#!/usr/bin/env python
#E:\Desktop_ab_20140620\Desktop_Arduino\libraries\esp8266-1.6.5-947-g39819f0\libraries\ESP8266mDNS\examples\DNS_SD_Arduino_OTA
#C:\Espressif\examples\ArduinoOTA\examples
# Original espota.py by Ivan Grokhotkov:
# https://gist.github.com/igrr/d35ab8446922179dc58c
# Modified since 2015-09-18 from Pascal Gollor (https://github.com/pgollor)
# Modified since 2015-11-09 from Hristo Gochkov (https://github.com/me-no-dev)
# Modified since 2016-01-03 from Matthew O'Gorman (https://githumb.com/mogorman)
# This script will push an OTA update to the ESP
# use it like: python espota.py -i <ESP_IP_address> -I <Host_IP_address> -p <ESP_port> -P <Host_port> [-a password] -f <sketch.bin>
# espota.py  liegt in c:\Users\Thomas>
# 1. cd c:\Users\Thomas> 2. In normaler Eingabeaufforderung den folgenden String ausführen
# python espota.py -i myesp8266.local -I 192.168.0.111 -p 8266 -P 8267  -f C:\Espressif\examples\ArduinoOTA\examples\.pioenvs\esp12e\firmware.bin
# Or to upload SPIFFS image:
# python espota.py -i <ESP_IP_address> -I <Host_IP_address> -p <ESP_port> -P <HOST_port> [-a password] -s -f <spiffs.bin>
# C:\Espressif\examples\ArduinoOTA\examples\src\saBasicOTA_DS1820.ino
# Changes
# 2015-09-18:
# - Add option parser.
# - Add logging.
# - Send command to controller to differ between flashing and transmitting SPIFFS image.
# Changes
# 2015-11-09:
# - Added digest authentication
# - Enchanced error tracking and reporting
# Changes
# 2016-01-03:
# - Added more options to parser.
from __future__ import print_function
import socket
import sys
import os
import optparse
import logging
import hashlib
import random
# Commands
FLASH = 0
SPIFFS = 100
AUTH = 200
PROGRESS = False
# update_progress() : Displays or updates a console progress bar
## Accepts a float between 0 and 1. Any int will be converted to a float.
## A value under 0 represents a 'halt'.
## A value at 1 or bigger represents 100%
def update_progress(progress):
  if (PROGRESS):
    barLength = 60 # Modify this to change the length of the progress bar
    status = ""
    if isinstance(progress, int):
      progress = float(progress)
    if not isinstance(progress, float):
      progress = 0
      status = "error: progress var must be float\r\n"
    if progress < 0:
      progress = 0
      status = "Halt...\r\n"
    if progress >= 1:
      progress = 1
      status = "Done...\r\n"
    block = int(round(barLength*progress))
    text = "\rUploading: [{0}] {1}% {2}".format( "="*block + " "*(barLength-block), int(progress*100), status)
    sys.stderr.write(text)
    sys.stderr.flush()
  else:
    sys.stderr.write('.')
    sys.stderr.flush()
def serve(remoteAddr, localAddr, remotePort, localPort, password, filename, command = FLASH):
  # Create a TCP/IP socket
  sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
  server_address = (localAddr, localPort)
  logging.info('Starting on %s:%s', str(server_address[0]), str(server_address[1]))
  try:
    sock.bind(server_address)
    sock.listen(1)
  except:
    logging.error("Listen Failed")
    return 1
  content_size = os.path.getsize(filename)
  f = open(filename,'rb')
  file_md5 = hashlib.md5(f.read()).hexdigest()
  f.close()
  logging.info('Upload size: %d', content_size)
  message = '%d %d %d %s\n' % (command, localPort, content_size, file_md5)
  # Wait for a connection
  logging.info('Sending invitation to: %s', remoteAddr)
  sock2 = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
  remote_address = (remoteAddr, int(remotePort))
  sent = sock2.sendto(message.encode(), remote_address)
  sock2.settimeout(10)
  try:
    data = sock2.recv(37).decode()
  except:
    logging.error('No Answer')
    sock2.close()
    return 1
  if (data != "OK"):
    if(data.startswith('AUTH')):
      nonce = data.split()[1]
      cnonce_text = '%s%u%s%s' % (filename, content_size, file_md5, remoteAddr)
      cnonce = hashlib.md5(cnonce_text.encode()).hexdigest()
      passmd5 = hashlib.md5(password.encode()).hexdigest()
      result_text = '%s:%s:%s' % (passmd5 ,nonce, cnonce)
      result = hashlib.md5(result_text.encode()).hexdigest()
      sys.stderr.write('Authenticating...')
