<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?fileVersion 4.0.0?>
<cproject>
<storageModule moduleId="org.eclipse.cdt.core.settings">
<cconfiguration id="de.innot.avreclipse.configuration.app.debug.1921630434">
<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="de.innot.avreclipse.configuration.app.debug.1921630434" moduleId="org.eclipse.cdt.core.settings" name="Debug">
<externalSettings/>
<extensions>
<extension id="org.eclipse.cdt.core.ELF" point="org.eclipse.cdt.core.BinaryParser"/>
<extension id="org.eclipse.cdt.core.MakeErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GCCErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GASErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
<extension id="org.eclipse.cdt.core.GLDErrorParser" point="org.eclipse.cdt.core.ErrorParser"/>
</extensions>
</storageModule>
<storageModule moduleId="cdtBuildSystem" version="4.0.0">
<configuration artifactExtension="elf" artifactName="Loetst" buildArtefactType="de.innot.avreclipse.buildArtefactType.app" buildProperties="org.eclipse.cdt.build.core.buildType=org.eclipse.cdt.build.core.buildType.debug,org.eclipse.cdt.build.core.buildArtefactType=de.innot.avreclipse.buildArtefactType.app" description="" id="de.innot.avreclipse.configuration.app.debug.1921630434" name="Debug" parent="de.innot.avreclipse.configuration.app.debug" postannouncebuildStep="" postbuildStep="avr-nm -n -S loetst.elf &gt; loest.sym" preannouncebuildStep="" prebuildStep="">
<folderInfo id="de.innot.avreclipse.configuration.app.debug.1921630434." name="/" resourcePath="">
<toolChain id="de.innot.avreclipse.toolchain.winavr.app.debug.1675776382" name="WinAVR Toolchain" superClass="de.innot.avreclipse.toolchain.winavr.app.debug" unusedChildren="de.innot.avreclipse.tool.objcopy.flash.winavr.app.debug;de.innot.avreclipse.tool.objcopy.eeprom.winavr.app.debug">
<option defaultValue="de.innot.avreclipse.mcus.atmega32" id="de.innot.avreclipse.toolchain.options.target.mcutype.app.debug.1477925893" name="MCU Type" superClass="de.innot.avreclipse.toolchain.options.target.mcutype.app.debug" value="de.innot.avreclipse.mcus.atmega32" valueType="enumerated"/>
<option defaultValue="16000000" id="de.innot.avreclipse.toolchain.options.target.fcpu.app.debug.1773870926" name="MCU Clock Frequency" superClass="de.innot.avreclipse.toolchain.options.target.fcpu.app.debug" value="16000000" valueType="string"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objcopy.flash.app.debug.1564389027" name="Generate HEX file for Flash memory" superClass="de.innot.avreclipse.toolchain.options.toolchain.objcopy.flash.app.debug" value="true" valueType="boolean"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objcopy.eeprom.app.debug.1061486573" name="Generate HEX file for EEPROM" superClass="de.innot.avreclipse.toolchain.options.toolchain.objcopy.eeprom.app.debug"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objdump.app.debug.1850627808" name="Generate Extended Listing (Source + generated Assembler)" superClass="de.innot.avreclipse.toolchain.options.toolchain.objdump.app.debug"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.size.app.debug.1780839831" name="Print Size" superClass="de.innot.avreclipse.toolchain.options.toolchain.size.app.debug"/>
<targetPlatform id="de.innot.avreclipse.targetplatform.winavr.app.debug.399031415" name="AVR Cross-Target" superClass="de.innot.avreclipse.targetplatform.winavr.app.debug"/>
<builder buildPath="${workspace_loc:/Loetst/Debug}" id="de.innot.avreclipse.target.builder.winavr.app.debug.180417157" keepEnvironmentInBuildfile="false" managedBuildOn="true" name="AVR GNU Make Builder" superClass="de.innot.avreclipse.target.builder.winavr.app.debug"/>
<tool id="de.innot.avreclipse.tool.linker.winavr.app.debug.1869855593" name="winAVR Linker" superClass="de.innot.avreclipse.tool.linker.winavr.app.debug">
<option id="de.innot.avreclipse.linker.option.avrtargetmcu.1753186568" name="MCU Type" superClass="de.innot.avreclipse.linker.option.avrtargetmcu" value="atmega32" valueType="string"/>
