!SESSION 2017-01-18 13:15:58.677 ----------------------------------------------- eclipse.buildId=4.6.2.M20161124-1400 java.version=1.8.0_112 java.vendor=Oracle Corporation BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US Framework arguments: -product org.eclipse.epp.package.cpp.product Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product !ENTRY org.eclipse.equinox.p2.metadata 1 0 2017-01-18 13:17:00.002 !MESSAGE No translation source unavailable. Default language will be used. !SESSION 2017-01-18 13:21:44.160 ----------------------------------------------- eclipse.buildId=4.6.2.M20161124-1400 java.version=1.8.0_112 java.vendor=Oracle Corporation BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US Framework arguments: -product org.eclipse.epp.package.cpp.product Command-line arguments: -data file:/home/vinci/Develop/Eclipse/Workspace/ -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product !ENTRY org.eclipse.launchbar.core 2 0 2017-01-18 13:34:11.804 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2017-01-18 13:34:11.818 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.cdt.core 1 0 2017-01-18 13:34:32.254 !MESSAGE Indexed 'stm32l476_decoder' (389 sources, 474 headers) in 47.4 sec: 59,833 declarations; 226,408 references; 0 unresolved inclusions; 127 syntax errors; 323 unresolved names (0.11%) !ENTRY org.eclipse.cdt.dsf 4 10005 2017-01-18 13:37:51.366 !MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.mi.service.MIRunControl$9@277b4e1b): Status ERROR: org.eclipse.cdt.dsf.gdb code=10004 Suspend operation timeout. null' resulted in an error. !SUBENTRY 1 org.eclipse.cdt.dsf.gdb 4 10004 2017-01-18 13:37:51.366 !MESSAGE Suspend operation timeout. !ENTRY org.eclipse.cdt.dsf 4 10005 2017-01-18 13:37:53.399 !MESSAGE Request for monitor: 'RequestMonitor (org.eclipse.cdt.dsf.concurrent.RequestMonitor@d12c421): Status ERROR: org.eclipse.cdt.dsf.gdb code=10004 Suspend operation timeout. null' resulted in an error. !SUBENTRY 1 org.eclipse.cdt.dsf.gdb 4 10004 2017-01-18 13:37:53.399 !MESSAGE Suspend operation timeout. !ENTRY org.eclipse.cdt.dsf 4 -1 2017-01-18 13:37:55.463 !MESSAGE Invocation exception when calling a service event handler method !STACK 0 java.lang.reflect.InvocationTargetException at sun.reflect.GeneratedMethodAccessor47.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.cdt.dsf.service.DsfSession.doDispatchEvent(DsfSession.java:531) at org.eclipse.cdt.dsf.service.DsfSession.access$2(DsfSession.java:475) at org.eclipse.cdt.dsf.service.DsfSession$3.run(DsfSession.java:398) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) Caused by: java.util.concurrent.RejectedExecutionException: Display org.eclipse.swt.widgets.Display@26be9a6 is disposed at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor.execute(SimpleDisplayExecutor.java:85) at org.eclipse.cdt.dsf.ui.viewmodel.AbstractVMAdapter.handleEvent(AbstractVMAdapter.java:260) at org.eclipse.cdt.dsf.ui.viewmodel.datamodel.AbstractDMVMAdapter.eventDispatched(AbstractDMVMAdapter.java:103) ... 13 more Caused by: org.eclipse.swt.SWTException: Device is disposed at org.eclipse.swt.SWT.error(SWT.java:4533) at org.eclipse.swt.SWT.error(SWT.java:4448) at org.eclipse.swt.SWT.error(SWT.java:4419) at org.eclipse.swt.widgets.Display.error(Display.java:1236) at org.eclipse.swt.widgets.Display.asyncExec(Display.java:775) at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor.execute(SimpleDisplayExecutor.java:77) ... 15 more Root exception: java.util.concurrent.RejectedExecutionException: Display org.eclipse.swt.widgets.Display@26be9a6 is disposed at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor.execute(SimpleDisplayExecutor.java:85) at org.eclipse.cdt.dsf.ui.viewmodel.AbstractVMAdapter.handleEvent(AbstractVMAdapter.java:260) at org.eclipse.cdt.dsf.ui.viewmodel.datamodel.AbstractDMVMAdapter.eventDispatched(AbstractDMVMAdapter.java:103) at sun.reflect.GeneratedMethodAccessor47.