Version 4 SHEET 1 880 680 WIRE 80 -208 64 -208 WIRE 192 -208 176 -208 WIRE 320 -208 304 -208 WIRE 432 -208 416 -208 WIRE 560 -208 544 -208 WIRE 64 -192 64 -208 WIRE 176 -192 176 -208 WIRE 304 -192 304 -208 WIRE 416 -192 416 -208 WIRE 544 -192 544 -208 WIRE 496 80 480 80 WIRE 528 80 496 80 WIRE 80 240 64 240 WIRE 176 240 80 240 WIRE 304 240 288 240 WIRE 176 256 176 240 WIRE 400 256 400 240 WIRE 80 304 80 240 WIRE 304 304 304 240 WIRE 176 352 176 320 WIRE 400 352 400 320 WIRE 480 352 464 352 WIRE 512 352 480 352 WIRE 512 368 512 352 WIRE 400 432 400 416 WIRE 464 432 464 352 WIRE 464 432 400 432 WIRE 80 448 80 384 WIRE 80 448 64 448 WIRE 176 448 176 416 WIRE 176 448 80 448 WIRE 304 448 304 384 WIRE 304 448 288 448 WIRE 512 448 304 448 FLAG 368 -128 0 FLAG 64 -112 0 FLAG 320 -208 sw FLAG 368 -176 sw FLAG 416 -112 0 FLAG 304 -112 0 FLAG 64 448 s1 FLAG 496 -128 0 FLAG 496 -176 sw FLAG 176 -112 0 FLAG 192 -208 v2 FLAG 80 -208 v1 FLAG 64 240 v1 FLAG 432 -208 s1 FLAG 544 -112 0 FLAG 560 -208 s2 FLAG 288 448 s2 FLAG 288 240 v2 FLAG 400 240 0 FLAG 480 352 k FLAG 480 160 0 FLAG 496 80 xpind FLAG 528 160 0 SYMBOL ind 96 288 M0 WINDOW 39 6 92 Right 2 WINDOW 123 6 108 Right 2 WINDOW 40 6 124 Right 2 SYMATTR SpiceLine Rser={rsx} SYMATTR InstName L1 SYMATTR Value 1 SYMATTR Value2 Rpar={rpx} SYMATTR SpiceLine2 Cpar={cpx} SYMBOL voltage 64 -208 R0 WINDOW 123 0 0 Left 2 WINDOW 39 24 112 Left 2 SYMATTR SpiceLine Rser=1u SYMATTR InstName V1 SYMATTR Value 10 SYMBOL diode 160 320 M180 WINDOW 0 24 64 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D11 SYMATTR Value 1N4148 SYMBOL zener 160 352 R0 SYMATTR InstName D12 SYMATTR Value KDZ20B SYMATTR Description Diode SYMATTR Type diode SYMBOL sw 416 -96 M180 SYMATTR InstName S1 SYMBOL voltage 304 -208 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 WINDOW 3 -5 119 Left 2 SYMATTR InstName V3 SYMATTR Value PULSE(0 1 1m 1u 1u 50m 100m 1) SYMBOL sw 544 -96 M180 SYMATTR InstName S2 SYMBOL voltage 176 -208 R0 WINDOW 123 0 0 Left 2 WINDOW 39 24 112 Left 2 SYMATTR SpiceLine Rser=1u SYMATTR InstName V2 SYMATTR Value 10 SYMBOL diode 384 320 M180 WINDOW 0 24 64 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName D21 SYMATTR Value 1N4148 SYMBOL zener 384 352 R0 SYMATTR InstName D22 SYMATTR Value KDZ20B SYMATTR Description Diode SYMATTR Type diode SYMBOL bv 512 464 M180 WINDOW 0 24 96 Left 2 WINDOW 3 -46 138 Left 2 SYMATTR InstName B1 SYMATTR Value V=V(s1)-V(k) SYMBOL bi 480 160 R180 WINDOW 0 24 80 Left 2 WINDOW 3 24 0 Left 2 WINDOW 123 24 -16 Left 2 SYMATTR InstName B2 SYMATTR Value I=xpind(V(v1,s1), I(L1), rsx, rpx, cpx) SYMBOL res 512 64 R0 SYMATTR InstName R1 SYMATTR Value 1 SYMBOL ind 320 288 M0 WINDOW 39 6 92 Right 2 WINDOW 123 6 108 Right 2 WINDOW 40 6 124 Right 2 SYMATTR SpiceLine Rser={rsx} SYMATTR InstName L2 SYMATTR Value 1 SYMATTR Value2 Rpar={rpx} SYMATTR SpiceLine2 Cpar={cpx} TEXT 48 -240 Left 2 !.tran 0 6m 0 100n TEXT 296 -72 Left 2 !.model sw SW(Ron={1/gmin} Roff=1u Vt=0.5) TEXT 48 -280 Left 2 ;https://www.mikrocontroller.net/topic/387998#4441902 TEXT 40 -24 Left 2 !.func xpind(u, i, rs, rp, cp) {(i-(u/rp)-ddt(u*cp))**2*rs+(u**2/rp)} TEXT 40 -56 Left 2 !.param rsx=100, rpx=100k, cpx=1p TEXT 40 0 Left 2 !.meas e1ind integ pind(V(v1,s1), I(L1), rsx, rpx, cpx) trig V(sw) val=0.5 rise=1 TEXT 40 16 Left 2 !.meas e1dio integ V(s1,v1)*I(D11) trig V(sw) val=0.5 rise=1 TEXT 40 32 Left 2 !.meas e1tot param e1ind+e1dio TEXT 40 -40 Left 2 !.func pind(u, i, rs, rp, cp) {(i-(u/rp))**2*rs+(u**2/rp)} TEXT 40 56 Left 2 !.meas e2ind integ pind(V(v2,s2), I(L2), rsx, rpx, cpx) trig V(sw) val=0.5 rise=1 TEXT 40 72 Left 2 !.meas e2dio integ V(s2)*I(D21) trig V(sw) val=0.5 rise=1 TEXT 40 88 Left 2 !.meas e2src integ V(v2)*I(V2) trig V(sw) val=0.5 rise=1 TEXT 40 104 Left 2 !.meas e2tot param e2ind+e2dio TEXT 256 32 Left 2 ;targ I(L2) val=1u fall=1 TEXT 176 -240 Left 2 ;.opt plotwinsize=0 TEXT 40 120 Left 2 !.meas e2dif param e2tot+e2src TEXT 40 192 Left 2 !.meas xe1ind integ xpind(V(v1,s1), I(L1), rsx, rpx, cpx) trig V(sw) val=0.5 rise=1 TEXT 40 208 Left 2 !.meas ye1ind integ V(xpind) trig V(sw) val=0.5 rise=1
