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
