(module THY_HB_TO240AA (layer F.Cu) (tedit 57BF2D7B)
  (descr "Thyristorhalbbrücke TO240AA Unterseite!")
  (fp_text reference THY_HB_TO240AA (at 20.4 8.5) (layer B.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value Val** (at -10.3 -8.9) (layer B.Fab) hide
  (fp_arc (start 39 9) (end 40 9) (angle 90) (layer Edge.Cuts) (width 0.15))
  (fp_arc (start 31 9) (end 31 10) (angle 90) (layer Edge.Cuts) (width 0.15))
  (fp_arc (start 39 -9) (end 39 -10) (angle 90) (layer Edge.Cuts) (width 0.15))
  (fp_arc (start 31 -9) (end 30 -9) (angle 90) (layer Edge.Cuts) (width 0.15))
  (fp_line (start 40 -9) (end 40 9) (layer Edge.Cuts) (width 0.15))
  (fp_line (start 39 10) (end 31 10) (layer Edge.Cuts) (width 0.15))
  (fp_line (start 30 9) (end 30 -9) (layer Edge.Cuts) (width 0.15))
  (fp_line (start 31 -10) (end 39 -10) (layer Edge.Cuts) (width 0.15))
  (fp_text user 6 (at 33 -5.5) (layer B.Fab)
    (effects (font (size 1 1) (thickness 0.15)) (justify mirror))
  (fp_text user 7 (at 33 -3.7) (layer B.Fab)
  (fp_text user 4 (at 33 3.7) (layer B.Fab)
  (fp_text user 5 (at 33 5.7) (layer B.Fab)
  (fp_line (start 32 -6.4) (end 31.5 -6.9) (layer B.Fab) (width 0.3))
  (fp_line (start 31.5 -6.9) (end 32 -7.4) (layer B.Fab) (width 0.3))
  (fp_line (start 32 -7.4) (end 32 -9) (layer B.Fab) (width 0.3))
  (fp_line (start 32 -9) (end 38 -9) (layer B.Fab) (width 0.3))
  (fp_line (start 38 -9) (end 38 -0.5) (layer B.Fab) (width 0.3))
  (fp_line (start 38 -0.5) (end 32 -0.5) (layer B.Fab) (width 0.3))
  (fp_line (start 32 -0.5) (end 32 -6.4) (layer B.Fab) (width 0.3))
  (fp_line (start 32 7.2) (end 32 9) (layer B.Fab) (width 0.3))
  (fp_line (start 32 9) (end 38 9) (layer B.Fab) (width 0.3))
  (fp_line (start 32 0.5) (end 32 6.4) (layer B.Fab) (width 0.3))
  (fp_line (start 32 6.4) (end 31.6 6.8) (layer B.Fab) (width 0.3))
  (fp_line (start 31.6 6.8) (end 32 7.2) (layer B.Fab) (width 0.3))
  (fp_line (start 38 9) (end 38 0.5) (layer B.Fab) (width 0.3))
  (fp_line (start 38 0.5) (end 32 0.5) (layer B.Fab) (width 0.3))
  (fp_line (start -14.5 -6.5) (end -25.5 -6.5) (layer B.Fab) (width 0.3))
  (fp_line (start -25.5 -6.5) (end -25.5 8.5) (layer B.Fab) (width 0.3))
  (fp_line (start -25.5 8.5) (end -14.5 8.5) (layer B.Fab) (width 0.3))
  (fp_line (start -14.5 8.5) (end -14.5 -6.5) (layer B.Fab) (width 0.3))
  (fp_line (start 5.5 -6.5) (end -5.5 -6.5) (layer B.Fab) (width 0.3))
  (fp_line (start -5.5 -6.5) (end -5.5 8.5) (layer B.Fab) (width 0.3))
  (fp_line (start -5.5 8.5) (end 5.5 8.5) (layer B.Fab) (width 0.3))
  (fp_line (start 5.5 8.5) (end 5.5 -6.5) (layer B.Fab) (width 0.3))
  (fp_line (start 25.5 -8.4) (end 14.5 -8.4) (layer B.Fab) (width 0.3))
  (fp_line (start 14.5 -8.4) (end 14.5 6.5) (layer B.Fab) (width 0.3))
  (fp_line (start 14.5 6.5) (end 25.5 6.5) (layer B.Fab) (width 0.3))
  (fp_line (start 25.5 6.5) (end 25.5 -8.3) (layer B.Fab) (width 0.3))
  (fp_line (start 25.5 -8.3) (end 25.5 -8.4) (layer B.Fab) (width 0.3))
  (fp_line (start 33.6 -6.9) (end 36.4 -6.9) (layer B.Fab) (width 0.8))
  (fp_line (start 33.6 6.9) (end 36.4 6.9) (layer B.Fab) (width 0.8))
  (fp_line (start 33.6 2.5) (end 36.4 2.5) (layer B.Fab) (width 0.8))
  (fp_line (start 33.6 -2.5) (end 36.4 -2.5) (layer B.Fab) (width 0.8))
  (fp_line (start -29 -10.5) (end -29 10.5) (layer B.Fab) (width 0.3))
  (fp_line (start 39 -10.5) (end 39 10.5) (layer B.Fab) (width 0.3))
  (fp_circle (center 45 0) (end 50 0) (layer B.Fab) (width 0.3))
  (fp_circle (center 45 0) (end 47.75 0) (layer B.Fab) (width 0.3))
  (fp_circle (center -35 0) (end -30 0) (layer B.Fab) (width 0.3))
  (fp_circle (center -35 0) (end -32.25 0) (layer B.Fab) (width 0.3))
  (fp_line (start -41 -10.5) (end -41 10.5) (layer B.Fab) (width 0.3))
  (fp_line (start -41 -10.5) (end 51 -10.5) (layer B.Fab) (width 0.3))
  (fp_line (start 51 -10.5) (end 51 10.5) (layer B.Fab) (width 0.3))
  (fp_line (start 51 10.5) (end -41 10.5) (layer B.Fab) (width 0.3))
  (pad 1 thru_hole circle (at -20 0) (size 11 11) (drill 5.5) (layers *.Cu *.Mask F.SilkS))
  (pad 2 thru_hole circle (at 0 0) (size 11 11) (drill 5.5) (layers *.Cu *.Mask F.SilkS))
  (pad 3 thru_hole circle (at 20 0) (size 11 11) (drill 5.5) (layers *.Cu *.Mask F.SilkS))
