############################################################################### MAKEFILE ############################################################################### # Hey Emacs, this is a -*- makefile -*- # # WinARM template makefile # by Martin Thomas, Kaiserslautern, Germany # # # based on the WinAVR makefile written by Eric B. Weddington, Jörg Wunsch, et al. # Released to the Public Domain # Please read the make user manual! # # # On command line: # # make all = Make software. # # make clean = Clean out built project files. # # make program = Download the hex file to the device # # (TODO: make filename.s = Just compile filename.c into the assembler code only) # # To rebuild project do "make clean" then "make all". # # Changelog: # - 17. Feb. 2005 - added thumb-interwork support (mth) # - 28. Apr. 2005 - added C++ support (mth) # - 29. Arp. 2005 - changed handling for lst-Filename (mth) # - 1. Nov. 2005 - exception-vector placement options (mth) # - 15. Nov. 2005 - added library-search-path (EXTRA_LIB...) (mth) # - 2. Dec. 2005 - fixed ihex and binary file extensions (mth) # - 22. Feb. 2006 - added AT91LIBNOWARN setting (mth) # - 19. Apr. 2006 - option FLASH_TOOL (default lpc21isp); variable IMGEXT (mth) # - 23. Jun. 2006 - option USE_THUMB_MODE -> THUMB/THUMB_IW # - 3. Aug. 2006 - added -ffunction-sections -fdata-sections to CFLAGS # and --gc-sections to LDFLAGS. Only availble for gcc 4 (mth) # - 4. Aug. 2006 - pass SUBMDL-define to frontend (mth) # - 27. Oct. 2006 - Toolchain-prefix (mth), linker-scripts-path TOOLCHAIN_PREFIX=arm-elf PATH_TO_LINKSCRIPTS=C:/workspace/usartUSB #FLASH_TOOL = UVISION FLASH_TOOL = OPENOCD # MCU name and submodel MCU = arm7tdmi SUBMDL = AT91SAM7S256 USE_THUMB_MODE = YES ## Create ROM-Image (final) RUN_MODE=ROM_RUN ## Create RAM-Image (debugging) ##( not used: example does not fit in AT91SAM7S64 RAM ) #RUN_MODE=RAM_RUN ## Exception-Vector placement only supported for "ROM_RUN" ## (placement settings ignored when using "RAM_RUN") ## - Exception vectors in ROM: #VECTOR_LOCATION=VECTORS_IN_ROM ## - Exception vectors in RAM: VECTOR_LOCATION=VECTORS_IN_RAM # Target file name (without extension). TARGET = main # List C source files here. (C dependencies are automatically generated.) # use file-extension c for "c-only"-files SRC = Cstartup_SAM7.c SRC += swi_handler_user.c SRC += $(TARGET).c cdc_enumerate.c interrupt_Usart.c # List C source files here which must be compiled in ARM-Mode. # use file-extension c for "c-only"-files SRCARM = # List C++ source files here. # use file-extension cpp for C++-files (use extension .cpp) CPPSRC = # List C++ source files here which must be compiled in ARM-Mode. # use file-extension cpp for C++-files (use extension .cpp) CPPSRCARM = # List Assembler source files here. # Make them always end in a capital .S. Files ending in a lowercase .s # will not be considered source files but generated files (assembler # output from the compiler), and will be deleted upon "make clean"! # Even though the DOS/Win* filesystem matches both .s and .S the same, # it will preserve the spelling of the filenames, and gcc itself does # care about how the name is spelled on its command-line. ASRC = # List Assembler source files here which must be assembled in ARM-Mode.. ASRCARM = Cstartup.S ASRCARM += swi_handler.S ## Output format. (can be ihex or binary) ## (binary i.e. for openocd and SAM-BA, hex i.e. for lpc21isp and uVision) #FORMAT = ihex FORMAT = binary # Optimization level, can be [0, 1, 2, 3, s]. # 0 = turn off optimization. s = optimize for size. # (Note: 3 is not always