// Compiler Atmel Studio 6.2
// Processor: ATMega32
// Written by 
// Peter Menges			9 of december 2015
// Paraguay
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include "portdefs.h"
#include "rotary.h"
#ifndef F_CPU
#define F_CPU		16000000UL // Equals to 62,5 ns per tick
#endif
#define PRESCALER0      ((1 << CS00) | (1 << CS02))					// CLK/1024
#define PRESCALER1		((1 << CS12)|  (1 << CS10))					// same.
#define PRESCALER2		((1 << CS20) | (1 << CS21) | (1 << CS22))	// same.
volatile uint8_t key_press;				// This hold the key-bits
extern volatile uint8_t disp_data[];	// The data to be displayed
extern volatile uint8_t z_axis[];		// I use an 8-Bit array because of the faster access
extern volatile uint8_t x_axis[];		// Data from the calipers
volatile uint8_t cal_sig;				// signaling new values
volatile uint8_t bitcount_z=0;			//counting incoming bits (port pin values)
volatile uint8_t sample_z=0;			//monitor the input time to reset when not synchronized
volatile uint8_t running_z=0;			//Flag indicating that this input time should be monitored by sample_
volatile uint8_t bitcount_x=0;
volatile uint8_t sample_x=0;
volatile uint8_t running_x=0;
volatile uint8_t error_x=0;				// Incremented by the Timer 1 interrupt to recognize
volatile uint8_t error_z=0;				// a failure of the caliper (disconnected, battery weak, a.s.o)
										// A different reading at the display will be shown if this is the case
volatile uint8_t	event=0;				// encoder events
/* Multiplex of display */
ISR(TIMER0_COMP_vect)
	static uint8_t idx=0;
	static uint8_t seg=0x10;		// start with the 5th segment (From the left to the right)
	static uint8_t blc=0,blc2=0;			// blink counter
	static uint8_t dir=1,dir2=1;           // direction of blcs 1=up
	static uint8_t rot_state = 0;	// encoder	
	uint8_t pinstate=0;				// Encoder
	OE_UPPER_DIS;
	OE_LOWER_DIS;
	DISP_DATA = 0x00;			// reset all data on bus
	if ( idx == DISP_BUF_MAX) // end of buffer reached
			idx = 0;		  // reset idx
		if ( idx == 0 || idx == 5) {		// Show the signs if any 
				if ( disp_data[idx] & DISP_BLINK ){
								if ( blc2 < DISP_BLC_TIME && dir2 == 1) {
									blc2++;
									DISP_DATA = (disp_data[idx] & 0xf0);
								} else {
									dir2 = 0;
									if ( --blc2 == 0)
										dir2 = 1;
				} else
		DISP_DATA |= seg;		// set the bit of the segment
		CLK_PULS;				// latch it
		if ( (disp_data[idx] & DISP_BLINK) ){
				if ( blc < DISP_BLC_TIME && dir == 1){
					blc++;
					DISP_DATA = disp_data[idx];
					if ( idx < 5) {
								OE_UPPER_EN;			// show it
						}else{
								OE_LOWER_EN;
				} else {
					dir = 0;
					if ( --blc == 0 )
						dir = 1;
		} else {
				if ( idx < 5) {
				}else{
					OE_LOWER_EN;
		idx++;	
		seg >>= 1;
		if ( seg == 0)				// start over
				seg = 0x10;
		/*** encoder ***************************************/
		if (PHASE_A )
			pinstate |= 0x01;
		if (PHASE_B)
			pinstate |= 0x02;
		rot_state = ttable[rot_state & 0x0F][pinstate];
		if ((rot_state & 0x30) == DIR_CW)
		  event |= DIR_CW;
		if ((rot_state & 0x30) == DIR_CCW)
		  event |= DIR_CCW;	
}// ISR END
/* 3 ms interrupt for timeout handling of calipers 
   and the rotary encoder*/
ISR(TIMER1_COMPA_vect)
		/* Z-Axis */										
	if(running_z){							// Start monitoring the time consumed by the INT0 ISR						
		if((++sample_z)==5){				//After 15 ms it should be terminated hard
			bitcount_z=0;					//This condition shows that the input could not be completed
			sample_z=0;						// Reset all counters and flags to start with a new input frame
		/* X-Axis */
	if(running_x){
		if((++sample_x)==5){
			bitcount_x=0;
			sample_x=0;
	// Monitoring the interface (checking if it is unplugged or not sending data)	
	error_x++;
	error_z++;
				if ( error_x > 200){			// Beyond 600 ms, something happens wrong
					cal_sig |= CAL_INVALID_X;
					error_x = 0;
				if ( error_z > 200){
					cal_sig |= CAL_INVALID_Z;		// offline?
