void SSD1963_Init(){
    //SOFTWARE RESET
	SSD1963_Write_cmd(0x01);
    delay_ms(5);				//Wait a stable condition
    //SOFTWARE RESET
    //SOFTWARE RESET
	//SET THE INTERNAL PLL NM
    SSD1963_Write_cmd(0xE2);
    SSD1963_Write_data(0x0023);		//Set Multiplier to 35
    SSD1963_Write_data(0x0002);		//Set Divider to 2
    SSD1963_Write_data(0x0054);		//Set 10Mhz*35/2=175Mhz PLL clock
	//ENABLE PLL
	SSD1963_Write_cmd(0xE0);
	SSD1963_Write_data(0x0001);		//Reference clock , Enable PLL
	delay_us(10);				//Wait a stable condition
	SSD1963_Write_data(0x0003);		//PLL clock , Enable PLL
    //SOFTWARE RESET
    delay_ms(20);				//Wait a stable condition
    //PIXEL CLOCK SETTING (LSHIFT Frequency)
    SSD1963_Write_cmd(0xE6);
    SSD1963_Write_data(0x0003);		//Highest 4bits
    SSD1963_Write_data(0x0033);		//Mid 8bits
    SSD1963_Write_data(0x0033);		//Low 8bits, 175MhzPLL*(209715 PCLK +1)/2^20=875Hz
    //LCD MODE AND SPECIFICATIONS
    SSD1963_Write_cmd(0xB0);
    SSD1963_Write_data(0x0020);		//24bit TFT panel, Rising Edge, Active Low
    SSD1963_Write_data(0x0000);		//HSYNC+VSYNC+DE mode TFT panel
    SSD1963_Write_data((799>>8)&0x0007);		//Highest 3bits HPS
    SSD1963_Write_data(799 & 0x00FF);		//Lowest 8bist HPS, Horizontal Panel Size 800px
    SSD1963_Write_data((479>>8)&0x0007);		//Highest 3bits VPS
    SSD1963_Write_data(479 & 0x00FF);		//Lowest 8bist VPS, Vertical Panel Size 480px
    SSD1963_Write_data(0x0000);		//RGB sequence for even and odd lines
    //Horizontal Period HSYNC Settings
    SSD1963_Write_cmd(0xB4);
    SSD1963_Write_data(0x0004);		//Highest 3bits HT
    SSD1963_Write_data(0x001F);		//Lowest 8bist HT, Horizontal Total Period 1055PCK+1
    SSD1963_Write_data(0x0000);		//Highest 3bits HPS
    SSD1963_Write_data(0x00D2);		//Lowest 8bist HPS, Horizontal non display Period 210PCK+1
    SSD1963_Write_data(0x0000);		//HPW, Horizontal Pulse Width 0PCK+1
    SSD1963_Write_data(0x0000);		//Highest 3bits LPS
    SSD1963_Write_data(0x0000);		//Lowest 8bist LPS, Horizontal sync pulse Period 0PCK+1
    SSD1963_Write_data(0x0000);		//LPSPP, Horizontal sync pulse start position 0PCK
    SSD1963_Write_cmd(0xB6);
    SSD1963_Write_data(0x0002);		//Highest 3bits VT
    SSD1963_Write_data(0x000C);		//Lowest 8bist VT, Vertical Total Period 524PCK+1
    SSD1963_Write_data(0x0000);		//Highest 3bits VPS
    SSD1963_Write_data(0x0022);		//Lowest 8bist VPS, Vertical non display Period 34PCK+1
    SSD1963_Write_data(0x0000);		//VPW, Vertical Pulse Width 0PCK+1
    SSD1963_Write_data(0x0000);		//Lowest 8bist VPS, Vertical sync pulse Period 0PCK+1
    //SSD1963 GPIO CONFIGURATION
    SSD1963_Write_cmd(0xB8);
    SSD1963_Write_data(0x000F);		//GPIO of the SSD1963 are output controlled by host
    SSD1963_Write_data(0x0001);		//GPIO0 operates normally
    //SET GPIO VALUES
    SSD1963_Write_cmd(0xBA);
    SSD1963_Write_data(0x0001);		//GPIO0=1 -> LCD ON
    //write_data_565(0x0000);	//GPIO0=0 -> LCD OFF
    //SET ADRESSING MODE
    SSD1963_Write_cmd(0x36);
    SSD1963_Write_data(0x0008);		//FrameBuffer RGB -> DisplayPanel BGR
    //SET PIXEL FORMAT
    SSD1963_Write_cmd(0x3A);
    SSD1963_Write_data(0x0050);		//16bit per pixel
    //SET PIXEL DATA INTERFACE
    SSD1963_Write_cmd(0xF0);
    SSD1963_Write_data(0x0003);		//16bit at 565 color interface
    //SET IMAGE POST PROCESSOR
    SSD1963_Write_cmd(0xBC);
    SSD1963_Write_data(0x0040);		//Default Contrast Value
    SSD1963_Write_data(0x0080);		//Default Brightness Value
    SSD1963_Write_data(0x0040);		//Default Saturation Value
    SSD1963_Write_data(0x0001);		//Post Processor is Enabled
    delay_us(5);
