Build started 10.1.2008 at 16:27:04 avr-gcc.exe -mmcu=atmega32 -Wall -gdwarf-2 -DF_CPU=16000000UL -O0 -fsigned-char -MD -MP -MT Int0.o -MF dep/Int0.o.d -c ../Int0.c .avr-gcc.exe -mmcu=atmega32 Int0.o lcd.o -o Int0.elf avr-objcopy -O ihex -R .eeprom Int0.elf Int0.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 -O ihex Int0.elf Int0.eep c:\Programme\WinAVR\bin\avr-objcopy.exe: there are no sections to be copied! c:\Programme\WinAVR\bin\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never used make: *** [Int0.eep] Error 1 Build succeeded with 0 Warnings... Build started 10.1.2008 at 16:29:38 avr-gcc.exe -mmcu=atmega32 -Wall -gdwarf-2 -DF_CPU=16000000UL -Os -fsigned-char -MD -MP -MT Int0.o -MF dep/Int0.o.d -c ../Int0.c avr-gcc.exe -mmcu=atmega32 Int0.o lcd.o -o Int0.elf avr-objcopy -O ihex -R .eeprom Int0.elf Int0.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 -O ihex Int0.elf Int0.eep c:\Programme\WinAVR\bin\avr-objcopy.exe: there are no sections to be copied! c:\Programme\WinAVR\bin\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never used make: *** [Int0.eep] Error 1 Build succeeded with 0 Warnings... Build started 10.1.2008 at 16:31:34 avr-gcc.exe -mmcu=atmega32 -Wall -gdwarf-2 -DF_CPU=16000000UL -O0 -fsigned-char -MD -MP -MT Int0.o -MF dep/Int0.o.d -c ../Int0.c avr-gcc.exe -mmcu=atmega32 Int0.o lcd.o -o Int0.elf avr-objcopy -O ihex -R .eeprom Int0.elf Int0.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 -O ihex Int0.elf Int0.eep c:\Programme\WinAVR\bin\avr-objcopy.exe: there are no sections to be copied! c:\Programme\WinAVR\bin\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never used make: *** [Int0.eep] Error 1 Build succeeded with 0 Warnings...