					error_z = 0;
/* Thanks to Peter Dannegger, Germany*/
/* This is his coding!*/
ISR(TIMER2_COMP_vect)
  static uint8_t key_state=0;		
  static uint8_t ct0=0, ct1=0,i=0; 
 			i = key_state ^ ~(KEY_PIN);   // key changed ?
 			ct0 = ~( ct0 & i );			// reset or count ct0
  			ct1 = (ct0 ^ ct1) & i;	    // reset or count ct1  
  			i &= ct0 & ct1;			    // count until roll over ?
  			key_state ^= i;			    // then toggle debounced state
   * To notify main program of pressed key, the corresponding bit
   * in global variable key_press is set.
   * The main loop needs to clear this bit
  			key_press |= key_state & i;	// 0->1: key press detect
/* ISR reading the data of the Z-Axis */
ISR(INT0_vect){
	if(bitcount_z==0)
		running_z=1;						//Start capturing of the packet frame
	if(bitcount_z < CAL_LENGTH){							
		if (CAL_PORT & CAL_ZPIN)
		z_axis[bitcount_z] = 1;				// Write into buffer of this axis
		else
		z_axis[bitcount_z] = 0;
	bitcount_z++;
	if(bitcount_z == CAL_LENGTH){ 			//24 bits done
		if ( z_axis[CAL_UNIT] == CAL_INCHES)
		cal_sig |= CAL_INCH_Z;				// handled as an error
		else
		cal_sig |= CAL_NEW_Z;
		running_z=0;
		bitcount_z = 0;						
		sample_z=0;							//reset to stop the monitoring by ISR TIMER1
		error_z=0;
/* ISR reading the data of the X-Axis */
ISR(INT1_vect){
	if(bitcount_x==0)
		running_x=1;						
	if(bitcount_x < CAL_LENGTH){							
		if (CAL_PORT & CAL_XPIN)
		x_axis[bitcount_x] = 1;
		else
		x_axis[bitcount_x] = 0;
	bitcount_x++;
	if(bitcount_x == CAL_LENGTH){ 					
		if ( x_axis[CAL_UNIT] == CAL_INCHES)
		cal_sig |= CAL_INCH_X;				// handled as an error
		else
		cal_sig |= CAL_NEW_X;
		running_x=0;
		bitcount_x = 0;								
		sample_x=0;							
		error_x = 0;
void Init_Timer(void)
	/* Init all timers */
	TIMSK  |= (1 << OCIE0)| (1 << OCIE1A) | ( 1 << OCIE2);	// OCIE0 and
															// OCIE1A int
															// OCIE2 int
	// Timer 0 is used to multiplex the display
	TCCR0 |= PRESCALER0| (1 << WGM01);						// Prescaler and CTC Mode WGM01
	TCNT0  = 0;
	OCR0 = 30;												// 30 => 2 ms per segment
	// Timer 1 for the timing of the calipers (central clocking)
	TCCR1B = PRESCALER1 | (1 << WGM12);					// Prescaler 1024 and CTC Mode
	TCNT1 = 0; 											// Set to zero
	OCR1A = CAL_TIMER1_VAL; 							// set to 3 ms
	// Timer2 is used to debounce the keys
	TCCR2 |= PRESCALER2 | (1 << WGM21);					// Prescaler 1024 and CTC Mode
	TCNT2 = 0;
	OCR2 = 255;											// 16 ms
	// INT1 and INT0 rising edge triggered (the interface to the calipers) 21.12.2015 (! changed from falling)
	MCUCR |= (1 << ISC11) | (1 << ISC01 ) | ( 1 << ISC10) | ( 1 << ISC00);
	GICR |= ( 1 << INT0 ) | ( 1 << INT1 );				//enable
	sei();												// Let ball roll...