      sys.stderr.flush()
      message = '%d %s %s\n' % (AUTH, cnonce, result)
      try:
        data = sock2.recv(32).decode()
      except:
        sys.stderr.write('FAIL\n')
        logging.error('No Answer to our Authentication')
        sock2.close()
        return 1
      if (data != "OK"):
        logging.error('%s', data)
        sock2.close()
        sys.exit(1);
        return 1
      sys.stderr.write('OK\n')
    else:
      logging.error('Bad Answer: %s', data)
      sock2.close()
      return 1
  sock2.close()
  logging.info('Waiting for device...')
  try:
    sock.settimeout(10)
    connection, client_address = sock.accept()
    sock.settimeout(None)
    connection.settimeout(None)
  except:
    logging.error('No response from device')
    sock.close()
    return 1
  try:
    f = open(filename, "rb")
    if (PROGRESS):
      update_progress(0)
    else:
      sys.stderr.write('Uploading')
      sys.stderr.flush()
    offset = 0
    while True:
      chunk = f.read(1460)
      if not chunk: break
      offset += len(chunk)
      update_progress(offset/float(content_size))
      connection.settimeout(10)
      try:
        connection.sendall(chunk)
        res = connection.recv(4)
      except:
        sys.stderr.write('\n')
        logging.error('Error Uploading')
        connection.close()
        f.close()
        sock.close()
        return 1
    logging.info('Waiting for result...')
    try:
      connection.settimeout(60)
      data = connection.recv(32).decode()
      logging.info('Result: %s' ,data)
      connection.close()
      f.close()
      sock.close()
      if (data != "OK"):
        return 1;
      return 0
    except:
      logging.error('No Result!')
      connection.close()
      f.close()
      sock.close()
      return 1
  finally:
    connection.close()
    f.close()
  sock.close()
  return 1
# end serve
def parser():
  parser = optparse.OptionParser(
    usage = "%prog [options]",
    description = "Transmit image over the air to the esp8266 module with OTA support."
  # destination ip and port
  group = optparse.OptionGroup(parser, "Destination")
  group.add_option("-i", "--ip",
    dest = "esp_ip",
    action = "store",
    help = "ESP8266 IP Address.",
    default = False
  group.add_option("-I", "--host_ip",
    dest = "host_ip",
    action = "store",
    help = "Host IP Address.",
    default = "0.0.0.0"
  group.add_option("-p", "--port",
    dest = "esp_port",
    type = "int",
    help = "ESP8266 ota Port. Default 8266",
    default = 8266
  group.add_option("-P", "--host_port",
    dest = "host_port",
    type = "int",
    help = "Host server ota Port. Default random 10000-60000",
    default = random.randint(10000,60000)
  parser.add_option_group(group)
  # auth
  group = optparse.OptionGroup(parser, "Authentication")
  group.add_option("-a", "--auth",
    dest = "auth",
    help = "Set authentication password.",
    action = "store",
    default = ""
  # image
  group = optparse.OptionGroup(parser, "Image")
  group.add_option("-f", "--file",
    dest = "image",
    help = "Image file.",
    metavar="FILE",
    default = None
  group.add_option("-s", "--spiffs",
    dest = "spiffs",
    action = "store_true",
    help = "Use this option to transmit a SPIFFS image and do not flash the module.",
    default = False
  # output group
  group = optparse.OptionGroup(parser, "Output")
  group.add_option("-d", "--debug",
    dest = "debug",
    help = "Show debug output. And override loglevel with debug.",
    default = False
  group.add_option("-r", "--progress",
    dest = "progress",
    help = "Show progress output. Does not work for ArduinoIDE",
    default = False
  (options, args) = parser.parse_args()
  return options
# end parser
def main(args):
  # get options
  options = parser()
  # adapt log level
  loglevel = logging.WARNING
  if (options.debug):
    loglevel = logging.DEBUG
  # end if
  # logging
  logging.basicConfig(level = loglevel, format = '%(asctime)-8s [%(levelname)s]: %(message)s', datefmt = '%H:%M:%S')
  logging.debug("Options: %s", str(options))
  # check options
  global PROGRESS
  PROGRESS = options.progress
  if (not options.esp_ip or not options.image):
    logging.critical("Not enough arguments.")
    return 1
  # end if
  command = FLASH
  if (options.spiffs):
    command = SPIFFS
  # end if
  return serve(options.esp_ip, options.host_ip, options.esp_port, options.host_port, options.auth, options.image, command)
# end main
if __name__ == '__main__':
  sys.exit(main(sys.argv))
# end if