    //DISPLAY THE FRAME BUFFER ON THE DEVICE
    SSD1963_Write_cmd(0x29);
    //BLANKS THE DEVICE WITH UNCHANGED BUFFER
    //write_command_565(0x28);
    //SET PWM TO THE BACKLIGHT DRIVER
    SSD1963_Write_cmd(0xBE);
    SSD1963_Write_data(0x0006);		//PWMF = 175MHz/(256*6)/256 =
    SSD1963_Write_data(0x0080);		//PWM duty cycle = 50%
    SSD1963_Write_data(0x0000);		//PWM is controlled by host and ENABLED
    SSD1963_Write_data(0x00F0);		//DBC Manual Brightness  98%
    SSD1963_Write_data(0x0000);		//DBC Minimum Brightness 10%
    SSD1963_Write_data(0x0000);		//Brightness Prescaler to the dimmest
    //DBC CONFIGURATION (Dynamic Brightness Control)
    SSD1963_Write_cmd(0x00D0);
    SSD1963_Write_data(0x0000);		//DBC is ENABLED
uint8_t FMC_SSD1963_FAST_Init(void){
	FMC_NORSRAMInitTypeDef  FMC_NORSRAMInitDef;
	FMC_NORSRAMTimingInitTypeDef  FMC_NORSRAMTimingInitDef_Write, FMC_NORSRAMTimingInitDef_Read;
	/* Enable FMC clock */
	RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FMC, ENABLE);
	/* FMC SSD1963 as a NORSRAM device initialization sequence ---*/
	/* Step 1 ----------------------------------------------------------*/
	/* Timing configuration for 84 Mhz of SD clock frequency (168Mhz/2) */
	FMC_NORSRAMTimingInitDef_Write.FMC_AddressSetupTime			= 0x01;
	FMC_NORSRAMTimingInitDef_Write.FMC_AddressHoldTime			= 0x00;
	FMC_NORSRAMTimingInitDef_Write.FMC_DataSetupTime			= 0x01;
	FMC_NORSRAMTimingInitDef_Write.FMC_BusTurnAroundDuration  	= 0x00;
	FMC_NORSRAMTimingInitDef_Write.FMC_CLKDivision    			= 0x01;
	FMC_NORSRAMTimingInitDef_Write.FMC_DataLatency           	= 0x00;
	FMC_NORSRAMTimingInitDef_Write.FMC_AccessMode             	= FMC_AccessMode_A;
	FMC_NORSRAMTimingInitDef_Read.FMC_AddressSetupTime			= 0x0A;
	FMC_NORSRAMTimingInitDef_Read.FMC_AddressHoldTime			= 0x00;
	FMC_NORSRAMTimingInitDef_Read.FMC_DataSetupTime				= 0x0A;
	FMC_NORSRAMTimingInitDef_Read.FMC_BusTurnAroundDuration 	= 0x00;
	FMC_NORSRAMTimingInitDef_Read.FMC_CLKDivision    			= 0x01;
	FMC_NORSRAMTimingInitDef_Read.FMC_DataLatency           	= 0x00;
	FMC_NORSRAMTimingInitDef_Read.FMC_AccessMode            	= FMC_AccessMode_A;
	/* FMC SDRAM control configuration */
	FMC_NORSRAMInitDef.FMC_Bank 						= FMC_Bank1_NORSRAM1;
    FMC_NORSRAMInitDef.FMC_DataAddressMux 				= FMC_DataAddressMux_Disable;
	FMC_NORSRAMInitDef.FMC_MemoryType 					= FMC_MemoryType_SRAM;
	FMC_NORSRAMInitDef.FMC_MemoryDataWidth 				= FMC_NORSRAM_MemoryDataWidth_16b;
	FMC_NORSRAMInitDef.FMC_BurstAccessMode 				= FMC_BurstAccessMode_Disable;
	FMC_NORSRAMInitDef.FMC_AsynchronousWait 			= FMC_AsynchronousWait_Disable;
	FMC_NORSRAMInitDef.FMC_WaitSignalPolarity 			= FMC_WaitSignalPolarity_Low;
	FMC_NORSRAMInitDef.FMC_WrapMode 					= FMC_WrapMode_Disable;
	FMC_NORSRAMInitDef.FMC_WaitSignalActive 			= FMC_WaitSignalActive_BeforeWaitState;
	FMC_NORSRAMInitDef.FMC_WriteOperation 				= FMC_WriteOperation_Enable;
	FMC_NORSRAMInitDef.FMC_WaitSignal 			    	= FMC_WaitSignal_Disable;
	FMC_NORSRAMInitDef.FMC_ExtendedMode 				= FMC_ExtendedMode_Disable;
	FMC_NORSRAMInitDef.FMC_WriteBurst 					= FMC_WriteBurst_Disable;
	FMC_NORSRAMInitDef.FMC_ContinousClock 				= FMC_CClock_SyncOnly;  //FMC_CClock_SyncAsync
	FMC_NORSRAMInitDef.FMC_ReadWriteTimingStruct		= &FMC_NORSRAMTimingInitDef_Read;
	FMC_NORSRAMInitDef.FMC_WriteTimingStruct			= &FMC_NORSRAMTimingInitDef_Write;
	/* DISABLING THE NORSRAM BANK WHILE CHANGING SPEED */
	FMC_NORSRAMCmd(FMC_Bank1_NORSRAM1, DISABLE);
	/* FMC NORSRAM bank initialization */
	FMC_NORSRAMInit(&FMC_NORSRAMInitDef);
	/* FMC NORSRAM bank enable */
	FMC_NORSRAMCmd(FMC_Bank1_NORSRAM1, ENABLE);
	return 1;
