* Atmel Corporation
* File              : USI_TWI_Master.h
* Compiler          : AVRGCC Toolchain version 3.4.2
* Revision          : $Revision: 992 $
* Date              : $Date: 2013-11-07 $
* Updated by        : $Author: Atmel $
* Support mail      : avr@atmel.com
* Supported devices : All device with USI module can be used.
*                     The example is written for the ATmega169, ATtiny26 and ATtiny2313
* AppNote           : AVR310 - Using the USI module as a TWI Master
* Description       : This is an implementation of an TWI master using
*                     the USI module as basis. The implementation assumes the AVR to
*                     be the only TWI master in the system and can therefore not be
*                     used in a multi-master system.
* Usage             : Initialize the USI module by calling the USI_TWI_Master_Initialise() 
*                     function. Hence messages/data are transceived on the bus using
*                     the USI_TWI_Start_Transceiver_With_Data() function. If the transceiver
*                     returns with a fail, then use USI_TWI_Get_Status_Info to evaluate the 
*                     couse of the failure.
    #include<avr/io.h> 
//********** Defines **********//
// Defines controlling timing limits
#define TWI_FAST_MODE
#define SYS_CLK   1000.0  // [kHz]
#ifdef TWI_FAST_MODE               // TWI FAST mode timing limits. SCL = 100-400kHz
#define T2_TWI    ((SYS_CLK *1300) /1000000) +1 // >1,3us
#define T4_TWI    ((SYS_CLK * 600) /1000000) +1 // >0,6us
#else                              // TWI STANDARD mode timing limits. SCL <= 100kHz
#define T2_TWI    ((SYS_CLK *4700) /1000000) +1 // >4,7us
#define T4_TWI    ((SYS_CLK *4000) /1000000) +1 // >4,0us
#endif
// Defines controling code generating
//#define PARAM_VERIFICATION
//#define NOISE_TESTING
//#define SIGNAL_VERIFY
//USI_TWI messages and flags and bit masks
//#define SUCCESS   7
//#define MSG       0
  Bit and byte definitions
#define TWI_READ_BIT  0       // Bit position for R/W bit in "address byte".
#define TWI_ADR_BITS  1       // Bit position for LSB of the slave address bits in the init byte.
#define TWI_NACK_BIT  0       // Bit position for (N)ACK bit.
#define USI_TWI_NO_DATA             0x00  // Transmission buffer is empty
#define USI_TWI_DATA_OUT_OF_BOUND   0x01  // Transmission buffer is outside SRAM space
#define USI_TWI_UE_START_CON        0x02  // Unexpected Start Condition
#define USI_TWI_UE_STOP_CON         0x03  // Unexpected Stop Condition
#define USI_TWI_UE_DATA_COL         0x04  // Unexpected Data Collision (arbitration)
#define USI_TWI_NO_ACK_ON_DATA      0x05  // The slave did not acknowledge  all data
#define USI_TWI_NO_ACK_ON_ADDRESS   0x06  // The slave did not acknowledge  the address
#define USI_TWI_MISSING_START_CON   0x07  // Generated Start Condition not detected on bus
#define USI_TWI_MISSING_STOP_CON    0x08  // Generated Stop Condition not detected on bus
// Device dependant defines
#if defined(__AVR_AT90Mega169__) | defined(__AVR_ATmega169PA__) | \
    defined(__AVR_AT90Mega165__) | defined(__AVR_ATmega165__) | \
    defined(__AVR_ATmega325__) | defined(__AVR_ATmega3250__) | \
    defined(__AVR_ATmega645__) | defined(__AVR_ATmega6450__) | \
    defined(__AVR_ATmega329__) | defined(__AVR_ATmega3290__) | \
    defined(__AVR_ATmega649__) | defined(__AVR_ATmega6490__)
    #define DDR_USI             DDRE
    #define PORT_USI            PORTE
    #define PIN_USI             PINE
    #define PORT_USI_SDA        PORTE5
    #define PORT_USI_SCL        PORTE4
    #define PIN_USI_SDA         PINE5
    #define PIN_USI_SCL         PINE4
#endif
#if defined(__AVR_ATtiny25__) | defined(__AVR_ATtiny45__) | defined(__AVR_ATtiny85__) | \
    defined(__AVR_AT90Tiny26__) | defined(__AVR_ATtiny26__)
    #define DDR_USI             DDRB
    #define PORT_USI            PORTB
    #define PIN_USI             PINB
    #define PORT_USI_SDA        PORTB
    #define PORT_USI_SCL        PORTB
    #define PIN_USI_SDA         PINB0
    #define PIN_USI_SCL         PINB2
#endif
#if defined(__AVR_AT90Tiny2313__) | defined(__AVR_ATtiny2313__) | defined(__AVR_ATtiny4313__)
    #define PORT_USI_SDA        PORTB5
    #define PORT_USI_SCL        PORTB7
    #define PIN_USI_SDA         PINB5
    #define PIN_USI_SCL         PINB7
#endif
// General defines
#define TRUE  1
#define FALSE 0
//********** Prototypes **********//
void              USI_TWI_Master_Initialise( void );
 unsigned char USI_TWI_Start_Transceiver_With_Data( unsigned char * , unsigned char );
unsigned char USI_TWI_Get_State_Info( void );