the best optimization level. See avr-libc FAQ.) OPT = s #OPT = 0 # Debugging format. # Native formats for AVR-GCC's -g are stabs [default], or dwarf-2. # AVR (extended) COFF requires stabs, plus an avr-objcopy run. #DEBUG = stabs DEBUG = dwarf-2 # List any extra directories to look for include files here. # Each directory must be seperated by a space. EXTRAINCDIRS = # List any extra directories to look for library files here. # Each directory must be seperated by a space. EXTRA_LIBDIRS = ## Using the Atmel AT91_lib produces warning with ## the default warning-levels. ## yes - disable these warnings; no - keep default settings AT91LIBNOWARN = yes #AT91LIBNOWARN = no # Compiler flag to set the C Standard level. # c89 - "ANSI" C # gnu89 - c89 plus GCC extensions # c99 - ISO C99 standard (not yet fully implemented) # gnu99 - c99 plus GCC extensions CSTANDARD = -std=gnu99 # Place -D or -U options for C here CDEFS = -D$(RUN_MODE) # Place -I options here CINCS = # Place -D or -U options for ASM here ADEFS = -D$(RUN_MODE) ifdef VECTOR_LOCATION CDEFS += -D$(VECTOR_LOCATION) ADEFS += -D$(VECTOR_LOCATION) endif CDEFS += -D__WinARM__ -D__WINARMSUBMDL_$(SUBMDL)__ ADEFS += -D__WinARM__ -D__WINARMSUBMDL_$(SUBMDL)__ # Compiler flags. ifeq ($(USE_THUMB_MODE),YES) THUMB = -mthumb THUMB_IW = -mthumb-interwork else THUMB = THUMB_IW = endif # -g*: generate debugging information # -O*: optimization level # -f...: tuning, see GCC manual and avr-libc documentation # -Wall...: warning level # -Wa,...: tell GCC to pass this to the assembler. # -adhlns...: create assembler listing # # Flags for C and C++ (arm-elf-gcc/arm-elf-g++) CFLAGS = -g$(DEBUG) CFLAGS += $(CDEFS) $(CINCS) CFLAGS += -O$(OPT) CFLAGS += -ffunction-sections -fdata-sections CFLAGS += -Wall -Wcast-align -Wimplicit CFLAGS += -Wpointer-arith -Wswitch CFLAGS += -Wredundant-decls -Wreturn-type -Wshadow -Wunused CFLAGS += -Wa,-adhlns=$(subst $(suffix $<),.lst,$<) CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS)) # flags only for C CONLYFLAGS += -Wnested-externs CONLYFLAGS += $(CSTANDARD) ifneq ($(AT91LIBNOWARN),yes) #AT91-lib warnings with: CFLAGS += -Wcast-qual CONLYFLAGS += -Wmissing-prototypes CONLYFLAGS += -Wstrict-prototypes CONLYFLAGS += -Wmissing-declarations endif # flags only for C++ (arm-elf-g++) CPPFLAGS = -fno-rtti -fno-exceptions # Assembler flags. # -Wa,...: tell GCC to pass this to the assembler. # -ahlns: create listing # -g$(DEBUG): have the assembler create line number information ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:.S=.lst),--g$(DEBUG) #Additional libraries. # Extra libraries # Each library-name must be seperated by a space. # To add libxyz.a, libabc.a and libefsl.a: # EXTRA_LIBS = xyz abc efsl #EXTRA_LIBS = efsl EXTRA_LIBS = #Support for newlibc-lpc (file: libnewlibc-lpc.a) #NEWLIBLPC = -lnewlib-lpc MATH_LIB = -lm # CPLUSPLUS_LIB = -lstdc++ # Linker flags. # -Wl,...: tell GCC to pass this to linker. # -Map: create map file # --cref: add cross reference to map file LDFLAGS = -nostartfiles -Wl,-Map=$(TARGET).map,--cref,--gc-sections LDFLAGS += -lc LDFLAGS += $(NEWLIBLPC) $(MATH_LIB) LDFLAGS += -lc -lgcc LDFLAGS += $(CPLUSPLUS_LIB) LDFLAGS += $(patsubst %,-L%,$(EXTRA_LIBDIRS)) LDFLAGS += $(patsubst %,-l%,$(EXTRA_LIBS)) # Set Linker-Script Depending On Selected Memory and Controller ifeq ($(RUN_MODE),RAM_RUN) LDFLAGS +=-T$(PATH_TO_LINKSCRIPTS)/$(SUBMDL)-RAM.ld else LDFLAGS +=-T$(PATH_TO_LINKSCRIPTS)/$(SUBMDL)-ROM.ld endif # Define directories, if needed. ## DIRARM = c:/WinARM/ ## DIRARMBIN = $(DIRAVR)/bin/ ## DIRAVRUTILS = $(DIRAVR)/utils/bin/ # Define programs and commands. CC = $(TOOLCHAIN_PREFIX)-gcc CPP = $(TOOLCHAIN_PREFIX)-g++ OBJCOPY = $(TOOLCHAIN_PREFIX)-objcopy OBJDUMP = $(TOOLCHAIN_PREFIX)-objdump SIZE = $(TOOLCHAIN_PREFIX)-size NM = $(TOOLCHAIN_PREFIX)-nm SHELL = sh REMOVE = rm -f COPY = cp # Define Messages # English MSG_ERRORS_NONE = Errors: none MSG_BEGIN = "-------- begin (mode: $(RUN_MODE)) --------" MSG_END = -------- end -------- MSG_SIZE_BEFORE = Size before: MSG_SIZE_AFTER = Size after: MSG_FLASH = Creating load file for Flash: MSG_EXTENDED_LISTING = Creating Extended Listing: MSG_SYMBOL_TABLE = Creating Symbol Table: MSG_LINKING = Linking: MSG_COMPILING = Compiling C: MSG_COMPILING_ARM = "Compiling C (ARM-only):" MSG_COMPILINGCPP = Compiling C++: MSG_COMPILINGCPP_ARM = "Compiling C++ (ARM-only):" MSG_ASSEMBLING = Assembling: MSG_ASSEMBLING_ARM = "Assembling (ARM-only):" MSG_CLEANING = Cleaning project: MSG_FORMATERROR = Can not handle output-format MSG_LPC21_RESETREMINDER = You may have to bring the target in bootloader-mode now. # Define all object files. COBJ = $(SRC:.c=.o) AOBJ = $(ASRC:.S=.o) COBJARM = $(SRCARM:.c=.o) AOBJARM = $(ASRCARM:.S=.o) CPPOBJ = $(CPPSRC:.cpp=.o) CPPOBJARM = $(CPPSRCARM:.cpp=.o) # Define all listing files. LST = $(ASRC:.S=.lst) $(ASRCARM:.S=.lst) $(SRC:.c=.lst) $(SRCARM:.c=.lst) LST += $(CPPSRC:.cpp=.lst) $(CPPSRCARM:.cpp=.lst) # Compiler flags to generate dependency files. ### GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d # Combine all necessary flags and optional flags. # Add target processor to flags. ALL_CFLAGS = -mcpu=$(MCU) $(THUMB_IW) -I. $(CFLAGS) $(GENDEPFLAGS) ALL_ASFLAGS = -mcpu=$(MCU) $(THUMB_IW) -I. -x assembler-with-cpp $(ASFLAGS) # Default target. all: begin gccversion sizebefore build sizeafter finished end ifeq ($(FORMAT),ihex) build: elf hex lss sym hex: $(TARGET).hex IMGEXT=hex else ifeq ($(FORMAT),binary) build: elf bin lss sym bin: $(TARGET).bin IMGEXT=bin else $(error "$(MSG_FORMATERROR) $(FORMAT)") endif endif elf: $(TARGET).elf lss: $(TARGET).lss sym: $(TARGET).sym # Eye candy. begin: @echo @echo $(MSG_BEGIN) finished: @echo $(MSG_ERRORS_NONE) end: @echo $(MSG_END) @echo # Display size of file. HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex ELFSIZE = $(SIZE) -A $(TARGET).elf sizebefore: @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi sizeafter: @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi # Display compiler version information. gccversion : @$(CC) --version ifeq ($(FLASH_TOOL),OPENOCD) # Program the device with Dominic Rath's OPENOCD in "batch-mode", needs cfg and "reset-script". # see files in distribution program: $(TARGET).$(IMGEXT) @echo @echo "Programming with OPENOCD" openocd_go_flash.cmd endif # Create final output file (.hex) from ELF output file. %.hex: %.elf @echo @echo $(MSG_FLASH) $@ $(OBJCOPY) -O $(FORMAT) $< $@ # Create final output file (.bin) from ELF output file. %.bin: %.elf @echo @echo $(MSG_FLASH) $@ $(OBJCOPY) -O $(FORMAT) $< $@ # Create extended listing file from ELF output file. # testing: option -C %.lss: %.elf @echo @echo $(MSG_EXTENDED_LISTING) $@ $(OBJDUMP) -h -S -C $< > $@ # Create a symbol table from ELF output file. %.sym: %.elf @echo @echo $(MSG_SYMBOL_TABLE) $@ $(NM) -n $< > $@ # Link: create ELF output file from object files. .SECONDARY : $(TARGET).elf .PRECIOUS : $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM) %.elf: $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM) @echo @echo $(MSG_LINKING) $@ $(CC) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM) --output $@ $(LDFLAGS) # $(CPP) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM) --output $@ $(LDFLAGS) # Compile: create object files from C source files. ARM/Thumb $(COBJ) : %.o : %.c @echo @echo $(MSG_COMPILING) $< $(CC) -c $(THUMB) $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@ # Compile: create object files from C source files. ARM-only $(COBJARM) : %.o : %.c @echo @echo $(MSG_COMPILING_ARM) $< $(CC) -c $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@ # Compile: create object files from C++ source files. ARM/Thumb $(CPPOBJ) : %.o : %.cpp @echo @echo $(MSG_COMPILINGCPP) $< $(CPP) -c $(THUMB) $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@ # Compile: create object files from C++ source files. ARM-only $(CPPOBJARM) : %.o : %.cpp @echo @echo $(MSG_COMPILINGCPP_ARM) $< $(CPP) -c $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@ # Compile: create assembler files from C source files. ARM/Thumb ## does not work - TODO - hints welcome ##$(COBJ) : %.s : %.c ## $(CC) $(THUMB) -S $(ALL_CFLAGS) $< -o $@ # Assemble: create object files from assembler source files. ARM/Thumb $(AOBJ) : %.o : %.S @echo @echo $(MSG_ASSEMBLING) $< $(CC) -c $(THUMB) $(ALL_ASFLAGS) $< -o $@ # Assemble: create object files from assembler source files. ARM-only $(AOBJARM) : %.o : %.S @echo @echo $(MSG_ASSEMBLING_ARM) $< $(CC) -c $(ALL_ASFLAGS) $< -o $@ # Target: clean project. clean: begin clean_list finished end clean_list : @echo @echo $(MSG_CLEANING) $(REMOVE) $(TARGET).hex $(REMOVE) $(TARGET).bin $(REMOVE) $(TARGET).obj $(REMOVE) $(TARGET).elf $(REMOVE) $(TARGET).map $(REMOVE) $(TARGET).obj $(REMOVE) $(TARGET).a90 $(REMOVE) $(TARGET).sym $(REMOVE) $(TARGET).lnk $(REMOVE) $(TARGET).lss $(REMOVE) $(COBJ) $(REMOVE) $(CPPOBJ) $(REMOVE) $(AOBJ) $(REMOVE) $(COBJARM) $(REMOVE) $(CPPOBJARM) $(REMOVE) $(AOBJARM) $(REMOVE) $(LST) $(REMOVE) $(SRC:.c=.s) $(REMOVE) $(SRC:.c=.d) $(REMOVE) $(SRCARM:.c=.s) $(REMOVE) $(SRCARM:.c=.d) $(REMOVE) $(CPPSRC:.cpp=.s) $(REMOVE) $(CPPSRC:.cpp=.d) $(REMOVE) $(CPPSRCARM:.cpp=.s) $(REMOVE) $(CPPSRCARM:.cpp=.d) $(REMOVE) .dep/* # Include the dependency files. -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*) # Listing of phony targets. .PHONY : all begin finish end sizebefore sizeafter gccversion \ build elf hex bin lss sym clean clean_list program ###################################################################################### ###################################################################################### #daemon configuration telnet_port 4444 gdb_port 3333 #interface interface ft2232 ft2232_device_desc "Olimex OpenOCD JTAG TINY A" ft2232_layout jtagkey ft2232_vid_pid 0x15BA 0x0003 jtag_speed 2 jtag_nsrst_delay 200 jtag_ntrst_delay 200 #use combined on interfaces or targets that can't set TRST/SRST separately reset_config srst_only srst_pulls_trst #jtag scan chain #format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE) jtag_device 4 0x1 0xf 0xe #target configuration daemon_startup reset #target #target arm7tdmi target arm7tdmi little run_and_init 0 arm7tdmi run_and_halt_time 0 30 # flash-options AT91 target_script 0 reset openocd_at91sam7s_flash_program.script working_area 0 0x00200000 0x4000 nobackup flash bank at91sam7 0 0 0 0 0 # Information: # erase command (telnet-interface) for complete flash: # flash erase 0 numlockbits-1 (can be seen from output of flash info 0) # SAM7S64 with 16 lockbits and bank 0: flash erase 0 0 15 # set/clear NVM-Bits: # at91sam7 gpnvm # at91sam7 gpnvm 0 2 set #disable locking from SAM-BA #flash protect 0 0 1 off # For more information about the configuration files, take