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.cdt.dsf.service.DsfSession.doDispatchEvent(DsfSession.java:531) at org.eclipse.cdt.dsf.service.DsfSession.access$2(DsfSession.java:475) at org.eclipse.cdt.dsf.service.DsfSession$3.run(DsfSession.java:398) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) Caused by: org.eclipse.swt.SWTException: Device is disposed at org.eclipse.swt.SWT.error(SWT.java:4533) at org.eclipse.swt.SWT.error(SWT.java:4448) at org.eclipse.swt.SWT.error(SWT.java:4419) at org.eclipse.swt.widgets.Display.error(Display.java:1236) at org.eclipse.swt.widgets.Display.asyncExec(Display.java:775) at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor.execute(SimpleDisplayExecutor.java:77) ... 15 more !ENTRY org.eclipse.cdt.dsf 4 -1 2017-01-18 13:37:55.503 !MESSAGE Invocation exception when calling a service event handler method !STACK 0 java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.cdt.dsf.service.DsfSession.doDispatchEvent(DsfSession.java:531) at org.eclipse.cdt.dsf.service.DsfSession.access$2(DsfSession.java:475) at org.eclipse.cdt.dsf.service.DsfSession$3.run(DsfSession.java:398) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) Caused by: java.lang.IllegalStateException: RequestMonitor: RequestMonitor (org.eclipse.cdt.dsf.mi.service.MIRunControl$MakeTargetAvailableStep$1@183de53b): Status ERROR: org.eclipse.cdt.dsf.gdb code=10001 Connection is shut down null, done() method called more than once at org.eclipse.cdt.dsf.concurrent.RequestMonitor.done(RequestMonitor.java:285) at org.eclipse.cdt.dsf.concurrent.RequestMonitor.done(RequestMonitor.java:339) at org.eclipse.cdt.dsf.gdb.service.GDBRunControl_7_12$3.handleFailure(GDBRunControl_7_12.java:107) at org.eclipse.cdt.dsf.concurrent.RequestMonitor.handleCompleted(RequestMonitor.java:387) at org.eclipse.cdt.dsf.concurrent.RequestMonitor$2.run(RequestMonitor.java:312) at org.eclipse.cdt.dsf.concurrent.ImmediateExecutor.execute(ImmediateExecutor.java:63) at org.eclipse.cdt.dsf.concurrent.RequestMonitor.done(RequestMonitor.java:309) at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl.stopCommandProcessing(AbstractMIControl.java:290) at org.eclipse.cdt.dsf.gdb.service.command.GDBControl_7_0.eventDispatched(GDBControl_7_0.java:121) ... 14 more Root exception: java.lang.IllegalStateException: RequestMonitor: RequestMonitor (org.eclipse.cdt.dsf.mi.service.MIRunControl$MakeTargetAvailableStep$1@183de53b): Status ERROR: org.eclipse.cdt.dsf.gdb code=10001 Connection is shut down null, done() method called more than once at org.eclipse.cdt.dsf.concurrent.RequestMonitor.done(RequestMonitor.java:285) at org.eclipse.cdt.dsf.concurrent.RequestMonitor.done(RequestMonitor.java:339) at org.eclipse.cdt.dsf.gdb.service.GDBRunControl_7_12$3.handleFailure(GDBRunControl_7_12.java:107) at org.eclipse.cdt.dsf.concurrent.RequestMonitor.handleCompleted(RequestMonitor.java:387) at org.eclipse.cdt.dsf.concurrent.RequestMonitor$2.run(RequestMonitor.java:312) at org.eclipse.cdt.dsf.concurrent.ImmediateExecutor.execute(ImmediateExecutor.java:63) at org.eclipse.cdt.dsf.concurrent.RequestMonitor.done(RequestMonitor.java:309) at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl.stopCommandProcessing(AbstractMIControl.java:290) at org.eclipse.cdt.dsf.gdb.service.command.GDBControl_7_0.eventDispatched(GDBControl_7_0.java:121) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.cdt.dsf.service.DsfSession.doDispatchEvent(DsfSession.java:531) at org.eclipse.cdt.dsf.service.DsfSession.access$2(DsfSession.java:475) at org.eclipse.cdt.dsf.service.DsfSession$3.run(DsfSession.java:398) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) !ENTRY org.eclipse.core.resources 2 10035 2017-01-18 13:38:04.839 !MESSAGE The workspace will exit with unsaved changes in this session. !ENTRY org.eclipse.core.jobs 2 2 2017-01-18 13:38:05.706 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.cdt.dsf.gdb.internal.ui.console.GdbBasicCliConsole$InputReadJob
