Version 4 SHEET 1 1316 680 WIRE 16 112 -48 112 WIRE 128 112 96 112 WIRE 176 112 128 112 WIRE 240 112 176 112 WIRE 240 144 240 112 WIRE 128 192 128 112 WIRE -48 208 -48 112 WIRE 240 240 240 224 WIRE 304 240 240 240 WIRE 384 240 304 240 WIRE 448 240 384 240 WIRE 640 240 528 240 WIRE 688 240 640 240 WIRE 240 272 240 240 WIRE 688 272 688 240 WIRE 880 320 864 320 WIRE 896 320 880 320 WIRE 1072 320 1040 320 WIRE 1088 320 1072 320 WIRE -48 384 -48 288 WIRE 128 384 128 272 WIRE 128 384 -48 384 WIRE 240 384 240 352 WIRE 240 384 128 384 WIRE 688 384 688 352 WIRE 688 384 240 384 WIRE 240 400 240 384 FLAG 240 400 0 FLAG 240 112 1 FLAG 688 240 2 FLAG 304 240 3 DATAFLAG 176 112 "round($*1000)/1000" DATAFLAG 384 240 "round($*1000)/1000" DATAFLAG 640 240 "" DATAFLAG -48 112 "" DATAFLAG 1072 320 "round(V(2)*100)/100" DATAFLAG 880 320 "round(V(3)*10000)/10000" DATAFLAG 480 192 "round(I(R5)*1000)/1000" SYMBOL res 0 128 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R1 SYMATTR Value 10 SYMBOL res 112 176 R0 SYMATTR InstName R2 SYMATTR Value 12 SYMBOL res 224 128 R0 SYMATTR InstName R3 SYMATTR Value 15 SYMBOL res 224 256 R0 SYMATTR InstName R4 SYMATTR Value 12 SYMBOL res 432 256 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R5 SYMATTR Value 30 SYMBOL voltage 688 256 R0 SYMATTR InstName V1 SYMATTR Value 9 SYMBOL voltage -48 192 R0 SYMATTR InstName V2 SYMATTR Value 10 TEXT -72 40 Left 2 !.op TEXT -120 -240 Left 2 ;Run the simulation.\n \nRight mouse-click into an empty area.\nChoose View -> Place .op Data Label\n \nIf you have only a .op analysis,\njust clicking on a net is sufficient\nto place a Data Label. TEXT 432 -240 Left 2 ;Change the number of digits\nRight-mouse-click on the Plot Label \nChange the $ to this expression.\n$ -> round($*1000)/1000 TEXT 760 80 Left 2 ;Plot labels can be copied and moved \nto any place on the schematic. TEXT -104 456 Left 2 ;The plot labels are available when a DC operating point \nhas been calculated from LTspice. This will be not the case\nif a pure linear circuit is simulated in an AC-analysis. Something\nnonlinear can be added to force a DC-op analysis in this case. TEXT 504 -16 Left 2 ;Plot labels show voltages, currents or expressions. TEXT 824 232 Left 2 ;Voltmeter TEXT 1016 232 Left 2 ;Voltmeter TEXT 848 264 Left 2 ;net 1 TEXT 1040 264 Left 2 ;net 2 LINE Normal 224 80 464 -112 LINE Normal 240 80 224 80 LINE Normal 224 80 240 80 LINE Normal 224 64 224 80 LINE Normal 480 144 544 16 LINE Normal 496 144 480 144 LINE Normal 480 144 496 144 LINE Normal 480 128 480 144 LINE Normal 984 184 973 171 LINE Normal 996 169 984 184 LINE Normal 984 184 996 169 LINE Normal 984 136 984 184 LINE Normal 368 192 480 -112 LINE Normal 384 176 368 192 LINE Normal 368 192 384 176 LINE Normal 368 160 368 192 RECTANGLE Normal 976 320 784 288 RECTANGLE Normal 976 288 784 208 RECTANGLE Normal 1152 320 992 288 RECTANGLE Normal 1152 320 992 208