a look at: # http://openfacts.berlios.de/index-en.phtml?title=Open+On-Chip+Debugger ################################################################################### openocd_at91sam7s_flash_program.script #################################################################################### # The following command wills be executed on # reset (because of run_and_init in the config-file) # - halt target # - init ecr # - flash content of file main.bin into target-memory # - shutdown openocd # # created by Martin Thomas # http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects # based on information from Dominic Rath # halt sleep 10 wait_halt #disable locking from SAM-BA flash protect 0 0 1 off # set/clear NVM-Bits: # at91sam7 gpnvm at91sam7 gpnvm 0 2 set # Init - taken form the script openocd_at91sam7_ecr.script mww 0xfffffd44 0x00008000 # disable watchdog mww 0xfffffd08 0xa5000001 # enable user reset mww 0xfffffc20 0x00000601 # CKGR_MOR : enable the main oscillator sleep 10 mww 0xfffffc2c 0x00481c0e # CKGR_PLLR: 96.1097 MHz sleep 10 mww 0xfffffc30 0x00000007 # PMC_MCKR : MCK = PLL / 2 ~= 48 MHz sleep 10 mww 0xffffff60 0x003c0100 # MC_FMR: flash mode (FWS=1,FMCN=60) # arm7_9 force_hw_bkpts enable # program resides in flash # AT91SAM7 flash command-"batch" arm7_9 dcc_downloads enable flash probe 0 flash write 0 main.bin 0x0 sleep 10 reset run sleep 10 shutdown ################################################################################### ################################################################################### ################################################################################### ################################################################################### #daemon configuration telnet_port 4444 gdb_port 3333 #interface interface ft2232 ft2232_device_desc "Olimex OpenOCD JTAG TINY A" ft2232_layout jtagkey ft2232_vid_pid 0x15BA 0x0003 jtag_speed 2 jtag_nsrst_delay 200 jtag_ntrst_delay 200 #use combined on interfaces or targets that can't set TRST/SRST separately reset_config srst_only srst_pulls_trst #jtag scan chain #format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE) jtag_device 4 0x1 0xf 0xe #target configuration daemon_startup reset #target #target arm7tdmi target arm7tdmi little run_and_init 0 arm7tdmi run_and_halt_time 0 30 # flash-options AT91 #target_script 0 reset openocd_at91sam7s_flash_debug.script #working_area 0 0x00200000 0x4000 nobackup flash bank at91sam7 0 0 0 0 0 # Information: # erase command (telnet-interface) for complete flash: # flash erase 0 numlockbits-1 (can be seen from output of flash info 0) # SAM7S64 with 16 lockbits and bank 0: flash erase 0 0 15 # set/clear NVM-Bits: # at91sam7 gpnvm # disable locking from SAM-BA # flash protect 0 0 1 off # For more information about the configuration files, take a look at: # http://openfacts.berlios.de/index-en.phtml?title=Open+On-Chip+Debugger ###################################################################################### openocd_at91sam7s_flash_debug.script ###################################################################################### # Information: # erase command (telnet-interface) for complete flash: # flash erase 0 numlockbits-1 (can be seen from output of flash info 0) # SAM7S64 with 16 lockbits and bank 0: flash erase 0 0 15 # set/clear NVM-Bits: # at91sam7 gpnvm #at91sam7 gpnvm 0 2 set #disable locking from SAM-BA #flash protect 0 0 1 off # For more information about the configuration files, take a look at: # http://openfacts.berlios.de/index-en.phtml?title=Open+On-Chip+Debugger
