 * Heizpatrone_PID.c
 * Created: 26.06.2016 17:47:31
 *  Author: Chris
static uint16_t adc_val;
static uint32_t r_ntc;
static float temp_sens;
#define TEMP_PID_INTERVAL	10		// only in this interval the PID is active, otherwise just MIN_HEATER_POWER / FULL_HEATER_POWER
#define MIN_HEATER_POWER	0
#define FULL_HEATER_POWER	255	
static float temp_setpoint = 60;	// target temperature
#define K_P		7500
#define K_I		0
#define K_D		0
static pidData_t	hotend_pid;
static volatile uint8_t timerflag_100ms = 0;	// 100ms flag, set in timer interrupt
static void set_pwm(uint8_t val)
	// ... set pwm value
static PID_STATE_T pid_mode = PID_OFF;
int main(void)
	pid_Init(K_P, K_I, K_D, &hotend_pid);
    while(1)
		if (timerflag_100ms)
			// get temperature
			adc_val = adc_read_multi(NTC_ADC_CHANNEL);
			temp_sens = analog2temp(adc_val, 0);
			// perform PID calculation
			int16_t output;
			output = pid_Controller(temp_setpoint, temp_sens, &hotend_pid);	// PID uses int16_t, so maybe we can eliminate the use of float
			// set PWM value
			if (output < 0)		// we cannot cool, so just turn the heater off
				pid_Reset_Integrator(&hotend_pid);	// reset integrator, since it doesn't make sense to sum up negative values cause we cannot cool
				set_pwm(0);
			else
				if (output > 255)	// 8 bit PWM --> max 255
					output = 255;
				set_pwm(output);