<option id="de.innot.avreclipse.linker.option.genmap.52258215" name="Map Filename" superClass="de.innot.avreclipse.linker.option.genmap" value="loetst.map" valueType="string"/>
<option id="de.innot.avreclipse.linker.option.otherlinkargs.2053164848" name="Other Arguments" superClass="de.innot.avreclipse.linker.option.otherlinkargs" value="--cref" valueType="string"/>
<option id="de.innot.avreclipse.linker.option.libs.368134831" name="Libraries (-l)" superClass="de.innot.avreclipse.linker.option.libs" valueType="libs">
<listOptionValue builtIn="false" value="m"/>
</option>
</tool>
<tool id="de.innot.avreclipse.tool.compiler.winavr.app.debug.570354180" name="winAVR Compiler" superClass="de.innot.avreclipse.tool.compiler.winavr.app.debug">
<option id="de.innot.avreclipse.compiler.option.debug.1245320642" name="Generate Debugging Info (-g)" value="false" valueType="boolean"/>
<option id="de.innot.avreclipse.compiler.option.optimize.1720407027" name="Optimization Level" superClass="de.innot.avreclipse.compiler.option.optimize" value="de.innot.avreclipse.compiler.optimize.none" valueType="enumerated"/>
<option id="de.innot.avreclipse.compiler.option.avrtargetmcu.90946162" name="MCU Type" superClass="de.innot.avreclipse.compiler.option.avrtargetmcu" value="atmega32" valueType="string"/>
<option id="de.innot.avreclipse.compiler.option.avrtargetfcpu.820036261" name="MCU Clock Frequency" superClass="de.innot.avreclipse.compiler.option.avrtargetfcpu" value="16000000" valueType="string"/>
<option id="de.innot.avreclipse.compiler.option.incpath.465356119" name="Include Paths (-I)" superClass="de.innot.avreclipse.compiler.option.incpath" valueType="includePath">
<listOptionValue builtIn="false" value="&quot;${workspace_loc:/Loetst}&quot;"/>
<listOptionValue builtIn="false" value="&quot;C:\Programme\WinAVR\avrlib&quot;"/>
</option>
<option id="de.innot.avreclipse.compiler.option.otherflags.2026526451" name="Other flags" superClass="de.innot.avreclipse.compiler.option.otherflags" value="-c" valueType="string"/>
<option id="de.innot.avreclipse.compiler.option.debug.type.613566638" name="Debug Info Format" superClass="de.innot.avreclipse.compiler.option.debug.type" value="de.innot.avreclipse.compiler.option.debug.level.stabs" valueType="enumerated"/>
<inputType id="de.innot.avreclipse.compiler.winavr.input.103256222" name="C Source Files" superClass="de.innot.avreclipse.compiler.winavr.input"/>
</tool>
<tool id="de.innot.avreclipse.tool.size.winavr.app.debug.762095194" name="winAVR Print Size" superClass="de.innot.avreclipse.tool.size.winavr.app.debug"/>
<tool id="de.innot.avreclipse.tool.objdump.winavr.app.debug.1447717901" name="winAVR Create Extended Listing" superClass="de.innot.avreclipse.tool.objdump.winavr.app.debug"/>
<tool id="de.innot.avreclipse.tool.archiver.winavr.base.858460469" name="winAVR Archiver" superClass="de.innot.avreclipse.tool.archiver.winavr.base"/>
<tool id="de.innot.avreclipse.tool.assembler.winavr.app.debug.1764148309" name="winAVR Assembler" superClass="de.innot.avreclipse.tool.assembler.winavr.app.debug">
<inputType id="de.innot.avreclipse.tool.assembler.input.1916393827" superClass="de.innot.avreclipse.tool.assembler.input"/>
</tool>
<tool id="de.innot.avreclipse.tool.objcopy.flash.winavr.1285677163" name="winAVR Create Flash image" superClass="de.innot.avreclipse.tool.objcopy.flash.winavr">
<option id="de.innot.avreclipse.objcopy.flash.option.output.1087887392" name="Output Filename" superClass="de.innot.avreclipse.objcopy.flash.option.output" value="${BuildArtifactFileBaseName}.hex" valueType="string"/>
</tool>
</toolChain>
</folderInfo>
<sourceEntries>
<entry flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name=""/>
</sourceEntries>
</configuration>
</storageModule>
<storageModule moduleId="scannerConfiguration">
<autodiscovery enabled="true" problemReportingEnabled="true" selectedProfileId="org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile"/>
<profile id="org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile">
