 RS485 protocol library - non-blocking.
 Devised and written by Nick Gammon.
 Date: 4 December 2012
 Version: 1.0
 Licence: Released for public use.
 Can send from 1 to 255 bytes from one node to another with:
 * Packet start indicator (STX)
 * Each data byte is doubled and inverted to check validity
 * Packet end indicator (ETX)
 * Packet CRC (checksum)
 To allow flexibility with hardware (eg. Serial, SoftwareSerial, I2C)
 you provide three "callback" functions which send or receive data. Examples are:
 size_t fWrite (const byte what)
   return Serial.write (what);
 int fAvailable ()
   return Serial.available ();
 int fRead ()
   return Serial.read ();
#include <RS485_nonBlocking.h>
// allocate the requested buffer size
void RS485::begin ()
  data_ = (uint8_t *) malloc (bufferSize_);
  reset ();
  errorCount_ = 0;
  } // end of RS485::begin
// get rid of the buffer
void RS485::stop ()
  reset ();
  free (data_);
  data_ = NULL;
} // end of RS485::stop
// called after an error to return to "not in a packet"
void RS485::reset ()
  haveSTX_ = false;
  available_ = false;
  inputPos_ = 0;
  startTime_ = 0;
  } // end of RS485::reset
// calculate 8-bit CRC
uint8_t RS485::crc8 (const byte *addr, uint8_t len)
  uint8_t crc = 0;
  while (len--)
    uint8_t inbyte = *addr++;
    for (uint8_t i = 8; i; i--)
      uint8_t mix = (crc ^ inbyte) & 0x01;
      crc >>= 1;
      if (mix)
        crc ^= 0x8C;
      inbyte >>= 1;
      }  // end of for
    }  // end of while
  return crc;
}  // end of RS485::crc8
// send a byte complemented, repeated
// only values sent would be (in hex):
// 0F, 1E, 2D, 3C, 4B, 5A, 69, 78, 87, 96, A5, B4, C3, D2, E1, F0
void RS485::sendComplemented (const uint8_t what)
uint8_t c;
  // first nibble
  c = what >> 4;
  fWriteCallback_ ((c << 4) | (c ^ 0x0F));
  // second nibble
  c = what & 0x0F;
}  // end of RS485::sendComplemented
// send a message of "length" bytes (max 255) to other end
// put STX at start, ETX at end, and add CRC
void RS485::sendMsg (const uint8_t * data, const uint8_t length)
  // no callback? Can't send
  if (fWriteCallback_ == NULL)
    return;
  fWriteCallback_ (STX);  // STX
  for (byte i = 0; i < length; i++)
    sendComplemented (data [i]);
  fWriteCallback_ (ETX);  // ETX
  sendComplemented (crc8 (data, length));
}  // end of RS485::sendMsg
// called periodically from main loop to process data and
// assemble the finished packet in 'data_'
// returns true if packet received.
// You could implement a timeout by seeing if isPacketStarted() returns
// true, and if too much time has passed since getPacketStartTime() time.
bool RS485::update ()
  // no data? can't go ahead (eg. begin() not called)
  if (data_ == NULL)
    return false;
  // no callbacks? Can't read
  if (fAvailableCallback_ == NULL || fReadCallback_ == NULL)
    return false;
  while (fAvailableCallback_ () > 0)
    uint8_t inByte = fReadCallback_ ();
    switch (inByte)
        case STX:   // start of text
          haveSTX_ = true;
          haveETX_ = false;
          inputPos_ = 0;
          firstNibble_ = true;
          startTime_ = millis ();
          break;
        case ETX:   // end of text (now expect the CRC check)
          haveETX_ = true;
          break;
        default:
          // wait until packet officially starts
          if (!haveSTX_)
            break;
          // check byte is in valid form (4 bits followed by 4 bits complemented)
          if ((inByte >> 4) != ((inByte & 0x0F) ^ 0x0F) )
            reset ();
            errorCount_++;
            break;  // bad character
            } // end if bad byte
          // convert back
          inByte >>= 4;
          // high-order nibble?
          if (firstNibble_)
            currentByte_ = inByte;
            firstNibble_ = false;
            break;
            }  // end of first nibble
          // low-order nibble
          currentByte_ <<= 4;
          currentByte_ |= inByte;
          // if we have the ETX this must be the CRC
          if (haveETX_)
            if (crc8 (data_, inputPos_) != currentByte_)
              reset ();
              errorCount_++;
              break;  // bad crc
              } // end of bad CRC
            available_ = true;
            return true;  // show data ready
            }  // end if have ETX already
          // keep adding if not full
          if (inputPos_ < bufferSize_)
            data_ [inputPos_++] = currentByte_;
          else
            reset (); // overflow, start again
            errorCount_++;
          break;
      }  // end of switch
    }  // end of while incoming data
  return false;  // not ready yet
  } // end of RS485::update