<buildOutputProvider>
<openAction enabled="true" filePath=""/>
<parser enabled="true"/>
</buildOutputProvider>
<scannerInfoProvider id="specsFile">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/${specs_file}" command="gcc" useDefault="true"/>
</scannerInfoProvider>
</profile>
<profile id="org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile">
<scannerInfoProvider id="makefileGenerator">
<runAction arguments="-f ${project_name}_scd.mk" command="make" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile">
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.cpp" command="g++" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC">
<runAction arguments="-E -P -v -dD ${plugin_state_location}/specs.c" command="gcc" useDefault="true"/>
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile">
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP">
</profile>
<profile id="org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC">
</profile>
</storageModule>
<storageModule moduleId="org.eclipse.cdt.core.externalSettings"/>
<storageModule moduleId="org.eclipse.cdt.core.language.mapping"/>
<storageModule moduleId="org.eclipse.cdt.make.core.buildtargets"/>
</cconfiguration>
<cconfiguration id="de.innot.avreclipse.configuration.app.release.810607443">
<storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="de.innot.avreclipse.configuration.app.release.810607443" moduleId="org.eclipse.cdt.core.settings" name="Release">
<externalSettings/>
<extensions>
</extensions>
</storageModule>
<configuration artifactExtension="elf" artifactName="Loetst" buildArtefactType="de.innot.avreclipse.buildArtefactType.app" buildProperties="org.eclipse.cdt.build.core.buildType=org.eclipse.cdt.build.core.buildType.release,org.eclipse.cdt.build.core.buildArtefactType=de.innot.avreclipse.buildArtefactType.app" description="" id="de.innot.avreclipse.configuration.app.release.810607443" name="Release" parent="de.innot.avreclipse.configuration.app.release" postannouncebuildStep="" postbuildStep="" preannouncebuildStep="" prebuildStep="">
<folderInfo id="de.innot.avreclipse.configuration.app.release.810607443." name="/" resourcePath="">
<toolChain id="de.innot.avreclipse.toolchain.winavr.app.release.544458421" name="WinAVR Toolchain" superClass="de.innot.avreclipse.toolchain.winavr.app.release" unusedChildren="de.innot.avreclipse.tool.objcopy.eeprom.winavr.app.release">
<option defaultValue="de.innot.avreclipse.mcus.atmega32" id="de.innot.avreclipse.toolchain.options.target.mcutype.app.release.1048363134" name="MCU Type" superClass="de.innot.avreclipse.toolchain.options.target.mcutype.app.release" value="de.innot.avreclipse.mcus.atmega32" valueType="enumerated"/>
<option defaultValue="16000000" id="de.innot.avreclipse.toolchain.options.target.fcpu.app.release.587010866" name="MCU Clock Frequency" superClass="de.innot.avreclipse.toolchain.options.target.fcpu.app.release" value="16000000" valueType="string"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objcopy.flash.app.release.454146448" name="Generate HEX file for Flash memory" superClass="de.innot.avreclipse.toolchain.options.toolchain.objcopy.flash.app.release"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objcopy.eeprom.app.release.705499439" name="Generate HEX file for EEPROM" superClass="de.innot.avreclipse.toolchain.options.toolchain.objcopy.eeprom.app.release" value="false" valueType="boolean"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.objdump.app.release.1364754505" name="Generate Extended Listing (Source + generated Assembler)" superClass="de.innot.avreclipse.toolchain.options.toolchain.objdump.app.release"/>
<option id="de.innot.avreclipse.toolchain.options.toolchain.size.app.release.1388110818" name="Print Size" superClass="de.innot.avreclipse.toolchain.options.toolchain.size.app.release"/>
<targetPlatform id="de.innot.avreclipse.targetplatform.winavr.app.release.1565493504" name="AVR Cross-Target" superClass="de.innot.avreclipse.targetplatform.winavr.app.release"/>
<builder buildPath="${workspace_loc:/Loetst/Release}" id="de.innot.avreclipse.target.builder.winavr.app.release.1503681313" keepEnvironmentInBuildfile="false" managedBuildOn="true" name="AVR GNU Make Builder" superClass="de.innot.avreclipse.target.builder.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.linker.winavr.app.release.1643303983" name="winAVR Linker" superClass="de.innot.avreclipse.tool.linker.winavr.app.release">
<option id="de.innot.avreclipse.linker.option.avrtargetmcu.1701180419" name="MCU Type" superClass="de.innot.avreclipse.linker.option.avrtargetmcu" value="atmega32" valueType="string"/>
<option id="de.innot.avreclipse.linker.option.genmap.2138427961" name="Map Filename" superClass="de.innot.avreclipse.linker.option.genmap" value="loetst.map" valueType="string"/>
</tool>
<tool id="de.innot.avreclipse.tool.compiler.winavr.app.release.1027523500" name="winAVR Compiler" superClass="de.innot.avreclipse.tool.compiler.winavr.app.release">
<option id="de.innot.avreclipse.compiler.option.debug.1199654975" name="Generate Debugging Info (-g)"/>
<option id="de.innot.avreclipse.compiler.option.optimize.339080334" name="Optimization Level" superClass="de.innot.avreclipse.compiler.option.optimize" value="de.innot.avreclipse.compiler.optimize.size" valueType="enumerated"/>
<option id="de.innot.avreclipse.compiler.option.avrtargetmcu.709804701" name="MCU Type" superClass="de.innot.avreclipse.compiler.option.avrtargetmcu" value="atmega32" valueType="string"/>
<option id="de.innot.avreclipse.compiler.option.avrtargetfcpu.1797905707" name="MCU Clock Frequency" superClass="de.innot.avreclipse.compiler.option.avrtargetfcpu" value="16000000" valueType="string"/>
<option id="de.innot.avreclipse.compiler.option.incpath.1337755287" name="Include Paths (-I)" superClass="de.innot.avreclipse.compiler.option.incpath" valueType="includePath">
</option>
<option id="de.innot.avreclipse.compiler.option.otherflags.403902198" name="Other flags" superClass="de.innot.avreclipse.compiler.option.otherflags" value="-c" valueType="string"/>
<option id="de.innot.avreclipse.compiler.option.debug.type.1426453899" superClass="de.innot.avreclipse.compiler.option.debug.type" value="de.innot.avreclipse.compiler.option.debug.level.dwarf-2" valueType="enumerated"/>
<inputType id="de.innot.avreclipse.compiler.winavr.input.1844995877" name="C Source Files" superClass="de.innot.avreclipse.compiler.winavr.input"/>
</tool>
<tool id="de.innot.avreclipse.tool.size.winavr.app.release.979188869" name="winAVR Print Size" superClass="de.innot.avreclipse.tool.size.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.objdump.winavr.app.release.196704258" name="winAVR Create Extended Listing" superClass="de.innot.avreclipse.tool.objdump.winavr.app.release"/>
<tool id="de.innot.avreclipse.tool.archiver.winavr.base.855341358" name="winAVR Archiver" superClass="de.innot.avreclipse.tool.archiver.winavr.base"/>
<tool id="de.innot.avreclipse.tool.assembler.winavr.app.release.409969440" name="winAVR Assembler" superClass="de.innot.avreclipse.tool.assembler.winavr.app.release">
<inputType id="de.innot.avreclipse.tool.assembler.input.736199008" superClass="de.innot.avreclipse.tool.assembler.input"/>
</tool>
<tool id="de.innot.avreclipse.tool.objcopy.flash.winavr.app.release.536262662" name="winAVR Create Flash image" superClass="de.innot.avreclipse.tool.objcopy.flash.winavr.app.release">
<option id="de.innot.avreclipse.objcopy.flash.option.output.1324106342" name="Output Filename" superClass="de.innot.avreclipse.objcopy.flash.option.output" value="${BuildArtifactFileBaseName}.hex" valueType="string"/>
</tool>
</toolChain>
</folderInfo>
</configuration>
</storageModule>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</profile>
</storageModule>
</cconfiguration>
</storageModule>
<project id="Loetst.de.innot.avreclipse.project.winavr.elf.1070612261" name="AVR Cross Target Application" projectType="de.innot.avreclipse.project.winavr.elf"/>
</storageModule>
</cproject>
